[PADS格式] MN101EF51A+TDA7388 +SGM9119 车载主板原理图共享 PADS logic格式
查看2657 | 回复6 | 2017-6-21 11:45:24 | 显示全部楼层 |阅读模式
PADS9.5格式的
没有PCB文件, 为了避免大家下载到没用的。所以把使用到的元件贴出来。有需要的下载。
NamePart TypePCB DecalValue
ANT96ANT2ANT-CANT
CN1CON4_54P/1.25MMCON4
CN2CON4_54P/1.25MMCON4
CN3CN50P_HSDCN50PA05TAINNOLUX TFT
CON1CON-SMT-60PIN-HANNSTARFPC-60PIN-0.5MM
D1DIODEDIODE_DO201AD_7MMIN5401
D2TVSSTVS0603ESD
D3TVSSTVS0603NC
D4DSSD2010SS14
D5DIODESD0805IN4148W
D6DIODESD0805IN4148W
D8DSSD2010SS14
D9BAT54CSOT23-BAT54BAT54C
D10TVSSTVS06030603ESDA-LP
D11TVSSTVS06030603ESDA-LC
D12DIODESD0805IN4148W
D13TVSSTVS06030603ESDA-LP
D15BAT54CSOT23-BAT54BAT54C
D16DIODE_DIACESD0603ESD
D17DIODE_DIACESD0603ESD
D21TVSSTVS06030603ESDA-LC
D23TVSSTVS06030603ESDA-LC
D24TVSSTVS06030603ESDA-LC
D26DIODE_DIACESD0603ESD
D27TVSSTVS0603ESD
D28DIODE_DIACESD0603ESD
D30DIODESD08051N4148
D31DIODESD08051N4148
F1FUSESF1308500MA
F2FUSESF1308500MA
F3FUSESF1308500MA
F4FUSESF1308200MA
FB1INDUCTOR_0_2RES0805600R
FB2INDUCTOR_0L0603600R
FB3FBL0805SZ2012K421TF
FB4FBSLB0805SZ2012K601TF
FB5FBL0805FB310
FB8FBSLB0805SZ2012K601TF
FB11INDUCTOR_0_2RES0805600R
FB12INDUCTOR_0L0603600R
FB13FBL0805SZ2012K421TF
J1JACK-26PINJACK-26PINAAA
J2DDTAP
J3FM-4750DIP-10PIN-FMTDQ-30FMV-001
J5DDTAP
J6CON-4PIN-IPODSIP4-78D74-32DUSB_JK CON
J7DDTAP
J8DDTAP
L1FBSL08051.8uH
L2INDL-5X510uH/1.6A
L3FBSL08051.8uH
L4IND_18X25MML-13/2535mH非晶呃流线圈
L5INDL-5X510uH/1.6A
L6FBSL08051.8uH
L7INDUCTOR/CHIPCF2522NC
L15CD74IND-SMT-CD7522UH
L21INDUCTOR/CHIPIND-SMD-CDH8B28/38/43/58NC
L51FBSL08051.8uH
Q1NPNSOT239014
Q2NPNSOT239014
Q3NPNSOT239014
Q4PNPSOT238550
Q5NPNSOT239014
Q6PNPSOT238550
Q7PMOSSOT23-MOSDMP3098L
Q8NPNSOT898050
Q9NPNSOT239014
Q10PMOSSOT23-MOSDMP3098L
Q11PMOSSOT23-MOSDMP3098L
Q12NPNSOT239014
Q13NPNSOT239014
Q14NPNSOT233904
Q15PNPSOT23MMBT3906
Q16PNPSOT238550
Q17NPNSOT239014
Q18NPNSOT239014
Q19NPNSOT239014
Q20NPNSOT23MMBT3904
Q21NPNSOT233904
Q23PMOSSOT23-MOSDMP3098L
Q24NPNSOT233904
Q25PNPSOT238550
Q26PNPSOT238550
Q27PMOSSOT23-MOSDMP3098L
Q28NPNSOT239014
SC2SCREW-2.6-3.0MMSCREW-2.6MM-4
SC3SCREW-2.6-3.0MMSCREW-2.6MM-4
SC4SCREW-2.6-3.0MMSCREW-2.6MM-4
TP1TP-2TEST-1.0TP-2
TP2TP-2TEST-1.0TP-2
TP3MARKMARKMARK
TP4MARKMARKMARK
TP5MARKMARKMARK
TP7TP-2TEST-1.0TP-2
TP8TP-2TEST-1.0TP-2
TP9TP-2TEST-1.0TP-2
TP10TP-2TEST-1.0TP-2
TP114MARKMARKMARK
T]1JACK60PIN_2.0MMJACK_60PIN_2.0MM
U1MN101EF51A_1QFP44-31D5-472MN101EF51A
U2RT9164-33CG//AIC1117-33CY_0SOT2231117/3.3V
U3MTK_CON126_1.27MMMTK_CON126_1.27MM
U4SGM9119SOP8-25D59-197SGM9119
U6MP3302SOT23-5MP3302
U7MP1541SOT23-5MP1541
U878MXXTO-25278M08/NC
U11TDA7381_0TDA7386ATDA7388
U16HT7133SOT89-1HT7533
Z1DZSD0805-15.6V
Z2DZSD0805-15.6V
Z3DZSD0805-10R
Z4DZSD0805-1BZT52C9V1
Z5DIODESD0805IN4148W
Z6DZSD0805-1BZT52C15V
Z7DZSD0805-1BZT52C6V8
Z10DZSD0805-13V9
ZD4BAV99SOT23-BAV99BAT54S
ZD5BAV99SOT23-BAV99BAT54S
A6U(无碟)-V1.0.7z (85 KB, 下载次数: 13)
单枪舞九州 | 2017-6-21 13:36:43 | 显示全部楼层
友韵 | 2017-6-22 09:02:41 | 显示全部楼层
cybi1861 | 2019-5-28 22:04:02 | 显示全部楼层
dqh520 | 2019-7-1 00:10:40 | 显示全部楼层
hbjsss | 2019-7-1 08:58:42 | 显示全部楼层
sxbjlxy | 2019-7-8 14:59:37 | 显示全部楼层
