• 芯片制造中的阻挡层沉积技术介绍
  • 接地搭接电缆布局屏蔽!!!
  • 北美液冷生态解码:超微spuermicro,24年营
  • SK海力士全球首发HBM4-16层堆叠、2.0TB/s
  • 2纳米Nanosheet技术及其以后的选择性层减薄
STM32F030 ADC驱动
查看728 | 回复11 | 2020-11-24 17:48:50 | 显示全部楼层 |阅读模式
#include "ADC1.h"
unsigned short AD[4];    //12位AD
//函数功能:初始化ADC
void ADC1_DMA_Init(void)
    GPIO_InitTypeDef    GPIO_InitStructure;
    DMA_InitTypeDef     DMA_InitStructure;
    ADC_InitTypeDef     ADC_InitStructure;
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);    //配置IO时钟
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 , ENABLE);
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1 , ENABLE);
    ADC_DeInit(ADC1);    //ADC恢复默认设置
    DMA_DeInit(DMA1_Channel1);                                                /* DMA1 Channel1 Config */
    DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_Address;    //外设地址
    DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)AD;    //内存地址
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;                        //外设作为数据传输的来源
    DMA_InitStructure.DMA_BufferSize = 4;                                    //DMA连续传输数据的个数
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;        //外设地址寄存器不变
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                    //内存地址寄存器不变
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;//数据宽度为16位
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;            //数据宽度为16位
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;                            //DMA_Priority设定DMA通道x的软件优先级
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;                                //DMA通道x没有设置为内存到内存传输
    DMA_Init(DMA1_Channel1, &DMA_InitStructure);
    DMA_Cmd(DMA1_Channel1, ENABLE);                            /* DMA1 Channel1 enable */
    ADC_DMARequestModeConfig(ADC1, ADC_DMAMode_Circular);     /* Enable ADC_DMA */
    ADC_DMACmd(ADC1, ENABLE);
    ADC_StructInit(&ADC_InitStructure);                        //初始化ADC结构
    ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;    //12位精度
    ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;         //规定模式装换工作在连续模式
    ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;                //数据对其为右对齐
    ADC_InitStructure.ADC_ScanDirection = ADC_ScanDirection_Backward;     //ADC的扫描方向
    ADC_Init(ADC1, &ADC_InitStructure);
    //前面开启的DMA连续传输数据的个数和这里开启的转换通道个数有关系,对应开启下面两个通道,连续传输数据的个数也为两个
    ADC_ChannelConfig(ADC1, ADC_Channel_0|ADC_Channel_1|ADC_Channel_2|ADC_Channel_3 , ADC_SampleTime_239_5Cycles);         //对通道1的输入进行AD转换
    ADC_GetCalibrationFactor(ADC1);                  /* ADC Calibration */
    ADC_Cmd(ADC1, ENABLE);                           /* Enable ADCperipheral[PerIdx] */
    while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_ADEN));  /* Wait the ADCEN falg */
    ADC_StartOfConversion(ADC1);                     /* ADC1 regular Software Start Conv */
yangxf0120 | 2020-11-24 18:58:27 | 显示全部楼层
谢谢分享STM32F030 ADC驱动
tian_000 | 2020-11-24 22:35:52 | 显示全部楼层
良心帖子,这个必须要顶起来
wlk1986 | 2020-11-24 22:50:15 | 显示全部楼层
小小路人甲 | 2020-11-25 07:59:28 | 显示全部楼层
郑先生 | 2020-11-25 08:01:32 | 显示全部楼层
郑先生 | 2020-11-25 08:09:12 | 显示全部楼层
kingboy100 | 2020-11-25 08:59:50 | 显示全部楼层
bidezhi7777 | 2020-11-25 09:06:15 | 显示全部楼层
ozh | 2020-11-27 08:36:30 | 显示全部楼层
