[PADS9.5以下] 一款rk3088的板子PCB文件,分享给车载的朋友
查看4512 | 回复14 | 2014-7-7 20:14:26 | 显示全部楼层 |阅读模式
****************以下信息由管理员 @老吴   整理补充*******************
板子有以下元件和封装库,如有需要可以下载提取使用。
NameValuePCB DecalPart Type
ANT3NFL_CL331NFL_CL331NFL_CL331
C11040402CCAP-0402-104
C41030402CCAP-0402-103
C51040402CCAP-0402-104
C61060805CCAP-0805-106
C72260805CCAP-0805-226
C81060805CCAP-0805-106
C9330P0402CCAP-0402-330P
C10680P0402CCAP-0402-680P
C11104pCAP0603CAP0603
C121030402CCAP-0402-103
C131060805CCAP-0805-106
C141060805CCAP-0805-106
C1522P0402CCAP-0402-22P
C171050402CCAP-0402-105
C18680P0402CCAP-0402-680P
C2110n(M)CAP0603CAP
C2222P0402CCAP-0402-22P
C231060805CCAP-0805-106
C241040402CCAP-0402-104
C2522P0402CCAP-0402-22P
C291060805CCAP-0805-106
C30330P0402CCAP-0402-330P
C311060805CCAP-0805-106
C321060805CCAP-0805-106
C331040402CCAP-0402-104
C342260805CCAP-0805-226
C35226/16V1206CCAP-1206-226
C361040402CCAP-0402-104
C392260805CCAP-0805-226
C411060805CCAP-0805-106
C421060805CCAP-0805-106
C472261206CCAP-1206-226-10V
C521060805CCAP-0805-106
C551040402CCAP-0402-104
C591040402CCAP-0402-104
C651060805CCAP-0805-106
C661040402CCAP-0402-104
C671060805CCAP-0805-106
C68NC/47P0402CCAP-0402-47P
C70NC/47P0402CCAP-0402-47P
C711040402CCAP-0402-104
C721040402CCAP-0402-104
C731050402CCAP-0402-105
C741050402CCAP-0402-105
C761040402CCAP-0402-104
C771040402CCAP-0402-104
C7827P0402CCAP-0402-27P
C792260805CCAP-0805-226
C801050402CCAP-0402-105
C816840402CCAP-0402-684
C8227P0402CCAP-0402-27P
C83226/16V1206CCAP-1206-226
C916840402CCAP-0402-684
C9210n(M)CAP0805CAP
C941040402CCAP-0402-104-25V
C951040402CCAP-0402-104
C113680P0402CCAP-0402-680P
C1186840402CCAP-0402-684
C119330P0402CCAP-0402-330P
C1202260805CCAP-0805-226
C1242260805CCAP-0805-226
C1262250402CCAP-0402-225
C12712P0402CCAP-0402-12P
C1281050402CCAP-0402-105
C1311060805CCAP-0805-106
C1321030402CCAP-0402-103
C1331040402CCAP-0402-104
C1351050402CCAP-0402-105
C1362260805CCAP-0805-226
C1371060805CCAP-0805-106-16V
C1381060805CCAP-0805-106
C1402260805CCAP-0805-226
C1441050402CCAP-0402-105
C1471050402CCAP-0402-105
C1481050402CCAP-0402-105
C1492260805CCAP-0805-226
C1531050402CCAP-0402-105
C1544750805CCAP-0805-475
C1551050402CCAP-0402-105
C1561040402CCAP-0402-104-25V
C157105C0603CAP-0603-1UF-25V
C1581060805CCAP-0805-106-16V
