[技术文章] Allegro导入结构DXF方法教程
查看2916 | 回复6 | 2021-4-27 15:35:27 | 显示全部楼层 |阅读模式
结构工程师使用AutoCAD软件一般生成的是DWG文件,DWG文件在Allegro中是无法识别的,需要转换成DXF文件才能识别。如果不想麻烦结构工程师,可以自己安装AutoCAD进行准换。下图是结构DXF文件:
watermark,type_ZmFuZ3poZW5naGVpdGk,shadow_10,text_aHR0cHM6Ly9ibG9nLmNzZG4ubmV0L3N0ZXJubHljb3Jl,size (95.2 MB, 下载次数: 0)
此广告位出租
zoey_zhou | 2021-4-27 17:04:42 | 显示全部楼层
.brd的单位可以不用设置成mm,只要导入的时候DXF的单位为mm即可
ww645133040 | 2021-6-28 08:59:28 | 显示全部楼层
jiuqiu | 2021-9-15 14:14:17 | 显示全部楼层
你好,我导入dxf时报错了,不知道怎么解决,请问可以帮忙看一下吗?
Reading Layer Conversion File
Reading DXF file...
NOTE: Replacing illegal character * with X in *Model_Space.
NOTE: Replacing illegal character * with X in *Paper_Space.
NOTE: Replacing illegal character * with X in *Paper_Space0.
ERROR: 3D data has been found in this dxf file.
  Most 3D data is not supported by dxf2a.
  For the special case of DXF code 230 = -1.0, ARC, CIRCLE
  and SOLID entities will be mirrored about the Y axis.
ERROR: 3D data (DXF code 30, value = 0.0038) detected on ARC at line 18082
ERROR: 3D data (DXF code 210, value = 0.0000) detected on ARC at line 18086
ERROR: 3D data (DXF code 220, value = 0.0000) detected on ARC at line 18088
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 18090
ERROR: 3D data (DXF code 30, value = 0.0010) detected on ARC at line 18152
ERROR: 3D data (DXF code 210, value = 0.0000) detected on ARC at line 18156
ERROR: 3D data (DXF code 220, value = -0.0000) detected on ARC at line 18158
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 18160
ERROR: 3D data (DXF code 30, value = 0.0010) detected on ARC at line 18638
ERROR: 3D data (DXF code 210, value = 0.0000) detected on ARC at line 18642
ERROR: 3D data (DXF code 220, value = -0.0000) detected on ARC at line 18644
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 18646
ERROR: 3D data (DXF code 30, value = 0.0038) detected on ARC at line 18676
ERROR: 3D data (DXF code 210, value = 0.0000) detected on ARC at line 18680
ERROR: 3D data (DXF code 220, value = 0.0000) detected on ARC at line 18682
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 18684
done.
WARNING: Ignoring zero length segment at (451.4700 253.5925)
WARNING: Ignoring zero length segment at (450.5151 257.0325)
WARNING: Ignoring zero length segment at (450.5150 256.6825)
WARNING: Ignoring zero length segment at (450.5147 248.3825)
我想逆天 | 2021-9-16 14:51:52 | 显示全部楼层
frens | 2021-9-19 19:10:16 | 显示全部楼层
zfw152666 | 2021-9-23 09:09:28 | 显示全部楼层
