[Allegro17.4以下] MCIMX8M-EVK i.MX 8M应用处理器评估套件原理图PCB
查看12891 | 回复54 | 2018-12-7 14:41:39 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUEREFDES
SPACER_139TSPACER_SPACER_139T_IC_16.13MM_2.635" LONGBH1401
SPACER_139TSPACER_SPACER_139T_IC_16.13MM_2.635" LONGBH1402
SPACER_139TSPACER_SPACER_139T_IC_16.13MM_2.635" LONGBH1403
SPACER_139TSPACER_SPACER_139T_IC_16.13MM_2.635" LONGBH1404
MH244-166TMOUNT_HOLE_MH244-166T_IC_2.13MMSMTSO-M25BH1406
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D401
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D402
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D701
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D702
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D703
SOD323DIODE_SOD323_IC_1.05MM_480-75131N4148WSD705
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D801
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D802
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D901
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D902
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D903
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D904
SOD-128DIODE_SCHTKY_SOD-128_IC_1.1MM_4PMEG6030ELPD905
SMADIODE_SCHTKY_SMA_IC_2.3MM_480-7B330AD907
SOD123WDIODE_TVS_SOD123W_IC_1.1MM_480-PTVS24VS1URD908
SOD123WDIODE_TVS_SOD123W_IC_1.1MM_480-PTVS24VS1URD909
SOD523ZDIODE_SOD523_IC_0.65MM_480-798BZX585-B3V3D910
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1001
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1003
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1201
LED_1X0P6_SMLED_LED_1X0P6_SM_IC_0.25MM_370-GREEN LEDD1301
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1303
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1304
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1401
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1402
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1403
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1404
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1405
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1501
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1502
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1503
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1504
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1505
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1506
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1507
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1508
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1509
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1510
LED_DUAL_3025MM_SMLED_DUAL_SEP_RG_LED_DUAL_3025MMLED_RED-GRND1601
