[Allegro16.6以下] A20开发板底板PCB FT5206GE1+GSL1680F+JM20329+RTL8211E-VB-CG
查看9438 | 回复40 | 2017-7-9 13:01:59 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
10D1DIODE_SCHOTTKY_SOD123_1N4148WS1N4148WSSOD123
10D2DIODE_SCHOTTKY_SOD123_1N4148WS1N4148WSSOD123
10R1R_R0402_47K47KR0402
ANT1T_POINT_R_3_CHIPANTENNA-3_NC/AANC/AA077-BCHIPANTENNA-3
B1SPEAKER_BUZZERC9-5L-5_5DRA_BUZZBUZZEBUZZERC9-5L-5_5DRA
C2CAPNP_2_C1206_22UF/10V22uF/10VC1206
C4CAP NP_C0603_4U74u7C0603
CN1CON30_CON30-PT05-H2A_CTP/FPC30XCTP/FPC30x-0_5mmCON30-PT05-H2A
CN6CON2-4_SIP-2P-2_54-B_ASIP2-2.54ASIP2-2.54MMSIP-2P-2_54-B
CN7CON2_1_ASIP4_CON04CON04ASIP4
CN9CONZ30-2MM54_CONZ-30-2_0_CONZ15CONZ15x2-2mmCONZ-30-2_0
CN10CONZ24-2MM54_CONZ-24-2_0_NC/CONNC/CON-12x2-2mmCONZ-24-2_0
CN11CONZ30-2MM54_1_CONZ-36-2_0_NC/CNC/CONZ18x2-2mmCONZ-36-2_0
CN12CONZ24-2MM54_CONZ-24-2_0_NC/CONNC/CON-12x2-2mmCONZ-24-2_0
CN13CONZ30-2MM54_CONZ-30-2_0_CONZ15CONZ15x2-2mmCONZ-30-2_0
CN15CON2-4_2_A1250WF-2P-1_25-A_NC/ANC/A1250WF-2PA1250WF-2P-1_25-A
CN37CON2_0_CON-1X3-1_25H4_2_WAFE-3XWAFE-3x1_25mmCON-1X3-1_25H4_2
CON1AT070TN93_0_FPC50PIN-0_5H2B_FPCFPC50x0.5MMFPC50PIN-0_5H2B
D3D_0_SOD123_IN5819IN5819SOD123
D4DIODE_DUAL_SOT-23_BAT54SBAT54SSOT-23
D5DIODESCHOTTKY_0_SOD123_18V18VSOD123
D6DIODE_DUAL_SOT-23_BAT54SBAT54SSOT-23
D7DIODESCHOTTKY_0_SOD123_6V26V2SOD123
D8D_0_SOD123_IN5819IN5819SOD123
D14LED_LED-0805_BLUEBLUELED-0805
D29DIODESCHOTTKY_DO-214AC_SS34SS34DO-214AC
D44DIODE_SCHOTTKY_0_DO-214AC_SS34SS34DO-214AC
D551N4148_4_DO-214AC_NC/SS34NC/SS34DO-214AC
D57DIODE_SCHOTTKY_0_DO-214AC_SS34SS34DO-214AC
D60DIODESCHOTTKY_DO-214AC_SS34SS34DO-214AC
D611N4148_4_DO-214AC_NC/SS34NC/SS34DO-214AC
DCLKT_POINT_R_TP_NCNCTP
DET_POINT_R_TP_NCNCTP
DITHBT_POINT_R_TP_NCNCTP
ESD1DIODE_SCHOTTKY_0_SOD-523_AU0551AU0551D5SOD-523
ESD3RRCLAMP0524P_RCLAMP0524P_SEDFN0SEDFN05V4RCLAMP0524P
ESD4RRCLAMP0524P_RCLAMP0524P_SEDFN0SEDFN05V4RCLAMP0524P
ESD5RRCLAMP0524P_RCLAMP0524P_SEDFN0SEDFN05V4RCLAMP0524P
ESD6DIODE TVSLC_2_ESD0402_ULCE0505ULCE0505A015FRESD0402
ESD7DIODE TVSLC_2_ESD0402_ULCE0505ULCE0505A015FRESD0402
ESD8DIODE TVSLC_2_ESD0402_ULCE0505ULCE0505A015FRESD0402
