[Pads_VX.2x] 独家-展讯SC9853I做的智能手机PCB和原理图8层盲埋孔设计(SC
查看5197 | 回复31 | 2020-9-30 11:33:37 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
NamePCB DecalValuePart Type
ANT1ELJ_M08M001-G0G000-WA035R_TP_H3.5_W3.0POGO PINELJ_M08M001-G0G000-WA025R_W1.2L2.7H2.5
ANT2ELJ_M08M001-G0G000-WA035R_TP_H3.5_W3.0POGO PINELJ_M08M001-G0G000-WA025R_W1.2L2.7H2.5
ANT3ELJ_SOLDERING_ANTPADNCELJ_SOLDERING_ANTPAD
ANT4ELJ_SOLDERING_ANTPADNCELJ_SOLDERING_ANTPAD
ANT5102ELJ_M08M001-G0G000-WA035R_TP_H3.5_W3.0POGO PINELJ_M08M001-G0G000-WA025R_W1.2L2.7H2.5
BEAD6001B0603BLM18BB750SN1B0603-75R
BEAD6002B0603BLM18BB750SN1B0603-75R
BEAD6003B0603BLM18BB750SN1B0603-75R
BEAD6004B0603BLM18BB750SN1B0603-75R
CON2ELJ_YHTKP-1915-W_PHS_H1.9YHTKP-1915-CELJ_YHTKP-1915-W_PHS_H1.9
CON3301MM4829-2702BMHC-310CON-RF-TEST-MM4829-2702B-MURATA
CON3302MM4829-2702BMHC-310CON-RF-TEST-MM4829-2702B-MURATA
D1SOD123MM1Z5VDIODE_SCHOTTKY_2
D2SOD123MM1Z20VDIODE_SCHOTTKY_2
D1301EMD2-SOD523NC/RB520S30RB520S30
D5201PQFN_14_P050_250X300_H086_LSM6DSLNCSENSOR-ACCEL+GYRO-LSM6DSL
D6100SOD_2513_H110DIODE-ZENER-PZ3D5V1H
D6101DIO_BD_DFN_2_100X060_H050NC/ESD5651N-2/TR/4.35VTVS-ESD5651N-2/TR
D6102SOT23_3BAT54SBAT54S
D6103DIO_BD_DFN_2_100X060_H0504.35V(NF)TVS-ESD5651N-2/TR
D6108SOT23_3BAT54SBAT54S
D6109SOD1231N5819DIODE_SCHOTTKY_2
D6110SOD1231N5819DIODE_SCHOTTKY_2
EMI6001FILTER/SMD/TCM0806GNCEMIX21A390FNPE_1
FB2100SL04021000ohm@100MHzBEAD-1K-OHM-100MHZ-300MA-0402
FB3103SL0603-S600ohm@100MHz 700mABEAD-600-OHM-100MHZ-700MA-0603
FB3104SL04021000ohm@100MHzBEAD-1K-OHM-100MHZ-300MA-0402
FB4101FILTER/SMD/TCM0806GNC/DLP0NSC280HL2EMIX21A390FNPE_1
FB6600SL04021000ohm@100MHzBEAD-1K-OHM-100MHZ-300MA-0402
FB6601SR04020RRES-0-0402
FB7201SR04020RES-0-0402
H1PTH_HOLE_1.6/2.8MMAAADNIPTH_HOLE_1.6/2.8MM
H2PTH_HOLE_1.6/2.8MMADNIPTH_HOLE_1.6/2.8MM
H1000PTH_HOLE_1.6/2.8MMDNIPTH_HOLE_1.6/2.8MM
H1001PTH_HOLE_1.6/2.8MMDNIPTH_HOLE_1.6/2.8MM
H1002PTH_HOLE_1.6/2.8MMDNIPTH_HOLE_1.6/2.8MM
J0001CON-RF-SWITCH-MM8030-2610RK0CON-RF-SWITCH-MM8030-2610RK0
J12CON-CLIP-SHIELD-PTC0703BELJ-KS270013
