查看: 3026|回复: 14
[Allegro16.6以下] SAMA5D27-SOM1-EK1 官方评估板
发表于 2018-11-28 22:53:50 | 显示全部楼层 |阅读模式
SAMA5D27-SOM1-EK1_Board Files_1.B.B.rar (5.71 MB, 下载次数: 16)
Bill of MaterialReport
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDES
C0402C0402_100NF_C0402_100NF100nF ICC1
C0603C0603 10_C0603_10UF10uF ICC2
C0603C0603 10_C0603_10UF10uF ICC3
C0402C0402_100NF_C0402_100NF100nF ICC4
C0603C0603 10_C0603_10UF10uF ICC5
C0402C0402_100NF_C0402_4.7UF4.7uF ICC6
C0402C0402_100NF_C0402_4.7UF4.7uF ICC7
C0402C0402_100NF_C0402_4.7UF4.7uF ICC8
C0402C0402_100NF_C0402_100NF100nF ICC9
C0402C0402_100NF_C0402_4.7UF4.7uF ICC10
C0402C0402_100NF_C0402_100NF100nF ICC12
C0402C0402_100NF_C0402_100NF100nF ICC13
DSK-614SUPER_CAP_DSK-614_0.2F/3.3V0.2F/3.3V ICC14
C0402C0402_100NF_C0402_100NF100nF ICC15
C0603C06032_0.2_C0603_2.2UF2.2uF ICC16
C0402C0402_100NF_C0402_100NF100nF ICC17
C0402C0402_100NF_C0402_100NF100nF ICC18
C0603C06032_0.2_C0603_2.2UF2.2uF ICC19
C0402C0402_100NF_C0402_100NF100nF ICC20
C0603C06032_0.2_C0603_2.2UF2.2uF ICC21
C0402C0402_100NF_C0402_100NF100nF ICC22
C0603C06032_0.2_C0603_2.2UF2.2uF ICC23
C0402C0402_100NF_C0402_100NF100nF ICC24
C0402C0402_10NF_C0402_10NF10nF ICC25
C0402C0402_10NF_C0402_10NF10nF ICC26
C0402C0402_10PF_C0402_10PF10pF ICC27
C0402C0402_8.2PF_C0402_8.2PF8.2pF ICC28
C0402C0402_8.2PF_C0402_8.2PF8.2pF ICC29
C0402C0402_100NF_C0402_100NF100nF ICC30
C0402C0402_100NF_C0402_100NF100nF ICC31
C0402C0402_100NF_C0402_100NF100nF ICC32
C0402C0402_100NF_C0402_4.7UF4.7uF ICC33
C0402C0402_100NF_C0402_100NF100nF ICC34
C0402C0402_100NF_C0402_100NF100nF ICC35
C0402C0402_100NF_C0402_100NF100nF ICC36
C0402C0402_100NF_C0402_100NF100nF ICC37
C0402C0402_100NF_C0402_4.7UF4.7uF ICC38
C0402C0402_100NF_C0402_100NF100nF ICC39
C0402C0402_100NF_C0402_100NF100nF ICC40
C0402C0402_100NF_C0402_100NF100nF ICC41
C0402C0402_100NF_C0402_100NF100nF ICC42
C0402C0402_100NF_C0402_100NF100nF ICC43
C0402C0402_100NF_C0402_100NF100nF ICC44
C0402C0402_100NF_C0402_100NF100nF ICC45
C0402C0402_100NF_C0402_100NF100nF ICC46
C0402C0402_100NF_C0402_100NF100nF ICC47
C0402C0402_100NF_C0402_100NF100nF ICC48
C0603C06032_0.2_C0603_2.2UF2.2uF ICC49
C0603C06032_0.2_C0603_2.2UF2.2uF ICC50
C0402C0402_100NF_C0402_100NF100nF ICC51
C0402C0402_100NF_C0402_100NF100nF ICC52
C0603C0603 10_C0603_10UF10uF ICC53
C0402C0402_100NF_C0402_100NF100nF ICC54
C0402C0402_100NF_C0402_100NF100nF ICC55
C0603C0603 10_C0603_10UF10uF ICC56
C0402C0402_100NF_C0402_100NF100nF ICC57
C0402C0402_100NF_C0402_100NF100nF ICC58
C0402C0402_100NF_C0402_100NF100nF ICC59