C1591060805CCAP-0805-106
C1601040402CCAP-0402-104
C1611040402CCAP-0402-104-25V
C1621030402CCAP-0402-103
C163105C0603CAP-0603-1UF-25V
C1644.7uF/25V1206CCAP-1206-4.7U-25V
C1651050402CCAP-0402-105
C1661060805CCAP-0805-106-16V
C1671040402CCAP-0402-104
C16822P0402CCAP-0402-22P
C1701040402CCAP-0402-104-25V
C1711010402CCAP-0402-101
C1721010402CCAP-0402-101
C1731010402CCAP-0402-101
C1771060805CCAP-0805-106
C1781010402CCAP-0402-101
C1791040402CCAP-0402-104
C1801040402CCAP-0402-104
C1811050402CCAP-0402-105
C1821040402CCAP-0402-104
C1841040402CCAP-0402-104
C1851060805CCAP-0805-106
C1861040402CCAP-0402-104
C1871040402CCAP-0402-104
C1881040402CCAP-0402-104
C1891040402CCAP-0402-104
C1901040402CCAP-0402-104
C1911040402CCAP-0402-104
C1921040402CCAP-0402-104
C1931040402CCAP-0402-104
C1941040402CCAP-0402-104
C1951040402CCAP-0402-104
C1961040402CCAP-0402-104
C1971040402CCAP-0402-104
C1981040402CCAP-0402-104
C2031040402CCAP-0402-104
C20422P0402CCAP-0402-22P
C2051040402CCAP-0402-104
C2061040402CCAP-0402-104
C2071040402CCAP-0402-104
C2081040402CCAP-0402-104
C2091040402CCAP-0402-104
C210100uF/6.3V35283528_100UF
C2111060805CCAP-0805-106
C212100uF/6.3V35283528_100UF
C2131060805CCAP-0805-106
C21422P0402CCAP-0402-22P
C2151040402CCAP-0402-104
C2161060805CCAP-0805-106
C2171040402CCAP-0402-104
C21822P0402CCAP-0402-22P
C2191040402CCAP-0402-104
C2202220402CCAP-0402-222
C2214730402CCAP-0402-473
C2221050402CCAP-0402-105
C223100uF/6.3V35283528_100UF
C2241040402CCAP-0402-104
C2341040402CCAP-0402-104
CB11040402CCAP-0402-104
CB21040402CCAP-0402-104
CB41040402CCAP-0402-104
CB81040402CCAP-0402-104
CB91040402CCAP-0402-104
CN112P-1.0-TOPSOCKET12/SMD0.5ACN12-SMD
CN3SG2918_CORESG2918_CORE_120P_NRK2918_120_CORE
CN7FPC-10PIN-1.25MM1.25SMD-10VCN7-1.25MM-SMD
CN8FPC50-0.5mmFPC50/0.5ACN50-0.5MM-SMD-RIGHT
CN14FPC-4PIN-1.0MM4PINCHIPCON1.0MMCN4-1.0MM-SMD
CN1860P-0.5MM0.5SMD-60VCN60-0.5MM-SMD
CN2712P-1.0-TOPSOCKET12/SMD0.5ACN12-SMD
CON29PINSD_XIAO9P
CON59PINSD_XIAO9P
D2CRS08D1206DIODE-CRS08-1206
D3NC/ESD0402D-EDIODE_BI-DIR_TRIG
D4NC/ESD0402D-EDIODE_BI-DIR_TRIG
D5BAT54CSOT23ABAT54C-SOT23
D6BAT54CSOT23ABAT54C-SOT23
D7NC/ESD0402D-EDIODE_BI-DIR_TRIG
D9NC/ESD0402D-EDIODE_BI-DIR_TRIG
D111N4148D0805DIODE-1N4148-D0805
D12NCD1206DIODE-1N4148-D1206
D14BAT54SSOT23ABAT54S-SOT23
