[IC] LAN9514 LAN9514i
查看640 | 回复1 | 2016-6-6 09:17:29 | 显示全部楼层 |阅读模式
LAN9514 LAN9514i USB 2.0 Hub and 10/100 Ethernet Controller
Highlights
„ Four downstream ports, one upstream port
— Four integrated downstream USB 2.0 PHYs
— One integrated upstream USB 2.0 PHY
„ Integrated 10/100 Ethernet MAC with full-duplex
support
„ Integrated 10/100 Ethernet PHY with HP Auto-MDIX
„ Implements Reduced Power Operating Modes
„ Minimized BOM Cost
— Single 25 MHz crystal (Eliminates cost of separate
crystals for USB and Ethernet)
— Built-in Power-On-Reset (POR) circuit (Eliminates
requirement for external passive or active reset)
LAN9514 LAN9514i.pdf (832 KB, 下载次数: 0)
kkkkp | 2021-3-4 15:14:39 | 显示全部楼层
0000000000000000000000000000000000000000
