[Allegro16.6以下] 炬力ATM7029 +ATC2603+GL827+JMS562A1 平板PCB文件
查看4913 | 回复23 | 2017-8-29 09:56:36 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
D1DIODE-ESD_1_ESD0402_NC/ULCE0524NC/ULCE0524A015FRESD0402
D2DIODE BI-DIRTRIG_ESD0402_ULCE0ULCE0505A015FRESD0402
D3MLVS0402E10_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
D41N4148_4_TVS-SOD214A_1N58191N5819TVS-SOD214A
D5MLVS0402E10_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
D7RCLAMP0524P_0_RCLAMP0524P_SEDFNSEDFN05V4RCLAMP0524P
D8MLVS0402E10_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
D9MLVS0402E10_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
D10MLVS0402E10_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
D11RCLAMP0524P_1_RCLAMP0524P_SEDFNSEDFN05V4RCLAMP0524P
D12DIODE-ESD_1_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
D13DIODE-ESD_1_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
D14DIODE_SCHOTTKY_0_ESD0402_ULCE05ULCE0505A015FRESD0402
D15DIODE_SCHOTTKY_0_ESD0402_ULCE05ULCE0505A015FRESD0402
D16DIODE TVSLC_2_ESD0402_ULCE0505ULCE0505A015FRESD0402
D17DIODE TVSLC_2_ESD0402_ULCE0505ULCE0505A015FRESD0402
D18DIODE TVSLC_2_ESD0402_ULCE0505ULCE0505A015FRESD0402
D19DIODE TVSLC_2_ESD0402_ULCE0505ULCE0505A015FRESD0402
D20DIODE-ESD_1_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
D21DIODE-ESD_1_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
D22DIODE-ESD_1_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
D23MLVS0402E10_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
D24DIODE-ESD_1_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
D25MLVS0402E10_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
D26MLVS0402E10_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
D27MLVS0402E10_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
D28MLVS0402E10_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
D29MLVS0402E10_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
D30MLVS0402E10_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
D31MLVS0402E10_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
D32MLVS0402E10_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
ESD11_1.5KE100A_ESD0402_ULCE0505A01ULCE0505A015FRESD0402
FB1INDUCTOR_4_R0805_100Z(100M)100Z(100M)R0805
FB2INDUCTOR_0805_R0805_100R-100M100R-100MR0805
FB3INDUCTOR_4_R0603_120Z(100M)120Z(100M)R0603
FB4INDUCTOR_4_R0603_120Z(100M)120Z(100M)R0603
FB5L0805_0_L0603_600R-100M600R-100ML0603
FB6INDUCTOR_4_R0603_120Z(100M)120Z(100M)R0603
FB7INDUCTOR_4_R0603_0R0RR0603
IC1CAPACITOR_0_C0402_0.22UF0.22uFC0402