C0402C0402_100NF_C0402_4.7UF4.7uF ICC60
C0402C0402_100NF_C0402_100NF100nF ICC61
C0402C0402_15PF_C0402_15PF15pF ICC62
C0402C0402_100NF_C0402_100NF100nF ICC63
C0402C0402_100NF_C0402_100NF100nF ICC64
C0402C0402_20PF_C0402_20PF20pF ICC65
C0402C0402_100NF_C0402_100NF100nF ICC66
C0603C0603 10_C0603_10UF10uF ICC67
C0402C0402_100NF_C0402_100NF100nF ICC68
C0402C0402_330PF_C0402_330PF330pF ICC69
C0402C0402_330PF_C0402_330PF330pF ICC70
C0402C0402_100NF_C0402_100NF100nF ICC71
SOT23BAT54C_SOT23_BAT54CBAT54C ICD1
SOD123RB160M-60TR_SOD123_RB160M-60TRRB160M-60TR ICD2
SOD3231N4148_SOD323_1N41481N4148 ICD3
KPTB-1615LEDBI_RG_KPTB-1615_BI COLORBi Color ICD4
PLCC-4RGB_FULLCOLOR_LED_PLCC-4_RGBRGB ICD5
HEADER2-1001X2PTS_MALE_STRIGHT_2.54MM_HEADTSW-102-07-G-S ICJ1
HEADER2-1001X2PTS_MALE_STRIGHT_2.54MM_HEADTSW-102-07-G-S ICJ2
HEADER2-1001X2PTS_MALE_STRIGHT_2.54MM_HEADTSW-102-07-G-S ICJ4
HDR11PTS_MALE_HDR1_TSW-101-07-G-STSW-101-07-G-S ICJ5
MEC2MEC1_PCB_0_MEC2_PADSON PCBpads on PCB ICJ6
HEADER2-1001X2PTS_MALE_STRIGHT_2.54MM_HEADTSW-102-07-G-S ICJ7
HEADER2-1001X2PTS_MALE_STRIGHT_2.54MM_HEADTSW-102-07-G-S ICJ8
HEADER2-1001X2PTS_MALE_STRIGHT_2.54MM_HEADTSW-102-07-G-S ICJ9
USB_MICRO_ABUSB_MICROAB_USB_MICRO_AB_MICROMicro AB ICJ10
FTSH-105-01-F-DV-K2X5PTS_FTSH_1.27MMSMD_FTSH-105FTSH-105-01-F-DV-K ICJ11
7SDMM-F0-2211SD_MMCPLUS_7SDMM-F0-2211_SD/MMCSD/MMCPlus CARD ICJ12
HEADER2-1001X2PTS_MALE_STRIGHT_2.54MM_HEADTSW-102-07-G-S ICJ13
DM3AT-SF-PEJM5PJS008-2120-0_DM3AT-SF-PEJM5_DMDM3AT-SF-PEJM5 ICJ14
RJ45_PULSERJ45 10/100 BASEJ00-0061NL_RJ4RJ45 10/100 BASEJ00-0061NL ICJ15
MKDS_1-3-3_81SCREW3X1_MKDS_1-3-3_81_SCREW3XScrew 3x1 ICJ16
USB_MICRO_ABUSB_MICROAB_USB_MICRO_AB_MICROMicro AB ICJ17
HEADER2-1001X2PTS_MALE_STRIGHT_2.54MM_HEADTSW-102-07-G-S ICJ18
SD-105450-001USB3 TYPEC_SD-105450-001_USB CUSB C ICJ19
HEADER6-1001X6PTS_MALE_STRAIGHT_2.54MM_HEATSW-106-07-G-S ICJ20
SSQ-106-02-G-S-RA1X6PTS_FEMALE_RIGHTANGLE_2.54_SSQ-106-02-G-S-RA ICJ21
HEADER2-1001X2PTS_MALE_STRIGHT_2.54MM_HEADTSW-102-07-G-S ICJ22
HEADER3-1001X3PTS_MALE_STRAIGHT_2.54_HEADETSW-103-07-G-S ICJ23
SSQ-108-01-G-S1X8PTS_FEMALE_STRAIGHT_2.54_SSQ1X8PTS_Female_Straight_2.54 ICJ24
SSQ-108-01-G-S1X8PTS_FEMALE_STRAIGHT_2.54_SSQ1X8PTS_Female_Straight_2.54 ICJ25
XF2M-5015-1ACON FPC50PTS_XF2M-5015-1A_CONCon FPC 50Pts ICJ26
TSW-2X152X15PTS_MALE_STRAIGHT_2.54_TSW-TSW-115-07-G-D ICJ27
HEADER2-1001X2PTS_MALE_STRIGHT_2.54MM_HEADTSW-102-07-G-S ICJ28
SSQ-108-01-G-S1X8PTS_FEMALE_STRAIGHT_2.54_SSQ1X8PTS_Female_Straight_2.54 ICJ29
SSQ-108-01-G-S1X8PTS_FEMALE_STRAIGHT_2.54_SSQ1X8PTS_Female_Straight_2.54 ICJ30
