• 芯片制造中的阻挡层沉积技术介绍
  • 接地搭接电缆布局屏蔽!!!
  • 北美液冷生态解码:超微spuermicro,24年营
  • SK海力士全球首发HBM4-16层堆叠、2.0TB/s
  • 2纳米Nanosheet技术及其以后的选择性层减薄
[Allegro16.6以下] TWR-S08GW64 MC9S08GW 8位段式LCD塔式系统模块 6-926
查看1904 | 回复4 | 2018-11-29 23:04:31 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
37 TWR-S08GW64 MC9S08GW 8位段式LCD塔式系统模块.rar (4.81 MB, 下载次数: 2)
Bill of MaterialReport
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDES
BAT338ABATTERY-B_BAT338A_IC_13.5MM_670338A ICBT1
BATT_CR2016-1F2BATTERY_BATT_CR2016-1F2_IC_2.0MCR2016-1F2 ICBT2
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC1
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC2
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC3
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC4
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.86M22PF DISCRETEC5
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.86M22PF DISCRETEC6
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.86M22PF DISCRETEC7
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC8
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.86M22PF DISCRETEC9
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC10
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC11
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC12
CC3216CAP_POL_CC3216_DISCRETE_1.8MM_110UF DISCRETEC13
CC3216CAP_POL_CC3216_DISCRETE_1.8MM_110UF DISCRETEC14
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC15
CC3216CAP_POL_CC3216_DISCRETE_1.8MM_110UF DISCRETEC16
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC17
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC18
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC19
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC20
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC21
CC3216CAP_POL_CC3216_DISCRETE_1.8MM_110UF DISCRETEC22
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PF DISCRETEC23
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PF DISCRETEC24
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.871000PF DISCRETEC25
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC26
CC3528-21CAP_POL_CC3528-21_DISCRETE_2.1M10UF DISCRETEC27
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.871000PF DISCRETEC28
CC3528-21CAP_POL_CC3528-21_DISCRETE_2._147UF DISCRETEC29
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC30
CC3528-21CAP_POL_CC3528-21_DISCRETE_2.1M10UF DISCRETEC31
CCE63X55CAP_POL_CCE63X55_DISCRETE_5.7MM100UF DISCRETEC32
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC33
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_0.7MM0.1UF10%DISCRETEC34
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC35
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC36
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC37
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC38
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC39
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC40
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC41
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC42
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC43
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC44
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC45
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC46
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC47
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC48
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC49
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.1UF DISCRETEC50