IC2CAPACITOR_0_C0402_1UF1uFC0402
IC3CAPACITORNON-POL_C0402_2.2UF 12.2uF 16VC0402
IC5CAP NP_5_C0402_1.8PF1.8pFC0402
IC6CAP NP_5_C0402_2.2PF2.2pFC0402
ID1DIODE TVSLC_2_ESD0402_NC/ULCE0NC/ULCE0505A015FRESD0402
IJ1CN_3_FPC20-PT05A_FPC24X0.5MMFPC24x0.5mmFPC20-PT05A
IJ2ANT3_0_CHIPANTENNA-3_ANTANTCHIPANTENNA-3
IL1INDUCTOR_8_R0402_2.2NH2.2nHR0402
IM9T_POINT_R_HOLE80CIR160D_M-VIAM-viaHOLE80CIR160D
IM10T_POINT_R_HOLE80CIR160D_M-VIAM-viaHOLE80CIR160D
IQ1PMOS_2_SOT23_AO3423AO3423SOT23
IQ2NPN_1_SOT23_2N39042N3904SOT23
IQ3NPN_1_SOT23_2N39042N3904SOT23
IU1IR_MODULE_1_SMT-IR-6_8X3H3_2_IRIR_MODULESMT-IR-6_8X3H3_2
IU2MMA7660FC_10_LED-3528-3_2X2_8H1RGBLEDLED-3528-3_2X2_8H1_9
IU5MMA7660FC_0_SOP16-4X10PT1_27H1_CD74AC238M96SOP16-4X10PT1_27H1_75A
IU9XC6219-SOT25_0_SOT23-5_TCS2015_TCS2015_E33/CL9193-33/XC6221B33MRSOT23-5
IU10MMA7660FC_10_LED-3528-3_2X2_8H1RGBLEDLED-3528-3_2X2_8H1_9
IU11MMA7660FC_10_LED-3528-3_2X2_8H1RGBLEDLED-3528-3_2X2_8H1_9
IU12MMA7660FC_10_LED-3528-3_2X2_8H1RGBLEDLED-3528-3_2X2_8H1_9
IU13MMA7660FC_10_LED-3528-3_2X2_8H1RGBLEDLED-3528-3_2X2_8H1_9
IU14MMA7660FC_10_LED-3528-3_2X2_8H1RGBLEDLED-3528-3_2X2_8H1_9
IU15MMA7660FC_9_RL-UM02WBD-8821_RL-RL-UM02WBD-8821RL-UM02WBD-8821
J1CON2_3_CON-2P-2_54-B_4PIN-2.54M4PIN-2.54mmCON-2P-2_54-B
J2CON2_1_PIN1X4_2-54_4PIN-2.54MM4PIN-2.54mmPIN1X4_2-54
J4CNS-MMC-A_1_SD-002U_SD-002USD-002USD-002U
J5CNS-CF-AT_1_CF50-063-47_CNS-CF-CNS-CF-CustomerCF50-063-47
J6HDMI19_PLUG_0_HDMI_TYPE_0_5_HDMHDMI type AHDMI_TYPE_0_5
J7CN_2_FPC40_PT05_H2A_FPC40X0.5MMFPC40x0.5mmFPC40_PT05_H2A
J8TSH-3865D_0_SJ1-351X-SMT-H5_SJ1SJ1-3513-SMTSJ1-351X-SMT-H5
J9SPDIFX2_0_OPTICAL_OWAOWAOPTICAL
J10USB_MINI_SOCKET_4_USB_2_0_USB_TUSB_TYPE-AUSB_2_0
J11USB_MINI_SOCKET_4_USB_2_0_USB_TUSB_TYPE-AUSB_2_0
J12USB_MINI_SOCKET_5_MICRO-USB5P-AMicro-USB-5PMICRO-USB5P-AB-H3_75
J13CN_3_FPC20-PT05B_FPC20X0.5MMFPC20x0.5mmFPC20-PT05B
L1INDUCTOR_4_CDH5250_SPM5050100MESPM5050100MESHCDH5250
L2INDUCTOR_4_CDH5250_SPM50501R5MESPM50501R5MESH(5.4*6.1mm)CDH5250
L3FB-0603_L0603_600R@100MHZFB600R@100MHZ FBL0603
L4R-PACK4_0_L0805X2_WLMCM2012B900WLMCM2012B900FBPL0805X2
L5R-PACK4_0_L0805X2_WLMCM2012B900WLMCM2012B900FBPL0805X2
L6R-PACK4_0_L0805X2_WLMCM2012B900WLMCM2012B900FBPL0805X2
LP1INDUCTOR_0_CD41_SPM40402R2MESH(SPM40402R2MESH(4.7*4.2mm)CD41
LP2INDUCTOR_0_CD41_SPM40402R2MESH(SPM40402R2MESH(4.7*4.2mm)CD41
LP3INDUCTOR_0_CD41_SPM40402R2MESH(SPM40402R2MESH(4.7*4.2mm)CD41
LP4INDUCTOR_0_CD41_SPM40404R7MESH(SPM40404R7MESH(4.7*4.2mm)CD41
LP5INDUCTOR_0_CD41_SPM40402R2MESH(SPM40402R2MESH(4.7*4.2mm)CD41