J13ELJ_0.5-H1.5-8P_ZIF_8PIN_H1.5ELJ_0.5-H1.5-8P_ZIF_8PIN_H1.5ELJ_0.5-H1.5-8P_ZIF_8PIN_H1.5_ZJW
J14CON-CLIP-SHIELD-PTC0703BELJ-KS270013
J15NC-2PINFPC-3X0.5MMNCNC-2PINFPC-3X0.5MM
J16ELJ_HC301-13RL-GF_ZIF-H1.0ELJ_HC301-13RL-GF_ZIF-H1.0ELJ_HC301-13RL-GF_ZIF-H1.0
J20CON-CLIP-SHIELD-PTC0703BELJ-KS270013
J23CON-CLIP-SHIELD-PTC0703BELJ-KS270013
J24CON-CLIP-SHIELD-PTC0703BELJ-KS270013
J103ELJ_ADJ-312-P3.2-X5_EAR-H4.2-FC1.0ELJ_ADJ-312-P3.2-X5_EAR-H4.2-FC1.0ELJ_ADJ-312-P3.2-X5_EAR-H4.2-FC1.0
J0703CON-RF-SWITCH-MM8030-2610RK0CON-RF-SWITCH-MM8030-2610RK0
J0800CON-RF-SWITCH-MM8030-2610RK0CON-RF-SWITCH-MM8030-2610RK0
J0801CON-RF-SWITCH-MM8030-2610RK0CON-RF-SWITCH-MM8030-2610RK0
J901ELJ_HC503-6R-GF_PJ_0.5_H1.0HC503-6R-GFELJ_HC503-6R-GF_PJ_0.5_H1.0
J1010ELJ_SA-1505-001_SIM_H1.5ELJ_SA-1505-001_SIM_H1.5ELJ_SA-1505-001_SIM_H1.5
J1011ELJ_SA-1505-001_SIM_H1.5ELJ_SA-1505-001_SIM_H1.5ELJ_SA-1505-001_SIM_H1.5
J1102ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85NCELJ_BAR080T028-NYZ_2P-0.8JP-H1.85
J1103ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85NCELJ_BAR080T028-NYZ_2P-0.8JP-H1.85
J1105ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85NC ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85
J2001NC_BAT_CON_3NCNC_BAT_CON_3
J2002ELJ-BAT1254001-05YZ_5PIN-1.25JP-H1.9BAT-5PIN-1.25JP-H1.9ELJ-BAT1254001-05YZ_5PIN-1.25JP-H1.9
J6002ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85NC ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85
J6003REC1506NCREC1506
J6201ELJ_FH26-39S-0.3SHW_PH0.6-FPC0309-39B3AXK7L30227GELJ_FH26-39S-0.3SHW_PH0.6-FPC0309
J6503ELJ_HC503-6R-GF_PJ_0.5_H1.0HC503-6R-GFELJ_HC503-6R-GF_PJ_0.5_H1.0
J6602ELJ_UC3-0B0751R0_TYPE-C-CB0.8ELJ_1181-32XA8-23A_USB3.1-CB1.42ELJ_UC3-0B0751R0_TYPE-C-CB0.8
J6701ELJ_0.5-H1.5-30P_ZIF_30PIN_H1.5ELJ_0.5-H1.5-30P_ZIF_30PIN_H1.5ELJ_0.5-H1.5-30P_ZIF_30PIN_H1.5
J6702ELJ_FH26-51S-0.3SHW_PH0.6-FPC0309-51B3NC FPC51P-0.3MMELJ_FH26-51S-0.3SHW_PH0.6-FPC0309-51B3
L1ELLVFG-C_1.4_3.210uHELLVFG-C_1.4_3.2
L0001CAP-NF-0201NFCAP-NF-0201
L0002IND-NF-0201NFIND-NF-0201
L0307IND_POWER_WPN2520120.33uHIND-POWER-0.33UH-WPN2520
