重要提示:PCB作品文件展下载说明
REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | CW13 | C0402 | 103P | C0402 | D1 | SOD323 | RB551V-30 | SOD323 | D7 | D0603-4148 | TS4148C | D0603-4148 | D8 | D0603-4148 | TS4148C | D0603-4148 | D21 | D0603-4148 | TS4148C | D0603-4148 | D22 | D0603-4148 | TS4148C | D0603-4148 | D23 | D-SOD323 | LRB751V-40 | D-SOD323 | D25 | D-SMA | SS34AF | D-SMA | D27 | SOD523 | IN4148WT | SOD523 | D28 | DLED0603 | GREEN-LED | DLED0603 | D29 | DLED0603 | GREEN-LED | DLED0603 | FB18 | L0805 | CBW160808U310 | L0805 | J21 | SIP-4P-1_25_SMD | SIP_4P_1P25_SMD | SIP-4P-1_25_SMD | J23 | FPC40P_0_5MM | FPC-0_5-JX-40PWT | FPC40P_0_5MM | JP18 | SIP_2P_200 | 1X2P_2.0M | SIP_2P_200 | L14 | L0603 | CBW160808U101 | L0603 | L15 | L0603 | CBW160808U101 | L0603 | L17 | L0603 | CBW160808U101 | L0603 | L18 | L0603 | CBW160808U101 | L0603 | L74 | L0603 | CBW160808U101 | L0603 | L75 | L0603 | CBW160808U101 | L0603 | L80 | L3015 | VLS3015ET-4R7M | L3015 | L81 | L3015 | VLS3015ET-4R7M | L3015 | L82 | L3015 | VLS3015ET-4R7M | L3015 | L92 | L3015 | VLS3015ET-4R7M | L3015 | P1 | PTHOLE2_3MM | PTHOLE2_3MM | PTHOLE2_3MM | P2 | PTHOLE2_3MM | PTHOLE2_3MM | PTHOLE2_3MM | P3 | PTHOLE2_3MM | PTHOLE2_3MM | PTHOLE2_3MM | P4 | PTHOLE2_3MM | PTHOLE2_3MM | PTHOLE2_3MM | Q2 | SOT23-3 | SK2301 | SOT23-3 | Q3 | SOT23-3 | 2N7002PT | SOT23-3 | Q5 | SOT23-3 | 2N7002PT | SOT23-3 | Q6 | SOT23-3 | 2N7002PT | SOT23-3 | SW1 | SW_HDS404 | YED-04CT | SW_HDS404 | SW5 | SW_HDS404 | YED-04CT | SW_HDS404 | TP17 | SIP_1P | TP_2.54 | SIP_1P | U1 | BGA256_065_12X12 | GM8139_TFBGA256 | BGA256_065_12X12 | U2 | SOT23 | G691L293T73U | SOT23 | U3 | FBGA_X16_9X13P3 | K4B2G1646B-HCK0-1600_2G | FBGA_X16_9X13P3 | U4 | FBGA_X16_9X13P3 | K4B2G1646B-HCK0-1600_2G | FBGA_X16_9X13P3 | U5 | PG-TSLP-9-1 | ESD5V3U4U-HDMI | PG-TSLP-9-1 | U6 | SOIC8_208 | W25Q128FV | SOIC8_208 | U9 | SOT25 | NC | SOT25 | U18 | SOT23 | S-1206B28-M3T1S | SOT23 | U20 | SOT23 | S-1206B18-M3T1S | SOT23 | U25 | PG-TSLP-9-1 | ESD5V3U4U-HDMI | PG-TSLP-9-1 | U26 | HDMI-A-TYPE | HDMI-19P | HDMI-A-TYPE | U27 | PG-TSLP-9-1 | ESD5V3U4U-HDMI | PG-TSLP-9-1 | U28 | IC-LQFP128 | EP9555E | IC-LQFP128 | U33 | SOT23-5 | AP2171WG | SOT23-5 | U39 | SOT23-6 | TPS562200DDCR | SOT23-6 | U53 | SIP-4P-1_25_SMD | SIP_4P_1P25_SMD | SIP-4P-1_25_SMD | U54 | SIP-4P-1_25_SMD | SIP_4P_1P25_SMD | SIP-4P-1_25_SMD | U55 | MICRO_USB_180 | MICRO_USB_180 | MICRO_USB_180 | U63 | SOT23-6 | TPS562200DDCR | SOT23-6 | U64 | SOT23-6 | TPS562200DDCR | SOT23-6 | U74 | SOT23-6 | TPS562200DDCR | SOT23-6 | Y1 | XTAL_SMD_50X32 | 30MHz | XTAL_SMD_50X32 | Y4 | OSC-3225 | 24MHz/20P/10PPM | OSC-3225 |
重要提示:PCB作品文件展下载说明
