[Allegro16.6以下] 18层PCB设计中太的XLP8xx系列 网络安全数据处理板主板 PCB文
查看4815 | 回复38 | 2017-9-23 20:13:26 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
18层 PCB设计 。主要是用在网络数据处理和安全监控上。
BAT1BAT_HBAT_HBAT_H
C1278CP-SM-2R2X6R3100uFCP-SM-2R2X6R3
C1279C0402-BGA0.1uFC0402-BGA
C1280C04020.1uFC0402
C1281C080522uFC0805
C1282C04021000pFC0402
C1283CP-SM-2R2X6R3100uFCP-SM-2R2X6R3
C1284CP-SM-2R2X6R3100uFCP-SM-2R2X6R3
CN1SD-15PIN-PUSHSD Card ConnectorSD-15PIN-PUSH
CN3USB4-79USB-A-S-F-B-THUSB4-79
D1SMA403B-02NCSMA403B-02
DV8SOT23SOT23SOT23
FT1COOLF66COOLF66COOLF66
FT2COOLF66COOLF66COOLF66
FT3SCKMBG1605_TOPSCKMBG1605_TOPSCKMBG1605_TOP
G1X4-2520ECS-2018-480-BNX4-2520
G2X4-0705ASV-133.333MHZ-E-C-TX4-0705
G3X6-0705 X6-0705
J1HOLE2_7P_6 HOLE2_7P_6
J2HOLE2_7P_6 HOLE2_7P_6
J3CON_ZD_4_10 CON_ZD_4_10
J4DIN240R-SM782940001DIN240R-SM
J6PHM1610-S PHM1610-S
J7CON_ZD_4_10 CON_ZD_4_10
J8DIN240R-SM782940001DIN240R-SM
J9HOLE2_7P_6 HOLE2_7P_6
J10HOLE2_7P_6 HOLE2_7P_6
J11HOLE2_7P_6 HOLE2_7P_6
J12HOLE2_7P_6 HOLE2_7P_6
J13HOLE2_7P_6 HOLE2_7P_6
J14DIN240R-SM782940001DIN240R-SM
J15HOLE2_7P_6 HOLE2_7P_6
J16HOLE2_7P_6 HOLE2_7P_6
J17SIP2-10022-23-2031SIP2-100
J18DIN240R-SM782940001DIN240R-SM
J19HOLE2_7P_6 HOLE2_7P_6
J20HOLE2_7P_6 HOLE2_7P_6
J22CON2X5_2_54CON2X5_2_54CON2X5_2_54
J23CON_ZD_4_10 CON_ZD_4_10
L1PL1313300nHPL1313
L2PL1313300nHPL1313
L57IHLP2525_9X61.5uH/9AIHLP2525_9X6
L58L06034.7uHL0603
L59PL1313300nHPL1313
L60PL1313300nHPL1313
P1PIM PIM
P7PWR1_4_12PWR1_4_12PWR1_4_12
P8CON_POWER_34_MCON_POWER_34_MCON_POWER_34_M
Q1SOT23_M SOT23_M
Q2TDSON8-50-0506BSC020N03LSTDSON8-50-0506
SP1SW4-7166 SW4-7166
SP5CLS-050 CLS-050
T1TESTPOINTTESTPOINTTESTPOINT
T2DIS_CHARGE_FDIS_CHARGE_FDIS_CHARGE_F
T3DIS_CHARGE_FDIS_CHARGE_FDIS_CHARGE_F
T4DISCHARGE_MDISCHARGE_MDISCHARGE_M
T5DISCHARGE_MDISCHARGE_MDISCHARGE_M
T6DIS_CHARGE_RDIS_CHARGE_RDIS_CHARGE_R
T7DIS_CHARGE_RDIS_CHARGE_RDIS_CHARGE_R
T69TESTPOINTTESTPOINTTESTPOINT
TT1H5020NLH5020NLH5020NL
TT2H5020NLH5020NLH5020NL
TT3H5020NLH5020NLH5020NL
TT4H5020NLH5020NLH5020NL
TT6H5020NLH5020NLH5020NL
U1BGA2003-40-4747XLP8xxBGA2003-40-4747
U2QFN48-050-0707HLISL6333AQFN48-050-0707HL
U3SOP16-26-177HMAX8869EUE50SOP16-26-177H
