[IC] DS_4G_D-die_DDR3_135V_Rev10-0
查看418 | 回复0 | 2016-6-16 08:50:31 | 显示全部楼层 |阅读模式
• JEDEC standard 1.35V(1.28V~1.45V) & 1.5V(1.425V~1.575V)
• V
DDQ = 1.35V(1.28V~1.45V) & 1.5V(1.425V~1.575V)
• 400 MHz f
CK for 800Mb/sec/pin, 533MHz fCK for 1066Mb/sec/pin,
667MHz f
CK for 1333Mb/sec/pin, 800MHz fCK for 1600Mb/sec/pin
• 8 Banks
• Programmable CAS Latency(posted CAS): 5,6,7,8,9,10,11
• Programmable Additive Latency: 0, CL-2 or CL-1 clock
• Programmable CAS Write Latency (CWL) = 5 (DDR3-800), 6
(DDR3-1066), 7 (DDR3-1333) and 8 (DDR3-1600)
• 8-bit pre-fetch
• Burst Length: 8 (Interleave without any limit, sequential with starting
address “000” only), 4 with tCCD = 4 which does not allow seamless
read or write [either On the fly using A12 or MRS]
• Bi-directional Differential Data-Strobe
• Internal(self) calibration : Internal self calibration through ZQ pin
(RZQ : 240 ohm ± 1%)
• On Die Termination using ODT pin
• Average Refresh Period 7.8us at lower than TCASE 85C, 3.9us at
85C < T
CASE < 95 C
• Asynchronous Reset
• Package : 78 balls FBGA - x4/x8
• All of Lead-Free products are compliant for RoHS
• All of products are Halogen-free
DS_4G_D-die_DDR3_135V_Rev10-0.pdf (1.44 MB, 下载次数: 0)