D151N5819D1206DIODE-1N5819-1206
D16BAT54SSOT23ABAT54S-SOT23
D176.8VD12066.8V-1206
D1815VD120615V-1206
D191N4148D0805DIODE-1N4148-D0805
D201N4148D0805DIODE-1N4148-D0805
D21NC/ESD0402D-EDIODE_BI-DIR_TRIG
D24BAT54CSOT23ABAT54C-SOT23
D261N5819D1206DIODE-1N5819-1206
D281N4001DO-214AC(SMA)1N4001-DO-214AC(SMA)
EC14750805CCAP-0805-475
EC2105C0603CAP-0603-1UF-25V
EC3105C0603CAP-0603-1UF-25V
EN1VOLENCODERENCODER
FB1601HL0805INDUCTOR/CHIP/FERB/601H/0805
FB2601HL0805INDUCTOR/CHIP/FERB/601H/0805
FB4601HL0805INDUCTOR/CHIP/FERB/601H/0805
FB5601HL0805INDUCTOR/CHIP/FERB/601H/0805
FB6601HL0805INDUCTOR/CHIP/FERB/601H/0805
FB7601HL0805INDUCTOR/CHIP/FERB/601H/0805
FB8601HL0805INDUCTOR/CHIP/FERB/601H/0805
J14Po??ì4PAAC4P-PAD-USB
J24Po??ì4PAAC4P-PAD-USB
J34Po??ì2.0SIP-4H4P-PAD-USB
J6CON2 3.0MM??TFT-BL-CON2P_3.0MMTFT_BL-CON2-3.0MM
KEY-1?′???a1?SW/2P/6X3X5/SMDSW-2P
KEY-2?′???a1?KEY-SMD-6X5SW-2P
KEY-3?′???a1?KEY-SMD-6X5SW-2P
KEY-4?′???a1?KEY-SMD-6X5SW-2P
KEY-6?′???a1?KEY-SMD-6X5SW-2P
L12.7uHL0805INDUCTOR/2.7UH-0805
L4600R/100MHZ0603LINDUCTOR/FERB/601E/0603
L62.7uHL0805INDUCTOR/2.7UH-0805
L810uHSMD_L_4X4INDUCTOR-SM3D16-10UH
L9600R/100MHZ0603LINDUCTOR/FERB/601E/0603
L10600R/100MHZ0603LINDUCTOR/FERB/601E/0603
L11600R/100MHZ0603LINDUCTOR/FERB/601E/0603
L1222uHSMD_L_4X4INDUCTOR-SM3D16-22UH
L13600R/100MHZ0603LINDUCTOR/FERB/601E/0603
L14NC0402RINDUCTOR-0402-NC
L15600R/100MHZ0402RINDUCTOR/FERB/601E/0402
L172.7uHL0805INDUCTOR/2.7UH-0805
L18601HL0805INDUCTOR/CHIP/FERB/601H/0805
L34601HL0805INDUCTOR/CHIP/FERB/601H/0805
LED1LED/0805LED-0603DIODE-LED
LED2LED/0805LED-0603DIODE-LED
LED3LED/0805LED-0603DIODE-LED
LED4LED/0805LED-0603DIODE-LED
LED5LED/0805LED-0603DIODE-LED
LED6LED/0805LED-0603DIODE-LED
LED7LED/0805LED-0603DIODE-LED
LED8LED/0805LED-0603DIODE-LED
LED10LED/0805LED-0603DIODE-LED
LED11LED/0805LED-0603DIODE-LED
LED12LED/0805LED-0603DIODE-LED
LED13LED/0805LED-0603DIODE-LED
MIC1MICí·MIC_2.0MIC
MINIUSB1MINIUSB5PINMIIUSB-5PINMINIUSB5PIN
P3PADPAD-15-0.5APAD-1.5-0.5A
P4PADPAD-15-0.5APAD-1.5-0.5A
Q1AO3415SOT23AMOSFET-AO3415-SOT23
Q7N8050SOT-23KTC3875/C114/C231
Q93904SOT23A3904-SOT23
Q163904SOT23A3904-SOT23
R110K0402RRES/CHIP-0402-10K
R2NC0402RRES/CHIP-0402-NC
R31M0402RRES/CHIP-0402-1M
R447K0402RRES/CHIP-0402-47K
R50R0402RRES/CHIP-0402-0R
R60R0402RRES/CHIP-0402-0R