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P3L ICD1
LED_0603_C1LED_LED_0603_C1_IC_1.0MM_370-76YEL ICD2
0603LED_1A2CLED_1A2C_0603LED_1A2C_IC_0.85MMGRN ICD3
TSOP6_0P95_1P7X3P1DIODE_TVS_TSOP6_TSOP6_0P95_1P7XNUP2201 ICD4
0603LED_1A2CLED_1A2C_0603LED_1A2C_IC_0.85MMGRN ICD5
0603LED_1A2CLED_1A2C_0603LED_1A2C_IC_0.85MMGRN ICD6
0603LED_1A2CLED_1A2C_0603LED_1A2C_IC_0.85MMGRN ICD7
LED_0603_C1LED_LED_0603_C1_IC_1.0MM_370-_1OR/RED ICD8
DIODE_3P2X2P2LED_DIODE_3P2X2P2_IC_1.1MM_480-QTLP610CIR ICD9
LCD29_59_78P2X33P2GD-4972P_29P_LCD29_59_78P2X33P2GD-4972P ICDS1
HDR103CONN_HDR_3X1_HDR103_IO_8.6MM_21HDR TH 1X3 IOJ1
HDR203_M20CONN_HDR_3X2_HDR203_M20_IO_8.64HDR 2X3 IOJ2
HDR103CONN_HDR_3X1_HDR103_IO_8.6MM_21HDR TH 1X3 IOJ3
HDR102CONN_HDR_1X2_HDR102_IO_8.6MM_21HDR 1X2 TH IOJ4
HDR203_M20CONN_HDR_3X2_HDR203_M20_IO_8.64HDR 2X3 IOJ5
HDR103CONN_HDR_3X1_HDR103_IO_8.6MM_21HDR TH 1X3 IOJ6
HDR102CONN_HDR_1X2_HDR102_IO_8.6MM_21HDR 1X2 TH IOJ7
CON5_MUSB_AB_0P8_RA_SMTUSB_MINI_B_SKT_CON5_MUSB_AB_0P8USB_MINI_B 5 IOJ8
HDR102CONN_HDR_1X2_HDR102_IO_8.6MM_21HDR 1X2 TH IOJ9
HDR103CONN_HDR_3X1_HDR103_IO_8.6MM_21HDR TH 1X3 IOJ10
HDR102CONN_HDR_1X2_HDR102_IO_8.6MM_21HDR 1X2 TH IOJ11
HDR103CONN_HDR_3X1_HDR103_IO_8.6MM_21HDR TH 1X3 IOJ12
HDR205CONN_HDR_5X2_HDR205_IO_8.6MM_21HDR 2X5 IOJ13
HDR203_M20CONN_HDR_3X2_HDR203_M20_IO_8.64HDR 2X3 IOJ14
HDR103CONN_HDR_3X1_HDR103_IO_8.6MM_21HDR TH 1X3 IOJ15
HDR103CONN_HDR_3X1_HDR103_IO_8.6MM_21HDR TH 1X3 IOJ16
CON164_1MM_FINGERPCI_EXPRESSX16_CON164_1MM_FINGEPCI EXPRESS 164 TWRSYS PRIMARY IOJ17
CON164_1MM_FINGERPCI_EXPRESSX16_CON164_1MM_FINGEPCI EXPRESS 164 TWRSYS PRIMARY IOJ18
IND_1206ABEAD_IND_1206A_DISCRETE_1.3MM_126OHM DISCRETEL1
IND_1206ABEAD_IND_1206A_DISCRETE_1.3MM_126OHM DISCRETEL2
IND_1206ABEAD_IND_1206A_DISCRETE_1.3MM_126OHM DISCRETEL3
IND_1206ABEAD_IND_1206A_DISCRETE_1.3MM_126OHM DISCRETEL4
QTLP610TRAN_PHOTO_QTLP610_IC_1.1MM_480QTLP610CPD ICQ1
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER1
RC0603_OVRES_RC0603_OV_DISCRETE_470-755510M DISCRETER2
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER3
RC0603_OVRES_RC0603_OV_DISCRETE_470-755510M DISCRETER4
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER5
RC0603_OVRES_RC0603_OV_DISCRETE_470-75392.2K DISCRETER6
RC0603_OVRES_RC0603_OV_DISCRETE_470-799947 DISCRETER7
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER8
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER9
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER10
RC0603_OVRES_RC0603_OV_DISCRETE_470-75_11K DISCRETER11
RC0603_OVRES_RC0603_OV_DISCRETE_470-75_24.7K DISCRETER12
RC0603_OVRES_RC0603_OV_DISCRETE_470-75_11K DISCRETER13
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER14
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER15
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER16
RC0603_OVRES_RC0603_OV_DISCRETE_470-755510M DISCRETER17
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER18
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER19
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER20
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER21
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER22
RC0603_OVRES_RC0603_OV_DISCRETE_470-758433 DISCRETER23
RC0603_OVRES_RC0603_OV_DISCRETE_470-758433 DISCRETER24
RC0603_OVRES_RC0603_OV_DISCRETE_470-7545330 DISCRETER25
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER26
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER27
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER28
RC0603_OVRES_RC0603_OV_DISCRETE_470-7545330 DISCRETER29
