• 芯片制造中的阻挡层沉积技术介绍
  • 接地搭接电缆布局屏蔽!!!
  • 北美液冷生态解码:超微spuermicro,24年营
  • SK海力士全球首发HBM4-16层堆叠、2.0TB/s
  • 2纳米Nanosheet技术及其以后的选择性层减薄
[Pads_VX.2x] MT6223D+CW6626M+RDA5802 功能手机PCB文件共享
查看3182 | 回复13 | 2018-12-30 20:27:49 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
NamePCB DecalValuePart Type
ANT603ANT_FM_D2311ANT_FM_D2311
B101IND-FERR_BEAD-100M_BLM18HD102SN1D_0603BLM18HD102SN1DIND-FERR_BEAD-100M_BLM18HD102SN1D_0603
B402BEAD0402BLM15AG601SN1DIND-FERR_BEAD-100MHZ_BLM15AG601SN1D_0402
BF601IC-BT_SAW_LTB-1608-2G4H6-A1-RPIC-BT_SAW_LTB-1608-2G4H6-A1-RP
CON501CON-RF_COAXIAL-MM8430-2610_MURATARF_COAXIALCON-RF_COAXIAL-MM8430-2610_MURATA
D102SOD_323UDZSTE-176.2BUDZSTE-176.2B
D301SOD-5231SS400TE61DIODE-1SS400TE61_SOD-523_ROHM
D707CAP0603-LEDBlue LEDDIODE-LED_BLUE_QSMR-C139_0603-AVAGO
D708D2313_BRIGHTAD2311_BRIGHT
J103CON-BAT_PAN26-03432-1500++PAN26-03432-1500CON-BAT_PAN26-03432-1500_LCN_V818
J301CON-SIM_WKSM010-1901-JTCONN+CON-SIM_6108-06-G_CTCCON-SIM_6108-06-G_CTC
J302CON-SIM_WKSM010-1901-JTCONN+CON-SIM_6108-06-G_CTCCON-SIM_6108-06-G_CTC
J303CON-I/O_10PIN_U02-4B1B380ACON-I/O_10PIN_U02-1B1F380A
J304DC_JACK_SMT_2PINCON-DC_JACK_DC_2PIN
J305CON-TFLASH_TFS07-8K30000TFLASHCON-TFLASH_TFS307-8K30000
J701JON_14PIN_PITCH0.8JON_14PIN_PITCH0.8
J702JON_5PIN_PITCH1.0JON_5PIN_PITCH1.0
J703JON_5PIN_PITCH1.0JON_5PIN_PITCH1.0
J802CON-D2311_LCM_1.8TFT_ETM180034N00CON-D2311_LCM_1.8TFT_ETM180034N00
J803CON-LCM_2.0'FS20006ANP22CON-LCM_2.0'FS20006ANP22
J804CON-D2311_CAM_PAS6167_SPICON-D2311_CAM_SSY309-B_SPI
J805JON-2PIN-0.8PITCHJON-2PIN-1.0PITCH
L408IND040239nHIND-ML-39NH_5%_LQG15HS39NJ02D-0402
L501IND040215nHIND-ML-15NH_5%_LQG15HN15NJ02D-0402
L502IND04024.7nHIND-ML-4.7NH_0.3N_LQG15HN4N7S02D-0402
L503IND040215nHIND-ML-15NH_5%_LQG15HN15NJ02D-0402
L504IND040215nHIND-ML-15NH_5%_LQG15HN15NJ02D-0402
L508IND0402270nHIND-MULTILAYER-270NH_+/-5%_0402
MARK1MARK_1.0MARK_1.0
MARK2MARK_1.0MARK_1.0
MARK3MARK_1.0MARK_1.0
MARK4MARK_1.0MARK_1.0
MIC+TP_2.0X1.0ATP_2.0X1.0
MIC-TP_2.0X1.0ATP_2.0X1.0
QN801SOT-323TRAN-BJT-NPN_BC847BT_PHILIPS
