[Allegro16.6以下] KITPF3000FRDMEVM评估套件-PF30001电源管理集成电路原理图PCB
查看2596 | 回复14 | 2018-12-10 19:37:20 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
SYM_NAME
COMP_DEVICE_TYPE
COMP_VALUE
COMP_TOL
COMP_CLASS
REFDES
RC0805_OV
RES_RC0805_OV_DISCRETE_0.4MM_47
1K
5%
DISCRETE
020
RC0805_OV
1K
5%
DISCRETE
BATT_MS
LICELL_BATT_MS_IC_2.8MM_670-000
LICELL
IC
BAT1
C280-130T
MOUNT_HOLE_C280-130T_IC_0 MM_28
MTG
IC
BH1
C280-130T
MTG
IC
BH2
C280-130T
MTG
IC
BH3
C280-130T
MTG
IC
BH4
CC0805_OV
CAP_NP_CC0805_OV_DISCRETE_1.45
47uF
DISCRETE
C1
CC0805_OV
47uF
DISCRETE
C2
CC0603_OV
CAP_NP_CC0603_OV_DISCRETE_0.90M
1.0UF
DISCRETE
C3
CC0805_OV
CAP_NP_CC0805_OV_DISCRETE_1.45M
22uF
20%
DISCRETE
C4
CC0805_OV
22uF
20%
DISCRETE
C5
CC0603_OV
1.0UF
DISCRETE
C6
CC0805_OV
CAP_NP_CC0805_OV_DISCRETE_1.4MM
10UF
10%
DISCRETE
C7
CC0402_25
CAP_NP_CC0402_25_DISCRETE_0.55M
0.22uF
10%
DISCRETE
C8
CC0402_25
CAP_NP_CC0402_25_DISCRETE_0.6MM
1.0UF
DISCRETE
C9
CC0402_25
CAP_NP_CC0402_25_DISCRETE_0.64M
0.1UF
10%
DISCRETE
C10
CC0402_25
1.0UF
DISCRETE
C11
CC0402_25
1.0UF
DISCRETE
C12
CC0402_25
0.22uF
10%
DISCRETE
C13
CC0805_OV
22uF
20%
DISCRETE
C14
CC0402_25
CAP_NP_CC0402_25_DISCRETE_0.6_1
0.47uF
10%
DISCRETE
C15
CC0402_25
CAP_NP_CC0402_25_DISCRETE_0.65M
4.7uF
20%
DISCRETE
C16
CC0805_OV
22uF
20%
DISCRETE
C17
CC0805_OV
22uF
20%
DISCRETE
C18
CC0805_OV
22uF
20%
DISCRETE
C19
CC0805_OV
22uF
20%
DISCRETE
C20
CC0402_25
1.0UF
DISCRETE
C21
CC0402_25
0.1UF
10%
DISCRETE
C22
CC0805_OV
22uF
20%
DISCRETE
C23
CC0402_25
CAP_NP_CC0402_25_DISCRETE_0.5_1
2.2UF
20%
DISCRETE
C24
CC0402_25
1.0UF
DISCRETE
C25
CC0402_25
1.0UF
DISCRETE
C26
CC0402_25
4.7uF
20%
DISCRETE
C27
CC0402_25
0.1UF
10%
DISCRETE
C28
CC0402_25
1.0UF
DISCRETE
C29
CC0402_25
2.2UF
20%
DISCRETE
C30
CC0805_OV
22uF
20%
DISCRETE
C31
CC0805_OV
22uF
20%
DISCRETE
C32
CC0402_25
0.1UF
10%
DISCRETE
C33
CC0402_25
0.1UF
10%
DISCRETE
C34
CC0402_25
0.1UF
10%
DISCRETE
C35
CC0805_OV
22uF
20%
DISCRETE
C36
CC0805_OV
10UF
10%
DISCRETE
C37
CC0402_25
CAP_NP_CC0402_25_DISCRETE_0.74
0.01UF
10%
DISCRETE
C38
CC0805_OV
22uF
20%
DISCRETE
C39
CC0805_OV
10UF
10%
DISCRETE
C41
CC0402_25
2.2UF
20%
DISCRETE
