重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | CN1 | FPC30 | 6705-E20N-00R | FPC_CON24P_2 | CN2 | FPC30 | 6705-E20N-00R | FPC_CON24P_2 | CN2 | LCD40 | AO25BN02_V5 | P40_4 | D1 | DIP_0.8_2.4 | 334-15-T2C1 | LED_0 | D1 | SOT-23 | F05J4L | DIODE_0 | D1 | LED_SMD | 11-22SRUGC | BI-COLOR_LED_1 | D2 | DIP_0.8_2.4 | 334-15-T2C1 | LED_0 | D3 | DIP_0.8_2.4 | 334-15-T2C1 | LED_0 | D3 | SOD-323 | 1SS355 | DIODE_1 | D4 | SMT | SELF_LED | LED_0 | D5 | SOD-323 | 1SS355 | DIODE_1 | D6 | SOD-323 | 1SS355 | DIODE_1 | D7 | SOT23 | RB491 | DIODE_SCHOTTKY_4 | D11 | SOT23 | RB491 | DIODE_SCHOTTKY_4 | D12 | SOD-323 | 1SS355 | DIODE_1 | D13 | SOT23 | RB491 | DIODE_SCHOTTKY_4 | D18 | SOD-323 | UDZS-5.6B | DIODE_ZENER_0 | ESD1 | SOT-23 | SP0502BAHT/NL | FB_2 | F1 | R0603 | Little fuse 434002 | FUSE | FB14 | R0805 | HCB2012K-300T30 | FB | J1 | CIM-E90 | WK21923-S1P | CONNECTOR_SD_4 | J1 | CON15_2 | SEN_CON_28PIN | CON8AP_1 | J1 | CONF6_2 | B06A-1200-121 | CONN_FLEX_12_4 | J1 | FPC2_2 | Apr/00 | HEADER_4 | J2 | PLA0139 | MINI USB-B | MINI_USB-B_0 | J3 | CON15_2 | SEN_CON_30PIN | CON8AP_1 | J4 | FPC4 | Apr/00 | HEADER_4 | J5 | LI_BAT | BATTERY | CONN_PLUG_2_1 | J6 | AV_JACKB | TV_AUDIO INPUT JACK | PHONEJACK_0 | J7 | CONF6_2 | B06A-1200-121 | CONN_FLEX_12_5 | J7 | CON12_2 | B06A-1200-121 | CONN_FLEX_12_5 | J8 | | p14 | P14_1 | J8 | QJ51193-MFT1 | HDMI | HDMI | J9 | CONF6_2 | B06A-1200-121 | CONN_FLEX_12_4 | JP1 | SIP2P/2.0 | MIKE | RS_MIKE | JP2 | RS232 | HEADER 4 | HEADER_4 | L1 | R0805 | 33uH | INDUCTOR | L1 | R0805 | 33uH | INDUCTOR | L1 | R0805 | 33uH | INDUCTOR | L2 | R0805 | 33uH | INDUCTOR | L2 | R0805 | HCB2012K-300T30 | INDUCTOR | L3 | CUB-T4P-3216-222T | CUB | CUB_2 | L4 | SL61H2.0 | 10uH | INDUCTOR_2 | L6 | SL61H2.0 | 10uH | INDUCTOR_2 | L7 | SL61H2.0 | 47uH | INDUCTOR_2 | L8 | SL61H2.0 | 10uH | INDUCTOR_2 | L12 | SL61H2.0 | 10uH | INDUCTOR_2 | L13 | SL61H2.0 | 10uH | INDUCTOR_2 | L14 | SL61H2.0 | 10uH | INDUCTOR_2 | LS1 | SIP2P/2.0 | SPEAKER 8ohm 0.5W | SPEAKER | LS2 | SIP2P/2.0 | SPEAKER 8ohm 1W | SPEAKER | Q2 | SOT-523 | DDTC124EE | NPN_4 | Q4 | SOT23 | AO3418 | MOSFET_N_2 | Q5 | SOT23 | AO3418 | MOSFET_N_2 | Q6 | SOT-23 | AO3415 | P-MOSFET_SOT23_1 | Q6 | SOT-23 | AO3415 | P-MOSFET_SOT23_1 | Q7 | SOT-23 | AO3415 | P-MOSFET_SOT23_1 | Q8 | SOT-523 | DTC144WKA | DTDNPN_1 | Q9 | SOT-23 | AO3415 | P-MOSFET_SOT23_1 | Q10 | SOT-523 | DTC144WKA | DTDNPN_1 | Q11 | SOT-23 | AO3415 | P-MOSFET_SOT23_1 | Q12 | SOT-23 | SN3904 | NPN_9 | Q15 | SOT-363 | MMDT3946 | MMDT3946 | Q16 | SOT-363 | MMDT3946 | MMDT3946 | Q24 | SOT-23 | AO3415 | P-MOSFET_SOT23_1 | Q25 | SOT-523 | DTC144WKA-SOT23 | DTDNPN_1 | Q26 | SOT-523 | DTC144WKA | DTDNPN_1 | Q27 | SOT-523 | DTC144WKA | DTDNPN_1 | Q29 | SOT-23 | SN3904 | NPN_9 | Q30 | SOT-23 | AO3415 | P-MOSFET_SOT23_1 | Q31 | SOT-523 | DTC144WKA | DTDNPN_1 | Q32 | SOT-23 | AO3415 | P-MOSFET_SOT23_1 | Q33 | SOT-523 | DTC144WKA | DTDNPN_1 | Q34 | SOT-23 | AO3415 | P-MOSFET_SOT23_1 | Q35 | SOT-523 | DTC144WKA | DTDNPN_1 | Q36 | SOT-23 | SN3904 | NPN_9 | Q38 | SOT-23 | SN3904 | NPN_9 | S1 | SW1AB-260AU-T28 | LI_DET | SW_PUSHBUTTON_1 | S1 | P376-00 | MICRO | SW_PUSHBUTTON_1 | S1 | 1501 | LEVER AND PUSH OPERATION SWITCH | SW_KEY-Y2011_5 | S2 | TSW-3AS2-GT50 | TACK-SW TSW-3AS2-GT50 | SKHHAJ_0 | S3 | | SW KEY-Y2011_5 | SW_KEY-Y2011_6 | SW6 | SOT-154HST | TACT-SW SOT-154SHT | SW_PUSHBUTTON-SPST_1 | U1 | QFN10 | A3901 | ST1155B-MOTOR_DRIVER_2 | U1 | 384BGA | COACH_10P | COACH_10P | U1 | 384BGA | COACH_10P | COACH_10P | U1 | 384BGA | COACH_10P | COACH_10P | U1 | ILCC-48 | MT9E001 | MI5100_0 | U1 | TO-92 | AH182-P | RX5RL_1 | U2 | QFN10 | A3901 | ST1155B-MOTOR_DRIVER_2 | U4 | TSOP48_20_12.4_ | K9F5608U0C-YCB1 | K9F2808_1 | U5 | MSOP8 | NC7WZ02 | OR2_1 | U8 | SOT23 | CM2830 | DP-08_3 | U9 | SOT25 | AS2930M5-2.8/TR | AME8800_4 | U12 | SOT-23 | MLX90248 | AME8800_1 | U14 | QFN25 | A8430 | AT1366_0 | U15 | SOT25 | AT1366 | AT1366 | U16 | SOT25 | AT1366 | AT1366 | U17 | SOT25 | AT1366 | AT1366 | U18 | QFN25 | A8430 | AT1366_0 | U19 | | AT1780 | AT1780 | U20 | SOT25 | 74AHC1G08GV | AT1202_2 | U21 | SOT25 | AT1366 | AT1366 | U22 | DDR_84BALL | HY5PS121621C | HY5PS121621B | U23 | MSOP-8 | AS9890 | 101_2 | Y1 | XT-12 | 24MHZ | RS_CRYSTAL_0 | Y2 | XT-100 | 32K768HZ | RS_CRYSTAL_0 |
重要提示:PCB作品文件展下载说明