R710K0402RRES/CHIP-0402-10K
R8NC0402RRES/CHIP-0402-1K
R90R0402RRES/CHIP-0402-0R
R1033R0402RRES/CHIP-0402-100R
R1133R0402RRES/CHIP-0402-100R
R121M0402RRES/CHIP-0402-1M
R1333R0402RRES/CHIP-0402-100R
R1433R0402RRES/CHIP-0402-100R
R1533R0402RRES/CHIP-0402-100R
R1633R0402RRES/CHIP-0402-100R
R170R0402RRES/CHIP-0402-0R
R18NC0402RRES/CHIP-0402-NC
R1947K0402RRES/CHIP-0402-47K
R2010K0402RRES/CHIP-0402-10K
R21NC0402RRES/CHIP-0402-NC
R2247K0402RRES/CHIP-0402-47K
R2347K0402RRES/CHIP-0402-47K
R2410K0402RRES/CHIP-0402-10K
R250R0402RRES/CHIP-0402-0R
R261.5kRES0603RES0603
R27470R0402RRES/CHIP-0402-470R
R281.5kRES0603RES0603
R291.5kRES0603RES0603
R3047K0402RRES/CHIP-0402-47K
R31100K0402RRES/CHIP-0402-100K
R32120K0402RRES/CHIP-0402-120K
R3310K0402RRES/CHIP-0402-10K
R34200K0402RRES/CHIP-0402-200K
R354.7K0402RRES/CHIP-0402-4.7K
R361.5kRES0603RES0603
R371.5kRES0603RES0603
R3810K0402RRES/CHIP-0402-10K
R3933R0402RRES/CHIP-0402-100R
R4033R0402RRES/CHIP-0402-100R
R411.5kRES0603RES0603
R421.5kRES0603RES0603
R441.5kRES0603RES0603
R4510K0402RRES/CHIP-0402-10K
R4633R0402RRES/CHIP-0402-100R
R471.5kRES0603RES0603
R4833R0402RRES/CHIP-0402-100R
R4933R0402RRES/CHIP-0402-100R
R50NC0603RRES/CHIP-0603-0R
R5133R0402RRES/CHIP-0402-100R
R5233R0402RRES/CHIP-0402-100R
R5333R0402RRES/CHIP-0402-100R
R540RRES-0603RES
R551.5kRES0603RES0603
R561.5kRES0603RES0603
R571.5kRES0603RES0603
R600R0402RRES/CHIP-0402-0R
R6147K0402RRES/CHIP-0402-47K
R63RES0603RES0603
R64RES0603RES0603
R654.7K0402RRES/CHIP-0402-4.7K
R664.7K0402RRES/CHIP-0402-4.7K
R674.7K0402RRES/CHIP-0402-4.7K
R68RES0603RES0603
R6947K0402RRES/CHIP-0402-47K
R70RES0603RES0603
R7147K0402RRES/CHIP-0402-47K
R724.7K0402RRES/CHIP-0402-4.7K
R734.7K0402RRES/CHIP-0402-4.7K
R74RES0603RES0603
R7610KRES-0603RES
R7720KRES-0603RES
R782.2R0603RESR0603-NC
R792.2R0603RESR0603-NC
R80RES0603RES
R81RES0603RES
R8247K0402RRES/CHIP-0402-47K
R831.2K0402RRES/CHIP-0402-1.2K
R846.8K0603RESR0603-NC
R8510K0402RRES/CHIP-0402-10K
R86NC0402RRES/CHIP-0402-10K
R8710K0402RRES/CHIP-0402-10K
R8810K0603RESR0603-NC
R9210K0402RRES/CHIP-0402-10K
R9310K0402RRES/CHIP-0402-10K
R945.1K0402RRES/CHIP-0402-5.1K
R951.2K0402RRES/CHIP-0402-1.2K
R96100R0402RRES/CHIP-0402-100R
R97100R0402RRES/CHIP-0402-100R
R9851R0402RRES/CHIP-0402-51R
R9933R0402RRES/CHIP-0402-33R
