[Allegro16.6以下] Allwinner H8 VR BOX PCB 全志VR虚拟现实 PCB文件共享下载
查看10076 | 回复36 | 2016-9-6 11:02:23 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
ANT2T_POINT_R_0_CON2-WIFI-PT4_ANTANTCON2-WIFI-PT4
BAT2300BATTERY_7_WAFER5PIN_1P25MM_SMTWLI_3.7VWAFER5PIN_1P25MM_SMTW
CON2HDMI19_PLUG_0_HDMI_C_HM11_0010XHDMI_19plug type CHDMI_C_HM11_0010XR
D3D_0_R0603_LEDledR0603
D4DIODE_SCHOTTKY_0_SOD123_SS14SS14SOD123
D5DIODE_SCHOTTKY_0_SOD123_NC/XBS1NC/XBS104S14SOD123
D12D_0_SOD123_SS14SS14SOD123
D231_1.5KE100A_C0402_ESD9B5V-2/TRESD9B5V-2/TRC0402
DR1R_R0402_240-1%240-1%R0402
DR3R_R0402_240-1%240-1%R0402
DR5R_R0402_240-1%240-1%R0402
DR6?_0_R0402_2K-1%2K-1%R0402
DR7?_0_R0402_2K-1%2K-1%R0402
DR10R_R0402_240-1%240-1%R0402
DR11R_R0402_240-1%240-1%R0402
DR14?_0_R0402_100R100RR0402
DU1DDR3_1_FBGA96C80P9X13_DDR3-FBGADDR3-FBGA96FBGA96C80P9X13
DU2DDR3_1_FBGA96C80P9X13_DDR3-FBGADDR3-FBGA96FBGA96C80P9X13
DU3DDR3_1_FBGA96C80P9X13_DDR3-FBGADDR3-FBGA96FBGA96C80P9X13
DU4DDR3_1_FBGA96C80P9X13_DDR3-FBGADDR3-FBGA96FBGA96C80P9X13
ED7100TVS_ESD0402A_AZ5425-01FAZ5425-01FESD0402A
ED7101TVS_ESD0402A_AZ5425-01FAZ5425-01FESD0402A
ED7102TVS_ESD0402A_AZ5425-01FAZ5425-01FESD0402A
ED8106DIODE BI-DIRTRIG_ESD0402A_AZ54AZ5425-01FESD0402A
EL101ICMS212B900MFR_ICMS212B900MFR_IICMS212B900MFRICMS212B900MFR
EL102ICMS212B900MFR_ICMS212B900MFR_IICMS212B900MFRICMS212B900MFR
ESD11_1.5KE100A_C0402_AU0511P1AU0511P1C0402
ESD21_1.5KE100A_C0402_AU0511P1AU0511P1C0402
ESD31_1.5KE100A_C0402_AU0511P1AU0511P1C0402
ESD41_1.5KE100A_C0402_AU0511P1AU0511P1C0402
ESD51_1.5KE100A_ESD0402A_AU0511P1AU0511P1ESD0402A
ESD141_1.5KE100A_ESD0402A_ESD9B5VL-2ESD9B5VL-2/TRESD0402A
ESD151_1.5KE100A_ESD0402A_ESD9B5VL-2ESD9B5VL-2/TRESD0402A
ESD161_1.5KE100A_ESD0402A_ESD9B5VL-2ESD9B5VL-2/TRESD0402A
ESD171_1.5KE100A_ESD0402A_ESD9B5VL-2ESD9B5VL-2/TRESD0402A
J725RT9293B_9_CA0103021-R_PBZpbzCA0103021-R
J2000USB_MINI_SOCKET_1_MICROUSB_MCD_MICROUSB_MCD_HXQK5F_LJ12MICROUSB_MCD_HXQK5F_LJ12
J4700MINI5IN1CON_0_FPC21_0310_21B2G1FPC0310_21B2G1RFPC21_0310_21B2G1R_P3MM_DW
J5003FPC30_3_FPCX_PIN25_P3MM_WD_FPCXFPCX_PIN25_P3MM_WDFPCX_PIN25_P3MM_WD
J7100PHONEJACK STEREOSW_3_PJ0016_00YSHJAK0016-006PJ0016_006_N
J8100MMCCONNECTOR_0_TFCARD_SOCKET_TTFCARDTFCARD_SOCKET
J8106FPC6MMP5_0_FPC8PIN_P5MM_WD_FPC8fpc8pin_p5mm_wFPC8PIN_P5MM_WD
J8107FPC6MMP5_0_FPC8PIN_P5MM_W_FPC8Pfpc8pin_p5mm_wFPC8PIN_P5MM_W
JP14HEADER_3_CON_F_0D5_6P_R_C_CONCON-6P-0.5CON_F_0D5_6P_R_C
L1INDUCTOR_0_L3015_1.0UH@2ADCR<01.0uH@2A DCR<0.1RL3015
L2INDUCTOR_0_L4012_1.0UH@3ADCR<01.0uH@3A DCR<0.1RL4012
L3INDUCTOR_0_L4012_1.0UH@3ADCR<01.0uH@3A DCR<0.1RL4012
L5INDUCTOR_0_L4012_1.0UH@3ADCR<01.0uH@3A DCR<0.1RL4012
L6INDUCTOR_0_L3015_1.0UH@2ADCR<01.0uH@2A DCR<0.1RL3015
L7INDUCTOR_0_L3015_1.0UH@2ADCR<01.0uH@2A DCR<0.1RL3015
L9INDUCTOR_L4018_10UH@1ADCR<0.1R10uH@1A DCR<0.1RL4018
