• 新手一枚,学习两个月的板子
  • 芯片制造中的阻挡层沉积技术介绍
  • 接地搭接电缆布局屏蔽!!!
  • 北美液冷生态解码:超微spuermicro,24年营
  • SK海力士全球首发HBM4-16层堆叠、2.0TB/s
[Allegro16.6以下] 5CSEB2U23I7S挂2个DDR3  8层工控主板 PCB(KSZ8041FTL+USB3300-
查看4854 | 回复22 | 2017-9-1 16:42:14 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
D1LED_LED0603_LED0603/REDLED0603/REDLED0603
D2LED_LED0603_LED0603/REDLED0603/REDLED0603
D3LED_LED0603_LEDLEDLED0603
D4LED_LED0603_LEDLEDLED0603
D5DIODETVS_1_SMA_SMAJ5.0ASMAJ5.0ASMA
D6DIODETVS_1_SMA_SMAJ5.0ASMAJ5.0ASMA
D7LED_LED0603_LEDLEDLED0603
D8LED_LED0603_LEDLEDLED0603
D10LED_LED0603_LED0603/REDLED0603/REDLED0603
F1FB_1_LC0805_120R120RLC0805
F2FB_1_LC0805_120R120RLC0805
F3FB_1_LC0805_FBFBLC0805
F4FB_1_LC0805_FBFBLC0805
F5FB_1_LC0805_120R120RLC0805
F6FB_1_LC0805_120R120RLC0805
F7FB_1_LC0805_120R120RLC0805
F8FB_1_LC0805_120R120RLC0805
F9FB_1_LC0805_120R120RLC0805
F10FB_1_LC0805_120R120RLC0805
F11FB_1_LC0805_FBFBLC0805
F12FB_1_LC0805_FBFBLC0805
F13FB_1_LC0805_FBFBLC0805
FB1FB_RC0805_0R0RRC0805
FB2FB_RC0805_0R0RRC0805
J1CONN-ALTERA-JTAG-10P_HR2X5-2_54CONN-ALTERA-JTAG-10PHR2X5-2_54-SA
J2HEADER44_2_35363-0610_HEADER 6HEADER 635363-0610
J3COM40_ES_HR2X20P-2_54-RA_COM40COM40ES_HR2X20P-2_54-RA
J4CON10_A_HR2X5-2_54-RA_CON10CON10A_HR2X5-2_54-RA
J5CONN-LCD-LVDS-20P_DF20F-10DP-1HCONN-LCD-LVDS-20PDF20F-10DP-1H_59
J8CON2_5045-02A_CON2CON25045-02A
J9FX2CA2-120S-1.27DSAL_FX2CA2-120FX2CA2-120S-1.27DSALFX2CA2-120S-1_27DSAL
M1GND_EARTH_0_MH-8-4-9P-A_GND_EARGND_EARTHMH-8-4-9P-A
M2GND_EARTH_0_MH-8-4-9P-A_GND_EARGND_EARTHMH-8-4-9P-A
Q1NPN BEC_SOT23_80508050SOT23
Q2MOSFET-EP/SO8_0_SO8-1_27-3_90_SSI9407SO8-1_27-3_90
Q3NPN BEC_SOT23_80508050SOT23
Q13PNP_BEC_1_SOT23_85508550SOT23
Q14PNP_BEC_1_SOT23_85508550SOT23
RN1RESAR_IS_4/SM/SP_RN8-0603_62R62RRN8-0603
RN2RESAR_IS_4/SM/SP_RN8-0603_62R62RRN8-0603
RN3RESAR_IS_4/SM/SP_RN8-0603_62R62RRN8-0603
RN4RESAR_IS_4/SM/SP_RN8-0603_62R62RRN8-0603
RN5RESAR_IS_4/SM/SP_RN8-0603_62R62RRN8-0603
RN6RESAR_IS_4/SM/SP_RN8-0603_62R62RRN8-0603
RN7RESARR_IS_0_RN8-0603_4.7K4.7KRN8-0603
RN8RESAR_IS_4/SM/SP_RN8-0603_10K10KRN8-0603
RN9RESAR_IS_4/SM/SP_RN8-0603_10K10KRN8-0603
RN18RESAR_IS_4/SM/SP_RN8-0603_22R22RRN8-0603
T1HX1188NL_0_HR601627_HX1188NLHX1188NLHR601627
T2HX1188NL_0_HR601627_HX1188NLHX1188NLHR601627
T3HX1188NL_0_HR601627_HX1188NLHX1188NLHR601627
U15CSEB2U23I7S_1_BGA672-0_80-23X25CSEB2U23I7SBGA672-0_80-23X23
U2EN5339QI_1_EN5339QI_EN5339QIEN5339QIEN5339QI
U3EN5339QI_1_EN5339QI_EN5339QIEN5339QIEN5339QI
U4EP53A8XQI_EP53A8_EP53A8HQIEP53A8HQIEP53A8
U5EPCQ256SI16N_SO16-1_27-3_90_EPCEPCQ256SI16NSO16-1_27-3_90
U6OSC_SMD_4P_OSC7_0X5_0_25.0000MH25.0000MHz/50PPM/3.3V/5x3.2mmOSC7_0X5_0
U7IMP811_SOT143_IMP811IMP811SOT143
U8TPS3306-15_SO8-1_27-3_90_TPS330TPS3306-15SO8-1_27-3_90