FTS-105-01-L-DV2X5PTS_MALE_STRAIGHT_1.27MMSMDFTS-105-01-L-DV ICJ31
HDR11PTS_MALE_HDR1_TSW-101-07-G-STSW-101-07-G-S ICJ32
R0603BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHz ICL1
R0603BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHz ICL2
L1210L_1UH-2A_L1210_1UH1uH ICL3
R0603BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHz ICL5
L1210L_1UH-2A_L1210_1UH1uH ICL6
R0603BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHz ICL7
L1210L_1UH-2A_L1210_1UH1uH ICL8
R0603BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHz ICL9
R0603BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHz ICL10
R0603BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHz ICL11
R0603BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHz ICL12
R0603BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHz ICL13
HOLEPTH_5MMX3.2MM_HOLE_PTHPTH ICMH1
HOLEPTH_5MMX3.2MM_HOLE_PTHPTH ICMH2
HOLEPTH_5MMX3.2MM_HOLE_PTHPTH ICMH3
HOLEPTH_5MMX3.2MM_HOLE_PTHPTH ICMH4
FSM2JSMLSWITCHFSM2JSML_FSM2JSML_FSM2JSFSM2JSML ICPB1
FSM2JSMLSWITCHFSM2JSML_FSM2JSML_FSM2JSFSM2JSML ICPB2
FSM2JSMLSWITCHFSM2JSML_FSM2JSML_FSM2JSFSM2JSML ICPB3
FSM2JSMLSWITCHFSM2JSML_FSM2JSML_FSM2JSFSM2JSML ICPB4
U-DFN2020-6PMOS DUALDMP2160UFDB_U-DFN2020DMP2160 ICQ1
U-DFN2020-6PMOS DUALDMP2160UFDB_U-DFN2020DMP2160 ICQ2
SOT23BSS138_SOT23_BSS138BSS138 ICQ6
SOT23BSS138_SOT23_BSS138BSS138 ICQ7
SOT23BSS138_SOT23_BSS138BSS138 ICQ8
SOT23BSS138_SOT23_BSS138BSS138 ICQ9
SOT23BSS138_SOT23_BSS138BSS138 ICQ10
R0402R0402 100K_R0402_100K100K ICR1
R0402R0402 309K_R0402_309K309K ICR2
R0402R0402 10K_R0402_10K10K ICR3
R0402R0402 100R_R0402_100R100R ICR4
R0402R0402 71K5_R0402_71K571K5 ICR5
R0402R0402 301K_R0402_301K301K ICR6
R0402R0402 10K_R0402_10K10K ICR7
R0402R0402 100K_R0402_100K100K ICR8
R0402R0402 158K_R0402_158K158K ICR9
R0402R0402 10K_R0402_10K10K ICR10
R0402R0402 309K_R0402_309K309K ICR11
R0402R0402 100K_R0402_100K100K ICR12
R0402R0402 10K_R0402_10K10K ICR13
R0402R0402 71K5_R0402_71K571K5 ICR14
R0402R0402 10K_R0402_10K10K ICR15
R0402R0402 10K_R0402_10K10K ICR16
R0402R0402 0R_R0402_0R0R ICR17
R0402R0402 10K_R0402_10K10K ICR18
R0402R0402 0R_R0402_0R0R ICR19
R0402R0402 100R_R0402_100R100R ICR20
R0402R0402 0R_R0402_0R0R ICR21
R0402R0402 0R_R0402_0R0R ICR22
R0402R0402 100R_R0402_100R100R ICR23
R0402R0402 100R_R0402_100R100R ICR24
R0402R0402 0R_R0402_0R0R ICR25
R0402R0402 10K_R0402_10K10K ICR26
R0402R0402 39R_R0402_39R39R ICR27
R0402R0402 10K_R0402_10K10K ICR28
R0402R0402 0R_R0402_0R0R ICR29
R0402R0402 100R_R0402_100R100R ICR30