L0308IND-POWER-WPN20161.0uHIND-POWER-1.0UH-WPN201610H1R0MT
L403L/IND/SMD/2520NC / VLS252010HBX-R47MINDUCTOR
L0600IND-NF-0201NFIND-NF-0201
L0706SL02013.9nHIND-CER-3.9NH-0.3-0201-SDCL0603Q-02B01
L0707SL02015.1nHIND-CER-5.1NH-5%-0201-LQP03TN-02
L0708SL02015.6nH(NF)IND-CER-5.6NH-0.3-0201-SDCL0603Q-02B01
L0709SL020133nHIND-CER-33NH-5%-0201-LQP03TN-02
L0710IND-NF-0201NFIND-NF-0201
L0711SL02015.1nHIND-CER-5.1NH-0.3-0201-SDCL0603Q-02B01
L0713SC02014.7pF(NF)CAP-4.7PF-0201
L0714SL02013.3nH(NF)IND-CER-3.3NH-0.2-0201-LQP03TN-02
L0717SC02011.2pF/50V(NF)CAP-1.2PF-0.1-50V-0201-GRM0335C-A01
L0721SL02019.1nHIND-CER-9.1NH-0.3-0201-SDCL0603Q-02
L0724IND-NF-0201NFIND-NF-0201
L0751SL02015.6nHIND-CER-5.6NH-0.3-0201-SDCL0603Q-02B01
L0752IND-NF-0201NFIND-NF-0201
L0753IND-NF-0201NFIND-NF-0201
L0759SL02015.6nHIND-CER-5.6NH-5%-0201-LQP03TN-02
L0845SL02017.5nHIND-CER-7.5NH-5%-0201-SDCL0603Q-02B01
L0848IND-NF-0201NFIND-NF-0201
L0849IND-NF-0201NFIND-NF-0201
L2020L/IND/SMD/25201uH/WPN252012H1R0MTL/IND/SMD/2520
L6101IND-POWER-WPN2016NC/1.0uHIND-POWER-1.0UH-WPN201610H1R0MT
L6103CD4310uHIND-CD43
L6105MPH252012NRH2410T4R7MNMPH252012
L7200SL02014.3nHIND-CER-4.3NH-0.3-0201-SDCL0603Q-02B01
L7201SL02014.3nHIND-CER-4.7NH-3%-0201-LQP03TN-00
L7202SL02011.0nHIND-CER-1.0NH-0.3-0201-SDCL0603Q-02B01
L7203IND-NF-0201NFIND-NF-0201
L7204SL02011.2nHIND-CER-2.0NH-0.2-0201-LQP03TN-02
L7205SL02013.3nHIND-CER-3.3NH-0.3-0201-SDCL0603Q-02B01
L7206IND-NF-0201NFIND-NF-0201
L7207SL02015.6nHIND-CER-5.6NH-5%-0201-LQP03TN-02
L7209SL020127nHIND-CER-27NH-5%-0201-LQP03TN-02
L7229SL02013.3nHIND-CER-3.3NH-0.2-0201-LQP03TN-02
LED1ELJ_EFD3-G9CA/EFC3A-P3CA_2.04X1.64_H0.75ELJ_EFD3-G9CA_2.04X1.64_H0.75
Q901SC-75_SOT-416_DTC114EET1-DNC/DTC114YET1SC-75_SOT-416_DTC114EET1-D
Q6100SOT_3_P095_240_H120NC/WNM3003-3/TR/3.7AFET-N-WNM3003-3/TR
Q6101SC-75_SOT-416_DTC114EET1-DNC DTC114YET1SC-75_SOT-416_DTC114EET1-D
Q6102SC-75_SOT-416_DTC114EET1-DNC DTC114YET1SC-75_SOT-416_DTC114EET1-D
Q6103SOT23_3WPM2026IRF5210/TO_6
Q6104SOT23_3MMBT3904NPN_BEC
Q6601SOT-723-123WNM2030LNTK3043NT5G
SH2001NC/RSHORT / NC-MMD-L9-4MILNO_PAD_0402_SMD_1