ESD9DIODE TVSLC_2_ESD0402_ULCE0505ULCE0505A015FRESD0402
ESD10DIODE TVSLC_2_ESD0402_ULCE0505ULCE0505A015FRESD0402
ESD11DIODE TVSLC_2_ESD0402_ULCE0505ULCE0505A015FRESD0402
ESD12DIODE_SCHOTTKY_0_ESD0402_AU0511AU0511P1ESD0402
ESD13DIODE TVSLC_2_ESD0402_ULCE0505ULCE0505A015FRESD0402
ESD14DIODE TVSLC_2_ESD0402_ULCE0505ULCE0505A015FRESD0402
ESD16DIODE TVSLC_2_ESD0402_ULCE0505ULCE0505A015FRESD0402
ESD17DIODE TVSLC_2_ESD0402_ULCE0505ULCE0505A015FRESD0402
ESD18DIODE_SCHOTTKY_0_ESD0402_AU0511AU0511P1ESD0402
ESD19DIODE TVSLC_2_ESD0402_ULCE0505ULCE0505A015FRESD0402
ESD20DIODE TVSLC_2_ESD0402_ULCE0505ULCE0505A015FRESD0402
ESD22DIODE TVSLC_2_ESD0402_ULCE0505ULCE0505A015FRESD0402
ESD23DIODE TVSLC_2_ESD0402_ULCE0505ULCE0505A015FRESD0402
ESD30DIODE_SCHOTTKY_0_ESD0402_AU0511AU0511P1ESD0402
ESD31DIODE TVSLC_2_ESD0402_ULCE0505ULCE0505A015FRESD0402
ESD64DIODE_SCHOTTKY_0_ESD0402_AU0511AU0511P1ESD0402
FUSE1RESISTOR_0_F1206_4A-5V4A-5VF1206
GND1T_POINT_R_TP_NCNCTP
GND2T_POINT_R_TP_NCNCTP
GND3T_POINT_R_TP_NCNCTP
GND4T_POINT_R_TP_NCNCTP
GND5T_POINT_R_TP_NCNCTP
GND6T_POINT_R_TP_NCNCTP
HCON1HDMI19_PLUG_HDMI_TYPE_0_5_HDMI_HDMI_19plug type AHDMI_TYPE_0_5
HR1RESISTOR_R0402_NC/10KNC/10KR0402
HR2RESISTOR_R0402_NC/10KNC/10KR0402
HR3RESISTOR_R0402_10K10KR0402
HST_POINT_R_TP_NCNCTP
J2SDMMCSLOT_0_TF9P_MICROSD/TF_SLMICROSD/TF_SLOTTF9P
J6HP_JACK_6_PJ-327F_PHONEJACKPHONEJACKPJ-327F
J10USB_MINI_SOCKET_3_SIM-PUS_240_1SIM_SOCKETSIM-PUS_240_1826_08T8_H1_8
J14CON30_0_DIN-803-14X12_9L13_MIDIMIDI_JACKDIN-803-14X12_9L13
J15CON30_0_DIN-803-14X12_9L13_MIDIMIDI_JACKDIN-803-14X12_9L13
L4INDUCTOR_1_CD41_4.7UH/1.6A4.7uH/1.6ACD41
L5INDUCTOR_CD41_10UH10uHCD41
L6INDUCTOR_CD41_10UH10uHCD41
L7R-PACK4_1_L0805X2_WLMCM2012B900WLMCM2012B900FBPL0805X2
L8R-PACK4_1_L0805X2_WLMCM2012B900WLMCM2012B900FBPL0805X2
L9R-PACK4_1_L0805X2_WLMCM2012B900WLMCM2012B900FBPL0805X2
L10R-PACK4_1_L0805X2_WLMCM2012B900WLMCM2012B900FBPL0805X2
L12INDUCTOR_4_CD41_4.7UH/1.6A4.7uH/1.6ACD41
L13R-PACK4_1_L0805X2_WLMCM2012B900WLMCM2012B900FBPL0805X2
L14R-PACK4_1_L0805X2_WLMCM2012B900WLMCM2012B900FBPL0805X2
L19INDUCTOR_4_R0402_NC/2.7UHNC/2.7uHR0402
L20INDUCTOR_0805_CD21_4.7UH/600MA4.7uH/600mACD21
