[PADS9.5以下] MT7623A(MT7623)高端路由器DEMO  PCB 和原理图共享
查看23229 | 回复89 | 2017-9-3 13:50:40 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
NamePart TypePCB DecalValue
CON1MINI_10PIN_3MICROUSB/5P/SMD/000010611-0000/MAINSUPERMICROUSB/
CON4HOUSING_DIP_2_0.54DIP3X2/P2.0/F_DIP3X2/P2.0
D1LED_0603LED0603LED_YG
D10DIODE_SCHOTTKYVARISTOR/SMD/TVM5B150L103RYTVS SMCJ16A/NI
D14DIODE/ZENERDIODE/SMD/MMSZ5221BMMSZ5231BT1G
D26DIODE_SCHOTTKY_0D/SMD/UMD2UDZV 5.6B
F1FUSE_1812F1812PolyFuse-SMD1812P110TF/16
H1HOLE/3_0.5MMHOLE/NPTH/D3.3HOLE
J2USB3.0_TYPEAUSB3.0/9P/DIP/MAINSUPERUSB3.0_TypeA
J14SW_DPDT_1SW-2P2T-6.3SW DPDT
J15MINICARD_CARD_HOST_V12_2CONSG/54/MINICARD/AS0B22-S68-7F/HALF/FULMiniCard_Card_Host
J20RASPBERRY_PI_CONN_(23X2)DIP13X2/P2.54Raspberry Pi Conn (23x2)
J22QTH-060-01-F-D-A_(120_PIN)QTH-060-01-F-D-AQTH-060-01-FDA (120 pin)
J23DC_JACKDC-JACK/3P/DIP/R/JD003-PFDC JACK
J25HEADER_5X1_0DIP5/P2.54HEADER 5x1_0
J28JUMPER3_6DIP3/P2.54JUMPER3
J42CON20APDIP10X2/W/H/IDE/P2.54Box Header_2.54_2x10
J457SDCN-B0-1X14-SD_CARD_SLOTCON10P/SMD/R/F/7SDCN-B0-1X147SDCN-B0-1X14-SD Card Slot
L25L/GDR1012L/IND/SMD/GSTD6030PW-6R8M3.3uH-GSTC063 P-3R3MN
L36L/1206L/IND/DIP/D6H14WBR6HN/NI
L66L0603SB/0402SB/0R
L642L/GDR1012L/IND/SMD/LVS5045NI/4.7uH/VLC5045
LED1DIODE_10LED/4P/SMD/19-237ASMLP36RGB1W
NI/U15RT8293BSOP8/SMD/P1.27/IT7653IT7673M-SOP8
P1RJ45X1_4RJ45/8P/DIP/R/8208C-B01RJ45X1
P2PHJ8X4_2PHJ8X4_NPHJ 8*4
PL1INDUCTOR_CHOKE_SMD_D10H6L/IND/SMD/ZPWM-40202.2uH_3A
PL2INDUCTORL/IND/SMD/25202.2uH
Q1MMBT3906-SMDD/SMD/P1.9/SOT-23/BAS16LT1MMBT3906-SMD
Q2Q-MPSA42-DIP_1SOT23/SMD2N3904,NPN,SOT23
Q9BJT_2SB1386-PNP_0SOT-89/SMD/2SB13862SB1386
SH1009NO_PAD_0402_SMD_1NC/MMD/L1/4MILSHORT / NC-MMD-L9-4MIL
T1TXMR_GST5009LFTRANSFORMER/24P/DIP/G1PM109NTRANSFORMER/G1PM109N
T3TXMR_G2PM109NLFTRANSFORMER/48P/DIP/G2PM109NTXMR,G2PM109NLF
T5FT20-252B_2TRANSFORMER/24P/SMD/GSC-2401-RFT20-252B
TP1TEST_POINT_SMD0.6VIA1810/SLKTEST POINT
U1MT7623AMT7623/FBGA486/P0.8/B0.4/21X21MT7623A-test full ball
U2TXS0104ETSSOP14TXS0104E
U3IC_DDR3_X16_FBGA-96FBGA96/SMD/P0.8/10X14/DDR3L/16BIC DDR3 x16 FBGA-96
