重要提示:PCB作品文件展下载说明
网上行车记录仪很多,但是全志F20双镜头几乎没有,今天来一个抄底的.
资料在下面了。
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
Name | Part Type | PCB Decal | Value | CN1 | SPEAKER_4 | FPC_1.25MM_2PIN | LEFT-SPEAKER | CN4 | SPEAKER | RTC_PAD | RTC_BAT | D1 | 1_1.5KE100A | ESD0402 | ESD5V/4KV/5PF | D2 | DIODE_SCHOTTKY_0 | D1206 | D1N4148 | D4 | DIODE_SCHOTTKY_0 | D1206 | NC/0.2V | D6 | DIODE_SCHOTTKY | D1206 | SS14 | D7 | 95SQ015/TO | SOD123 | B340A | D8 | DIODE_DUAL | SOT-23 | BAT54S | D10 | 95SQ015/TO | SOD123 | Z6V | D20 | DIODE_SCHOTTKY_0 | D1206 | SS14 | D21 | DIODE_SCHOTTKY_0 | SOD123 | B340A | D22 | DIODE_SCHOTTKY | SOD123 | SK34 | ESD7 | DIODE_TVS_LC_0 | ESD0402 | ESD5V/4KV/5PF | ESD18 | DIODE_TVS_LC_0 | ESD0402 | ESD-0402-LF | FB6 | INDUCTOR_2 | L0603 | 600R-100M | FB8 | INDUCTOR_2 | L0603 | 1K-100M | FB11 | INDUCTOR | L0603 | 600R-100M | J2 | CON3_2 | FPC_1.25MM_2PIN | CON3 | J3 | HP_JACK_4 | PJ-327A | PJ-327A | JP1 | JP_0 | FPC-24PIN/0.5F | JP_12X2 | L3 | INDUCTOR | SDNR3012 | 4.7uH @1.0A DCR<0.1ohm | L4 | INDUCTOR_3 | L0603 | 0.27uH | L7 | INDUCTOR_4 | SDNR6045 | 6.8UH | LCD3 | LCD-TD043MGEB1_5 | LCD-40P | T27P02 | LED1 | LED | LED0603 | LED | LED5 | LED | LED-DIP | IRLED | MIC1 | MICPHONE | MIC125 | Micphone | OQ3 | NPN | SOT-23 | MMBT3904 | OQ4 | PMOS | SOT-23 | AO3401 | OQ9 | NPN | SOT-23 | MMBT3904 | P1 | USB_MINI_SOCKET | USB_SOCK1 | MICRO-USB | P2 | USB_MINI_SOCKET_0 | FPC_1.25MM_4PIN | PREGROM | Q8 | NPN_BCE_1 | SOT-23 | MMBT3904 | SU1 | SPI-NOR-SO8 | SOP-8FLASH | SPI-NOR-SO8 | SW1 | KEY-2PIN_2 | KFC-A03-03 | DOWN | SW2 | SW_TACT_SPST/SM | KFC-A03-03 | RESET | SW4 | KEY-2PIN_2 | SW-4 | DOWN | U1 | F20-FBGA400-100921_7 | FBGA400-0.8MM | F20-BGA400 | U2 | AXP198_2 | QFN_48L_188P | AXP193 | U4 | DMARD07_1 | LGA10 | DA380 | U5 | DDRII-FPGA84 | DDR2_BGA84 | DDRII-FPGA84 | U7 | SDMMC_SLOT_11 | MICRO-SD-TF | MICROSD/TF_SLOT | U12 | LY8006 | MMSOP8 | LM4890 | U13 | SN74AHCT04_0 | SOP8-FX001 | FX001 | U14 | RT9266PE_0 | PQFP_32 | TVP5150 | U15 | IT4054_1 | SOT23-6 | FX5402 | U25 | M9216 | SOT23-5 | RT9193B-15M | U26 | M9216 | SOT23-5 | RT9193B-33M | X1 | CRYSTAL_SMD3_1 | OSC-3225 | 24M | X2 | CRYSTAL_3 | MC-146 | 32768KHZ | X3 | CRYSTAL_0 | OSC-3225 | 14.31818MHZ |
重要提示:PCB作品文件展下载说明