QN802SOT-323TRAN-BJT-NPN_BC847BT_PHILIPS
REC401D2313_RECEIVERD2311_RECEIVER
S723DOME-5.8-CUTNUMBER 2DOME-5.8-CUT
S724SWITCH-NSS507-212F-CCCG1T_OD_08081401SWITCH-NSS507-212F-CCCG1T_OD_08081401
SPK401D2311_SPEAKERD2311_SPEAKER
SPK402D2311_SPEAKERD2311_SPEAKER
TVS306SOD-523ESD5Z12T1GDIODE-TVS-ESD5Z12T1G_SOD-523_ONSEMI
TVS408CAP04025.5V,40pFVARISTOR-5.5V_40P-0402_CTC
U101IC-BB_PROCESSOR_MT6223D_MTKMT6223DIC-BB_PROCESSOR_MT6223D_MTK
U102TRAN-PMOS+DIODE_NTHD4P02FT1G_ONSEMINTHD4P02FT1GTRAN-PMOS+DIODE_NTHD4P02FT1G_ONSEMI
U201IC-MEM_64M_32M_TV00560002EDGB_TOSHIBATV00560002EDGBIC-MEM_64M_32M_TV00560002EDGB_TOSHIBA
U301IC-ANALOG_SWITCH_MT6302_MTKMT6302N-LIC-ANALOG_SWITCH_MT6302_MTK
U401IC-AUDIO_AMP_AB_TS4990EIJT_STTS4990EIJTIC-AUDIO_AMP_AB_TS4990EIJT_ST
U402IC-AUDIO_AMP_AB_TS4990EIJT_STTS4990EIJTIC-AUDIO_AMP_AB_TS4990EIJT_ST
U501IC-RFPA_SKY77518-SKYWORKSSKY77518IC-RFPA_SKY77518_SKYWORKS
U502IC-FAR-G6KG_1G8425_Y4PA-FUJITSUEFCH9418TCQ1IC-FAR-G6KG_1G8425_Y4PA-FUJITSU
U503IC-RF_TRANSEIVER_AD6548BCPZ_ADIAD6548BCPZIC-RF_TRANSEIVER_AD6548BCPZ_ADI
U504RP9193-28PBRP9193-28PBIC-LDO_2.8V/300MA_RP9193-SOT235
U601RP9193-28PBRP9193-28PBIC-LDO_2.8V/300MA_RP9193-SOT235
U602IC_FM_RDA5802_RDARDA5802IC_FM_RDA5802_RDA
U603IC-BT_CW6626M-CONWISECW6626MIC-BT_CW6626M-CONWISE
U801SOT-23-6LDO-2.8/1.8VIC-LDO-DUAL_2.8V_1.8V_SOT236_RICHTEK
U802LED_RP1364LED_RP1364
VIB301D2311_VIBD2311_VIB
Y101CRYSTAL_MS3V-T1R_T7_12.5PF(KDS_XTAL_SM)?CRYSTAL-32.768KHZ_SSP-T7_SII
Y501CX32254SB26000B6FZF30TXC-26MHzCRYSTAL-26MHZ-CX3225SB26000B6FZF330
Y601NX3225DATXC-26MHzCRYSTAL-26MHZ-7M26000018_3225_TXC_AD6548
重要提示:PCB作品文件展下载说明
老吴 | 2018-12-30 20:28:22 | 显示全部楼层
PCB共享,没有原理图。
MT6223D+CW6626M.7z (829 KB, 下载次数: 12)
heming2216 | 2018-12-30 21:23:34 | 显示全部楼层
lcfmax | 2018-12-31 08:06:22 | 显示全部楼层
wangy2000 | 2018-12-31 08:06:52 | 显示全部楼层
小鑫鑫 | 2018-12-31 08:42:53 | 显示全部楼层
会飞的鱼589 | 2018-12-31 08:46:32 | 显示全部楼层
学海无涯 | 2018-12-31 10:11:37 | 显示全部楼层
带刀的老鼠 | 2018-12-31 21:02:58 | 显示全部楼层
zhifang88 | 2018-12-31 21:31:12 | 显示全部楼层
