REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
BT1 | BATTERY_0_CR-2032HFN_BATTERY | BATTERY | CR-2032HFN |
D1 | DIODE_SMA_SS14_1N4148 | 1N4148 | SMA_SS14 |
D2 | DIODE_SMA_SS14_1N4148 | 1N4148 | SMA_SS14 |
D3 | LED_LED0603_LED | LED | LED0603 |
D4 | LED_LED0603_LED | LED | LED0603 |
D5 | LED_LED0603_LED | LED | LED0603 |
D6 | DIODE_SMA_SS14_DIODE | DIODE | SMA_SS14 |
D7 | DIODE_SMA_SS14_DIODE | DIODE | SMA_SS14 |
D9 | LED_LED0603_LED | LED | LED0603 |
D10 | LED_LED0603_LED | LED | LED0603 |
D11 | LED_LED0603_LED | LED | LED0603 |
D12 | LED_LED0603_LED | LED | LED0603 |
D13 | LED_LED0603_LED | LED | LED0603 |
D14 | LED_LED0603_LED | LED | LED0603 |
D15 | LED_LED0603_LED | LED | LED0603 |
D16 | LED_LED0603_LED | LED | LED0603 |
D17 | LED_LED0603_LED | LED | LED0603 |
D18 | LED_LED0603_LED | LED | LED0603 |
D19 | DIODE_SMA_SS14_1N4148 | 1N4148 | SMA_SS14 |
D20 | DIODE_SMA_SS14_1N4148 | 1N4148 | SMA_SS14 |
D21 | LED_LED0603_LED | LED | LED0603 |
D22 | DIODE_SMA_SS14_1N4148 | 1N4148 | SMA_SS14 |
D23 | LED_LED0603_LED | LED | LED0603 |
F1 | F_1_SMD1812_1A | 1A | SMD1812 |
J1 | J4_P_1X4_J4 | J4 | P_1X4 |
J2 | J201-3_NIUJIO20P_J201-3 | J201-3 | NIUJIO20P |
J3 | TFT_LCD_1_P_2X17_TFT_LCD | TFT_LCD | P_2X17 |
J4 | J2_P_1X2_J2 | J2 | P_1X2 |
J5 | J2_PP5R2_J2 | J2 | PP5R2 |
J9 | J8_PP5R8_J8 | J8 | PP5R8 |
J10 | J3_PP5R3_J3 | J3 | PP5R3 |
J11 | J3_PP5R3_J3 | J3 | PP5R3 |
J12 | J3_PP5R3_J3 | J3 | PP5R3 |
J13 | J3_PP5R3_J3 | J3 | PP5R3 |
J14 | J3_PP5R3_J3 | J3 | PP5R3 |
J15 | J3_PP5R3_J3 | J3 | PP5R3 |
J16 | J4_24V-12V5A_J4 | J4 | 24V-12V5A |
J17 | J4_IN12_6V_J4 | J4 | IN12_6V |
J18 | J4_POWER_J4 | J4 | POWER |
JPP7 | J7_1X7_1600X500X500P_J7 | J7 | 1X7_1600X500X500P |
L1 | CHOKE_R0603_220R,2A,0.05DCR | 220R,2A,0.05DCR | R0603 |
L2 | INDUCTORAUDIO_SLH1207H_100UH | 100uH | SLH1207H |
SW1 | SWPUSHBUTTON-DPST_4JIAO_SW PUSHBUTTON-DPST | SWPUSHBUTTON-DPST | 4JIAO |
SW2 | SWPUSHBUTTON-DPST_4JIAO_SW PUSHBUTTON-DPST | SWPUSHBUTTON-DPST | 4JIAO |
SW3 | SWPUSHBUTTON-DPST_4JIAO_SW PUSHBUTTON-DPST | SWPUSHBUTTON-DPST | 4JIAO |