M5T_POINT_R_MH126CIR250D_M-VIAM-viaMH126CIR250D
M6T_POINT_R_MH126CIR250D_M-VIAM-viaMH126CIR250D
M7T_POINT_R_MH126CIR250D_M-VIAM-viaMH126CIR250D
M8T_POINT_R_MH126CIR250D_M-VIAM-viaMH126CIR250D
Q1NPN_1_SOT23_2N39042N3904SOT23
Q22N7002_2_SOT23-GDS_BSN20BSN20SOT23-GDS
Q32N7002_2_SOT23-GDS_BSN20BSN20SOT23-GDS
Q62N7002_2_SOT23-GDS_BSN20BSN20SOT23-GDS
Q82N7002_2_SOT23-GDS_BSN20BSN20SOT23-GDS
SC1C0402_1_C0402_10NF_11G10110315110nFC0402
SC2C0402_4_C0402_10NF_11G10110315110nFC0402
SC3C0402_0_C0402_10NF_11G10110315110nFC0402
SC4C0402_2_C0402_1UF_11G1011053211uFC0402
SC5C0402_3_C0402_10NF_11G10110315110nFC0402
SC6C0805_0_C0805_22UF_11G10310632A22uFC0805
SC7C0805_0_C0805_22UF_11G10310632A22uFC0805
SC8C0402_10_C0402_22PF_11G1012200522pFC0402
SC9C0603_0_C0603_1UF_11G10222532A1uFC0603
SC10C0402_11_C0402_22PF_11G1012200522pFC0402
SC11C0805_1_C0805_10UF10V_11G1031010uF 10VC0805
SC12C0805_2_C0805_10UF_11G10310632A10uFC0805
SC13C0402_0_C0402_100NF_11G10110434100nFC0402
SC16C0402_0_C0402_1UF_11G1011053211uFC0402
SC17C0402_0_C0402_100NF_11G10110434100nFC0402
SC18C0402_0_C0402_1UF_11G1011053211uFC0402
SC19C0402_0_C0402_0.1UF_11G101104340.1uFC0402
SC20C0402_0_C0402_0.1UF_11G101104340.1uFC0402
SC21C0402_0_C0402_0.1UF_11G101104340.1uFC0402
SC22C0402_0_C0402_0.1UF_11G101104340.1uFC0402
SC23C0402_0_C0402_1UF_11G1011053211uFC0402
SC24C0402_0_C0402_1UF_11G1011053211uFC0402
SC25C0402_0_C0402_0.1UF_11G101104340.1uFC0402
SC26C0402_0_C0402_0.1UF_11G101104340.1uFC0402
SC29C0402_0_C0402_0.1UF_11G101104340.1uFC0402
SC30C0402_0_C0402_1UF_11G1011053211uFC0402
SC31C0402_0_C0402_0.1UF_11G101104340.1uFC0402
SC32C0402_0_C0402_0.1UF_11G101104340.1uFC0402
SC33C0402_0_C0402_0.1UF_11G101104340.1uFC0402
SC35CAP NP_3_C0805_22UF22uFC0805
SC36CAPNP_3_C0402_NC/18PFNC/18pFC0402
SC37CAP NP_3_C0805_22UF22uFC0805
SC38CAP NP_4_C0402_0.1UF0.1uFC0402
SC39CAPACITOR_0_C0402_1UF1uFC0402
SC40C0402_0_C0402_1UF_11G1011053211uFC0402
SC41CAPACITOR_4_C0805_10UF25V10uF 25VC0805
SC42CAPACITOR_4_C0805_10UF25V10uF 25VC0805
SJ1SATA-FEMALE-22P-DIP-7_0_SATA-22HONKON/HSAT-022-R5S-06SATA-22-DIP-H6_6
SJ2GSDR32P-3R3M_1_CD41_SPM40404R7MSPM40404R7MESHCD41
SJ3C0805_0_C0805_10UF_11G10310632A10uFC0805
SJ4CN_3_FPC16-PT05B_FPC16X0.5MMFPC16x0.5mmFPC16-PT05B
SJ5CN_2_FPC40_PT05_H2B_FPC40X0.5MMFPC40x0.5mmFPC40_PT05_H2B
SL1INDUCTOR_4_CD41_4.7U-1.6A4.7u-1.6ACD41
SQ1APM2301CA_SOT-23_AO3423_07G1040AO3423SOT-23
SQ22N3904_SOT-23_2N3904_07G10100102N3904SOT-23
SSJ1CN_3_FPC16-PT05A_FPC16X0.5MMFPC16x0.5mmFPC16-PT05A
SSJ2SATA-FEMALE-22P-DIP-7_0_SATA-22HONKON/HSAT-022-R5S-06SATA-22-DIP-H6_6