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1608
LED_0606LED4_DUAL_OG_LED_0606_IC_0.7MM_LED ORANGE/GREEND1702
LED_0606LED4_DUAL_OG_LED_0606_IC_0.7MM_LED ORANGE/GREEND1703
SOD323DIODE_SCHTKY_SOD323_IC_1.16MM_4ZLLS400D1704
ANTENNA_ACM3_5036_A1ANTENNA_ACM3_ANTENNA_ACM3_5036_ACM3-5036-A1-CC-SE1301
ANTENNA_ACM3_5036_A1ANTENNA_ACM3_ANTENNA_ACM3_5036_ACM3-5036-A1-CC-SE1302
FUSE_3P4X1P8FUSE_FUSE_3P4X1P8_DISCRETE_0.867AF901
FUSE_3P4X1P8FUSE_FUSE_3P4X1P8_DISCRETE_0.867AF902
FUSE_1P8_2P2X1P5FUSE_RESETTABLE_FUSE_1P8_2P2X1PPICOSMDC035SF1001
CON_2RH_10_50CONN_HDR_5X2_CON_2RH_10_50_IO_3HDR 2X5J401
CON2X5_SKT_100_SMCONN_HDR_5X2_CON2X5_SKT_100_SM_CON 2X5J801
HDR1X3_THHDR_1X3_HDR1X3_TH_IO_12.04MM_21HDR 1X3J802
CON24_USB_TYPEC_RA_SMT_THUSB24_TYPEC_SH4_CON24_USB_TYPEC23K20101#LCP-582LFJ901
CON3_DC_PWR_JACK_THCONN_POWERJACK_3P_CON3_DC_PWR_JPJ1-021J902
CON9_USBA_VER_7P32X25P7USB_3P0_TYPEA_CON9_USBA_VER_7P3USB_TYPE_AJ903
CON_RA_HDMI_19P_0P5_SMATOM010130010052_HDMI_19P_CON_RCON HDMI 1X19J1001
CON6_AUDJACK_RA_THCONN_AUDIOJACK_6P_CON6_AUDJACK_SPJ-31060ADJ1101
CON_RJ45_10F_100_TH_RARJ45_HR851178C_CON_RJ45_10F_100HR851178CJ1201
CON_3_UFL_R_SMTUFL_CON_3_UFL_R_SMT_IO_1.4MM_21MXC3N2001J1301
CON_3_UFL_R_SMTUFL_CON_3_UFL_R_SMT_IO_1.4MM_21MXC3N2001J1302
CON_75_0P5_22X9_RACON_67_FEMALE_RA_A_CON_75_0P5_2CON_MINI CARD_RAJ1401
CON_36_0P8_THCONN_IPASS_36P_CON_36_0P8_TH_IOIPASS MINISASJ1501
CON_36_0P8_THCONN_IPASS_36P_CON_36_0P8_TH_IOIPASS MINISASJ1502
CON_36_0P8_THCONN_IPASS_36P_CON_36_0P8_TH_IOIPASS MINISASJ1503
CON9_SDCARD_1P1MMCONN_MICRO_SDCARD_9P_CON9_SDCARCONN_SD_CARD 9J1601
CON_USB_TYPE_B_SMMICRO_USB_CONN_11PIN_CON_USB_TYMICRO_USB_TYPEBJ1701
CON_FPC_60F_0P5_SM_RACON_1X60_CON_FPC_60F_0P5_SM_RA_XF2M-6015-1AHJ1801
0603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_120OHML101
0201_CCINDUCTOR_3_0201_CC_DISCRETE_0.3240 OHML104
IND_IHLPINDUCTOR_1_IND_IHLP_DISCRETE_3M1.5uHL701
IND_SPH2520INDUCTOR_IND_SPH2520_DISCRETE_21uHL702
IND_SPH2520INDUCTOR_IND_SPH2520_DISCRETE_21uHL703
IND_SPH2520INDUCTOR_IND_SPH2520_DISCRETE_21uHL704
IND_SPH2520INDUCTOR_IND_SPH2520_DISCRETE_21uHL705
IND_SPH2520INDUCTOR_IND_SPH2520_DISCRETE_30.47uHL706
IND_SPH2520INDUCTOR_IND_SPH2520_DISCRETE_21uHL707
IND2_4P3X4P3INDUCTOR_IND2_4P3X4P3_DISCRETE_4.7uHL709
IND_SPH2520INDUCTOR_IND_SPH2520_DISCRETE_30.47uHL710
0603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_120OHML901
0603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_120OHML1104
0603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_120OHML1201
IND_VLS3012_SMINDUCTOR_IND_VLS3012_SM_DISCRET4.7UHL1202
0603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_120OHML1203
IND_SPH2520INDUCTOR_IND_SPH2520_DISCRETE_11.5UHL1301
