查看: 1230|回复: 4
RK3288平台
社区居民社区明星忠实会员宣传大使奖终身成就奖特殊贡献奖
发表于 2015-7-4 22:09:33 | 显示全部楼层 |阅读模式
*  Bluetooth driver for the Anycom BlueCard (LSE039/LSE041)
*  Copyright (C) 2001-2002  Marcel Holtmann <marcel@holtmann.org>
*  This program is free software; you can redistribute it and/or modify
*  it under the terms of the GNU General Public License version 2 as
*  published by the Free Software Foundation;
*  Software distributed under the License is distributed on an "AS
*  IS" basis, WITHOUT WARRANTY OF ANY KIND, either express or
*  implied. See the License for the specific language governing
*  rights and limitations under the License.
*  The initial developer of the original code is David A. Hinds
*  <dahinds@users.sourceforge.net>.  Portions created by David A. Hinds
*  are Copyright (C) 1999 David A. Hinds.  All Rights Reserved.
#include <linux/module.h>
#include <linux/kernel.h>
#include <linux/init.h>
#include <linux/slab.h>
#include <linux/types.h>
#include <linux/sched.h>
#include <linux/delay.h>
#include <linux/timer.h>
#include <linux/errno.h>
#include <linux/ptrace.h>
#include <linux/ioport.h>
#include <linux/spinlock.h>
#include <linux/moduleparam.h>
#include <linux/wait.h>
#include <linux/skbuff.h>
#include <linux/io.h>
#include <pcmcia/cistpl.h>
#include <pcmcia/ciscode.h>
#include <pcmcia/ds.h>
#include <pcmcia/cisreg.h>
#include <net/bluetooth/bluetooth.h>
#include <net/bluetooth/hci_core.h>
/* ======================== Module parameters ======================== */
MODULE_AUTHOR("Marcel Holtmann <marcel@holtmann.org>");
MODULE_DESCRIPTION("Bluetooth driver for the Anycom BlueCard (LSE039/LSE041)");
MODULE_LICENSE("GPL");
/* ======================== Local structures ======================== */
typedef struct bluecard_info_t {
    struct pcmcia_device *p_dev;
    struct hci_dev *hdev;
    spinlock_t lock;        /* For serializing operations */
    struct timer_list timer;    /* For LED control */
    struct sk_buff_head txq;
    unsigned long tx_state;
    unsigned long rx_state;
    unsigned long rx_count;
    struct sk_buff *rx_skb;
    unsigned char ctrl_reg;
    unsigned long hw_state;        /* Status of the hardware and LED control */
} bluecard_info_t;
static int bluecard_config(struct pcmcia_device *link);
static void bluecard_release(struct pcmcia_device *link);
static void bluecard_detach(struct pcmcia_device *p_dev);
/* Default baud rate: 57600, 115200, 230400 or 460800 */
#define DEFAULT_BAUD_RATE  230400
/* Hardware states */
#define CARD_READY             1
#define CARD_HAS_PCCARD_ID     4
#define CARD_HAS_POWER_LED     5
#define CARD_HAS_ACTIVITY_LED  6
/* Transmit states  */
#define XMIT_SENDING         1
#define XMIT_WAKEUP          2
#define XMIT_BUFFER_NUMBER   5    /* unset = buffer one, set = buffer two */
#define XMIT_BUF_ONE_READY   6
#define XMIT_BUF_TWO_READY   7
#define XMIT_SENDING_READY   8
/* Receiver states */
#define RECV_WAIT_PACKET_TYPE   0
#define RECV_WAIT_EVENT_HEADER  1
#define RECV_WAIT_ACL_HEADER    2
#define RECV_WAIT_SCO_HEADER    3
#define RECV_WAIT_DATA          4
/* Special packet types */
#define PKT_BAUD_RATE_57600   0x80
#define PKT_BAUD_RATE_115200  0x81
#define PKT_BAUD_RATE_230400  0x82
#define PKT_BAUD_RATE_460800  0x83
/* These are the register offsets */
#define REG_COMMAND     0x20
#define REG_INTERRUPT   0x21
#define REG_CONTROL     0x22
#define REG_RX_CONTROL  0x24
#define REG_CARD_RESET  0x30
#define REG_LED_CTRL    0x30
/* REG_COMMAND */
#define REG_COMMAND_TX_BUF_ONE  0x01
#define REG_COMMAND_TX_BUF_TWO  0x02
  • 签到天数: 103 天
    7万
    发表于 2015-7-5 00:09:54 | 显示全部楼层
    游客
    社区居民忠实会员社区劳模最爱沙发终身成就奖优秀斑竹奖
    发表于 2015-7-5 08:47:15 | 显示全部楼层
    社区居民忠实会员社区劳模原创达人最爱沙发终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2015-7-5 09:07:11 | 显示全部楼层
    社区居民
    发表于 2015-7-5 09:23:36 | 显示全部楼层
    学习一下,3288性能还是很不错的