C42
CC0603_OV
CAP_NP_CC0603_OV_DISCRETE_0.9MM
4.7uF
10%
DISCRETE
C43
CC0402_25
0.1UF
10%
DISCRETE
C46
CC0402_25
0.1UF
10%
DISCRETE
C47
CC0402_25
0.1UF
10%
DISCRETE
C48
CC0402_25
0.1UF
10%
DISCRETE
C49
CC0805_OV
10UF
10%
DISCRETE
C50
CC0805_OV
10UF
10%
DISCRETE
C53
CC0402_25
0.1UF
10%
DISCRETE
C54
CC0805_OV
10UF
10%
DISCRETE
C55
CC0402_25
0.1UF
10%
DISCRETE
C56
CC0402_25
4.7uF
20%
DISCRETE
C58
CC0402_25
1.0UF
DISCRETE
C59
CC0402_25
0.1UF
10%
DISCRETE
C60
CC0805_OV
CAP_NP_CC0805_OV_DISCRETE_1.35
0.1UF
10%
DISCRETE
C63
CC0805_OV
CAP_NP_CC0805_OV_DISCRETE_1.4_1
10UF
10%
DISCRETE
C64
CC0805_OV
0.1UF
10%
DISCRETE
C65
CC0805_OV
10UF
10%
DISCRETE
C66
CC0805_OV
0.1UF
10%
DISCRETE
C67
CC0805_OV
0.1UF
10%
DISCRETE
C68
CC0805_OV
10UF
10%
DISCRETE
C69
CC0805_OV
0.1UF
10%
DISCRETE
C70
SOD123LF
DIODE_SCHTKY_SOD123LF_IC_1.0MM_
MBR120LSFT1G
IC
D1
LED_0603
LED_LED_0603_IC_1.1MM_370-76425
LED Green
IC
D2
RAPC722
DC_POWER_JACK_3_RAPC722_IO_11.0
CON_1_PWR
IO
J1
CON_BANANA_571
CONN_HDR_2X1_CON_BANANA_571_IO_
BANANA RED
IO
J2
CON_BANANA_571
CONN_HDR_2X1_CON_BANANA_571_I_1
CONN BANANA BLACK 2
IO
J3
CON_BANANA_571
BANANA RED
IO
J4
CONN_HDR_3X1
CONN_HDR_3X1_CONN_HDR_3X1_IO_8.
HDR 1X3
IO
J5
HDR102
CONN_HDR_1X2_HDR102_IO_8.6MM_21
HDR 1X2 TH
IO
J6
HDR102
HDR 1X2 TH
IO
J7
HDR102
HDR 1X2 TH
IO
J8
HDR102
HDR 1X2 TH
IO
J9
CONN_HDR_3X1
HDR 1X3
IO
J10
CONN_HDR_3X1
HDR 1X3
IO
J11
CONN_HDR_3X1
HDR 1X3
IO
J12
CONN_HDR_3X1
HDR 1X3
IO
J13
HDR102
HDR 1X2 TH
IO
J14
HDR102
HDR 1X2 TH
IO
J15
HDR102
HDR 1X2 TH
IO
J16
HDR102
HDR 1X2 TH
IO
J17
HDR102
HDR 1X2 TH
IO
J18
CON_SKT2X8_TH
HDR_2X8_M_CON_SKT2X8_TH_IO_8.76
CON 2X8
IO
J19
CON2X10_2P54_TH
CONN_HDR_10X2_CON2X10_2P54_TH_I
CON_2X10
IO
J20
CON_SKT2X8_TH
CON 2X8
IO
J21
CON_SKT2X6_TH
CONN_HDR_6X2_CON_SKT2X6_TH_IO_8
CON 2X6 SKT
IO
J22
HDR102
HDR 1X2 TH
IO
J24
HDR102
HDR 1X2 TH
IO
J25
IND_COILCRAFT_3X3MM
INDUCTOR_IND_COILCRAFT_3X3MM_DI
2.2UH
20%
DISCRETE
L1
IND2_2P2X2P7_SM
INDUCTOR_IND2_2P2X2P7_SM_DISCRE
1.5uH
DISCRETE
L2
IND2_2P2X2P7_SM
1.5uH
DISCRETE
L3
IND2_2P2X2P7_SM
1.5uH
DISCRETE
L4
IND2_2P2X2P7_SM
1.5uH
DISCRETE
L5
MLP6_2X2MM_SLUG
FDMA510PZ_MLP6_2X2MM_SLUG_IC_0.
