[Pads_VX.2x] 使用ADSP-CM408F的配电自动化解决方案原理图与PCB文件
查看2761 | 回复4 | 2018-11-29 14:14:13 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
4层1543PIN
游客,如果您要查看本帖隐藏内容请回复
ComponentTypeDescriptionQuantityPackage
PNP 三极管三极管STD2805T4 贴片
ST
1TO228P972X240-3N
(TO-252)
插针 3_PIN_PART 插针3X1(脚间距2.54mm)9IDC3X1
插座 4_PIN_CONNECT_PART CAN总线接口(插座)
5558872-1
TYCO
2CON039
插针 4_PIN_PART 4X1连接器(插针)1JK2EDG381_4P
插座 4_PIN_PART 插座4X1(脚间距2.54mm)14_PIN_2MMPITCH
芯片
AD8062_PART
AD8602
Precision CMOS, Single-Supply, Rail-to-Rail,Input/Output WidebandOperational Amplifiers
2SOIC8
芯片
AD8604_PART_TYPE
AD8604
2SOIC14
芯片
ADM2587E_PART_TYPE
ADM2587E
Signal and Power Isolated RS-485 Transceiver with ±15 kV ESD Protection
1SOIC_W_20
芯片 ADM3053_PART ADM30531SOIC_W_20
芯片 ADM3232E_PART ADM3232E1SOIC_W_16
芯片
ADM706_PART
ADM706T
3 V, Voltage Monitoring Microprocessor Supervisory Circuits
1SOIC8
芯片
ADP2118_PART_TYPE
ADP2118ACPZ
3 A, 1.2 MHz/600 kHz High Efficiency Synchronous Step-Down DC-to-DCRegulator
1QFN65P400X400X80-17N
芯片
ADP2119_PART_TYPE
ADP2119
2 A/1.25 A, 1.2 MHz, Synchronous,Step-Down DC-to-DC Regulators
1DFN50P300X300-11N
芯片
ADR34XX_PART_TYPE
ADR3425ARJZ
low cost, low power, high precision low cost, low power, high precision CMOS voltage references
1SOT23_6
芯片
ADUM1201_PART
ADuM1201
Dual-Channel Digital Isolators
1SOIC8
芯片
ADUM5402_PART_TYPE
ADUM5402
Quad-Channel Isolators with Integrated DC-to-DC Converter
1SOIC_W_16
线圈 ASSCOIL_PART共轭线圈
190 100MHZ 5A
DLW5BSN191SQ2
MURATA
1FER002
(5MM*5MM)
芯片
CM40X_PART_TYPE
ADSP-CM408FBSWZENG
Mixed-Signal Control Processor with ARM Cortex-M4
1LQFP_EP_176
插针 CON_12_PART_TYPE12X1连接器(插针)2JK2EDG381_12P
插座 CON_14_PART_TYPE以太网接口1CON065
插座 CON_6_PART_TYPE插座3X2(脚间距2.54mm)1IDC3X2
插座 DB9_PARTRS232接口1CON038
ESD保护二极管
ESD7004_PART
ESD保护二极管
ESD7004
Low Capacitance ESD Protection Diode for High Speed Data Line
ON Semiconductor
1DFN50P250X100-10N
(UDFN10)
ESD保护二极管
ESDAXXSC6_PART
ESD保护二极管
ESDA6VSC6
QUAD TRANSIL ARRAY FOR ESD PROTECTION
ST
1SOT95P280-6N
(SOT23-6L)
TVS ESD_GSOTXX_3P_PARTESD保护二极管
GSOT03
VISHAY
3SOT23-3
保险丝 FUSE_PART_TYPE保险丝(3A)
3A RESETABLE
SMD300F-2
TYCO
1FUS004
(5mm*8mm)
插座 HEADER20_PART处理器调试接口
IDC 10X2
MOUSER
1TE_5103308_5_20P
0.05 10X2 SAMTEC_
SHF-110-01-L-DTH
SAMTEC
1SAMTEC_SHF-110-01-L-D-TH_20P
插座 HEADER20_PART插座HEADER 10X2(脚间距2.54mm)1
插针 HEADER20_PART插针HEADER 10X2(脚间距2.54mm)3IDC20P
磁珠 INDUCTOR_PART磁珠600 100MHZ 500MA61206
电感 INDUCTOR_PART电感1.5UH2INDUCTANCE_10UH
(7mm*7mm)
按键 KEY_2_PIN_PART按键7KEY_2_PIN
芯片
LAN8742_PART_TYPE
LAN8742Ai_CZ
10/100M Ethernet transceiver
1SQFN_24
发光二级管 LED_SMTLED12LED_0603
芯片
MCP2200_PART
MCP2200-I/SO
带GPIO 的USB 2.0 至UART 协议转换器
1SOIC20
芯片
MCP256X_PART_TYPE
MCP2562-E/SN
high speed can transceiver
1SOIC8
芯片
MIC2025_PART_TYPE
MIC2025
Single-Channel Power Distribution Switch MM8
Micrel Semiconductor
1SOIC8
片容
NOPOLAR_CAP_PART
片容100nF 0603 50V  TDK43CAP0603
片容
NOPOLAR_CAP_PART
