Name | Part Type | PCB Decal | Value |
1 | PAD038D038B | PAD038D038BCAAAA | |
2 | PAD038D038B | PAD038D038BCB | |
3 | LF | LC210X110_11V230-EMI | 31Ts |
4 | PAD038D038B | PAD038D038BE | |
5 | PAD038D038B | PAD038D038BE | |
11 | LF | LC210X110_11V230-EMI | 31Ts |
BD1 | BD1 | BD254X048V190-GBJ | 8A 600V |
C1 | CE | CE180D450_075L180 | 560u_200V |
C2 | CE | CE180D450_075L180 | 560u_200V |
C3 | C | CS1206_H016 | 103/630V |
C4 | C | CS0805_H014 | NI |
C5 | C | CS0805_H014 | 104 |
C6 | C | CS0805_H014 | 105 |
C7 | C | CS0805_H014 | 102 |
C8 | C | CS0805_H014 | 104 |
C9 | C | CS0805_H014 | NI |
C10 | C | CS0805_H014 | 104 |
C11 | C | CS1206_H016 | 103/630V |
C12 | CE050D115_025L050 | CE050D115_025L050B | 47uF/35V |
C13 | C | CS0805_H014 | 104 |
C14 | CE050D115_025L050 | CE050D115_025L050A | 47uF/35V |
C15 | C | CS1206_H016 | 103/630V |
C16 | C | CS0805_H014 | 102 |
C17 | C | CS0805_H014 | 104 |
C200 | C | CS1206_H016 | 1NF |
C201 | C | CS1206_H016 | 1nF |
C202 | C | CS0805_H014 | 104 |
C203 | CE | CE100D125_050V125 | 1500uF/35V |
C204 | CE | CE100D125_050V125 | 1500uF/35V |
C205 | CE | CE100D125_050V125 | 1500uF/35V |
C206 | CE | CE100D125_050V125 | 1500uF/35V |
C207 | CE | CE100D125_050V125 | 1500uF/35V |
C208 | C | CS1206_H016 | 473 |
C209 | CE | CE063D110_025V110 | 47uF/35V |
C210 | C | CS0805_H014 | 104 |
C213 | C | CS0805_H014 | 104 |
C214 | C | CS0805_H014 | 104 |
CN1 | K-9P | K-9P1M130-DT-7X-A02X-XXAA | |
CX1 | C | CX170X090_150V160 | 0.47u |
CX2 | C | CX170X090_150V160 | 0.33U |
CY1 | C | CY160X080_100V200-Y1NSA-USUALLYD | 222 |
CY2 | C | CY160X080_100V200-Y1NSA-USUALLY | 222 |
CY3 | C | CY160X080_100V200-Y1NSA-USUALLYA | NI |
CY4 | C | CY160X080_100V200-Y1NSA-USUALLYB | NI |
CY5 | C | CY160X080_100V200-Y1NSA-USUALLY-L29A | 3300p |
CY6 | C | CY160X080_100V200-Y1NSA-USUALLY-L29B | 3300p |
CY7 | C | CY160X080_100V200-Y1NSA-USUALLYC | 222 |
D1 | DDDO15__160H040 | DDDO15__160H040A | FR207 |
D2 | DDDO15__160H040 | DDDO15__160H040 | FR207 |
D3 | D | DSDO214ACH023-SMA | RS1M |
D4 | D | DSSOD123H012 | 1N4148 |
D5 | D | DSSOD123H012 | 1N4148 |
D200 | D3P-PNP | DDTO220L_3PV195-SPBB | 20100 |
D201 | D3P-PNP | DDTO220L_3PV195-SPBB | 20100 |
D202 | D3P-PNP | DDTO220L_3PV195-SPBB | 20100 |
D203 | D3P-PNP | DDTO220L_3PV195-SPBB | 20100 |
D206 | D | DSSOD123H012 | 1N4148 |
D207 | D | DSSOD123H012 | 1N4148 |
F1 | FUSE | FUSEAA | ??? |
FAN | KD02P1M250V097-JWTA2501WV2 | KD02P1M250V097-JWTA2501WV2 | 2P |
J1 | JD170D08H008 | JD170D08H008A | |
J2 | JD170D08H008 | JD170D08H008 | |
J3 | JD170D08H008 | JD170D08H008 | |
J4 | JD200D08H008 | JD200D08H008 | |
J5 | JD225D06H006 | JD225D06H006AA | |
J6 | JS1206_H008 | JS1206_H008 | |
J7 | JS1206_H008 | JS1206_H008 | |
J8 | JS1206_H008 | JS1206_H008 | |
J9 | JS1206_H008 | JS1206_H008 | |
J10 | JS1206_H008 | JS1206_H008 | |
J11 | JS1206_H008 | JS1206_H008 | |
J12 | JD120D06H006 | JD120D06H006AA | |
J13 | JD165D06H006 | JD165D06H006AA | |
J200 | JD130D10H010 | JD130D10H010A | |
J201 | JD130D10H010 | JD130D10H010A | |
J202 | JD130D10H010 | JD130D10H010A | |
J203 | JD130D10H010 | JD130D10H010AA | |
J204 | JS1206_H008 | JS1206_H008 | |
J205 | JS1206_H008 | JS1206_H008 | |
J206 | JS1206_H008 | JS1206_H008 | |
J207 | JS1206_H008 | JS1206_H008 | |
J208 | JS1206_H008 | JS1206_H008A | |
LED2 | LED | LED3MM-1 | 3mm Green |
PC1 | UP-PH | UD04P102H043A | LT817B |
PC2 | UP-PH | UD04P102H043B | PC817 |
Q1 | QMOS-N-GDS | QDTO220KGDSV195 | FCPF20N60 |
Q2 | QMOS-N-GDS | QDTO220KGDSV195 | FCPF20N60 |
Q3 | QNPN-ECB | QSSOT23_BCEH014 | 3904 |
Q4 | QNPN-ECB | QSSOT23_BCEH014 | 3904 |
Q5 | QSSOT89____H017 | QSSOT89____H017 | 3904 |
Q6 | QPNP-BCE | QSSOT23_BCEH014 | 3906 |
Q7 | QNPN-ECB | QSSOT23_BCEH014 | 3904 |
Q200 | QNPN-ECB | QDTO92L_ECBV120 | A562 |
T2 | T-10P | TDEE13___10PH135-EE13551000LFAA | EE13 |
TH1 | RT | RTD170X060V230-15D | 2.5_8A |
TH2 | RT | RTD020X055V050A | 200K |
TH200 | RT | RTD020X055V050B | 200K |
U5 | NCP1252A | USSO08P____H017 | NCP1252A |
U200 | UA-TL431 | USSOT23_RAKH014 | AZ431 |
U201 | UA-TL431 | USSOT23_RAKH014 | AZ431 |
VAR1 | DVAR | DVD110X050075V170-10D | 10241 |
VAR2 | DVAR | DVD110X050075V170-10D | 10241 |
VAR3 | DVD170X050075V230-14D | DVD170X050075V230-14D | |
VR200 | VR | VRAAA | |
W1 | PAD030D030AA | PAD030D030AABA | |
W14 | PAD030D030AA | PAD030D030AABAACAA | |
W15 | L-36.8 | L36.8AAA | |
W16 | RW-3 | RW-3 | |
W17 | T | TDEQ30___10PV201A-3AAAA | |
W18 | PAD030D030AA | PAD030D030AABAACA | |
ZD201 | D | DSSOD123H012 | 27V |
ZD202 | D | DSSOD123H012 | 27V |
