REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
C1 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C2 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C3 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C4 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C5 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C6 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C7 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C8 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C9 | CAP_CC0402_0.1UF | 0.1uF | CC0402 |
C10 | CAP_CC0402_0.1UF | 0.1uF | CC0402 |
C11 | CAP_CC0402_0.1UF | 0.1uF | CC0402 |
C12 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C13 | CAP_CC0402_0.1UF | 0.1uF | CC0402 |
C14 | CAP_CC0402_0.1UF | 0.1uF | CC0402 |
C15 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C16 | CAP_CC0402_0.1UF | 0.1uF | CC0402 |
C17 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C18 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C19 | CAP_CC0402_0.1UF | 0.1uF | CC0402 |
C20 | CAP_CC0402_0.1UF | 0.1uF | CC0402 |
C21 | CAP_CC0402_27PF | 27pF | CC0402 |
C22 | CAP_CC0402_0.1UF | 0.1uF | CC0402 |
C23 | CAP_CC0402_0.1UF | 0.1uF | CC0402 |
C24 | C_CC0402_4.7UF | 4.7uF | CC0402 |
C25 | CAP_CC0402_27PF | 27pF | CC0402 |
C26 | CAP_CC0402_27PF | 27pF | CC0402 |
C27 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C28 | C_CC0402_4.7UF | 4.7uF | CC0402 |
C29 | C_CC0402_4.7UF | 4.7uF | CC0402 |
C30 | C_CC0402_0.1UF | 0.1uF | CC0402 |
C31 | CAP_CC0402_27PF | 27pF | CC0402 |
C32 | CAP_CC0402_33000 PF | 33000 pF | CC0402 |
C33 | CAP_CC0805_10UF | 10uF | CC0805 |
C34 | CAP_CC0402_15PF | 15pF | CC0402 |
C35 | CAP_CC0805_10UF | 10uF | CC0805 |
C36 | CAP_POL_TANT_1206_100UF | 100 uF | TANT_1206 |
D1 | LED_LED_0603_ | | LED_0603 |
D2 | LED_LED_0603_ | | LED_0603 |
D3 | LED_LED_0603_LED | LED | LED_0603 |
D4 | MBR130_SOD-123_2P_SOD_123FL_MBR | MBR130_SOD-123_2P | SOD_123FL |
D5 | MBR130_SOD-123_2P_SOD_123FL_MBR | MBR130_SOD-123_2P | SOD_123FL |
FB1 | FERRITE_BEAD_INDC0805_FB | FB | INDC0805 |
FB2 | FERRITE_BEAD_INDC0805_FB | FB | INDC0805 |
FB3 | FERRITE_BEAD_INDC0805_FB | FB | INDC0805 |
FB4 | FERRITE_BEAD_INDC0805_FB | FB | INDC0805 |
J1 | HEADER_1X2_HDR_THVT_1X2_100_M_H | HEADER_2 | HDR_THVT_1X2_100_M |
J2 | HEADER_1X2_HDR_THVT_1X2_100_M_H | HEADER_2 | HDR_THVT_1X2_100_M |
J3 | HEADER_3_HDR_THVT_1X3_100_M_HEA | HEADER_3 | HDR_THVT_1X3_100_M |
J4 | HEADER_1X2_HDR_THVT_1X2_100_M_H | HEADER_2 | HDR_THVT_1X2_100_M |
J5 | CONN_MICRO_USB_5P_6G_FCI_101181 | CONN_MICRO_USB | FCI_10118194-0001 |
J6 | CONN_MICRO_USB_5P_6G_FCI_101181 | CONN_MICRO_USB | FCI_10118194-0001 |
J7 | CONN_RCPT_0_HDR_THVT_2X10_100_F | CONN_RCPT_10x2 | HDR_THVT_2X10_100_F |
J8 | CONN_RCPT_0_HDR_THVT_2X10_100_F | CONN_RCPT_10x2 | HDR_THVT_2X10_100_F |
J22 | HEADER_1X2_HDR_THVT_1X2_100_M_H | HEADER_2 | HDR_THVT_1X2_100_M |
R1 | RESISTOR_RC0603_0.1 | 0.1 | RC0603 |
R2 | R_RC0402_33 | 33 | RC0402 |
R3 | R_RC0402_33 | 33 | RC0402 |
R4 | R_RC0402_100K | 100k | RC0402 |
R5 | R_RC0402_100K | 100k | RC0402 |
R6 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R7 | RESISTOR_RC0402_10K | 10k | RC0402 |
R8 | R_RC0402_33 | 33 | RC0402 |
R9 | R_RC0402_33 | 33 | RC0402 |
R10 | R_RC0402_33 | 33 | RC0402 |
R11 | R_RC0402_33 | 33 | RC0402 |
R12 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R13 | RESISTOR_RC0402_10K | 10k | RC0402 |
R14 | RESISTOR_RC0402_10K | 10k | RC0402 |
R15 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R16 | R_RC0402_33 | 33 | RC0402 |
R17 | R_RC0402_33 | 33 | RC0402 |
R18 | R_RC0402_100K | 100k | RC0402 |
R19 | R_RC0402_100K | 100k | RC0402 |