0603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_120OHML1306
0603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_120OHML1307
0603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_120OHML1401
0603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_120OHML1402
0603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_120OHML1702
IND4_CHOKE_0805DLW43_IND4_CHOKE_0805_DISCRETE_90OHML1703
SOT-23MOSFET_P_SOT-23_IC_1.12MM_480-7IRLML6401Q701
SOT323_32SK3018_SOT323_3_IC_0.9MM_480-72SK3018Q702
SOT323_32SK3018_SOT323_3_IC_0.9MM_480-72SK3018Q703
SOT323_3NMOSFET_3P_ESD_DIODE_1_SOT323_3RYU002N05Q704
DFN3P3X3P3_8L_EXMOSFET_P_5P_SO8_DFN3P3X3P3_8L_EAON7405Q901
SOT-23MOSFET_P_SOT-23_IC_1.11MM_480-7BSS84LT1Q902
SOT323_32SK3018_SOT323_3_IC_0.9MM_480-72SK3018Q903
SOT323_32SK3018_SOT323_3_IC_0.9MM_480-72SK3018Q905
SOT-23MOSFET_P_SOT-23_IC_1.12MM_480-7IRLML6401Q906
SOT323_32SK3018_SOT323_3_IC_0.9MM_480-72SK3018Q907
DFN3P3X3P3_8L_EXMOSFET_P_5P_SO8_DFN3P3X3P3_8L_EAON7405Q908
DFN3P3X3P3_8L_EXMOSFET_P_5P_SO8_DFN3P3X3P3_8L_EAON7405Q909
DFN3P3X3P3_8L_EXMOSFET_P_5P_SO8_DFN3P3X3P3_8L_EAON7405Q910
SOT-363_0P65_SMTTRAN_DUAL_NMOS_BSS138_SOT-363_0NX3020NAKSQ1001
SOT-363_0P65_SMTTRAN_DUAL_NMOS_BSS138_SOT-363_0NX3020NAKSQ1002
SOT-363_0P65_SMTTRAN_DUAL_NMOS_BSS138_SOT-363_0NX3020NAKSQ1003
SOT-363_0P65_SMTTRAN_DUAL_NMOS_BSS138_SOT-363_0NX3020NAKSQ1004
SOT323_32SK3018_SOT323_3_IC_0.9MM_480-72SK3018Q1301
SOT323_32SK3018_SOT323_3_IC_0.9MM_480-72SK3018Q1401
SOT-23MOSFET_P_SOT-23_IC_1.12MM_480-7IRLML6401Q1402
SOT323_32SK3018_SOT323_3_IC_0.9MM_480-72SK3018Q1403
SOT323_32SK3018_SOT323_3_IC_0.9MM_480-72SK3018Q1404
SOT323_32SK3018_SOT323_3_IC_0.9MM_480-72SK3018Q1405
SOT323_32SK3018_SOT323_3_IC_0.9MM_480-72SK3018Q1601
SOT-23MOSFET_P_SOT-23_IC_1.12MM_480-7IRLML6401Q1602
SOT323_32SK3018_SOT323_3_IC_0.9MM_480-72SK3018Q1603
SOT323_32SK3018_SOT323_3_IC_0.9MM_480-72SK3018Q1604
SOT_523NPN_SOT_523_IC_0.9 MM_480-78457MMBT3904TQ1605
SH0805RES_SHORT-2_3_SH0805_DISCRETE_0SOLDER SHORTSH701
SH0805RES_SHORT-2_3_SH0805_DISCRETE_0SOLDER SHORTSH702
SH0805RES_SHORT-2_3_SH0805_DISCRETE_0SOLDER SHORTSH703
SH0805RES_SHORT-2_3_SH0805_DISCRETE_0SOLDER SHORTSH704
SH0805RES_SHORT-2_3_SH0805_DISCRETE_0SOLDER SHORTSH706
SH0805RES_SHORT-2_3_SH0805_DISCRETE_0SOLDER SHORTSH708
SH0805RES_SHORT-2_3_SH0805_DISCRETE_0SOLDER SHORTSH709
SW_SPDT_RASW3_RA_SLIDE_SW_SPDT_RA_IC_1.4MSW SPDTSW701
97C04SW_DIP-4_SM_97C04_IC_1.65 MM_51DHN-04SW801
SW_DIP2_SMSW_DIP-2_SW_DIP2_SM_IC_1.65 MM_DHN-02SW802
SW2_3P4_TACT_SM_NSPNTC501-BG1G-B160T_SW2_3P4_TACT_TACT SWTICHSW1701
SW2_3P4_TACT_SM_NSPNTC501-BG1G-B160T_SW2_3P4_TACT_TACT SWTICHSW1702
C035STEST PAD_C035S_IC_0.1 MM_280-75TEST POINTTP1201
TESTPOINT_39MILTEST PAD_TESTPOINT_39MIL_IC_0MM1 mmTP1202
