重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | D1 | SOD123 | 1N5819 | SOD123 | D3 | SOD323_1 | 1N4148 | SOD323 | D7 | SOD323_1 | NC/1N4148 | SOD323 | D8 | SOD123 | NC/1N5819 | SOD123 | D9 | SOD128 | NC/1N5819 | SOD128 | D10 | SOT23_5 | BAT54C | SOT23 | D11 | SOD123 | 1N5819 | SOD123 | D14 | SOD80 | 18V | SOD80 | D15 | SOD80 | 7.5V | SOD80 | D19 | SOT23_5 | BAT54S | SOT23 | D24 | SOT23_5 | BAT54S | SOT23 | D26 | SOT23_5 | BAT54C | SOT23 | EC3 | C0603_2 | 22UF/4V | C0603 | EC4 | C0603_2 | 22UF/4V | C0603 | ED3 | E0402N_6 | ESD9B5V | E0402N | ED5 | E0402N_6 | NC/ESD9B5V | E0402N | FB2 | L0603 | FB180R | L0603 | FB4 | L0603 | FB180R | L0603 | J1 | CON50P_0D5MM | HSD070IDW1-A20 | CON50P_0D5MM | J2 | TF-CARD | TF_SD_SOCKET | TF-CARD | J3 | 757DC-B | DC-1520-A | 757DC-B | J9 | CON_05MM_24P | OV2659 | CON_05MM_24P | J11 | PJ-311A | 2SJ2271 | PJ-311A | J12 | FPC40-R-0.5A | NC | FPC40-R-0.5A | J13 | MICRO_USB_NJ2A | USB_JACK | MICRO_USB_NJ2 | J14 | FPC40-R-0.5A | NC | FPC40-R-0.5A | J25 | R1206 | SPEAK1 | R1206 | J28 | R1210 | BACKLIGHT | R1210 | J29 | WIFIANT | ANT1 | WIFIANT | J30 | WIFIANT | ANT1 | WIFIANT | L1 | IND_4X4&3X3 | 4.7UH/1.5A | IND_4X4&3X3 | L9 | IND_4X4&3X3 | 10UH/1.5A | IND_4X4&3X3 | L14 | IND_4X4&3X3 | 10UH/1.5A | IND_4X4&3X3 | L17 | IND_4X4&3X3 | NC/3.3UH/1A | IND_4X4&3X3 | L18 | IND_4X4&3X3 | 2.2UH/2A | IND_4X4&3X3 | L19 | IND_4X4&3X3 | 2.2UH/1.5A | IND_4X4&3X3 | L20 | L0402 | NC | L0402 | L21 | IND_4X4&3X3 | 2.2UH/1.5A | IND_4X4&3X3 | L22 | L0402 | NC | L0402 | L24 | L0402 | NC | L0402 | L25 | L0402 | NC | L0402 | L27 | L0402 | NC | L0402 | L36 | L0603 | FB180R | L0603 | MIC3 | MIC_4020 | MIC | MIC_4020 | Q1 | SOT23_5 | 8050 | SOT23 | Q6 | SOT23_5 | NC/SI2305 | SOT23 | Q10 | SOT23_5 | WPM2026 | SOT23 | Q13 | SOT23_5 | WPM2026 | SOT23 | Q14 | SOT23_5 | 8050 | SOT23 | Q15 | SOT23_5 | 8050 | SOT23 | Q31 | SOT23_5 | NC/WPM2026 | SOT23 | SW3 | SW8 | VOL+(RECOVER) | SW8 | SW4 | SW8 | VOL- | SW8 | SW9 | SW8 | POWER | SW8 | SW10 | SW-PB3 | RESET | SW-PB3 | T4 | MARK_3 | RTCK | MARK | T5 | MARK_3 | RTCK | MARK | T6 | MARK_3 | RTCK | MARK | T7 | MARK_3 | RTCK | MARK | U1 | LQFP176_16X16B | MCU_RK2926 | LQFP176_16X16B | U3 | FBGA96-10X14B | DDR3_256M_16BIT | FBGA96-10X14 | U4 | TSOP1_48 | NAND_FLASH | TSOP1_48 | U5 | SOT26_2 | AP2004H | SOT26 | U6 | FBGA96-10X14B | DDR3_256M_16BIT | FBGA96-10X14 | U7 | SOT25_1 | AP1610 | SOT25 | U8 | MSOP8 | HYM8563 | MSOP8 | U9 | QFN32 | ESP8089 | ESP8080_7 | U12 | MMA7660FC | STK8312 | MMA7660FC | U13 | MSOP8 | TCS7191 | MSOP8 | U15 | SOT26_2 | AP3127B | SOT26 | U22 | SOT25_1 | NC/AP2415 | SOT25 | U24 | QFN40L | ACT8931A | QFN40L | U25 | SOT26_2 | TCS3354 | SOT26 | U28 | CON50P_0D5MM | LC070LF02CWXXLA | CON50P_0D5MM | U43 | LCC6 | NC/MXC6225XU | LCC6 | U45 | QFN52 | GSL3670 | QFN52 | U46 | EMMC_BGA153B | EMMC4G-BGA153 | EMMC_BGA153B | U80 | WIFI_8723AS | WIFI+BT | WIFI_8723AS | X1 | M49S-SMD | 24MHZ | M49S-SMD | X2 | M49S-SMD | 26MHZ | M49S-SMD | Y5 | CRY_MC146-B | nc/32.768KHZ-20PPM | CRY_MC146 | Y7 | CRY_2X6 | 32.768KHZ-20PPM | CRY_2X6 |
重要提示:PCB作品文件展下载说明
