Name | Part Type | PCB Decal | Value | AD2 | DIODE_SCHOTTKY_1 | 1N5817-SMT | 1N5819-SMT | AU1 | LT1940 | DIP16-TSSOP | LT1940 | D2 | LED_3 | LED-SMT | RED LED-SMT | D3 | DIODE_ZENER_1 | DIODE-589 | AD589JR-SOP8 | D6 | DIODE_SCHOTTKY_1 | 1N5817-SMT | 1N5819-SMT | D7 | LM358N | | AD8092AR(nc) | D8 | DIODE_0 | 1N4148-SMT | 1N4148-SMT | D9 | DIODE_SCHOTTKY_1 | 1N5817-SMT | 1N4148-SMT(NC) | D10 | DIODE_ZENER1_0 | | 3V3ZENER | DJP1 | HEADER_30_1 | CON50P-0.5L | ZIFF50-0.5MM/DOWN TOUCH(NC) | DJP2 | HEADER_30_2 | CON50P-0.5L | ZIFF50-0.5MM/UP TOUCH(NC) | DJP3 | HEADER_30_2 | CON50P-0.5L | ZIFF50-0.5MM/DOWN TOUCH(NC) | DL1 | INDUCTOR | BEAD-0805 | SMB-201209-N2-401A | DL2 | INDUCTOR | BEAD-0805 | SMB-201209-N2-401A | DL3 | INDUCTOR | L-0805 | SMB-210209-F2-221P | DN1 | DIODE_SCHOTTKY_1 | 1N4148-SMT | 1N4148-SMT | DN2 | DIODE_SCHOTTKY_1 | 1N4148-SMT | 1N4148-SMT | DN3 | DIODE_SCHOTTKY_1 | 1N5817-SMT | 1N5819-SMT | DU1 | 74AHCT245_0 | FST3245-TSSOP | FST3245-TSSOP(NC) | DU2 | LM7805CT | TO-252 | LM7808/D-PAK | DU3 | 14053_0 | SOP16\225 | 74HC4053-SOP | DU8 | 74AHCT245_1 | FST3245-TSSOP | FST3245-TSSOP(NC) | FU1 | FUSE | FUSE-SMT | FUSE-2.0A-1812 | FU2 | FUSE | FUSE-SMT | FUSE-2.0A-1812 | GPS1 | HEADER_10X2_1 | GPS | HEADER10X2-2MM-FEMALE | IDE1 | HEADER20X2_0 | HEADER22X2-2.0 | HEADER22X2 | J1 | CON3_9 | CON-SIP-3P | FANCONN(NC) | J2 | CON3 | PAD3-2.5 | CON3(NC) | J3 | CON3_10 | CON-SIP-3P | FANCONN | J8 | CON10 | | C4255WR-2x5 | J29 | HEADER_25X2 | HEADER25X2-2.54 | HEADER25X2-R | J30 | CON5 | CON5-2.0 | CON5*2mm | JCF1 | HEADER_30_7 | CF-CARD1A | ALPS-CF(NC) | JP6 | CONN_SOCKET_6_1 | ENV-0.5G | ENV-O5F-03 | L3 | INDUCTOR_4 | L-1206 | BEAD-1206 | L4 | INDUCTOR_4 | L-1206 | BEAD-1206 | L7 | INDUCTOR_4 | L-2P7\S | 10UH/SMTDRS0732-100M | L8 | INDUCTOR_4 | L-2P7\S | 10UH/SMTDRS0732-100M | L348 | INDUCTOR | L-0805 | SMB-201209-F2-221P | LA1 | INDUCTOR | L-1206 | BEAD-1206(NC) | LA2(NC) | INDUCTOR | L-1206 | BEAD-1206 | LD1 | INDUCTOR_4 | L2P-SMD10UH | 10UH/SMD-453232-100K | LD2 | INDUCTOR_4 | L2P-SMD10UH | 0-1206 | LN1 | INDUCTOR_4 | L-0732 | 100UH/SMTDRS0745-101M | Q1 | MOSFET_N_0 | 2N7002 | 2N7002 | Q2 | VD-SOT23_2 | 2N7002 | LM61CIM3(NC) | Q3 | MOSFET_N_0 | 2N7002 | 2N3904(NC) | Q4 | MOSFET_N_0 | 2N7002 | 2N7002 | Q5 | MOSFET_P_4 | SOT-89 | XP162A12A6PR | Q6 | NPN_0 | 2N3904-SMT | 2N3904-SMT | Q7 | NPN_0 | 2N3904-SMT | 2N3904-SMT | Q271 | MOSFET_N_0 | 2N7002 | 2N7002 | U1 | EP9312 | EP9312 | EP9312 | U2 | 28F800CV_T_0 | SMT-SOP2-56 | E28F320JA-150 | U3 | SDRAM_1 | SMT-SOP2-54 | HY57V561620T-HI | U4 | SDRAM_1 | SMT-SOP2-54 | HY57V561620T-HI | U5 | 28F800CV_T_0 | SMT-SOP2-56 | E28F320JA-150 | U9 | CS4202 | CS4202 | CS4202 | U10 | LM393/SO | AD8092AR | LMV393ID/SO(NC) | U13 | 74HCT04_0 | DIP14-MTC | 74LCX14MTCX | U14 | XC6383A501PR_2 | SOT23-5 | XC6366B103MR | U27 | SPV516_128PIN_2 | QFP128-0.4 | SPV516 | U28 | TMS664164/SO_0 | DIP54-SSOP | K4S641632F(64Mb/1Mx16x4B) | U270 | NFR2401_2 | TQFP32 | ATMegaL8 | U290 | AIC1563_0 | SOP8\225 | MAX708CSA | U292 | LM7805CT_0 | TO\\263 | AIC1085CE / AIC086CY | U293 | TMS664164/SO_13 | DIP54-TSOP | K4S641632F | U294 | SOKET208_0 | LQFP216-0.4 | SPV311 | U295 | LM7805CT_0 | TO\\263 | AIC1085CE / AIC086CY | UD1 | ADV7120 | DIP48-PQFP | ADV7120KST30 | UN1 | AIC1563 | LTC1624 | AIC1563-SOP | UV1 | FLASH_1MX16_2 | TSOP48-0.5MM | MX29LV800T(B)I-70+soft | VC1 | CAPACITOR_POL_4 | CAP100 | 10UF-25V-C | VC2 | CAPACITOR_POL_4 | CAP100 | 10UF-25V-C | X1 | CRYSTAL_3 | XP | 24.576MHZ | Y1 | CRYSTAL | XP | 14.7456MHz | Y2 | CRYSTAL | XP-32 | 32.768kHz-1 | Y3 | CRYSTAL_1 | X'TAL1 | XQ-27MHz | Y4 | CRYSTAL_2 | XP | XQ-12MHZ |