片容10nF 0603 50V  TDK32CAP0603
片容 NOPOLAR_CAP_PART片容10pF 0603 50V  TDK14CAP0603
片容
NOPOLAR_CAP_PART
片容10uF 1206 50V  TDK221206
片容 NOPOLAR_CAP_PART片容1000pF 1206 50V  TDK21206
片容
NOPOLAR_CAP_PART
片容0.1uF 0603 50V  TDK11CAP0603
片容
NOPOLAR_CAP_PART
片容1uF 0805 50V  TDK70805
片容
NOPOLAR_CAP_PART
片容2.2nF 0603 50V  TDK15CAP0603
片容 NOPOLAR_CAP_PART片容22nF 1210 50V  TDK61210
片容 NOPOLAR_CAP_PART片容18pF 0603 50V  TDK2CAP0603
片容 NOPOLAR_CAP_PART片容4.7uF 0805 50V  TDK10805
片容 NOPOLAR_CAP_PART片容4700pF 0603 50V  TDK1CAP0603
片容 NOPOLAR_CAP_PART片容1nF 0603 50V  TDK1CAP0603
片容 NOPOLAR_CAP_PART片容20pF 0603 50V  TDK2CAP0603
无源晶振 OSC_NP_4P_PART,12MHZCRYSTAL12MHZ 1OSC013(3225)
无源晶振 OSC_NP_4P_PART,30MHZCRYSTAL30MHZ1OSC013
电解电容 POLE_CAP_PART 电解电容 150uF 25V 105℃ YXF 红宝石1CAP5-2
电源接口 POWER_CONNECT_PART电源接口1CON-BARREL
有源晶振 POWER_CRISTAL有源晶振30MHZ2OSC012(5032)
片阻
RESISTOR_PART
片阻0欧姆 5% 0603 100ppm TDK42RES0603
片阻 RESISTOR_PART片阻51欧姆 5% 0603 100ppm TDK4RES0603
片阻 RESISTOR_PART片阻165欧姆 5% 0603 100ppm TDK2RES0603
片阻 RESISTOR_PART片阻100欧姆 5% 0603 100ppm TDK2RES0603
片阻
RESISTOR_PART
精密电阻 80K 0.1% 0603 15ppm TDK
16RES0603
片阻
RESISTOR_PART
精密电阻64K 0.1% 0603 15ppm TDK8RES0603
片阻
RESISTOR_PART
精密电阻10K 0.1% 0603 15ppm TDK8RES0603
片阻
RESISTOR_PART
片阻10K 5% 0603 100ppm TDK52RES0603
片阻 RESISTOR_PART片阻45.3K 5% 0603 100ppm TDK1RES0603
片阻 RESISTOR_PART片阻100欧姆 5% 0603 100ppm TDK6RES0603
片阻 RESISTOR_PART片阻1K 5% 0603 100ppm TDK5RES0603
片阻 RESISTOR_PART片阻10欧姆 5% 0603 100ppm TDK8RES0603
片阻 RESISTOR_PART片阻220欧姆 5% 0603 100ppm TDK14RES0603
片阻 RESISTOR_PART片阻0.05欧姆 5% 1206 100ppm TDK41206
片阻 RESISTOR_PART片阻1M 5% 0603 100ppm TDK2RES0603
片阻 RESISTOR_PART片阻27K 5% 0603 100ppm TDK2RES0603
片阻 RESISTOR_PART片阻50欧姆 5% 0603 100ppm TDK6RES0603
片阻 RESISTOR_PART片阻330欧姆 5% 0603 100ppm TDK10RES0603
片阻 RESISTOR_PART片阻100K 5% 0603 100ppm TDK2RES0603
片阻 RESISTOR_PART片阻120欧姆 5% 0603 100ppm TDK2RES0603
片阻 RESISTOR_PART片阻470欧姆 5% 0603 100ppm TDK2RES0603
片阻 RESISTOR_PART片阻20K 5% 0603 100ppm TDK1RES0603
片阻 RESISTOR_PART片阻33欧姆 5% 0603 100ppm TDK3RES0603
片阻 RESISTOR_PART片阻60欧姆 5% 0603 100ppm TDK2RES0603
片阻 RESISTOR_PART片阻12K 5% 0603 100ppm TDK1RES0603
片阻 RESISTOR_PART片阻0欧姆 5% 0603 100ppm TDK10805
片阻 RESISTOR_PART_TYPE片阻0欧姆 5% 1206 100ppm TDK21206
肖特基二极管 SCHOTTKY_PARTSS14 5SMA
肖特基二极管 SCHOTTKY_PART5AMBRS540T3G SMC3SMC
热敏电阻 THERMISTOR_PART热敏电阻0.5A 0.4 1206
1206L050-C
LITTLEFUSE(力特保险丝)
11206
TVS管 TVS_BIDIR_PARTSMBJ15CA
BI-DIRECTIONAL TVS
8SMB
MINI_USB接口
USB_OTG_PART
MINI_USB接口
USB_MINI-AB 5PIN(MOLEX)
2CON052
压敏电阻
VARISTOR_PART
压敏电阻
V5.5MLA
30A 0603
V5.5MLA0603
LITTLEFUSE(力特保险丝)
10603
电流互感器ZM-BCT6A/3.53V(计量用)4ZM_BCT_BPT
ZM-BCT 100A/3.53V(保护用)
电压互感器ZM-BPT120V/3.53V4ZM_BCT_BPT
重要提示:PCB作品文件展下载说明
生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙!
ct991218620 | 2018-11-29 14:46:16 | 显示全部楼层
miaomiao | 2018-12-11 21:55:03 | 显示全部楼层
xianrui1989 | 2018-12-12 09:47:14 | 显示全部楼层
h_yun | 2019-11-20 10:21:38 | 显示全部楼层