R20 | RESISTOR_RC0402_10K | 10k | RC0402 |
R21 | R_RC0402_33 | 33 | RC0402 |
R22 | R_RC0402_100K | 100k | RC0402 |
R23 | R_RC0402_100K | 100k | RC0402 |
R24 | RESISTOR_RC0603_330 | 330 | RC0603 |
R25 | RESISTOR_RC0603_330 | 330 | RC0603 |
R26 | R_RC0402_100K | 100k | RC0402 |
R29 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R30 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R31 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R32 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R33 | RESISTOR_RC0402_10K | 10k | RC0402 |
R34 | R_RC0402_33 | 33 | RC0402 |
R35 | R_RC0402_33 | 33 | RC0402 |
R36 | R_RC0402_100K | 100k | RC0402 |
R37 | R_RC0402_100K | 100k | RC0402 |
R38 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R39 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R40 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R41 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R42 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R43 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R44 | RESISTOR_RC0402_2.2K | 2.2K | RC0402 |
R45 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R46 | RESISTOR_RC0402_10K | 10k | RC0402 |
R47 | RESISTOR_RC0402_10K | 10k | RC0402 |
R48 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R49 | RESISTOR_RC0402_10K | 10k | RC0402 |
R50 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R51 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R52 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R53 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R54 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R55 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R56 | RESISTOR_RC0402_2.2K | 2.2K | RC0402 |
R57 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R58 | RESISTOR_RC0402_10K | 10k | RC0402 |
R59 | RESISTOR_RC0402_10K | 10k | RC0402 |
R60 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R61 | RESISTOR_RC0402_10K | 10k | RC0402 |
R62 | RESISTOR_RC0402_10K | 10k | RC0402 |
R63 | RESISTOR_RC0402_0 R | 0 R | RC0402 |
R64 | RESISTOR_RC0402_1K | 1K | RC0402 |
R65 | RESISTOR_RC0402_12K | 12K | RC0402 |
R66 | RESISTOR_RC0402_470 | 470 | RC0402 |
R67 | RESISTOR_RC0402_2.2K | 2.2K | RC0402 |
R68 | RESISTOR_RC0402_10K | 10k | RC0402 |
R69 | RESISTOR_RC0603_270 | 270 | RC0603 |
R70 | RESISTOR_RC0402_30.1K | 30.1K | RC0402 |
R71 | RESISTOR_RC0402_28 | 28 | RC0402 |
R72 | RESISTOR_RC0402_28 | 28 | RC0402 |
R73 | RESISTOR_RC0402_51K | 51K | RC0402 |
R74 | R_RC0402_DNP | DNP | RC0402 |
R75 | R_RC0402_DNP | DNP | RC0402 |
TP1 | TP_SMD_RND_0P5MM_TP_SMD_RND_0P5 | SMD | TP_SMD_RND_0P5MM |
TP2 | TP_SMD_RND_0P5MM_TP_SMD_RND_0P5 | SMD | TP_SMD_RND_0P5MM |
TP3 | TP_1206_TP_RCW1206_TP_1206 | TP_1206 | TP_RCW1206 |
U1 | SN74AVC4T245PW_TSSOP_16_201X177 | SN74AVC4T245PW | TSSOP_16_201X177_26 |
U2 | SN74AVC4T245PW_TSSOP_16_201X177 | SN74AVC4T245PW | TSSOP_16_201X177_26 |
U3 | SN74AVC4T245PW_TSSOP_16_201X177 | SN74AVC4T245PW | TSSOP_16_201X177_26 |
U4 | SN74AVC4T245PW_TSSOP_16_201X177 | SN74AVC4T245PW | TSSOP_16_201X177_26 |
U5 | EEPROM-93C46B_4_TI_MSOP8_0P65_3 | 93LC46B-I/MS | TI_MSOP8_0P65_3 |
U6 | SN74AVC4T245PW_TSSOP_16_201X177 | SN74AVC4T245PW | TSSOP_16_201X177_26 |
U7 | FT4232H_TI_IC_LQFP64_0P5_10X10_ | FT4232H | TI_IC_LQFP64_0P5_10X10 |
U8 | EEPROM-93C46B_4_TI_MSOP8_0P65_3 | 93LC46B-I/MS | TI_MSOP8_0P65_3 |
U9 | FT2232_LQFP_48P_QFP_48_284X284_ | FT2232D | QFP_48_284X284_20 |
U10 | TPS79601_SOT-223_6P_SOT_223_6_T | TPS79601 | SOT_223_6_TG |
Y1 | ZTA_0_TI_XTAL4_ECS-53B_ECS-120- | ECS-120-20-30B-TR | TI_XTAL4_ECS-53B |
Y2 | CRYSTAL_XTAL_2P_TH_1P1MMP_CRYST | CRYSTAL | XTAL_2P_TH_1P1MMP |