C035STEST PAD_C035S_IC_0.1 MM_280-75TEST POINTTP1301
C035STEST PAD_C035S_IC_0.1 MM_280-75TEST POINTTP1401
TEST_PIN_TP107TESTLOOP_TEST_PIN_TP107_IO_2.28TESTLOOPTP1402
TEST_PIN_TP107TESTLOOP_TEST_PIN_TP107_IO_2.28TESTLOOPTP1403
TEST_PIN_TP107TESTLOOP_TEST_PIN_TP107_IO_2.28TESTLOOPTP1404
TEST_PIN_TP107TESTLOOP_TEST_PIN_TP107_IO_2.28TESTLOOPTP1405
TEST_PIN_TP107TESTLOOP_TEST_PIN_TP107_IO_2.28TESTLOOPTP1406
TEST_PIN_TP107TESTLOOP_TEST_PIN_TP107_IO_2.28TESTLOOPTP1407
TESTPOINT_35MILT POINT R_TESTPOINT_35MIL_IC_0.TP_35MILTP1601
TPAD_020TESTLOOP_TPAD_020_IO_0.1MM_211-TPAD_020TP1602
TESTPOINT_35MILT POINT R_TESTPOINT_35MIL_IC_0.TP_35MILTP1701
TESTPOINT_35MILT POINT R_TESTPOINT_35MIL_IC_0.TP_35MILTP1702
TESTPOINT_35MILT POINT R_TESTPOINT_35MIL_IC_0.TP_35MILTP1703
TESTPOINT_35MILT POINT R_TESTPOINT_35MIL_IC_0.TP_35MILTP1704
TESTPOINT_35MILT POINT R_TESTPOINT_35MIL_IC_0.TP_35MILTP1705
TESTPOINT_35MILT POINT R_TESTPOINT_35MIL_IC_0.TP_35MILTP1706
TPAD_020TESTLOOP_TPAD_020_IO_0.1MM_211-TPAD_020TP1707
TPAD_020TESTLOOP_TPAD_020_IO_0.1MM_211-TPAD_020TP1708
TESTPOINT_35MILT POINT R_TESTPOINT_35MIL_IC_0.TP_35MILTP1709
TESTPOINT_35MILT POINT R_TESTPOINT_35MIL_IC_0.TP_35MILTP1710
TESTPOINT_35MILT POINT R_TESTPOINT_35MIL_IC_0.TP_35MILTP1711
TESTPOINT_35MILT POINT R_TESTPOINT_35MIL_IC_0.TP_35MILTP1712
TESTPOINT_35MILT POINT R_TESTPOINT_35MIL_IC_0.TP_35MILTP1713
TESTPOINT_35MILT POINT R_TESTPOINT_35MIL_IC_0.TP_35MILTP1801
TESTPOINT_35MILT POINT R_TESTPOINT_35MIL_IC_0.TP_35MILTP1802
DIODE2_SOD523DIODE_TVS_BIDIR_DIODE2_SOD523_IESD5B5.0ST1GTVS902
DIODE2_SOD523DIODE_TVS_BIDIR_DIODE2_SOD523_IESD5B5.0ST1GTVS903
DIODE2_SOD523DIODE_TVS_BIDIR_DIODE2_SOD523_IESD5B5.0ST1GTVS907
DIODE2_SOD523DIODE_TVS_BIDIR_DIODE2_SOD523_IESD5B5.0ST1GTVS1002
DIODE2_SOD523DIODE_TVS_BIDIR_DIODE2_SOD523_IESD5B5.0ST1GTVS1003
DIODE2_SOD523DIODE_TVS_BIDIR_DIODE2_SOD523_IESD5B5.0ST1GTVS1004
DIODE2_SOD523DIODE_TVS_BIDIR_DIODE2_SOD523_IESD5B5.0ST1GTVS1005
DIODE2_SOD523DIODE_TVS_BIDIR_DIODE2_SOD523_IESD5B5.0ST1GTVS1101
DIODE2_SOD523DIODE_TVS_BIDIR_DIODE2_SOD523_IESD5B5.0ST1GTVS1103
DIODE2_SOD523DIODE_TVS_BIDIR_DIODE2_SOD523_IESD5B5.0ST1GTVS1601
DIODE2_SOD523DIODE_TVS_BIDIR_DIODE2_SOD523_IESD5B5.0ST1GTVS1602
BGA621_HEATSINKMIMX8MQ7DVAJZXA_BGA621_BGA621_HMIMX8MQ6DVAJZAA + MBF25004-15W/2.0P+T725A1U101
BGA200_0P65X0P8_10P1X14P6MT53B768M32D4NQ_200P_BGA200_0P6MT53B768M32D4NQ-062 WT:BU201
SOT-23SGM803_SOT23-3P_SOT-23_IC_1.25MUM803RSU401
FBGA153_0P5_11P5X13MTFC8GACAEAM_VFBGA_0_FBGA153_0PMTFC16GAKAECN-2M WTU601
WPDFN8_1P27_8X6MMMT25QL256ABA1EW9_9P_WPDFN8_1P27MT25QL256ABA1EW9U603
QFN12_0P5_3P1X2P1MP8756_QFN_0_QFN12_0P5_3P1X2P1_MP8759GDU701
QFN56_0P5_8X8_EP4P1X4P4MC34PF4210_56P_QFN56_0P5_8X8_EPMC34PF4210A1ESU702
