• 芯片制造中的阻挡层沉积技术介绍
  • 接地搭接电缆布局屏蔽!!!
  • 北美液冷生态解码:超微spuermicro,24年营
  • SK海力士全球首发HBM4-16层堆叠、2.0TB/s
  • 2纳米Nanosheet技术及其以后的选择性层减薄
[PADS9.5以下] LC4064V-75TN44I+TM4C1237E6PZ+ISO1176DW+TPS55010RTER+TPS2482PW+LM20242MH/NOPB
查看4703 | 回复0 | 2017-1-15 12:28:01 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
简单的4层板子。有需要提取封装的可以下载
板子有以下主要元件。
NamePart TypePCB DecalValue
D7DIODE_BI-DIR_TRIG_0DIO_SMCSMCJ15CA
D8DIODE_SCHOTTKY_2DIO_SMAB120-13-F
D9ZENER_2SMBJ5338B-TP, 5.1V
D10DIODE_SCHOTTKY_6DIO-SOD-123FMBR0540-TP
D11DIODE_SCHOTTKY_6DIO-SOD-123FMBR0540-TP
D12DIODE_SCHOTTKY_6DIO_DFLS1200-7DFLS1200-7
D13DIODE_SCHOTTKY_6DIO_DFLS1200-7DFLS1200-7
D14DIODE_SCHOTTKY_6DIO_SOD523SDM10U45-7-F
D15DIODE_SCHOTTKY_1DIO_SMC_P290_PD110X150_8.13_3.07_1.27_1MBRS4201T3G
D16MOVVAR_V20E30PDNP
D17SMBJ15CA_0DIO_DO-214AASMBJ45CA
D18MMSZ5233BT1_1DIO_SOD-123BZT52C8V2-7
D52SMBJ15CA_0DIO_DO-214AASMBJ45CA
D57ZENER_1DIO_SOD-123BZT52C2V4-7-F, 2.4V
D60DIODE_SCHOTTKY_6DIO_SOD523SDM10U45-7-F
D61ZENER_1DIO_SOD-123DNP
IC1TPS2482PW20TPS2482PW
J1CON2CN2_MTB_P100_PD80_D1.1_S5.54X6.5_STACKOSTVN02A150
J2HEADER_5X2CN10_BS5X2_P100_PD70_D1.0HEADER 5X2
J5CON-MINI-USB-ABSMDUSB MINI-AB SMD
J6HEADER_5X2HEADER 5X2
J7HEADER_2TE_282825-2RMC2
J8HEADER_2TE_282825-2RMC2
J18HEADER_2TE_282825-2RMC2
J19HEADER_5X2CN10_BS5X2_P100_PD70_D1.0HEADER 5X2
J20CON2CN2_MTB_P100_PD80_D1.1_S5.54X6.5_STACKOSTVN02A150
L1MMZ1608B102C_1FB0603MMZ1608B102C
L2CHOKE_CM14_4FIL_ACM2012ACM2012-900-2P-T002
L3CHOKE_CM14_0SMDACM2012-900-2P-T002
L4INDUCTORINDC12123.3uH
L5INDUCTOR_2IND_SRR7032220uH
L6INDUCTORINDC12123.3uH
L7INDUCTORINDC12123.3uH
L8COMMON_MODE_CHOKE_2IND_52106C52106C, 10mH
M1CSD18537NQ5A_0SON_CSD18537NQ5ACSD18537NQ5A
M3CSD18537NQ5A_0SON_CSD18501Q5ACSD18501Q5A
MH12MH_3.5MMMH3.2_H5_W6_KO8_STARHEADMH 3.2MM
SW2B3S-1000_SW_0SW_B3S-1000PB3S-1000 SW
T1TRAN_ISDN_0XFMR_760390015760390015, 1:2
T2TRAN_ISDN_9XFMR_750313998750342156
T3Q4337-BL_3XFMR_RLTI-1046RLTI-1046
U1TM4C1237E6PZTM4C1237E6PZ
U2AT2402_2IC8SOIC_P50X189_PD26X90_6.2_0.51_1.27AT24C02C-SSHM-T SL901
U3TPS3897APSON50P100X145X60-6NTPS3897ADRYR
U5REF3230SOT23-6REF3230AIDBVT
U6ISO3082_DW_3IC16SOW_P50X376_PD22X84_10.65_.51_1.27_5ISO3082DW
U7TPS55010_TRANS_4QFN50P300X300X55-17NTPS55010RTER
U8LC4032/4064-T44_2LC4064V-75TN44I
U9TPD4E1B06DCKR_0SC-70-6TPD4E1B06DCKR
U10SDCCCN50_ERM-DV-K_P0.8X5_PD20X70_SAMTECERM8-025-05.0-L-DV-TR
U11SDCCCN50_ERM-DV-K_P0.8X5_PD20X70_SAMTECERM8-025-05.0-L-DV-TR
U12LM5069_1SOP50P490X110-10NLM5069
U13LM5017_0SOIC127P517X168-9LM5017MR
U14LM20242_1SOP65P772X110-20LM20242MH/NOPB
U15LM5017_0SOIC127P517X168-9LM5017MR
Y1CRYSTAL_1XTAL_ABM1025MHz
Y2OSCILLATORCB3LV-3I-25M0000
PCB是PADS9.5  原理图是ORCAD16.3
TIDU191_PADS_PCB_Layout.zip (471 KB, 下载次数: 0)
重要提示:PCB作品文件展下载说明
此广告位出租