U4SOP16-26-177HMAX8869EUE50SOP16-26-177H
U5BGA1156_1_0BGA1156_1_0BGA1156_1_0
U6QFP256-040-2828BCM53128KQLEQFP256-040-2828
U7SOP8-50-157ICS85411SOP8-50-157
U8QFN48-050-0707HLISL6333AQFN48-050-0707HL
U9SOP16-26-177HMAX8869EUE50SOP16-26-177H
U106SOT23_6 6SOT23_6
U11LGA_104PINSLGA_104PINSLGA_104PINS
U12BGA332-32-1717 BGA332-32-1717
U13QFP144-080-2020 QFP144-080-2020
U14USOP0_5_10USOP0_5_10USOP0_5_10
U15SO8SO8SO8
U16SO8SO8SO8
U17SO8_5X6 SO8_5X6
U18SO8SO8SO8
U19SO20 SO20
U20SOP20-26-177 SOP20-26-177
U21SO20 SO20
U22BGA1020-40-3232CS3477_Ref_DesignBGA1020-40-3232
U23TSSOP20_0_65TSSOP20_0_65TSSOP20_0_65
U24TSSOP8_0_65TSSOP8_0_65TSSOP8_0_65
U25TSSOP8_0_65TSSOP8_0_65TSSOP8_0_65
U26SO8SO8SO8
U27BGA121-40-1212 BGA121-40-1212
U28SO8SO8SO8
U29TSSOP20_0_65TSSOP20_0_65TSSOP20_0_65
U30SOP8-50-157ICS85411SOP8-50-157
U31PBGA13R0X13R0-256-0R80 PBGA13R0X13R0-256-0R80
U32BGA121-40-1212 BGA121-40-1212
U33SOT143BPRTR5V0U2XSOT143B
U34SOP24-26-177ICS84300I-23SOP24-26-177
U35SOP48-20-480 SOP48-20-480
U36SOP8-50-157MIC2076-2YMSOP8-50-157
U37SOP28-26-212MAX3241ECAISOP28-26-212
U38SOP28-26-212MAX3241ECAISOP28-26-212
U39QFP48-050-0707 QFP48-050-0707
U40BGA121-40-1212 BGA121-40-1212
U41SO8SO8SO8
U42SOP16-26-177ICS854104SOP16-26-177
U43SOIC32 SOIC32
U44SOP8-50-157ICS85411SOP8-50-157
U45SO8SO8SO8
U46SO8SO8SO8
U47QFN8-050-0202L QFN8-050-0202L
U48TSOP56TSOP56TSOP56
U49SOP8-50-212 SOP8-50-212
U50TSSOP8_0_65TSSOP8_0_65TSSOP8_0_65
U51TSSOP8_0_65TSSOP8_0_65TSSOP8_0_65
U52TSSOP0_65_21LTC3414EFETSSOP0_65_21
U53LGA_104PINSLGA_104PINSLGA_104PINS
U54TSSOP0_65_21LTC3414EFETSSOP0_65_21
U58LGA_104PINSLGA_104PINSLGA_104PINS
U59TSSOP0_65_21LTC3414EFETSSOP0_65_21
U60BGA64-40-1113 BGA64-40-1113
U61VFQFN_10_5_7 VFQFN_10_5_7
U62SOP8-50-157ICS8302AMLFSOP8-50-157
U63TSSOP0_65_21LTC3414EFETSSOP0_65_21
U64SO20 SO20
U65SOP8-50-157ICS85411SOP8-50-157
U67SOP16-26-177HMAX8869EUE50SOP16-26-177H
U68SOP24-26-177ICS84300I-23SOP24-26-177
U69TSOP56TSOP56TSOP56
U70SOP16-26-177ICS854104SOP16-26-177
U71SOP10-20-122H SOP10-20-122H
U72SOP10-20-122H SOP10-20-122H
U73SOP10-20-122H SOP10-20-122H
U74SOP8-20-95 SOP8-20-95
U75SOP8-20-95 SOP8-20-95
U77SOP16-26-177HMAX8869EUE50SOP16-26-177H
U84TSSOP0_65_21LTC3414EFETSSOP0_65_21