U9MT41J256M16RE-125_BGA96-0_80-8XMT41J256M16RE-125BGA96-0_80-8X13_5
U10MT41J256M16RE-125_BGA96-0_80-8XMT41J256M16RE-125BGA96-0_80-8X13_5
U11EP53A8XQI_EP53A8_EP53A8LQIEP53A8LQIEP53A8
U12OSC_SMD_4P_OSC7_0X5_0_25.0000MH25.0000MHz/50PPM/3.3V/5x3.2mmOSC7_0X5_0
U13N25Q_SO16-1_27-7_50_N25QN25QSO16-1_27-7_50
U14M25P16-VMN6/SO8_SO8-1_27-3_90_MM25P16-VMN6/SO8SO8-1_27-3_90
U15MT29F8G08ABACAWPIT_0_TSOP48-0_5MT29F8G08ABACAWPITTSOP48-0_50-18_40
U16USB3300-EZK_QFN32-0_50-5X5_USB3USB3300-EZKQFN32-0_50-5X5
U17SN74LVC2T45_SOP8-0_65-3_00_SN74SN74LVC2T45SOP8-0_65-3_00
U18TPS2041BDBVR_SOT23-5-5P_TPS2041TPS2041BDBVRSOT23-5-5P
U19TPD2E009DBZR_SOT23_TPD2E009DBZRTPD2E009DBZRSOT23
U20SN65220DBVR_0_SOT23-6_SN65220DBSN65220DBVRSOT23-6
U21SN74LVC16T245DGGR_TSSOP48-0_50-SN74LVC16T245DGGRTSSOP48-0_50-6_10
U22SN74LVC8T245DB_SSOP24-0_635-3_9SN74LVC8T245DBSSOP24-0_635-3_90
U23TPD2E007DCKR_0_SC70_TPD2E007DCKTPD2E007DCKRSC70
U24TPD2E007DCKR_0_SC70_TPD2E007DCKTPD2E007DCKRSC70
U25TPD2E007DCKR_0_SC70_TPD2E007DCKTPD2E007DCKRSC70
U26TPD2E007DCKR_0_SC70_TPD2E007DCKTPD2E007DCKRSC70
U27TPD2E007DCKR_0_SC70_TPD2E007DCKTPD2E007DCKRSC70
U32KSZ8041FTL_LQFP48-0_50-7X7_KSZ8KSZ8041FTLLQFP48-0_50-7X7
U33KSZ8041FTL_LQFP48-0_50-7X7_KSZ8KSZ8041FTLLQFP48-0_50-7X7
U34TPD2E001DZDR_SOT143_TPD2E001DZDTPD2E001DZDRSOT143
U35TPD2E001DZDR_SOT143_TPD2E001DZDTPD2E001DZDRSOT143
U36TPD2E001DZDR_SOT143_TPD2E001DZDTPD2E001DZDRSOT143
U37TPD2E001DZDR_SOT143_TPD2E001DZDTPD2E001DZDRSOT143
U38KSZ8041FTL_LQFP48-0_50-7X7_KSZ8KSZ8041FTLLQFP48-0_50-7X7
U39TPD2E001DZDR_SOT143_TPD2E001DZDTPD2E001DZDRSOT143
U40TPD2E001DZDR_SOT143_TPD2E001DZDTPD2E001DZDRSOT143
U41AT88SC0204C_SO8-1_27-3_90_ATSHAATSHA204-SH-DA-BSO8-1_27-3_90
U42RX-8035SA_SO14-1_27-5_00_RX-803RX-8035SASO14-1_27-5_00
U43SN74LVC16T245DGGR_TSSOP48-0_50-SN74LVC16T245DGGRTSSOP48-0_50-6_10
U44SN74LVC8T245DB_SSOP24-0_635-3_9SN74LVC8T245DBSSOP24-0_635-3_90
U45SN74LVC8T245DB_SSOP24-0_635-3_9SN74LVC8T245DBSSOP24-0_635-3_90
U46SN74LVC2T45_SOP8-0_65-3_00_SN74SN74LVC2T45SOP8-0_65-3_00
U47SN74LVC2T45_TSSOP8-0_65-2_80_SNSN74LVC2T45TSSOP8-0_65-2_80
U48SN74LVC1G08DBV_SOT23-5-5P_SN74LSN74LVC1G08DBVSOT23-5-5P
U49EVB-EV1320QI_EV1320_EV1320QIEV1320QIEV1320
Y1CRYSTAL_HC49US_24MHZ24MHzHC49US
5CSEB2U23I7S.7z (1.27 MB, 下载次数: 23)
重要提示:PCB作品文件展下载说明
miaomiao | 2017-9-1 17:39:47 | 显示全部楼层
[Allegro16.6]5CSEB2U23I7S挂2个DDR3  8层工控主板 PCB(KSZ8041FTL+USB3300-EZK+SN74LVC8T245DB+SN74LVC16T245DGGR)
地沟油 | 2017-9-1 20:42:09 | 显示全部楼层
地沟油 | 2017-9-1 20:42:58 | 显示全部楼层
zhifang88 | 2017-9-1 20:43:03 | 显示全部楼层
xnima_irumei | 2017-9-1 22:15:04 | 显示全部楼层
woshizhengjie89 | 2017-9-2 00:06:55 | 显示全部楼层
学海无涯 | 2017-9-2 07:22:12 | 显示全部楼层
单枪舞九州 | 2017-9-2 07:29:43 | 显示全部楼层
jopey | 2017-9-2 08:23:26 | 显示全部楼层
