重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | 39 | C-0603 | 33P | CAP_NP_7 | 60 | CDA | 10uF | CAP_2 | AV1 | JACK3X1A | OPTI OUT | TOTX178_2 | AV2 | SCJACK | comp/S-video | COMP/S-VIDEO_3 | AV3 | AV-JACK | AV-JACK-1 | AV-JACK_8 | CN1 | HEADER6-2.54 | POWER/6PIN/2.54MM | CON6 | CN2 | HEADER5-2 | 5PIN/2.0MM | CON5 | CN3 | HEADER6-2 | 6PIN/2.0MM | CON6_0 | CN4 | | 7PIN/2.0MM | CON9_0 | CN4_SY | CON24-0.5-F2 | ELCO-CON24(Left) | ELCO-CON24_0 | CN5 | HEADER6-2.54 | 6PIN/2.0MM | CON6 | CN6 | CN7 | CON7 | CON7 | CN9 | HEADER6-2.54 | IR/VFD/6PIN/2.5MM | CON6 | CN10 | HEADER4-2.54 | 4PIN/2.5MM(OPEN) | CON4_2 | CN12 | | MIC/3PIN/2.5MM | CON3 | CN14 | | SCART/9PIN/2.0MM | CON9 | D1 | | 1N4148 | DIODE | D2 | D-1206 | 1N4148 | DIODE_2 | D3 | D-1206 | 1N4148 | DIODE_2 | D4 | D/DIP/P10.0/Z | 1N4001,DIP | DIODE_0 | D5 | D/DIP/P10.0/Z | 1N4001,DIP | DIODE_0 | D6 | | 1N4148 | DIODE | D8 | ZW | 9.1V | DIODE_ZENER | D9 | D-1206 | 1N4148(SMT) | DIODE_2 | D12 | D-1206 | 1N4148(SMT) | DIODE_2 | EC66 | CAP100 | 47U16V | CAP_0 | F1 | L-1206 | FUSE(1206,500mA)(OPEN) | FUSE | J1 | TUNER | CON13 1.25mm | CON12_4 | J2 | | CON4 | CON4 | JP1 | SIP2 | Bootstrap On | CON2_2 | Q1 | PNP-EBC1 | 9015(DIP EBC) | PNP_6 | Q2 | PNP-EBC1 | 9015(DIP EBC) | PNP_6 | Q3 | SOT-23 | 2SK3018 | MOSFET_N_0 | Q4 | SOT-23 | 2SK3018 | MOSFET_N_0 | Q5 | PNP-EBC1 | 9015(DIP EBC) | PNP_6 | Q6 | SOT-23 | 2N3904 | NPN_2 | Q7 | 2SB1132 | 2N8550 | PNP_5 | Q8 | 2SB1132 | 2N8550 | PNP_5 | Q10 | TO-92B | 2SS8550D | PNP_1 | Q11 | PNP-EBC1 | 9015(DIP EBC) | PNP_6 | Q12 | SOT-23 | 2N3906 | PNP_BCE_0 | Q13 | SOT-23 | 2N3906 | PNP_BCE_1 | Q14 | SOT-23 | 9014 | NPN_0_2 | Q15 | SOT-23 | 9014 | NPN_0_2 | Q16 | SOT-23 | 9014 | NPN_0_2 | Q17 | TRA\SMD | 9014 | NPN_0 | Q18 | SOT-23 | 2N3904 | NPN_2 | Q19 | SOT-23 | 2N3904 | NPN_2 | Q20 | SOT-23 | 2N3904 | NPN_2 | Q21 | SOT-23 | 2N3904 | NPN_2 | Q22 | SOT-23 | 2N3904 | NPN_2 | Q23 | TO-92B | 2SS8550D | PNP_1 | Q25 | SOT-23 | 3904(SMT) | NPN_0_2 | Q26 | SOT-23 | 2S8550 | PNP_6 | Q27 | SOT-23 | 2S8550 | PNP_6 | Q28 | SOT-23 | 2S8550 | PNP_6 | Q31 | SOT-23 | 9015 | PNP_6 | Q32 | SOT-23 | 9014(SMD) | NPN_0_2 | Q33 | NPN | 2S8050 | NPN_2 | TP24 | R30 | RFRP | TP-2 | U2 | DIP8-SOP | NJM4558 | 4558 | U3 | DIP8-SOP | NJM4558 | 4558 | U4 | DIP28-SSOPH | AM5888 | BA5934FP_8 | U5 | DIP8-SOP | 24C01/CAT24C021 | 24C01A_1 | U7 | QFP216-0.4 | SPHE8202S/D | SPHE8202A-216PIN_7 | U9 | DIP8-SOP | CS4334 | CS4334 | U10 | DIP28-SSOP1 | CS4360 | WM8766D_1 | U11 | DIP54-SSOP | SDRAM 1Mx16x4 | 4MX16 | U12 | DIP8-SOP | NJM4558 | 4558 | U13 | DIP50-TSOP | SDRAM 16M-6(512Kx16x2) | SDRAM_512KX16X2 | U15 | PLCC32S-1 | AM27C040/Flash MX29F040(PLCC) | AM27C040_4_2 | U16 | DIP50-TSOP | SDRAM 16M-6(512Kx16x2) | SDRAM_512KX16X2 | U16 | DIP20-SOP1 | SAA6588 | HEADER_10X2_1 | U17 | DIP48-TSOP | MX29LV800T/B,MX29F800T/B | FLASH_1MX16_2 | U18 | SO28 | PT2323 | PT2323 | U19 | SO28 | PT2322 | PT2322_1 | XT1 | X'TAL | 27MHz | CRYSTAL | XT2 | X'TAL | 4.332MHz | CRYSTAL_2 |
重要提示:PCB作品文件展下载说明
