[IC] 时钟扩频芯片SSDCP3128AF
查看990 | 回复0 | 2020-5-28 09:34:50 | 显示全部楼层 |阅读模式
时钟扩频芯片,主要解决emc电磁兼容辐射问题
• FCC  approved method of EMI attenuation.
• Generates a 1X low EMI spread spectrum clock
of the input frequency.
• Input / Output frequency 1 MHz to 40 MHz
• VDD 1.65V - 3.6V
• Multiple Spreading Range Selections(Refer
product table)
• Power save mode
• 8-pin TDFN package
• Operating Temperature 0℃ to 70℃
SSDCP3128AF DATA SHEET_REV3.0.pdf (725 KB, 下载次数: 0)