R1054.7K0402RRES/CHIP-0402-4.7K
R10910K0402RRES/CHIP-0402-10K
R11010K0402RRES/CHIP-0402-10K
R112NC0402RRES/CHIP-0402-NC
R11351R0402RRES/CHIP-0402-51R
R11511K%10402RRES/CHIP-0402-11K-F
R116NC0402RRES/CHIP-0402-NC
R11810K0402RRES/CHIP-0402-10K
R120200K%10402RRES/CHIP-0402-200K-F
R121392K%10402RRES/CHIP-0402-392K-F
R122120R0402RRES/CHIP-0402-120R
R12347R0402RRES/CHIP-0402-47R
R12515R0402RRES/CHIP-0402-15R
R12724R0402RRES/CHIP-0402-24R
R12824R0402RRES/CHIP-0402-24R
R1291M0402RRES/CHIP-0402-1M
R13010K0402RRES/CHIP-0402-10K
R13156K%10402RRES/CHIP-0402-56K-F
R132200K0402RRES/CHIP-0402-200K
R133NC\10K0402RRES/CHIP-0402-NC
R13447K%10402RRES/CHIP-0402-47K-F
R1362.2K0402RRES/CHIP-0402-2.2K
R1370R0402RRES/CHIP-0402-0R
R138180R0402RRES/CHIP-0402-180R
R13947R0402RRES/CHIP-0402-47R
R14020R0402RRES/CHIP-0402-20R
R141220R0402RRES/CHIP-0402-220R
R14220R0402RRES/CHIP-0402-20R
R143150R0402RRES/CHIP-0402-150R
R14447R0402RRES/CHIP-0402-47R
R14582R0402RRES/CHIP-0402-82R
R146220R0402RRES/CHIP-0402-220R
R14733R0402RRES/CHIP-0402-33R
R14815R0402RRES/CHIP-0402-15R
R14922R0402RRES/CHIP-0402-22R
R15020R0402RRES/CHIP-0402-20R
R15118R0402RRES/CHIP-0402-18R
R1524R70402RRES/CHIP-0402-4R7
R15315R0402RRES/CHIP-0402-15R
R15418R0402RRES/CHIP-0402-18R
R1550R0402RRES/CHIP-0402-0R
R15620R0402RRES/CHIP-0402-20R
R15833R0402RRES/CHIP-0402-33R
R15933R0402RRES/CHIP-0402-33R
R16033R0402RRES/CHIP-0402-33R
R1724.7K0402RRES/CHIP-0402-4.7K
R17333R0402RRES/CHIP-0402-33R
R17433R0402RRES/CHIP-0402-33R
R17533R0402RRES/CHIP-0402-33R
R17633R0402RRES/CHIP-0402-33R
R17733R0402RRES/CHIP-0402-33R
R1784.7K0402RRES/CHIP-0402-4.7K
R1794.7K0402RRES/CHIP-0402-4.7K
R1804.7K0402RRES/CHIP-0402-4.7K
R1810R0402RRES/CHIP-0402-0R
R18275R0402RRES/CHIP-0402-75R
R18333R0402RRES/CHIP-0402-33R
R1841K0402RRES/CHIP-0402-1K
R1884.7K0402RRES/CHIP-0402-4.7K
R196100K0402RRES/CHIP-0402-100K
R197100K0402RRES/CHIP-0402-100K
R215NC0402RRES/CHIP-0402-NC
R2254.7K0402RRES/CHIP-0402-4.7K
R226NC0402RRES/CHIP-0402-NC
R2274.7K0402RRES/CHIP-0402-4.7K
R2284.7K0402RRES/CHIP-0402-4.7K
R229NC0402RRES/CHIP-0402-NC
R23520K0402RRES/CHIP-0402-20K
R23720K0402RRES/CHIP-0402-20K
R250100K0402RRES/CHIP-0402-100K
R25133R0402RRES/CHIP-0402-33R
R252NC0402RRES/CHIP-0402-NC
R2534.7K0402RRES/CHIP-0402-4.7K
R2544.7K0402RRES/CHIP-0402-4.7K