R0402R0402 100R_R0402_100R100R ICR31
R0402R0402 10K_R0402_10K10K ICR32
R0402R0402 150R_R0402_150R150R ICR33
R0402R0402 10K_R0402_10K10K ICR34
R0402R0402 100R_R0402_100R100R ICR35
R0402R0402 0R_R0402_0R0R ICR36
R0402R0402 6K8_R0402_6K86K8 ICR37
R0402R0402 10K_R0402_10K10K ICR38
R0402R0402 100K_R0402_100K100K ICR39
R0402R0402 39R_R0402_39R39R ICR40
R0402R0402 39R_R0402_39R39R ICR41
R0402R0402 220R_R0402_220R220R ICR42
R0402R0402 220R_R0402_220R220R ICR43
R0402R0402 150R_R0402_150R150R ICR44
R0402R0402 150R_R0402_150R150R ICR45
R0402R0402 100K_R0402_100K100K ICR46
R0402R0402 100K_R0402_100K100K ICR47
R0402R0402 100K_R0402_100K100K ICR48
R0402R0402 150R_R0402_150R150R ICR49
R0402R0402 0R_R0402_0R0R ICR50
R0402R0402 100R_R0402_100R100R ICR51
R0402R0402 0R_R0402_0R0R ICR52
R0402R0402 10K_R0402_10K10K ICR53
R0402R0402 10K_R0402_10K10K ICR54
R0402R0402 10K_R0402_10K10K ICR56
R0402R0402 10K_R0402_10K10K ICR57
R0402R0402 10K_R0402_10K10K ICR58
R0402R0402 10K_R0402_10K10K ICR59
R0402R0402 10K_R0402_10K10K ICR60
R0402R0402 0R_R0402_0R0R ICR61
R0402R0402 10K_R0402_10K10K ICR62
R0402R0402 10K_R0402_10K10K ICR63
R0402R0402 0R_R0402_0R0R ICR64
R0402R0402 0R_R0402_0R0R ICR65
R1210R1210 62R_R1210_62R62R ICR66
R1210R1210 62R_R1210_62R62R ICR67
R0402R0402 0R_R0402_0R0R ICR68
R0402R0402 470R_R0402_470R470R ICR69
R0402R0402 100K_R0402_100K100K ICR70
R0402R0402 200K_R0402_200K200K ICR71
R0402R0402 100R_R0402_100R100R ICR72
R0402R0402 100R_R0402_100R100R ICR73
R0402R0402 2K2_R0402_2K22K2 ICR74
R0402R0402 2K2_R0402_2K22K2 ICR75
R0402R0402 1K_R0402_1K1K ICR76
R0402R0402 10K_R0402_10K10K ICR77
R0402R0402 36K_R0402_36K36K ICR78
R0402R0402 36K_R0402_36K36K ICR79
R0402R0402 0R_R0402_0R0R ICR80
R0402R0402 0R_R0402_0R0R ICR81
R0402R0402 39R_R0402_39R39R ICR82
R0402R0402 0R_R0402_0R0R ICR83
R0402R0402 22R_R0402_22R22R ICR84
R0402R0402 0R_R0402_0R0R ICR85
R0402R0402 22R_R0402_22R22R ICR86
R0402R0402 22R_R0402_22R22R ICR87
R0402R0402 22R_R0402_22R22R ICR88
R0402R0402 2K2_R0402_2K22K2 ICR89
R0402R0402 2K2_R0402_2K22K2 ICR90
R0402R0402 22R_R0402_22R22R ICR91
R0402R0402 2K2_R0402_2K22K2 ICR92
R0402R0402 2K2_R0402_2K22K2 ICR93
R0402R0402 22R_R0402_22R22R ICR94
R0402R0402 22R_R0402_22R22R ICR95
R0402R0402 22R_R0402_22R22R ICR96
R0402R0402 22R_R0402_22R22R ICR97
R0402R0402 39R_R0402_39R39R ICR98
R0402R0402 22R_R0402_22R22R ICR99
R0402R0402 39R_R0402_39R39R ICR100
R0402R0402 22R_R0402_22R22R ICR101
R0402R0402 22R_R0402_22R22R ICR102
R0402R0402 22R_R0402_22R22R ICR103
R0402R0402 22R_R0402_22R22R ICR104
R0402R0402 22R_R0402_22R22R ICR105