SH2002NC/RSHORT / NC-MMD-L9-4MILNO_PAD_0402_SMD_1
SH6100NC_SHORT_0402NC_SHORT_0402
SH6101NC_SHORT_0402NC_SHORT_0402
T0501TP_S050TP-S050
TVS3125SOD_FL_1006_H040(NF)TVS-ESD9L5.0ST5G
TVS4102SOD_FL_1608_H070(NF)TVS-ESD5Z5.0T1G
TVS6200SOD_2513_H110(NF)TVS-PTVSHC3D12VU
U0001QFN_12_P050_200X200_T076_H060_460LFRF-SWITCH-SKY13373-460LF
U0002FILTER_8_180X140_H060TxRx:847/806MHzRF-SAW-DUPLEX-SAYEY806MBA0F0A
U0003RF-SAW-1.1X0.9806MHzRF-SAW-SAFFB806MAA0F0A
U5FSUSB30UMXFSUSB30UMXFSUSB30UMX
U0006FILTER_CAF_6_P065_200X125_H100_LRFDIP2012090G77N2TRF-SAW-DIPLEX-DPX202700DT-4162A1
U0200BGA_212_P040_730X690_H085_SC2731GIASIC-SC2731GI-212-0.4
U404SY8823NC / SY8823SY8823
U501BGA_200_P080X065_1000X1450_H080_B031_CHK16GbMEM-LPDDR4-MT53B512M32D2NP-062WT-C_11254
U502BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBA169 ball eMMC169_BALL_EMMC_0
U0600BGAS_123_P035_450X450_H085_SR3595ARF-TRANSCEIVER-SR3595A
U0601SKY77643RF-PAM-SPM6743-11
U0700FILTER_8_180X140_H060TxRx:897.5/942.5MHzRF-SAW-DUPLEX-SAYEY897MBG0F0A
U0702FILTER_8_180X140_H060TxRx:831.5/876.5MHzRF-SAW-DUPLEX-SAYEY831MBA0B0A
U0703SKY77910RF-FEM-STM7910-31
U0704RF-SAW-1.1X0.92350MHzRF-SAW-SAFFB2G35AA0F0A
U0708FILTER_8_180X140_H060TxRx:2535/2655MHzRF-SAW-DUPLEX-SAYEY2G53BA0F0A
U0709FILTER_8_180X140_H060TxRx:1950/2140MHzRF-SAW-DUPLEX-SAYEY1G95GA0F0A
U0713FILTER_5_135X105_H0502350MHzRF-SAW-SAFEA2G35MF0F0A
U0715FILTER_8_180X140_H060TxRx:1880/1960MHzRF-SAW-DUPLEX-SAYEY1G88BA0B0A
U0716FILTER_6_250X200_H078_QOROVORF-BAW-MULTIPLEX-QM25002
U0800SKY13414RSW5106RF-SW-RSW5106
U0801RF-SAW-1.1X0.9SAFFB2G65AA0F0ARF-SAW-SAFFB2G65AA0F0A
U0804RF-SAW-1.5X1.1-10PIN1842.5/2140MHzRF-SAW-SAWFD1G84AA0F0A
U0811RF-SAW-1.1X0.9SAFFB2G35AA0F0ARF-SAW-SAFFB2G35AA0F0A
U0812PQFN_10_P040_150X110_H050NC/EC646RF-SW-EC646
U0813FILTER_CAF_6_P065_200X125_H100_LRFDIP2012090G77N2TRF-SAW-DIPLEX-DPX202700DT-4162A1
U0815RF-SAW-1.1X0.9SAFFB881MAN0F0ARF-SAW-SAFFB881MAN0F0A
U0816RF-SAW-1.1X0.9SAFFB942MAN0F0ARF-SAW-SAFFB942MAN0F0A
U0817RF-SAW-1.1X0.9SAFFB1G96AB0F0ARF-SAW-SAFFB1G96AB0F0A
U0818RF-ISOLATOR-LDJ18829M24AC002RF-ISOLATOR-LDJ18829M24AC002