RC0603_OVRES_RC0603_OV_DISCRETE_470-7545330 DISCRETER30
RC0603_OVRES_RC0603_OV_DISCRETE_470-7545330 DISCRETER31
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER32
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER33
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER34
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER35
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER36
RC0805_OVRES_RC0805_OV_DISCRETE_0.6MM_4710K5%DISCRETER37
RC0603_OVRES_RC0603_OV_DISCRETE_470-757733K DISCRETER38
RC0603_OVRES_RC0603_OV_DISCRETE_470-75_11K DISCRETER39
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER40
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER41
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER42
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER43
RC0603_OVRES_RC0603_OV_DISCRETE_470-758433 DISCRETER44
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER45
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_42.2K5%DISCRETER46
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER47
POT3_3352WPOT_POT3_3352W_DISCRETE_470-79910K DISCRETER48
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_42.2K5%DISCRETER49
POT3_3352WPOT_POT3_3352W_DISCRETE_470-79910K DISCRETER50
POT3_3352WPOT_POT3_3352W_DISCRETE_470-79910K DISCRETER51
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_42.2K5%DISCRETER52
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_42.2K5%DISCRETER53
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_42.2K5%DISCRETER54
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_42.2K5%DISCRETER55
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER56
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER57
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER58
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER59
RNET_4_8RES_ISO4_SINGLE_RNET_4_8_DISCRE10k DISCRETERN1
SH0402RES_SHORT-2_SH0402_DISCRETE_4700 DISCRETESH1
SH0402RES_SHORT-2_SH0402_DISCRETE_4700 DISCRETESH2
SH0402RES_SHORT-2_SH0402_DISCRETE_4700 DISCRETESH3
SH0402RES_SHORT-2_SH0402_DISCRETE_4700 DISCRETESH4
SH0402RES_SHORT-2_SH0402_DISCRETE_4700 DISCRETESH5
SH0402RES_SHORT-2_SH0402_DISCRETE_4700 DISCRETESH6
SH0402RES_SHORT-2_SH0402_DISCRETE_4700 DISCRETESH7
SH0402RES_SHORT-2_SH0402_DISCRETE_4700 DISCRETESH8
SW4_PB_6X6_SMSW_PB_4P_SW4_PB_6X6_SM_IC_5MM_5PTS645 ICSW1
SW4_PB_6X6_SMSW_PB_4P_SW4_PB_6X6_SM_IC_5MM_5PTS645 ICSW2
SW4_PB_6X6_SMSW_PB_4P_SW4_PB_6X6_SM_IC_5MM_5PTS645 ICSW3
SW4_PB_6X6_SMSW_PB_4P_SW4_PB_6X6_SM_IC_5MM_5PTS645 ICSW4
SW4_PB_6X6_SMSW_PB_4P_SW4_PB_6X6_SM_IC_5MM_5PTS645 ICSW5
LQFP80_0P65_14X14MMMC9S08LGW64_LQFP_80P_LQFP80_0P6PC9S08GW64CLK ICU1
SOT-23DDTD122LC_SOT-23_IC_1.1MM_480-7TRANSISTOR\BJT ICU2
SOT-23DDTA113ZCA_3P_SOT-23_IC_1.10MMDDTA113ZCA ICU3
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YM ICU4
SOT-23DDTD122LC_SOT-23_IC_1.1MM_480-7TRANSISTOR\BJT ICU5
SOT-23DDTD122LC_SOT-23_IC_1.1MM_480-7TRANSISTOR\BJT ICU6
TQFP44MC9S08JM60CFGE_TQFP44_IC_1.60MMC9S08JM60CLD ICU7
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45 ICU8
SOT223LM1117_SOT223_IC_1.9MM_315-788LD1117-3.3 ICU9
TSSOP16ICL3232_TSSOP16_IC_1.1MM_312-7ICL3232 ICU10
SOIC20MC9S08QE8CWJ_SOIC20_IC_2.65MM_3MC9S08QE8 ICU11
XTL2_ECS_CSM7_SMXTAL_XTL2_ECS_CSM7_SM_IC_4.2MM_4MHz ICX1
XTL2_ECS_SMXTAL_XTL2_ECS_SM_IC_2.25MM_230-32.768KHz ICY1
XTL2_ECS_SMXTAL_XTL2_ECS_SM_IC_2.25MM_230-32.768KHz ICY2
重要提示:PCB作品文件展下载说明
枯荷依风 | 2018-11-30 08:38:18 | 显示全部楼层
hotloo | 2018-11-30 08:47:28 | 显示全部楼层
mentor  xpedition    球球裙:156782529
ky175 | 2018-11-30 08:50:54 | 显示全部楼层
weizh168 | 2018-11-30 08:51:29 | 显示全部楼层