L26INDUCTOR_CDH5250_4.7UH4.7uHCDH5250
L27INDUCTOR_CDH5250_4.7UH4.7uHCDH5250
L42INDUCTORX4_2_RN0402_ICMF214P101ICMF214P101MFRRN0402
L67R-PACK4_1_L0805X2_WLMCM2012B900WLMCM2012B900FBPL0805X2
L68R-PACK4_1_L0805X2_WLMCM2012B900WLMCM2012B900FBPL0805X2
L69INDUCTORX4_2_RN0402_ICMF214P101ICMF214P101MFRRN0402
L70R-PACK4_1_L0805X2_WLMCM2012B900WLMCM2012B900FBPL0805X2
L71R-PACK4_1_L0805X2_WLMCM2012B900WLMCM2012B900FBPL0805X2
L72R-PACK4_1_L0805X2_WLMCM2012B900WLMCM2012B900FBPL0805X2
L73R-PACK4_1_L0805X2_WLMCM2012B900WLMCM2012B900FBPL0805X2
LCD-AVDDT_POINT_R_TP_NCNCTP
LCD-VCCT_POINT_R_TP_NCNCTP
LED3LED_1_LED-2-5X9X10_LED_RED_GREELED_RED_GREENLED-2-5X9X10
LSR1RESISTOR_R0402_33K33KR0402
M1T_POINT_R_HOLE130D100_NC/M-VIANC/M-viaHOLE130D100
M2T_POINT_R_HOLE130D100_NC/M-VIANC/M-viaHOLE130D100
M3T_POINT_R_HOLE130D100_NC/M-VIANC/M-viaHOLE130D100
M4T_POINT_R_HOLE130D100_NC/M-VIANC/M-viaHOLE130D100
M5T_POINT_R_HOLE130D100_NC/M-VIANC/M-viaHOLE130D100
M6T_POINT_R_HOLE130D100_NC/M-VIANC/M-viaHOLE130D100
MIC1MICPHONE_MIC45_MICPHONEMicphoneMIC45
MODET_POINT_R_TP_NCNCTP
P2RJ45_2_USB-A-DULE-H_USB-A-DULEUSB-A-DULEUSB-A-DULE-H
P3RJ45_2_USB-A-DULE-H_USB-A-DULEUSB-A-DULEUSB-A-DULE-H
P5RJ45_2_USB-A-DULE-H_USB-A-DULEUSB-A-DULEUSB-A-DULE-H
P9PHONEJACK_DCIN_0_DC-030_DC-JACKDC-JACKDC-030
P10MSATA_0_MINIPCIE-FEMALE-SMT52-DmSATAMINIPCIE-FEMALE-SMT52-D
Q5PMOS_SOT-23_AO3423AO3423SOT-23
Q6NPN_SOT-23_MMBT3904MMBT3904SOT-23
Q7PMOS_SOT-23_AO3423AO3423SOT-23
Q21WPM4005_0_SOP8_AO4435AO4435SOP8
Q22NPN_SOT-23_NC/MMBT3904NC/MMBT3904SOT-23
Q23PMOS_SOT-23_NC/AO3423NC/AO3423SOT-23
Q36NPN_0_SOT-23_MMBT3904MMBT3904SOT-23
Q37NPN_0_SOT-23_MMBT3904MMBT3904SOT-23
Q38NPN_0_SOT-23_MMBT3904MMBT3904SOT-23
Q39WPM4005_0_SOP8_AO4435AO4435SOP8
Q44NPN_SOT-23_MMBT3904MMBT3904SOT-23
Q452N3904SOT23_SOT-23_MMBT3904MMBT3904SOT-23
RESETT_POINT_R_TP_NCNCTP
RN1R-PACK4_1_RN0402_ICMF214P101MFRICMF214P101MFRRN0402
RN2R-PACK4_1_RN0402_ICMF214P101MFRICMF214P101MFRRN0402
RN3R-PACK4_1_RN0402_ICMF214P101MFRICMF214P101MFRRN0402
RN4R-PACK4_1_RN0402_ICMF214P101MFRICMF214P101MFRRN0402
RN5R-PACK4_1_RN0402_22R*422R*4RN0402
