重要提示:PCB作品文件展下载说明
Name | Part Type | PCB Decal | Value | 3V3 | TP_TEST/1.5MM | TP_TEST/1.5 | | BIN_VER | TP_TEST/1.5MM | TP_TEST/1.5 | | D1 | SMD_1N5819_SOD-323 | IN5819 | 1N5819 | D2 | LED0603_WHITE_BLUE | LED0603 | LED0603 | D3 | LCD_LED_87X41X2.3MM | LCD_LED_87X41X2.3MM | LCD_LED | D4 | SMD_LL4148_LL-34 | 1N4148 | 1N4148-S323 | D5 | LED0603_WHITE_BLUE | LED0603 | LED0603 | D6 | LED0603_WHITE_BLUE | LED0603 | LED0603 | D7 | LED0603_WHITE_BLUE | LED0603 | LED0603 | D8 | SMD_LL4148_LL-34 | 1N4148 | 1N5819 | D9 | SMD_LL4148_LL-34 | 1N4148 | 1N5819 | D10 | SMD_LL4148_LL-34 | 1N4148 | 1N5819 | DM | TP_TEST/1.5MM | TP_TEST/1.5 | | DP | TP_TEST/1.5MM | TP_TEST/1.5 | | ESD1 | ESD5B5VL_SOD523 | ESD-523 | ESD5B5VL | GND | TP_TEST/1.5MM | TP_TEST/1.5 | | H1 | HEADER1X2X2.54MM | HX2.54-2 | HEADER1X2X2.54mm | HF-3_3V | TP_TEST/1.5MM | TP_TEST/1.5 | | J1 | HEADER1X2X2.0MM | HEADER1X2X2.0MM | HEADER1X2X2mm | J2 | HEADER_SMD_1X7X1.5MM | HEADER_SMD_1X7X1.5MM | HEADER1X7X1.5MM SMD | J3 | HF060_MODULE | 010CC_MODULE | HF060 module | J4 | HEADER_SMD_1X5X1.5MM | HEADER_SMD_1X5X1.5MM | HEADER1X5X1.5MM SMD | J5 | HEADER_SMD_1X7X1.5MM | HEADER_SMD_1X7X1.5MM | HEADER1X7X1.5MM SMD | J6 | HF060C_MODULE | FS-060C | HF060C module | J8 | LCD_30PIN_0.5MM | LCD_30PIN_0.5MM | LCD | J10 | HDR1X(9-1)X1.5MM | HDR1X(9-1)X1.5MM | HDR1X(9-1)X1.5MM | J11 | HEADER_SMD_1X3X1.5MM | HEADER_SMD_1X3X1.5MM | HEADER1X3X1.5MM SMD | J13 | FPC_6X0.5MM | FPC_6X0.5MM | FPC_6X0.5MM | J15 | HEADER_SMD_1X7X1.5MM | HEADER_SMD_1X7X1.5MM | HEADER1X7X1.5MM SMD | RX | TP_TEST/1.5MM | TP_TEST/1.5 | | S3 | SW-7.2X7.2MM_TC6622C | SW-7.2X7.2MM_TC6622C | TC6622C | S5 | SW-7.2X7.2MM_TC6622C | SW-7.2X7.2MM_TC6622C | TC6622C | SP1 | BUZZER_9.5X5MM_AC_EET9055R16 | BUZZER_9.5X5MM/AC | Buzzer 9.5*5mm/AC | T5 | SMD-S8550-2TY-IC=0.5A_SOT-23 | SOT-23 | S8550 I=0.5A | T6 | SI2301ADS_SOT23 | SOT-23 | SI2301ADS | T7 | S8050_IC=0.5A | SOT23_8050 | 8050 Ic=0.5A | TX | TP_TEST/1.5MM | TP_TEST/1.5 | | U1 | LY6206A33P-3.3V_SOT-89 | SOT-89 | LY6206A33P | U2 | LY6206A33P-3.3V_SOT-89 | SOT-89 | LY6206A33P | U4 | 24C128_SOP8 | SOP8_24C64 | 24C128 | U9 | STM32F072VB_LQFP100 | ASM4130G_LQFP100 | STM32F072VB_LQFP100 | Y1 | 8MHZ/20PPM_5.0X3.2MM_SMD | CPX-49SP/5.0X3.2X0.8MM | 8.MHZ |
重要提示:PCB作品文件展下载说明