R0402R0402 22R_R0402_22R22R ICR106
R0402R0402 22R_R0402_22R22R ICR107
R0402R0402 22R_R0402_22R22R ICR108
R0402R0402 0R_R0402_0R0R ICR109
R0402R0402 330R_R0402_330R330R ICR110
R0402R0402 330R_R0402_330R330R ICR111
R0402R0402 330R_R0402_330R330R ICR112
R0402R0402 330R_R0402_330R330R ICR113
R0402R0402 330R_R0402_330R330R ICR114
R0402R0402 0R_R0402_0R0R ICR115
R0402R0402 330R_R0402_330R330R ICR116
R0402R0402 0R_R0402_0R0R ICR117
R0402R0402 0R_R0402_0R0R ICR118
R0402R0402 100R_R0402_100R100R ICR119
R0402R0402 10K_R0402_10K10K ICR120
R0402R0402 10K_R0402_10K10K ICR121
R0402R0402 100K_R0402_100K100K ICR126
R0402R0402 10K_R0402_10K10K ICR127
R0402R0402 10K_R0402_10K10K ICR128
R0402R0402 100K_R0402_100K100K ICR129
R0402R0402 0R_R0402_0R0R ICR130
R0402R0402 0R_R0402_0R0R ICR131
R0402R0402 100K_R0402_100K100K ICR132
R0402R0402 10K_R0402_10K10K ICR133
R0402R0402 100R_R0402_100R100R ICR134
R0402R0402 100R_R0402_100R100R ICR135
R0402R0402 100R_R0402_100R100R ICR136
R0402R0402 10K_R0402_10K10K ICR137
R0402R0402 10K_R0402_10K10K ICR138
R0402R0402 0R_R0402_0R0R ICR139
TC164RR1206 68K_TC164_68K68K ICRR1
TC164RR1206 68K_TC164_68K68K ICRR2
TC164RR1206 68K_TC164_68K68K ICRR3
QFN26_MIC23451MIC23451_QFN26_MIC23451_MIC2345MIC23451 ICU1
SC70-6ADG849_SC70-6_ADG849ADG849 ICU2
SAMA5D27-SOMATSAMA5D27-SOM1_SAMA5D27-SOM_ATATSAMA5D27-SOM1 ICU3
LQFP-100AT91SAM3UE_LQFP-100_ATSAM3U4CA-ATSAM3U4CA-AU ICU4
SOT353_5NL17SZ126DFT2G_SOT353_5_NL17SZ1NL17SZ126 ICU5
SOT353_5NL17SZ126DFT2G_SOT353_5_NL17SZ1NL17SZ126 ICU6
SC70_6MIC5528_SC70_6_MIC5528MIC5528 ICU7
QFN16NLAS3899B_QFN16_NLAS3899BNLAS3899B ICU8
SO8WMX25L25673GM2I-08G_SO8W_MX25L25MX25L25673GM2I-08G ICU9
SOT353_5NL17SZ125DFT2G_SOT353_5_NL17SZ1NL17SZ125 ICU10
SO8ATECC508A-SSHDA_SO8_ATECC508AATECC508A ICU11
DFN8ATA6561_DFN8_DFN8_ATA6561-GBQWATA6561-GBQW ICU12
SOIC8MIC2025_SOIC8_MIC2025MIC2025 ICU13
SMD7X5Q_12MHZ_IQD_12SMX_SMD7X5_12MHZ12Mhz ICY1
SMD3225OSC12MHZ_ABRACON_ASE_SMD3225_AASE-12.000MHZ-LC-T ICY2
    2 小时前
  • 签到天数: 155 天
    社区居民社区劳模原创先锋奖终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2018-11-29 00:31:17 | 显示全部楼层
    昨天 12:23
  • 签到天数: 58 天
    发表于 2018-11-29 05:33:41 | 显示全部楼层
    1元学习Allegro(2期)
    发表于 2018-11-29 07:53:00 | 显示全部楼层
    社区居民忠实会员社区劳模原创达人最爱沙发终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2018-11-29 08:29:25 | 显示全部楼层
    发表于 2018-11-29 08:46:55 | 显示全部楼层
    发表于 2018-11-29 08:50:44 | 显示全部楼层
    PADS20220105初级班
    发表于 2018-11-29 08:53:14 | 显示全部楼层
    发表于 2018-11-29 08:54:53 | 显示全部楼层
    发表于 2018-11-29 08:56:29 | 显示全部楼层
