重要提示:PCB作品文件展下载说明
挂3个DDR 的板子。
Name | Part Type | PCB Decal | Value | BT1 | BATERRY_0 | RTC | BATERRY_0 | BUZ1 | 126ANS_0 | BEEP12_75 | Buzzer | D41 | ZC2800E/SOT_0 | DO-214AC | SR24 | F1 | SMD050 | FUSE_2P_5.1D | HR16-500 | IR1 | CON3 | INFRARED_100 | Infrared | J2 | CONN_TRBLK_9 | MTGNP9-350MM | H3_5MM | J4 | CONN_TRBLK_9 | MTGNP9-350MM | H3_5MM | J5 | CONN_TRBLK_9 | MTGNP9-350MM | H3_5MM | J7 | CONN_TRBLK_9 | MTGNP9-350MM | H3_5MM | J8 | CONN_TRBLK_9 | MTGNP9-350MM | H3_5MM | J9 | CONN_TRBLK_9 | MTGNP9-350MM | H3_5MM | J10 | CONN_TRBLK_9 | MTGNP9-350MM | H3_5MM | J11 | CONN_TRBLK_9 | MTGNP9-350MM | H3_5MM | J12 | CONN_TRBLK_9 | MTGNP9-350MM | H3_5MM | J13 | CONN_TRBLK_9 | MTGNP9-350MM | H3_5MM | L1 | INDUCTOR | IND-D21-P8 | 16uH | L2 | INDUCTOR | IND-D8-P5 | 3uH | L3 | INDUCTOR | IND-D21-P8 | 16uH | L4 | INDUCTOR | IND-D8-P5 | 3uH | L5 | 100MHZ@110OHM_5 | IND0805N | 22uH | L6 | 100MHZ@110OHM_5 | IND0805N | 22uH | L7 | 3.3UH_0.26A_10%_SMD_CM_CC3225 | IND0805N | 1.8uH | L8 | INDUCTOR | INDB780X700N | 22uH/3A | L9 | INDUCTOR | INDB780X700N | 22uH/3A | L10 | INDUCTOR | INDB780X700N | 22uH/3A | LED1 | LED | RES0603N | GREEN | LED2 | LED | RES0603N | GREEN | LED3 | LED | RES0603N | GREEN | LED4 | LED_0 | LEDH254P500MM-TEST | GREEN | LED5 | LED_0 | LEDH254P500MM-TEST | GREEN | LED6 | LED_0 | LEDH254P500MM-TEST | GREEN | LED7 | LED_0 | LEDH254P500MM-TEST | GREEN | LED8 | LED_0 | LEDH254P500MM-TEST | GREEN | LED9 | LED_0 | LEDH254P500MM-TEST | GREEN | LED10 | LED_0 | LEDH254P500MM-TEST | GREEN | LEM1 | XFRM_LINEAR_0 | DNM01-S | XFRM_LINEAR | PT1 | PCB_TRACE_W_8MIL | SJO_120MIL | I=3A, W_120mil | PT2 | PCB_TRACE_W_8MIL | SJO_200MIL | I=5A, W_200mil | PT3 | PCB_TRACE_W_8MIL | SJO_320MIL | I=8A, W_320mil | PT4 | PCB_TRACE_W_8MIL | SJO_8MIL | PCB_Trace,W_8mil | PT5 | PCB_TRACE_W_8MIL | SJO_8MIL | PCB_Trace,W_8mil | PT6 | PCB_TRACE_W_8MIL | SJO_8MIL | PCB_Trace,W_8mil | PT7 | PCB_TRACE_W_8MIL | SJO_8MIL | PCB_Trace,W_8mil | PT8 | PCB_TRACE_W_8MIL | SJO_120MIL | I=3A, W_120mil | Q1 | MFE823_1 | TO-263(DPAK) | SUM110P06 | Q2 | MFE823_2 | TO-263(DPAK) | SUM110P06 | Q4 | 40237_1_2 | SOT23-240N | T5551 | Q5 | 40237_1_2 | SOT23-240N | T5551 | Q6 | 40237_3 | TO252-3 | KTC2020D | Q7 | MFE825_0 | TO-252 | FDD10AN06A0 | Q8 | MFE825_0 | TO-252 | FDD10AN06A0 | Q9 | MFE825_0 | TO-252 | FDD10AN06A0 | Q10 | MFE825_0 | TO-252 | FDD10AN06A0 | Q11 | 40237_0 | SOT23-240N | T5551 | Q12 | MFE825_0 | TO-252 | FDD10AN06A0 | Q13 | MFE825_0 | TO-252 | FDD10AN06A0 | Q14 | 2SD601AR_SOT23 | SOT23-240N | MMST3904 | Q15 | 2SD601AR_SOT23 | SOT23-240N | MMST3904 | Q16 | MFE823_0 | SOT23-240N | AO3401 | Q17 | 40237_1 | SOT23-240N | MMST3904 | Q18 | MFE823_0 | SOT23-240N | AO3401 | Q19 | MFE823_0 | SOT23-240N | AO3401/NC | Q20 | 40237_1 | SOT23-240N | MMST3904 | Q21 | NPN_BCE | SOT23-240N | MMST3904 | Q22 | BC178A | SOT23-240N | MMST3906 | Q23 | NPN_BCE | SOT23-240N | MMST3904 | Q24 | 40237_0_2 | SOT23-240N | MMST3904 | Q43 | AO3415_SOT23_0 | SOT23-240N | AO3415 | Q44 | MFE823_0 | SOT23-240N | AO3401 | Q45 | 40237_1 | SOT23-240N | MMST3904 | Q46 | MFE825_0 | SOT23-240N | AO3400 | Q47 | 40237_1 | SOT23-240N | MMST3904 | Q48 | 40237_1 | SOT23-240N | MMST3904 | Q49 | MFE825_0 | SOT23-240N | AO3400 | Q50 | 40237_1 | SOT23-240N | MMST3904 | RV1 | DIODE_BREAKDOWN_1 | VAR-D10-P7.5 | 10D560 | SW1 | SW_PUSHBUTTON | KEY2P-3.6X2.6-SMD | M_RST/NC | SW2 | SW_TACT-SPST/SM | KEY2P-3.6X2.6-SMD | M_RST/NC | T1 | H1102_1 | SOP16-127P953N | M3066ANL | TP1 | 1X1P_MALE_DIP_2.0 | TP80 | TP_SMD | TP2 | 1X1P_MALE_DIP_2.0 | TP80 | TP_SMD | TP3 | 1X1P_MALE_DIP_2.0 | TP80 | TP_SMD | TP4 | 1X1P_MALE_DIP_2.0 | TP80 | TP_SMD | TP5 | TESTPOINT_SMD | TP80 | TP_SMD | TP6 | TESTPOINT_SMD | TP80 | TP_SMD | TP7 | 1X1P_MALE_DIP_2.0 | TP80 | TP_SMD | TP8 | 1X1P_MALE_DIP_2.0 | TP80 | TP_SMD | TP9 | 1X1P_MALE_DIP_2.0 | TP80 | TP_SMD | U1 | LM393_3 | SOP8-127P600N | LM2904 | U2 | LM393_3 | SOP8-127P600N | LM2904 | U3 | 40237_2 | SOT23-240N | AZ431 | U4 | XWM8731EDSR_SSOP28_2 | TSOP24-65P640N | LTC3780 | U5 | LM5116 | SOP-20P-LM5116 | LM5116 | U6 | GM8185_BGA700_V2_9 | BGA700_100 | GM8185_BGA700_V2 | U7 | G916-120T1UF_SOT25 | SOT23-5-95P280N | G916-120T1Uf | U8 | S29GL256P90TFC02_TSOP56_1 | TSOP56-50P2000N | S29GL256P90TFCR2 | U9 | S29GL256P90TFC02_TSOP56_1 | TSOP56-50P2000N | S29GL256P90TFCR2 | U10 | MAX3490E | SOP8-127P600N | SP3490EN | U11 | ADM485_0 | SOP8-127P600N | SP3485EEN-L | U12 | K4T1G164QE-HCE7_FBGA84 | BGA84-80P9X15C | K4T1G164QE-HCE7,FBGA84 | U13 | K4T1G164QE-HCE7_FBGA84 | BGA84-80P9X15C | K4T1G164QE-HCE7,FBGA84 | U14 | G916-120T1UF_SOT25 | SOT23-5-95P280N | G916-120T1Uf | U15 | K4T1G164QE-HCE7_FBGA84 | BGA84-80P9X15C | K4T1G164QE-HCE7,FBGA84 | U16 | TW2865_3 | TQFP128-40P1600N | TW2865 | U17 | XWM8731EDSR_SSOP28_3 | SOP28-65P780N | XWM8731EDSR_SSOP28 | U18 | CAT24WC02J_SOP8_2 | TSOP8-65P490N-TEST | ADT75 | U19 | SII3512_2 | TQFP128_P | SII3512 | U20 | LAN8710 | QFN33-50P500N | LAN8710 | U21 | FE1_1S_SSOP28 | SOP28-64P600N | FE1_1s_SSOP28 | U22 | RT9701CB | SOT23-5-95P280N | RT9701PB | U23 | ISL1208IB8-TK | SOP8-127P600N | ISL1208 | U24 | CAT24WC02J_SOP8 | SOP8-127P600N | AT24C02 | U25 | AT89C52_2 | TQFP44-80P1200N | AT89S52 | U26 | CON2_3 | SOP8-127P600N | SP813LEN | U27 | CAT24WC02J_SOP8 | SOP8-127P600N | AT24C02 | U28 | RT9701CB | SOT23-5-95P280N | RT9701PB | U29 | XC9572XL | TQFP64-50P1200N | XC9572XV | U30 | CAT24WC02J_SOP8_1 | SOP8-127P600N | AOZ1360AIL | U31 | LTV847 | SO16 | TCMT4100 | U32 | LTV847 | SO16 | TCMT4100 | U33 | LTV847 | SO16 | TCMT4100 | U34 | LTV847 | SO16 | TCMT4100 | U35 | MAX3232CSE_SOP16_0 | SOP16-65P780N | SP3232EN | U36 | PESDXS2UAT | SOT23-240N | PESD24VS2UAT | U37 | CM1624 | SON17-40P135N | cm1624 | U38 | PACDN044Y | SOT5-65P210N | PACDN044Y | U39 | PACDN044Y | SOT5-65P210N | PACDN044Y | U40 | PACDN044Y | SOT5-65P210N | PACDN044Y | U41 | PACDN044Y | SOT5-65P210N | PACDN044Y | U42 | PACDN044Y | SOT5-65P210N | PACDN044Y | U43 | PACDN044Y | SOT5-65P210N | PACDN044Y | U44 | TPS54231 | SOP8-127P600N | TPS54331 | U45 | EM6323_0 | SOT23-5-95P280N | EM6323LXSP5B-2.9 | U46 | EM6323_0 | SOT23-5-95P280N | EM6323LXSP5B-2.9 | U47 | TPS54231 | SOP8-127P600N | TPS54331 | U48 | TPS54231 | SOP8-127P600N | TPS54331 | U49 | PESDXS2UAT | SOT23-240N | PESD24VS2UAT | X1 | 12MHZ_CRY_30PPM_49US_1 | SMAQ-5032B | 12MHz | X2 | 24_1.576MHZ_CRY_30PPM_49US | SMAQ-5032B | 24.576MHz | X3 | 27MHZ_OSC_30PPM_SMD5X3_0 | OSCS500X700-4N | 27MHz | X4 | ZTA_0 | SMAQ-5032B | 25MHZ | X5 | 30MHZ_CRY_30PPM_49US_0 | SMAQ-5032B | 25MHz | X6 | ZTA_1 | SMAQ-5032B | 12MHz | X7 | 27MHZ_OSC_30PPM_SMD5X3_1 | OSC-150X700N-TEST | 32.768KHz | X8 | CRYSTAL_0 | SMAQ-5032B | 22.1184 | ZD1 | ZC2800E/SOT_1 | SOD-123N | 14V | ZD2 | ZC2800E/SOT_1 | SOD-123N | 14V | ZD4 | ZC2800E/SOT_1 | SOD-123N | 9.1V | ZD5 | ZC2800E/SOT_1 | SOD-123N | 13V | ZD6 | ZC2800E/SOT_1 | SOD-123N | 5.1V |
重要提示:PCB作品文件展下载说明