U5MX25L6406EM2I-12GSO8-RT-LMX25L12835FM2I-10G
U6MX25L25735EMI-12GSO16/SMD/P1.27/W25Q32FVNI/MX25L12835FMI-10G
U7TPS2552DBV_0SOT-23-6/SMDTPS2553DBVT
U9NLSX3378_0UDFN8/SMD/P0.4/NLSX3373NLSX4373
U10TXS0104ETSSOP14NI/TXS0104E
U11MT6323_E1_4MT6323L/TFBGA158/P0.5/B0.27/7.6X7.6MT6323LGA/AGC-PCU-H
U12RT7236GCP_650KHZTSSOP14/SMD/P0.65/RT7236RT7236GCP_5A
U13FDG6303_2SOT-6NI/STT818B
U14MOSFET_N_22-1L1B/SMD/SSM3K35MFVNI/SSM3K35MFV
U16RT8293BSOP8/SMD/P1.27/IT7653NI/IT7673M-SOP8
U17CAT71990_3SOP8/SMD/P1.27/FR9888RT6206B
U19RT7236GCP_650KHZTSSOP14/SMD/P0.65/RT7236RT7236GCP_5A
U20AZ1045-02PESD/SMD/RCLAMP0582NAZ1045-02P/NC
U21RT8078AGQW_1MHZ_1WDFN810/SMD/P0.5/RT8078ART8078AGQW_1MHz_4A
U22REG_APL5910_0SOP8/SMD/P1.27/APL5910APL5910
U24G5175_0TQFN32/SMD/P0.4/4X4/G2156G2156
U25LDO_RT9164A-SOT223_1SOT223-3/SMD/P2.3/AX1007ZTP1117SA
U26TXB0180PWRTSSOP20TXB0108PWR
U29IP1001_0QFN64/SMD/P0.5/IP1001IP1001
U30RJ-45X1P-NO-SHRJ45/8P/DIP/R/8208C-B01RJ-45X1P
U31EMMCP-VFBGA153/SMD/P0.5/11.5X13/TOSHIBATHGBMBG6D1KBAIL
U32MICTOR38_0TSOP48/SMD/P0.5/K9F5608X0DNI/MX30LF1G08AA-TI
U33RN5VD28AA-TRSOT-23-5/SMD/G697G697L293TOUF SOT23-5
U36SMA/UFLRCOAXIAL/SMD/CON/V/I-PEX/W08-5801SMA/UFLR
U37F4P-2012/0402_0FILTER/4P/SMD/TCF0504H90002ATCF0504U30002/NI
VBAT1TEST_POINT_DIP0.6TP/SMD/D0.6TEST POINT
VR1VR0402VR0402EZJZ0V500AA
WU1TCXO_RAKON_SMD_4PTCXO/SMD/2.5X2.0/IT2205BETXC 7L26002015
WU6MT6611_SMD_WLCSP-61_0MT6625/SQFN40/SMD/P0.4/5X5MT6625LN/AME-PEGA-L
WU7SAW_3FILTER/3P/SMD/BF1608BPF / ACX / BF1608-L2R4NAF
X2CRYSTAL_1CRYS/SMD/MS3V-T1R32K (MS3V-T1R)
X3TCXO_RAKON_SMD_4P_3TCXO/SMD/2.5X2.0/IT2205BEMT6627 QVL TCXO
X5XTAL_3.2X2.5CRYS/SMD/3.2X2.5/FD2000030XTAL_25MHz_3.2x2.5
重要提示:PCB作品文件展下载说明
老吴 | 2017-9-3 14:00:38 | 显示全部楼层
MT7623A-V12.7z (1.42 MB, 下载次数: 117)
linyuanfei | 2017-9-3 15:03:24 | 显示全部楼层
ribber | 2017-9-3 15:13:44 | 显示全部楼层
zz60754405 | 2017-9-3 16:04:40 | 显示全部楼层
木子健518 | 2017-9-3 16:06:49 | 显示全部楼层
shuszhao | 2017-9-3 17:14:20 | 显示全部楼层
吴老大,你侵害我的版权了
老吴 | 2017-9-3 19:55:15 | 显示全部楼层
xnima_irumei | 2017-9-3 22:29:27 | 显示全部楼层
单枪舞九州 | 2017-9-4 07:20:49 | 显示全部楼层