RN6R-PACK4_1_RN0402_ICMF214P101MFRICMF214P101MFRRN0402
SPKLSPEAKER_CON2-3H0_8A_NC/SPEAKERNC/SPEAKERCON2-3H0_8A
SW1SW_PUSH_0_SW-6X6-DIP_PWRONPWRONSW-6X6-DIP
SW3SW_PUSH_1_SW4-SKQG-5_2X5_2H1_5AUBOOTSW4-SKQG-5_2X5_2H1_5A
SW4SW_PUSH_1_SW4-SKQG-5_2X5_2H1__1RSTSW4-SKQG-5_2X5_2H1_5A
U2SW2001_0_SOT23-6_NC/SW2001NC/SW2001SOT23-6
U6AP3019_0_SOT23-6_SY7200ASY7200ASOT23-6
U7AP3031_0_SOT23-6_SY7200ASY7200ASOT23-6
U8AW1612_2_QFN41-5X5-04_GSL1680FGSL1680FQFN41-5X5-04
U9FT5206QFN40_3_QFN41-5X5-04_NC/NC/FT5206GE1QFN41-5X5-04
U10LD1117-33_1_SOT23-5_TCS2108-2V5TCS2108-2V5SOT23-5
U12AT24C16B_SOIC-8-150MIL_NC/AT24CNC/AT24C04SOIC-8-150MIL
U13RT9266PE_2_SOT23-5_SY6280SY6280SOT23-5
U15RTL8169S_0_QFN49-8211E_RTL8211ERTL8211E-VB-CGQFN49-8211E
U16RT9266PE_2_SOT23-5_SY6280SY6280SOT23-5
U21RT9266PE_2_SOT23-5_SY6280SY6280SOT23-5
U26G5725_SOT23-5_TCS4122TCS4122SOT23-5
U31JM20329_LQFP48_0_LQFP48_FE2_1FE2_1LQFP48
U43RCLAMP0504F_0_SOP10-PT0_5-3X3H0RT9297SOP10-PT0_5-3X3H0_8A
U89G5725_SOT23-5_TCS4122TCS4122SOT23-5
U90IR_MODULE_IR-DIP_HS0038BHS0038BIR-DIP
U92LY8006_MSOP-8_LM4890LM4890MSOP-8
U93RCLAMP0504F_0_SOP10-PT0_5-3X3H0RT9297SOP10-PT0_5-3X3H0_8A
U97EP89_2_MINIPCIE-FEMALE-SMT52-D_MINI PCI E H9 /MF210/U8300CMINIPCIE-FEMALE-SMT52-D
U98WPM4005_4_SOP8_PL2303SAPL2303SASOP8
U99MAX3232_2_SOP16-4X10PT1_27H1_75MAX3232SOP16-4X10PT1_27H1_75A
U100MAX3232_2_SOP16-4X10PT1_27H1_75MAX3232SOP16-4X10PT1_27H1_75A
U101EINSTAIN-A20_MOD_200-PT1_2PIN-TEinstain-A20MOD_200-PT1_2PIN-TOP
U102HR911130C-GRJ45_1_HY911130C-DIPHR911130CHY911130C-DIP
UDT_POINT_R_TP_NCNCTP
USB2USB_MINI_SOCKET_0_USB-109-16_5XUSB-B-109USB-109-16_5X12L11_2
VST_POINT_R_TP_NCNCTP
X3CRYSTAL-4_3_CRY-TSX3225_12M12MCRY-TSX3225
X5CRYSTAL-4_4_CRY-TSX3225_25M25MCRY-TSX3225
A20_MB.7z (2.09 MB, 下载次数: 20)
重要提示:PCB作品文件展下载说明
暑假期间,免费代管18-28岁小孩,限女性。
带刀的老鼠 | 2017-7-9 13:23:07 | 显示全部楼层
zhoujian198909 | 2017-7-9 13:48:16 | 显示全部楼层
cdl511 | 2017-7-9 15:05:19 | 显示全部楼层
xnima_irumei | 2017-7-9 16:01:31 | 显示全部楼层
地沟油 | 2017-7-9 17:30:07 | 显示全部楼层
hf861004 | 2017-7-9 21:03:07 | 显示全部楼层
gyj82117 | 2017-7-10 06:36:00 | 显示全部楼层
jag6510 | 2017-7-10 07:57:07 | 显示全部楼层
单枪舞九州 | 2017-7-10 07:59:58 | 显示全部楼层
长期免费代管18-28岁小