SW4 | SWPUSHBUTTON-DPST_4JIAO_SW PUSHBUTTON-DPST | SWPUSHBUTTON-DPST | 4JIAO |
SW5 | SWPUSHBUTTON-DPST_4JIAO_SW PUSHBUTTON-DPST | SWPUSHBUTTON-DPST | 4JIAO |
TC1 | CAPPOL_CASE_3216_100UF/16V | 100uF/16V | CASE_3216 |
TC2 | CAPPOL_CASE_3216_100UF/6.3V | 100uF/6.3V | CASE_3216 |
U1 | RJ45_3_HR911105A_1_RJ45 | RJ45 | HR911105A_1 |
U2 | LAN8720A_QFN50P400X400X100-25N-D_LAN8720A | LAN8720A | QFN50P400X400X100-25N-D |
U3 | EFO-P_E49A_HC49S_25MHZ | 25MHz | E49A_HC49S |
U4 | P1*16_P_1X16_P1*16 | P1*16 | P_1X16 |
U5 | P2*22_P_2X22_P2*22 | P2*22 | P_2X22 |
U6 | P2*22_P_2X22_P2*22 | P2*22 | P_2X22 |
U7 | IS62WV51216_SOP80P1176X120-44N_IS62WV51216 | IS62WV51216 | SOP80P1176X120-44N |
U8 | P2*3_P_2X3_P2*3 | P2*3 | P_2X3 |
U9 | STM32F407ZGT6_STM32F407ZGT6_STM32F407ZGT6 | STM32F407ZGT6 | STM32F407ZGT6 |
U10 | EFO-P_32_768KHZ_32.768K | 32.768K | 32_768KHZ |
U11 | EFO-P_E49A_HC49S_8MHZ | 8MHz | E49A_HC49S |
U12 | RS485_MAX3485EESA_SP3485 | SP3485 | MAX3485EESA |
U19 | W25Q128-FLASH_SOIC127P790X216-8N_W25Q128 | W25Q128 | SOIC127P790X216-8N |
U20 | IPS73633_1_TPS73633_IPS73633 | IPS73633 | TPS73633 |
U21 | TLP521_TPL521_TLP521 | TLP521 | TPL521 |
U22 | TLP521_TPL521_TLP521 | TLP521 | TPL521 |
U23 | TLP521_TPL521_TLP521 | TLP521 | TPL521 |
U24 | TLP521_TPL521_TLP521 | TLP521 | TPL521 |
U25 | BPW36/TO_NPNSOT_23_BPW36/TO | BPW36/TO | NPNSOT_23 |
U26 | BPW36/TO_NPNSOT_23_BPW36/TO | BPW36/TO | NPNSOT_23 |
U27 | BPW36/TO_NPNSOT_23_BPW36/TO | BPW36/TO | NPNSOT_23 |
U28 | BPW36/TO_NPNSOT_23_BPW36/TO | BPW36/TO | NPNSOT_23 |
U29 | TLP521_TPL521_TLP521 | TLP521 | TPL521 |
U30 | JDQ_SRD-05VDC-SL-C_JDQ | JDQ | SRD-05VDC-SL-C |
U31 | BPW36/TO_NPNSOT_23_BPW36/TO | BPW36/TO | NPNSOT_23 |
U32 | JDQ_SRD-05VDC-SL-C_JDQ | JDQ | SRD-05VDC-SL-C |
U33 | TLP521_TPL521_TLP521 | TLP521 | TPL521 |
U34 | BPW36/TO_NPNSOT_23_BPW36/TO | BPW36/TO | NPNSOT_23 |
U35 | JDQ_SRD-05VDC-SL-C_JDQ | JDQ | SRD-05VDC-SL-C |
U36 | TLP521_TPL521_TLP521 | TLP521 | TPL521 |
U37 | BPW36/TO_NPNSOT_23_BPW36/TO | BPW36/TO | NPNSOT_23 |
U38 | LM2596_LM2596SX_LM2596 | LM2596 | LM2596SX |