L10INDUCTOR_L3518_3.3UH@0.7ADCR<03.3uH@0.7ADCR<0.1RL3518
L11INDUCTOR_0_L4012_1.0UH@3ADCR<01.0uH@3A DCR<0.1RL4012
MASK1T POINT R_SMD_SMDSMDSMD
MASK2T POINT R_SMD_SMDSMDSMD
MASK3T POINT R_SMD_SMDSMDSMD
MASK4T POINT R_SMD_SMDSMDSMD
MIC1MICPHONE_0_MIC1MM2_SMD_MICPHONEMicphoneMIC1MM2_SMD
OD1DIODE_SCHOTTKY_SOD123_SS24SS24SOD123
OL1INDUCTOR_0_L4012_2.2UH-DCR<0.1R2.2uH-DCR<0.1R-2AL4012
OU1RT9266PE_3_SOT23-6_MT3608MT3608SOT23-6
P2USB_A_1_USB_04AF_USB_A_1USB_A_1USB_04AF
Q2NMOS_0_SOT-23_BSN20BSN20SOT-23
Q3NMOS_0_SOT-23_BSN20BSN20SOT-23
Q4WPM4005_11_DFN8P0_65B2_00X2_00HWPM1481DFN8P0_65B2_00X2_00H0_75
Q5NMOS_0_SOT-23_NC/BSN20NC/BSN20SOT-23
Q7NPN_SOT-23_MMBT3904MMBT3904SOT-23
Q8NPN_SOT-23_MMBT3904MMBT3904SOT-23
Q3602NPN_SOT23_MMBT3904MMBT3904SOT23
Q3603MOSFETP_SOT23_WPM2015-3/TRWPM2015-3/TRSOT23
Q3604MOSFETP_SOT23_WPM2015-3/TRWPM2015-3/TRSOT23
Q3605NPN_SOT23_MMBT3904MMBT3904SOT23
SW104KEY_4PIN_SWITCH_0_KEY_TS-022-25KEY_4PIN_SWITCHKEY_TS-022-250
SW2304KEY_4PIN_SWITCH_KEY_TS-022-250_KEY_TS-022-250KEY_TS-022-250
T4701TESTPOINT1_0_TEST_CIRP8MM1P3_TETESTTEST_CIRP8MM1P3
TP1TEST POINTSURFACE_TP_SMD_SADBGSADBGTP_SMD
TP2TEST POINTSURFACE_TP_SMD_SDDBGSDDBG0TP_SMD
TP3TEST POINTSURFACE_TP_SMD_SDD_1SDDBG1TP_SMD
TP4T_POINT_R_TP_SMD_UART0-TXUART0-TXTP_SMD
TP5T_POINT_R_TP_SMD_UART0-RXUART0-RXTP_SMD
TP6T_POINT_R_TP_SMD_CPUS-UTXCPUS-UTXTP_SMD
TP7T_POINT_R_TP_SMD_CPUS-URXCPUS-URXTP_SMD
TP238TEST POINTSURFACE_TP_SMD_TESTTEST POINT SURFACETP_SMD
U1H8_0_BGA345P0_65B14X14_H8H8BGA345P0_65B14X14
U4NAND_FLASH_X8_TSOP-48_NANDFLASNAND FLASH X8TSOP-48
U6RRCLAMP0524P_RCLAMP0524P_RRCLAMrRClamp0524PRCLAMP0524P
U7RRCLAMP0524P_RCLAMP0524P_RRCLAMrRClamp0524PRCLAMP0524P
U11AP3031_0_SOT23-6_WS63032/AP3032WS63032/AP3032/SY7200ASOT23-6
U15LDO-PT5108/RT9013_SOT23-5_IA600IA6004-18S25FSOT23-5
U19RT9266PE_2_SOT23-5_SY6280SY6280SOT23-5
U24APSERIESAP6212QFN44-AP6476-12X12H1_6A
U28AXP818_BGA218_AXP813-BGA218_AXPAXP818-BGA218AXP813-BGA218
U29EMMC5_0_BGA169_BGA169P0_50B12_0EMMC5_0_BGA169BGA169P0_50B12_00X16_00H1_00
U49BMG160_2_QFN3X3X09_24P_EP_MPU65MPU6500QFN3X3X09_24P_EP_MPU6500
U159AK8975_0_BGA8_AK09911_AK09911AK09911BGA8_AK09911
U16074OL6011_2_BMI160_NC/BMI160NC/BMI160BMI160
U919ICL7660_1_SO8_OPT_ICL7660ICL7660SO8_OPT
X1CRYSTAL-4_0_CRY-TSX3225_24M-9PF24M-9pF-10PPMCRY-TSX3225
X2CRYSTAL_XCOL-3_2_IN-CRYSTAL_02032.768Khz/12.5PFIN-CRYSTAL_0206H1_4A
Y1CRYSTAL_0_CRY-TSX3225_26MHZCL=26MHz CL=16pFCRY-TSX3225
H8VR.zip (2.61 MB, 下载次数: 15)
重要提示:PCB作品文件展下载说明
天马艾维 | 2016-9-6 11:49:11 | 显示全部楼层
爱伤影313 | 2016-9-6 14:43:49 | 显示全部楼层
zhdett | 2016-9-6 14:55:25 | 显示全部楼层
地沟油 | 2016-9-6 16:12:29 | 显示全部楼层
单枪舞九州 | 2016-9-6 19:34:50 | 显示全部楼层
laowu1680 | 2016-9-7 08:25:36 | 显示全部楼层
lg0556 | 2016-9-7 08:26:07 | 显示全部楼层
myntpcb | 2016-9-7 08:26:43 | 显示全部楼层
mirage | 2016-9-7 08:51:57 | 显示全部楼层
终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