U91TSSOP0_65_21LTC3414EFETSSOP0_65_21
U97SOP10-20-120MAX16055CSOP10-20-120
U98SOP10-20-120MAX16055CSOP10-20-120
U100MSOP8LT3020EMS8MSOP8
U101SOP16-26-177HMAX8869EUE50SOP16-26-177H
U105SOP16-26-177HMAX8869EUE50SOP16-26-177H
U107TSSOP0_65_21LTC3414EFETSSOP0_65_21
U111MSOP8LT3020EMS8MSOP8
U113SOP16-26-177HMAX8869EUE50SOP16-26-177H
U124SOP24-26-177ICS84300I-23SOP24-26-177
U127SOP16-26-177HMAX8869EUE50SOP16-26-177H
U128TSSOP0_65_17LTC3413EFETSSOP0_65_17
U142SOP24-26-177ICS84300I-23SOP24-26-177
U143SOP8-50-157ICS85411SOP8-50-157
U605SOP8-50-157MX25L512 nmSOP8-50-157
X1DM7034 DM7034
X2MOLEX_SFP_4 MOLEX_SFP_4
X3RE_T_3 RE_T_3
X4CON1X2_2_54CON1X2_2_54CON1X2_2_54
X5MOLEX_SFP_4 MOLEX_SFP_4
X6CON1R0-64SM-P CON1R0-64SM-P
X7CON1X2_2_54CON1X2_2_54CON1X2_2_54
X8CON1X8_2_54CON1X8_2_54CON1X8_2_54
X9CON1X8_2_54CON1X8_2_54CON1X8_2_54
X10CON1X2_2_54CON1X2_2_54CON1X2_2_54
X11CON1X2_2_54CON1X2_2_54CON1X2_2_54
X12RJ8-01SRLZ RJ8-01SRLZ
X13CNRJ45_1X1-2LED CNRJ45_1X1-2LED
X14RE_T_3 RE_T_3
X15CON2X7_EJTAG39-28-5141CON2X7_EJTAG
X17CON1R0-64SM-P CON1R0-64SM-P
X18CON1X3_PWRCON1X3_PWRCON1X3_PWR
X19CON1R0-64SM-P CON1R0-64SM-P
X20CNRJ45_1X1-2LED CNRJ45_1X1-2LED
X21CON1R0-64SM-P CON1R0-64SM-P
X22RJ8-01SRLZ RJ8-01SRLZ
X23CON1R0-64SM-P CON1R0-64SM-P
X24CON1X2_2_54CON1X2_2_54CON1X2_2_54
X25CON1X2_2_54CON1X2_2_54CON1X2_2_54
X27CON21VP2R00-2X7TM CON21VP2R00-2X7TM
X28CON1X2_2_54CON1X2_2_54CON1X2_2_54
Y1OSC2_11X525.000625MHzOSC2_11X5
Y2XTALMC40532.768KHzXTALMC405
Y3OSC2_11X525.000625MHzOSC2_11X5
Y9OSC2_11X512MHzOSC2_11X5
Y10XTALMC40532.768KHzXTALMC405
Y12OSC2_11X525.000625MHzOSC2_11X5
Y13OSC2_11X525.000625MHzOSC2_11X5
Y15OSC2_11X525MHz CrystalOSC2_11X5
Y16OSC2_11X525.000625MHzOSC2_11X5
重要提示:PCB作品文件展下载说明
老吴 | 2017-9-23 20:16:02 | 显示全部楼层
只有PCB文件。ALLEGRO16.6格式。
有需要的下载,没需要的看看截图就好。RMB上。
XLP832.7z (8.58 MB, 下载次数: 7)
地沟油 | 2017-9-23 20:23:57 | 显示全部楼层
xnima_irumei | 2017-9-23 21:40:13 | 显示全部楼层
zhifang88 | 2017-9-23 22:38:27 | 显示全部楼层
yangxf0120 | 2017-9-23 22:58:51 | 显示全部楼层
谢谢分享18层PCB设计中太的XLP8xx系列 网络安全数据
红阳 | 2017-9-23 23:15:09 | 显示全部楼层
单枪舞九州 | 2017-9-24 05:45:16 | 显示全部楼层
longxuekai | 2017-9-24 08:04:37 | 显示全部楼层
wcjcn | 2017-9-24 08:35:24 | 显示全部楼层