U1002AW8736FCRAW8736FCRAW8736FCR
U1003AW8736FCRAW8736FCRAW8736FCR
U1005RF1628SPDT / RF1628ARF1628
U1201MMC3630KJMMC3630KJ
U1401SOT23-5NC/WL2003E28WL2003E
U2001FAN54015HL7007FAN54015
U2100BGA_729_P040_1180X1180_H090_SC9853I-IARDASIC-SC9853I-IA-729-0.4
U2305CP2155NC/CP2155DN10-A1CP2155
U3302RF1628SPDT / RF1628ARF1628
U6103SOT23_6CP2121ST-B2/TCS23352AP3031_0
U6105SOT23_5WD1013EA/TCS4150-ETCS4150-E
U6109SOT23_6EUP2530/CP2123ST-B1AP3031_0
U6303EPL21822STK3171EPL21822
U6305CLI_MPU5400_GYROSCOPE_0.4PTH_3X3X0.9MMCLI_MPU5400_GYROSCOPE_0.4PTH_3X3X0.9MM
U6403TLE4917-TSOP-6-2OCH167TWADTLE4917-TSOP-6-2
U6404BMA250BMA223IC-3-A-ACCELEROMETER-BMA250-BOSCH
U6603FSUSB30UMXFSUSB30UMXFSUSB30UMX
U6702ELI_GSL3676_QFN56_7X7X1_TPICGSL3676GSL3676
U7200FILTER_CAF_6_P050_160X080_H070_CW1575/2450MHzRF-SAW-DIPLEX-LFD181G57DPFC087
U7201BGA_175_P040_750X530_H104_SC2342BWCN-SC2342B-175-0.4
U7202FILTER_5_110X090_H0501561.1/1575.42/1602MHzRF-SAW-SAFFB1G56KB0F0A
U7203MAX2659AR8159IC-GPS-LNAP-MAX2659-MAXIM
U7204FILTER_5_135X105_H050SF14112450A03TRF-SAW-SAFEA2G45MC0F0A
VR1SR0402_AEZJZ0V500AAVR0402
VR2SR0402_AEZJZ0V500AAVR0402
VR3SR0402_AEZJZ0V500AAVR0402
VR6002ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45
VR6003ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45
VR6004SR0402_AEZJZ0V500AAVR0402
VR6012SR0402_AESD9B5VVR0402
VR6511SR0402_ASFI0402-180E10RPP-LFVR0402
X0200XTAL_CC_320X150_H08532.768KHzXTAL-CRYSTAL-32.768K-Q-SC32S0322070AAAF
X0600XTAL_CC_250X200_H10026MHz/9pF(NF)XTAL-CRY+THM-26M-OZ26000012
Y7200OSC_CC_250X200_H090_KDS26MHzXTAL-TCXO-26MHZ-1XXB26000MAB
重要提示:PCB作品文件展下载说明
老吴 | 2020-9-30 11:37:23 | 显示全部楼层
独家发布资料。全网唯一。请勿转载。 仅供学习交流。 10RMB 。有需要的下载。
SC9853I_PCB&SCH.7z (3.87 MB, 下载次数: 17)
bidezhi7777 | 2020-9-30 12:04:19 | 显示全部楼层
bingo426 | 2020-9-30 12:50:39 | 显示全部楼层
最后成功的人往往不是最有才华的人,而是那些默默付出直到最后一刻也不放弃的那些人!
zhang00963 | 2020-9-30 13:34:44 | 显示全部楼层
单枪舞九州 | 2020-9-30 13:40:00 | 显示全部楼层
luchonghui74 | 2020-9-30 14:37:30 | 显示全部楼层
mirage | 2020-9-30 14:52:29 | 显示全部楼层
拾柒2019 | 2020-9-30 15:16:28 | 显示全部楼层
yhgwork | 2020-9-30 17:19:53 | 显示全部楼层
