[IC] 5.8G PA RTC6659E数据手册
查看1056 | 回复3 | 2021-8-16 09:21:55 | 显示全部楼层 |阅读模式
## 说明
我不是卖芯片的
## RTC6659E
FEATURE
◆  4.9 ~5.9GHz Frequency Range
◆  5V Single Supply Voltage
◆  RTC6659 pin Compatible
◆  22dBm@3% EVM, 802.11a, 64QAM
◆  18dBm@1.8% EVM, 802.11ac, 256QAM
◆  Small Signal Gain : 32 dB
◆  On-chip Input Matching
◆  QFN 3mmX3mm 16 Lead Package
◆  RoHS / Halogen Free Compliant
◆  Moisture Sensitivity Level : MSL-3
APPLICATION
◆  High Power WLAN applications
◆  IEEE 802.11a/802.11ac Wireless LAN System
◆  5GHz ISM Band Application
◆  5GHz Cordless Phones
RTC6659E-DataSheet附赠RTC6705数据手册.zip
663 KB, 下载次数: 6, 下载积分: 金币 -1 枚
bidezhi7777 | 2021-8-16 09:28:17 | 显示全部楼层
cyzhang4_09 | 2021-8-21 08:58:45 | 显示全部楼层
mj8abcd | 2021-8-22 18:12:40 | 显示全部楼层
