重要提示:PCB作品文件展下载说明
6层PCB设计
Name | PCB Decal | Value | Part Type | ANT1 | ANT_JACK | ANT | ANT_JACK | ANT2 | ANT_JACK | ANT | ANT_JACK | CN1 | FPC4-1.2MM | FPC4-1.2MM | FPC4-1.2MM | D1 | DO214AC | PMEG3030 | DO214AC | D4 | SOT23 | BAT54C | SOT23 | D5 | DO214AC | MPEG3030 | DO214AC | D6 | SOT23 | BAT54C | SOT23 | D8 | SOD323 | 1N4148 | SOD323 | D9 | SOD323 | 1N4148 | SOD323 | D12 | SOD128 | PMEG3030EP | SOD128 | FB2 | L0603 | BLM18PG181SN1 | L0603 | J1 | DC-AJ420-X-S | DC12V | DC-AJ420-X-S | J2 | MICROUSB_DIP | HUM011D-5-S | MICROUSB_DIP | J7 | AJ302B-5-S | AJ302B-5-S | AJ302B-5-S | J8 | SPK-1206 | CON2 | SPK-1206 | J9 | SPK-1206 | CON2 | SPK-1206 | J11 | HDMI-19PF_C | NC | HDMI-19PF_C | J15 | UART-DEBUG | UART-DEBUG | UART-DEBUG | J17 | AJ752-B-S-51 | EDP_FLEX | AJ752-B-S-51 | J18 | D97-L3312A | D97-L3312A | D97-L3312A | L2 | IND-6X6 | 2.2UH/3A | IND-6X6 | L3 | IND-3X3 | 2.2UH/1.5A | IND-3X3 | L4 | IND-3X3 | 2.2UH/1.5A | IND-3X3 | L5 | IND-4X4 | 2.2UH/2A | IND-4X4 | L6 | IND-4X4 | 2.2UH/2A | IND-4X4 | L10 | IND-6X6 | 3.3UH/3A | IND-6X6 | L12 | L0402 | NC | L0402 | L13 | L0402 | NC | L0402 | L14 | IND-6X6 | 10UH/3A | IND-6X6 | L15 | L0402 | NC | L0402 | L16 | IND-3X3 | 2.2UH/1.5A | IND-3X3 | L17 | IND-3X3 | 2.2UH/1.5A | IND-3X3 | L18 | L0402 | NC | L0402 | L20 | IND-6X6 | 2.2UH/3A | IND-6X6 | L42 | L0603 | NC | L0603 | MIC1 | SMT_MIC | MIC-4020 | SMT_MIC | Q1 | SOT23 | 8050 | SOT23 | Q2 | SOT23 | WNM3003 | SOT23 | Q3 | SOT23 | WNM3003 | SOT23 | Q4 | SOT23 | WPM3407 | SOT23 | Q5 | SOT23 | 8050 | SOT23 | Q6 | SOT23 | 8050 | SOT23 | Q11 | SOT23 | 8050 | SOT23 | Q12 | SOT23 | WPM2341 | SOT23 | Q14 | SOT23 | NC | SOT23 | Q15 | SOT23 | NC | SOT23 | Q16 | SOT23 | WNM2021 | SOT23 | Q20 | SOT23 | WPM2341 | SOT23 | Q21 | SOT23 | 8050 | SOT23 | U1 | BGA453-19X19 | RK3066 | BGA453-19X19 | U2 | BGA78 | DDR3_256M_8BIT | BGA78 | U3 | BGA78 | DDR3_256M_8BIT | BGA78 | U4 | BGA78 | DDR3_256M_8BIT | BGA78 | U5 | BGA78 | DDR3_256M_8BIT | BGA78 | U6 | TSOP1-48 | NAND_FLASH_1 | TSOP1-48 | U7 | TSOP1-48 | NAND_FLASH_2 | TSOP1-48 | U9 | QFN24-3.5X5.5 | BQ24133 | QFN24-3.5X5.5 | U10 | SOT23 | NC | SOT23 | U11 | SOT23 | BP6212-21MMR | SOT23 | U13 | QFN81-8X8 | WM8326 | QFN81-8X8 | U16 | SOT25 | CD1612 | SOT25 | U17 | RL-UM12BS | NC | RL-UM12BS | U18 | QFN48-6X6 | ALC5631Q | QFN48-6X6 | U19 | SOT25 | SY8009B | SOT25 | U22 | TF-CKT01-009D_9.2 | TF_SD_SOCKET | TF-CKT01-009D_9.2 | U28 | QFN8-2X3 | MP3302 | QFN8-2X3 | U33 | LGA16 | LIS3DH/MMA8452Q | LGA16 | U36 | RK903 | RK903 | RK903 | U37 | BSM-24 | ZT300B1 | BSM-24 | U41 | QFN16-3X3 | TLV62130 | QFN16-3X3 | U47 | QFN-68X0.4 | CT363 | QFN-68X0.4 | U50 | SOT25 | NC | SOT25 | U55 | QFN16-3X3 | TLV62130 | QFN16-3X3 | U90 | MPU6050C | NC | MPU6050C | U91 | BGA81-8X8 | EPD_IC | BGA81-8X8 | Y1 | CRY-MC146 | 32.768K | CRY-MC146 | Y2 | CRY-D3225 | 24M-10PPM | CRY-D3225 | Y3 | CRY-D3225 | 26MHZ-10PPM | CRY-D3225 | Y4 | CRY-D3225 | 27M-10PPM | CRY-D3225 | ZD1 | SOD123 | NC | SOD123 |
重要提示:PCB作品文件展下载说明