STP1TESTPIN_TP_1_0_NAMENAMETP_1_0
STP2TESTPIN_TP_1_0_NAMENAMETP_1_0
STP3TESTPIN_TP_1_0_NAMENAMETP_1_0
STP4TESTPIN_TP_1_0_NAMENAMETP_1_0
STP5TESTPIN_TP_1_0_NAMENAMETP_1_0
STP6TESTPIN_TP_1_0_NAMENAMETP_1_0
SU1JMS562A1-QFN76-9X9-EP_1_QFN77-9JMS562-QFN76QFN77-9X9-04
SU2F25L04PA-100PG_SOP8_F25L04PA-10F25L04PA-100PGSOP8
SU3G5725_SOT23-5_LP3218AB5FLP3218AB5FSOT23-5
SU4NDS9435A_2_SOP8_FPF2700MXFPF2700MXSOP8
SU5NDS9435A_2_SOP8_FPF2700MXFPF2700MXSOP8
SU6NDS9435A_2_SOP8_FPF2700MXFPF2700MXSOP8
SU7NDS9435A_2_SOP8_FPF2700MXFPF2700MXSOP8
SW11197_0_SW-6X6-DIP_POWERKEYPOWER KEYSW-6X6-DIP
SW3KEY-2PIN_SD-1285_NC/POWRONNC/PowronSD-1285
SX1XTAL_4P_126X98_HELE_H3130MHzCRY-TSX3225
U1MMA7660FC_5_SOP8_FR9886FR9886SOP8
U2MMA7660FC_4_QFN3X3-12_SY8366ASY8366AQFN3X3-12
U3ATM7059_12_ATM7059_496_ATM7059ATM7059 TFBGA496ATM7059_496
U5EMMC-BGA169_2_BGA169-PT0_5-12X1eMMC-BGA169BGA169-PT0_5-12X16H1A
U6GL827-LQFP48-7X7X0_31_LQFP48_GLGL834LQFP48
U7AT24C02-DIP_0_SOIC_8P_50_197X23AT24C02-3P (NC)SOIC_8P_50_197X236
U8SY6280_0_SOT23_NC/AP2331NC/AP2331SOT23
U9RL5760_4_QFN24-4X4-05_RL5760_00RL5760_001QFN24-4X4-05
U10HY911105H_5_GX-RJ-1104D8021L8_8GX-RJ-1104D8021GX-RJ-1104D8021L8_85
U11GLI8024-48_8_QFN32-3X6-04_PI3USPI3USB3102QFN32-3X6-04
U12RT9266PE_2_SOT23-5_SY6280SY6280SOT23-5
U13RT9266PE_2_SOT23-5_SY6280SY6280SOT23-5
U14GLI8024-48_3_SSOP28_GL850GGL850GSSOP28
U15LM1086_0_SOT23-6_NL27WZU04DTT1NL27WZU04DTT1SOT23-6
U16LD1117-33_1_SOT25_TCS2108A332MRTCS2108A332MRSOT25
U17SW2001_0_SOT23-6_SW2001SW2001SOT23-6
UD1DDR3_FBGA96_1_FBGA96C80P9X13_MTMT41K256M16HAFBGA96C80P9X13
UD2DDR3_FBGA96_1_FBGA96C80P9X13_MTMT41K256M16HAFBGA96C80P9X13
UP1ATC2603C_1110_ATC2603_QFN68_0_4ATC2603C QFN68ATC2603_QFN68_0_4
UP2IC_RT9701GB_11_SOT23-5_RT8059TRT8059 TSOT23-5SOT23-5
UP3IC_RT9701GB_11_SOT23-5_RT8059TRT8059 TSOT23-5SOT23-5
X1CRYSTAL-4_0_CRY-TSX3225_12M-10P12M-10PPMCRY-TSX3225
YK1XTAL_3_CRY-TSX3225_24MHZ_37125024MHZCRY-TSX3225
YK2XTAL_0_CRY-TSX3225_24MHZ12PF 324MHZ 12PF 30PPM3.2X2.5CRY-TSX3225
YP1XL2P_FC-135_32.768KHZ32.768KHZFC-135
重要提示:PCB作品文件展下载说明
老吴 | 2017-8-29 09:57:47 | 显示全部楼层
ATM7029.7z (2.08 MB, 下载次数: 19)
thanky0u58 | 2017-8-29 10:04:56 | 显示全部楼层
lichengpcb | 2017-8-29 10:10:22 | 显示全部楼层
Re:炬力ATM7029 +ATC2603+GL827+JMS562A1 平板PCB文件
xnima_irumei | 2017-8-29 10:35:05 | 显示全部楼层
带刀的老鼠 | 2017-8-29 11:22:04 | 显示全部楼层
厉害了   学习下
wuhaoxian | 2017-8-29 16:30:28 | 显示全部楼层
joyce180250 | 2017-8-29 17:33:11 | 显示全部楼层
2749237077 | 2017-8-30 02:14:57 | 显示全部楼层
monamemak | 2017-8-30 03:35:06 | 显示全部楼层
我已经有这个文件
