[IC] AD9763_9765_9767
查看683 | 回复1 | 2020-4-17 09:36:18 | 显示全部楼层 |阅读模式
10-/12-/14-bit dual transmit digital-to-analog converters (DACs)
125 MSPS update rate
Excellent SFDR to Nyquist @ 5 MHz output: 75 dBc
Excellent gain and offset matching: 0.1%
Fully independent or single-resistor gain control
Dual-port or interleaved data
On-chip 1.2 V reference
5 V or 3.3 V operation
Power dissipation: 380 mW @ 5 V
Power-down mode: 50 mW @ 5 V
48-lead LQFP
AD9763_9765_9767.pdf
637 KB, 下载次数: 0, 下载积分: 金币 -1 枚
mj8abcd | 2020-4-20 16:16:32 | 显示全部楼层
