[IC] MB2SE345
查看1038 | 回复2 | 2021-6-17 08:39:40 | 显示全部楼层 |阅读模式
Miniature Glass Passivated Fast RecoverySurface Mount Bridge RectifierFEATURES• UL recognition, file number E54214• Saves space on printed circuit boards• Ideal for automated placement• High surge current capability• Meets MSL level 1, per J-STD-020, LF maximumpeak of 260 °C• Material categorization: For definitions of complianceplease see www.vishay.com/doc?99912TYPICAL APPLICATIONSGeneral purpose use in AC/DC bridge full wave rectificationfor power supply, lighting ballaster, battery charger, homeappliances, office equipment, and telecommunicationapplications.MECHANICAL DATACase: TO-269AA (MBS)Molding compound meets UL 94 V-0 flammability ratingBase P/N-E3 - RoHS-compliant, commercial gradeTerminals: Matte tin plated leads, solderable perJ-STD-002 and JESD22-B102E3 suffix meets JESD 201 class 1A whisker testPolarity: As marked on bodyNotes(1) On glass epoxy PCB mounted on 0.05" x 0.05" (1.3 mm x 1.3 mm) pads(2) On aluminum substrate PCB with an area of 0.8" x 0.8" (20 mm x 20 mm) mounted on 0.05" x 0.05" (1.3 mm x 1.3 mm) solder padPRIMARY CHARACTERISTICSPackage TO-269AA (MBS)IF(AV) 0.5 AVRRM 200 V, 400 V, 600 VIFSM 35 AIR 5 μAVF at IF = 0.4 A 1.0 VTJ max. 150 °CDiode variations Quad~~TO-269AA (MBS)~~MAXIMUM RATINGS (TA = 25 °C unless otherwise noted)PARAMETER SYMBOL MB2S MB4S MB6S UNITDevice marking code 2 4 6Maximum repetitive peak reverse voltage VRRM 200 400 600 VMaximum RMS voltage VRMS 140 280 420 VMaximum DC blocking voltage VDC 200 400 600 VMaximum average forward outputrectified current (fig. 1)on glass-epoxy PCB (1)IF(AV)0.5Aon aluminum substrate (2) 0.8Peak forward surge current 8.3 ms single half sine-wavesuperimposed on rated load IFSM 35 ARating for fusing (t < 8.3 ms) I2t 5.0 A2sOperating junction and storage temperature range TJ, TSTG - 55 to + 150 °C MB2S, MB4S, MB6Swww.vishay.com Vishay General SemiconductorRevision: 19-Aug-13 2 Document Number: 88661For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.comTHIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENTARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000Notes(1) On glass epoxy PCB mounted on 0.05" x 0.05" (1.3 mm x 1.3 mm) pads(2) On aluminum substrate PCB with an area of 0.8" x 0.8" (20 mm x 20 mm) mounted on 0.05" x 0.05" (1.3 mm x 1.3 mm) solder padRATINGS AND CHARACTERISTICS CURVES (TA = 25 °C unless otherwise noted)Fig. 1 - Derating Curve for Output Rectified Current Fig. 2 - Maximum Non-Repetitive Peak Forward SurgeCurrent Per DiodeELECTRICAL CHARACTERISTICS (TA = 25 °C unless otherwise noted)PARAMETER TEST CONDITIONS SYMBOL MB2S MB4S MB6S UNITMaximum instantaneous forwardvoltage per diode IF = 0.4 A VF 1.0 VMaximum DC reverse current at rated DC blockingvoltage per diodeTA = 25 °CIR5.0μA TA = 125 °C 100Typical junction capacitance per diode 4.0 V, 1 MHz CJ 13 pFTHERMAL CHARACTERISTICS (TA = 25 °C unless otherwise noted)PARAMETER SYMBOL MB2S MB4S MB6S UNITTypical thermal resistanceRJA (1) 85RJA °C/W (2) 70RJL (1) 20ORDERING INFORMATION (Example)PREFERRED P/N UNIT WEIGHT (g) PREFERRED PACKAGE CODE BASE QUANTITY DELIVERY MODEMB2S-E3/45 0.22 45 100 TubeMB2S-E3/80 0.22 80 3000 13" diameter paper tape and reel
tone | 2021-6-17 09:02:15 | 显示全部楼层
mj8abcd | 2021-6-18 22:34:49 | 显示全部楼层