SOT-23-5MIC5233_ADJ_SOT23_5P_SOT-23-5_ILDCL015MRU703
SOT_143UM805_4P_SOT_143_IC_1.22MM_315-UM805REU704
QFN12_0P5_2X3MM_EPMP2147GD_1_QFN12_0P5_2X3MM_EP_IMP2147GDU705
DFN15_0P4_2X3MP2263GD_DFN15_0_DFN15_0P4_2X3_MP2263GDU706
QFN12_0P5_2X3MM_EPMP2147GD_1_QFN12_0P5_2X3MM_EP_IMP2147GDU707
SOT-23SGM803_SOT23-3P_SOT-23_IC_1.25MUM803RSU801
TSSOP8_A2G125_4_TSSOP8_A_IC_1.1MM_312-874LVC2G125U802
DHXQFN18_0P4_2X2P45PTN36043BX_DHXQFN18_23_DHXQFN18PTN36043U901
WLCSP15_0P4_2P42X1P22_SMDPPCMF3USB3S_A_WLCSP15_0P4_2P42X1PCMF3USB3SU902
WLCSP10_0P4_1P2X1P6MM_SMDPPCMF2USB3S_10P_WLCSP10_0P4_1P_1PCMF2USB3SU903
WLCSP12_0P4_1P38X1P68MM_SMDPNX5P3090UK_WLCSP12_WLCSP12_0P4_NX5P3090UKU905
BGA16_0P5_2P15X2P15NX5P3290_WLCSP16_BGA16_0P5_2P15NX5P3290U906
HX2QFN16_0P4_2P7X2P7PTN5110DHQ_HX2QFN16_0P4_2P7X2P7PTN5110DHQU907
WLCSP15_0P4_2P42X1P22_SMDPPCMF3USB3S_A_WLCSP15_0P4_2P42X1PCMF3USB3SU908
SOT-23-5SGM8709YN5G_SOT-23-5_IC_1.25MM_SGM8709YN5GU909
SOT23-6SGM8710_6P_SOT23-6_IC_1.25 MM_3SGM8710YN6G/TRU910
WLCSP15_0P4_2P42X1P22_SMDPPCMF3USB3S_15P_WLCSP15_0P4_2P42PCMF3HDMI2SU1001
WLCSP10_0P4_1P2X1P6MM_SMDPPCMF2USB3S_10P_WLCSP10_0P4_1P2XPCMF2HDMI2SU1002
TSSOP16WM8524GEDT_TSSOP16_IC_1.2MM_315WM8524CGEDTU1101
QFN48_0P4_6X6MM_EPADAR8031_48P_EP_QFN48_0P4_6X6MM_EAR8031U1201
QFN92_0P5X11P1X8P9LBEE5U91CQ-TEMP_QFN92_0P5X11P1XLBEE5U91CQ-TEMPU1301
QFN24_0P5_4X4_EP2P29FGV0241AKLF_24P_QFN24_0P5_4X4_9FGV0241AKLFU1302
QFN24_0P5_4X4_EP2P29FGV0241AKLF_24P_QFN24_0P5_4X4_9FGV0241AKLFU1401
XQFN12_0P4_1P8X2P1NTBA104GU12_12P_XQFN12_0P4_1P8XNTBA104GU12U1402
XQFN12_0P4_1P8X2P1NTBA104GU12_12P_XQFN12_0P4_1P8XNTBA104GU12U1403
TSSOP14NTS0104PW_14P_TSSOP14_IC_1.1MM_NTS0104PWU1501
TSSOP8_ANTB0102_8P_TSSOP8_A_IC_1.1MM_31NTS0102U1502
SOT-23-5MIC5233_ADJ_SOT23_5P_SOT-23-5_ILDCL015MRU1601
RCVR_SM_IRM_V5IRM-V538_RCVR_SM_IRM_V5_IC_2.85IRM-V538/TR1U1602
QFN24_0P5_4X4_EPCP2105_QFN24P_QFN24_0P5_4X4_EP_CP2105U1701
XTAL4_2P6X2P1MM_SMXTAL_13Y_XTAL4_2P6X2P1MM_SM_IC_25MHzY401
XTAL4_2P6X2P1MM_SMXTAL_13Y_XTAL4_2P6X2P1MM_SM_I_127MHzY402
XTAL_3P4X1P7_SMXTAL_OSC_ASH7K_4P_XTAL_3P4X1P7_32.768KHZY403
OSC6_1P27_5P2X3P4NX5427001Z_6P_OSC6_1P27_5P2X3P427MHzY501
XTAL4_2P6X2P1MM_SMXTAL_13Y_XTAL4_2P6X2P1MM_SM_IC_25MHzY1201
XTAL4_2P6X2P1MM_SMXTAL_13Y_XTAL4_2P6X2P1MM_SM_IC_25MHzY1301
XTAL4_2P6X2P1MM_SMXTAL_13Y_XTAL4_2P6X2P1MM_SM_IC_25MHzY1401
重要提示:PCB作品文件展下载说明
mini | 2018-12-7 14:42:36 | 显示全部楼层
SCH-29615_B5.DSN.rar (710 KB, 下载次数: 27)
b838899 | 2018-12-7 16:03:57 | 显示全部楼层
ldj186 | 2018-12-8 10:35:04 | 显示全部楼层
hf861004 | 2018-12-8 14:48:26 | 显示全部楼层
steelen | 2019-1-9 15:26:58 | 显示全部楼层
ky175 | 2019-1-10 07:15:15 | 显示全部楼层
菜刀 | 2019-2-15 16:27:31 | 显示全部楼层
zzr1974418 | 2019-3-27 09:44:25 | 显示全部楼层
richardz | 2019-3-27 10:09:40 | 显示全部楼层
VERY GOOD!
