REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
D1 | DIODE_SOD-123_DISCRETE_MMSD914T | MMSD914T1 | SOD-123 |
FB1 | INDUCTOR_1_0603_C_BLM18KG700TN1 | BLM18KG700TN1D | 0603_C |
FB2 | INDUCTOR_1_0603_C_BLM18KG700TN1 | BLM18KG700TN1D | 0603_C |
FB3 | INDUCTOR_1_0603_C_BLM18KG700TN1 | BLM18KG700TN1D | 0603_C |
FB4 | INDUCTOR_1_0603_C_BLM18KG700TN1 | BLM18KG700TN1D | 0603_C |
FB12 | MLCB2B2012_0402_C_CZ | CZ | 0402_C |
FB13 | MLCB2B2012_0402_C_CZ | CZ | 0402_C |
FB14 | MLCB2B2012_0805_C_MLCB2B2012-60 | MLCB2B2012-600B | 0805_C |
FUSE1 | R2_0805_C_0.12A/0805 | 0.12A/0805 | 0805_C |
FUSE2 | R2_0805_C_0.12A/0805 | 0.12A/0805 | 0805_C |
J1 | HEADER3X2_HDR1X6-2R54-V_FPGA_J | FPGA_JTAG | HDR1X6-2R54-V |
J3 | SSMA-K_MCX-KHD_MCX_KWHD | MCX_KWHD | MCX-KHD |
J4 | DSPJTAG_HDR2X7-2R54-V_DSPJTAG | DSPJTAG | HDR2X7-2R54-V |
L1 | INDUCTOR2_0_XFL4012_XFL4012-102 | XFL4012-102 | XFL4012 |
L2 | INDUCTOR_1_XFL3012_XFL3012-222M | XFL3012-222ME | XFL3012 |
L3 | INDUCTOR_1_XFL3012_XFL3012-222M | XFL3012-222ME | XFL3012 |
L4 | INDUCTOR_1_XFL3012_XFL3012-222M | XFL3012-222ME | XFL3012 |
L5 | MLCH2B1608_0_0603_C_MLCH2B1608H | MLCH2B1608H68N | 0603_C |
L11 | INDUCTORAUDIO_0603_C_MLCH2B160 | MLCH2B1608HR22 | 0603_C |
L12 | INDUCTORAUDIO_0_0402_C_LQW15AN | LQW15AN68NG00D | 0402_C |
L15 | MLCH2B1608_0_0603_C_MLCH2B1608H | MLCH2B1608H68N | 0603_C |
L16 | MLCH2B1608_0_0603_C_MLCH2B1608H | MLCH2B1608H68N | 0603_C |
L17 | INDUCTORAUDIO_0402_C_LQW15AN68 | LQW15AN68NG00D | 0402_C |
L18 | INDUCTORAUDIO_0_0402_C_LQW15AN | LQW15AN68NG00D | 0402_C |
L19 | INDUCTORAUDIO_0_0402_C_LQW15_1 | LQW15AN33NG00D | 0402_C |
L20 | INDUCTORAUDIO_0_0402_C_LQW15_2 | LQW15AN27NG00D | 0402_C |
LED1 | LED_1_LED_0603_GREEN | green | LED_0603 |
LED2 | LED_1_LED_0603_GREEN | green | LED_0603 |
MC1 | TESTPOINT_M3R5_TP | TP | M3R5 |
R251 | R_0_0402_C_4.7K/0402 | 4.7K/0402 | 0402_C |
R300 | RMK1005_0402_C_"J"RM1005(0402)- | "J"RM1005(0402)-M-B-49R9-F | 0402_C |
T1 | 2N3501_0_NPN_BC846ALT1G | BC846ALT1G | NPN |
TP1 | TESTPOINT_TP1R0_IF_B1 | IF_B1 | TP1R0 |
U1 | SGL0622_2_SGL0622_SGL0622Z | SGL0622Z | SGL0622 |
U2 | SF1186B_1_SF1186B_TA1104A | TA1104A | SF1186B |
U3 | SF1186B_1_SF1186B_TA1104A | TA1104A | SF1186B |
U6 | SF1186B_1_SF1186B_TA1584A | TA1584A | SF1186B |
U7 | N25Q128_1_DFN8-1R27-8X6_N25Q128 | N25Q128A13BF840F | DFN8-1R27-8X6 |
U9 | TPS65910A1RSL_X-M_QFN48_01_TPS6 | TPS65910A1RSL | X-M_QFN48_01 |
U14 | TMS320C6748BZCEA3E_ZCE-361_(S1+ | TMS320C6748BZCEA3E | ZCE-361 |
U17 | CSG484_CSG484_(S1+S2+S3+S4+S5+S | XC6SLX150-3CSG484I | CSG484 |
U18 | MT29F1G08ABAEAH4-AITX-E_0_MT29F | MT29F1G08ABBEAH4-ITX-E | MT29F1G08ABAEAH4-AITX-E |
U24 | MIC5219_SOT23-5_XC6219B332MR | XC6219B332MR | SOT23-5 |
U25 | MIC5219_SOT23-5_XC6219B332MR | XC6219B332MR | SOT23-5 |
U26 | XN117-2_1_XN117_XN117-2 | XN117-2 | XN117 |
U27 | XN117-2_1_XN117_XN117-2 | XN117-2 | XN117 |
U30 | SF1186B_1_SF1186B_TA1584A | TA1584A | SF1186B |
U35 | MIC5219_SOT23-5_XC6219B302MR | XC6219B302MR | SOT23-5 |
U37 | TPS62095RGT_QFN16_TPS62095RGT | TPS62095RGT | QFN16 |
U38 | MT47H64M16HR_1_BGA84_0R8_12R08 | MT47H64M16HR_1 | BGA84_0R8_12R08 |
U50 | MAX488EESA_0_SO8-50-150_MAX490E | MAX490EESA+ | SO8-50-150 |
U71 | ADA4891-1_SOT23-5_ADA4891-1 | ADA4891-1 | SOT23-5 |
U72 | BGB741L7ESD_BGB741L7ESD_BGB741L | BGB741L7ESD | BGB741L7ESD |
U73 | PD1400U06-524_QFN_16_3X3MM_PD14 | PD1400U06-524 | QFN_16_3X3MM |
U74 | 1400BP41A0550_1400BP41A0550E_RB | RBBPF3225180C67B1U | 1400BP41A0550E |
U75 | FMC_CON40X4-1_27_FMC | FMC | CON40X4-1_27 |
X1 | XTAL4_0_DSA535_DSA535SD-10MHZ | DSA535SD-10MHz | DSA535 |
XTAL1 | XTAL1_2_CRYSTAL3225_25MHZ | 25MHz | CRYSTAL3225 |
XTAL2 | XTAL1_2_XTAL3215_DST310S-32.768 | DST310S-32.768KHz | XTAL3215 |