R255NC0402RRES/CHIP-0402-NC
R2564.7K0402RRES/CHIP-0402-4.7K
R257NC0402RRES/CHIP-0402-NC
R25833R0402RRES/CHIP-0402-33R
R26233R0402RRES/CHIP-0402-33R
R2652.7K0402RRES/CHIP-0402-2.7K
R2664.7K0402RRES/CHIP-0402-4.7K
R26733R0402RRES/CHIP-0402-33R
R2681M0402RRES/CHIP-0402-1M
R26933R0402RRES/CHIP-0402-33R
R27033R0402RRES/CHIP-0402-33R
R27233R0402RRES/CHIP-0402-33R
R27533R0402RRES/CHIP-0402-33R
R2774R70402RRES/CHIP-0402-4R7
R3231K0402RRES/CHIP-0402-1K
RP133RRA02-4RP-0402-33R
RP233RRA02-4RP-0402-33R
RP333RRA02-4RP-0402-33R
RP433RRA02-4RP-0402-33R
RP533RRA02-4RP-0402-33R
RP633RRA02-4RP-0402-33R
RP733RRA02-4RP-0402-33R
RP833RRA02-4RP-0402-33R
RP1133RRA02-4RP-0402-33R
RP1233RRA02-4RP-0402-33R
RP1333RRA02-4RP-0402-33R
RP1433RRA02-4RP-0402-33R
RP1533RRA02-4RP-0402-33R
RP1633RRA02-4RP-0402-33R
SW4SW-2PINKEY-6.5MM-SMTSW-2PIN-SMD
T1TEST-DOTTP_1.0TEST
T2TEST-DOTTP_1.0TEST
T3TEST-DOTTP_1.0TEST
T4TEST-DOTTP_1.0TEST
T5TEST-DOTTP_1.0TEST
T6TEST-DOTTP_1.0TEST
T7TEST-DOTTP_1.0TEST
T8TEST-DOTTP_1.0TEST
T9TEST-DOTTP_1.0TEST
T10TEST-DOTTP_1.0TEST
T11TEST-DOTTP_1.0TEST
T12TEST-DOTTP_1.0TEST
U1RT9167A-33CBSOT25RT9167A-SOT25
U2IRM3638T3809-87AAREMOTE
U4SY6288SOT25LPW5205H-SOT25
U5RT9167A-33CBSOT25RT9167A-SOT25
U6TSC2003SSOP-16A(TSC2003)TSC2003
U7AZ1117H-1.8VSOT-223(AMS1117)AZ1117H-1.8V
U10TVP5150TVP5150-S-PQFP32TVP5150-S-PQFP32
U17AZ1117H-3.3VSOT-223(AMS1117)AZ1117H-3.3V
U19AN_SY7201/FSP3307CAG/MP3302/RT9293SOT26SP1072-SOT26
U20T107BL107BLT107BL-LQFP128
U22ZEN098ZEN056ZEN056
U23WM8988QFN28IC-WM8988-QFN28
U25HYM8563MSOP8HYM8563-MSOP8
U26MMA7660FCMMA7660FCMMA7660FC-DFN10
U27RT9167A-33CBSOT25RT9167A-SOT25
U28AN_SY7201/RT9293/LP3301/G5126SOT26G5126-SOT26
U38RT9167A-33CBSOT25RT9167A-SOT25
WIFI1AP158USB_WIFI_AP158AP158_150M
X114.318MHzHC-49USMCRYSTAL
X232.768KCRY-MC146CRYSTAL-32.768
Y227MHZHC-49USMCRYSTAL
购买主题 本主题需向作者支付 7 枚金币 才能浏览
重要提示:PCB作品文件展下载说明
kingmen | 2014-7-7 23:15:04 | 显示全部楼层
活着就是一种挑战!
longxuekai | 2014-7-7 23:31:48 | 显示全部楼层
dai_lixing | 2014-7-8 11:48:09 | 显示全部楼层
哦,好东西, 不过没有金币了,帮你顶下
yinkzhdmisz | 2015-1-8 07:52:12 | 显示全部楼层
dahai_851129 | 2015-1-8 08:39:43 | 显示全部楼层
aabb888 | 2015-1-8 12:04:16 | 显示全部楼层
heming2216 | 2015-12-13 12:42:41 | 显示全部楼层
xingyw | 2017-12-25 21:32:35 | 显示全部楼层
yhgwork | 2020-8-8 00:52:48 | 显示全部楼层
社区居民忠实会员终身成就奖