FDMA908PZ
IC
Q2
SO8_1P27_4X5
MOSFET_N_S3_D4_SO8_1P27_4X5_IC_
SI4156DY
IC
Q20
SO8_1P27_4X5
SI4156DY
IC
Q21
RC0603_OV
RES_RC0603_OV_DISCRETE_0.4MM_47
DISCRETE
R1
RC0402_25
RES_RC0402_25_DISCRETE_0.45MM_4
100K
5%
DISCRETE
R2
RC0603_OV
DISCRETE
R3
RC0402_25
100K
5%
DISCRETE
R4
RC0805_OV
MOT_RES_RC0805_OV_DISCRETE_0._1
4.7K
1%
DISCRETE
R5
RC0805_OV
4.7K
1%
DISCRETE
R6
RC0402_25
100K
5%
DISCRETE
R7
RC0402_25
100K
5%
DISCRETE
R8
RC0402_25
100K
5%
DISCRETE
R9
RC0402_25
100K
5%
DISCRETE
R10
RC0603_OV
DISCRETE
R11
RC0805_OV
MOT_RES_RC0805_OV_DISCRETE_0.4
300
1%
DISCRETE
R12
RC0603_OV
DISCRETE
R14
RC0603_OV
DISCRETE
R15
RC0603_OV
DISCRETE
R16
RC0805_OV
4.7K
1%
DISCRETE
R17
RC0603_OV
DISCRETE
R18
RC0402_25
100K
5%
DISCRETE
R19
RC0805_OV
4.7K
1%
DISCRETE
R20
RC0603_OV
DISCRETE
R21
RC0402_25
RES_RC0402_25_DISCRETE_0.45MM_1
100K
5%
DISCRETE
R22
RC0402_25
100K
5%
DISCRETE
R23
RC0402_25
100K
5%
DISCRETE
R24
RC0402_25
100K
5%
DISCRETE
R25
RC0402_25
100K
5%
DISCRETE
R26
RC0805_OV
1K
5%
DISCRETE
R27
RC0805_OV
RES_RC0805_OV_DISCRETE_0.4MM__1
1.80K
5%
DISCRETE
R36
CASE6627
RES_CASE6627_DISCRETE_470-75919
1.0
DISCRETE
R37
RC0805_OV
RES_RC0805_OV_DISCRETE_470-7546
15.0K
DISCRETE
R38
CASE6627
1.0
DISCRETE
R39
RC0805_OV
15.0K
DISCRETE
R40
RC0805_OV
1K
5%
DISCRETE
R41
SW3_SPDT_4P3X8P6_TH
SW_MAG_SPDT_SW3_SPDT_4P3X8P6_TH
SPDT_SWITCH
IC
SW1
SW2_9P11_6X3P5_SM
SW2P_SW2_9P11_6X3P5_SM_IC_4.57M
FSMSM
IC
SW2
TEST_PIN_TP107
TESTLOOP_TEST_PIN_TP107_IO_2.28
TESTLOOP
IO
TP1
TEST_PIN_10_201-XX
TEST_POINT_10-201-X_TEST_PIN_10
TESTPOINT
IC
TP2
C035S
T POINT R_C035S_IC_0.1 MM_280-7
TEST POINT
IC
TP3
TEST_PIN_TP107
TESTLOOP
IO
TP4
TEST_PIN_10_201-XX
TESTPOINT
IC
TP5
TP_TH_063
T POINT TH_TP_TH_063_IC_5.6 MM_
5007
IC
TP6
TP_TH_063
5007
IC
TP7
C035S
TEST POINT
IC
TP8
TP_TH_063
5007
IC
TP9
C035S
TEST POINT
IC
TP10
TP_TH_063
TESTLOOP_TP_TH_063_IO_8.13MM_21
TESTLOOP_RED
IO
TP11
TP_TH_063
TESTLOOP_RED
IO
TP12
TP_TH_063
5007
IC
TP13
TP_TH_063
5007
IC
TP14
TP_TH_063
5007
IC
TP15
TP_TH_063
5007
IC
TP16
C035S
TEST POINT
IC
TP17
TEST_PIN_10_201-XX
TESTPOINT
IC
TP18
TEST_PIN_TP107
TESTLOOP
IO
TP19
TP_TH_063
TESTLOOP_RED
IO
TP20
TEST_PIN_10_201-XX
TESTPOINT
IC
TP21
TEST_PIN_TP107
TESTLOOP
IO
TP22
TEST_PIN_10_201-XX
TESTPOINT
IC
TP23
TP_TH_063
TESTLOOP_RED
IO
TP24
TP_TH_063
TESTLOOP_RED
IO
TP25
TP_TH_063
TESTLOOP_RED
IO
TP26
TEST_PIN_10_201-XX
TESTPOINT
IC
TP27
TEST_PIN_10_201-XX
TESTPOINT
IC
TP28
TP_TH_063
TESTLOOP_RED
IO
TP29
TP_TH_063
TESTLOOP_RED
IO
TP30
TEST_PIN_10_201-XX
TESTPOINT
IC
TP31
TESTPOINT_35MIL
T POINT R_TESTPOINT_35MIL_IC_0.
TP_35MIL
IC
TP32
TESTPOINT_35MIL
TP_35MIL
IC
TP33
TP_TH_063
5007
IC
TP35
TP_TH_063
5007
IC
TP36
TEST_PIN_10_201-XX
TESTPOINT
IC
TP37
TP_TH_063
5007
IC
TP41
TP_TH_063
5007
IC
TP42
TEST_PIN_10_201-XX
TESTPOINT
IC
TP44
SC82_4
NCP562_SC82_4_IC_1.1MM_312-7732
NCP562
IC
U1
QFN48_0P5_7X7_EP4P14X4P22
MC32PF300XEP_48P_QFN48_0P5_7X7_
MC32PF300XEP
IC
U2
MSOP08_0P65_3P2X3P2
AD8606ARMZ-R7_8P_MSOP08_0P65_3P
AD8606ARMZ-R7
IC
U3
SOT23-6
ADR34XX_SOT23_6P_SOT23-6_IC_1.4
ADR3425ARJZ
IC
U4
TSSOP24_0P65_7P9X4P5
ADG715_24P_TSSOP24_0P65_7P9X4P5
ADG715
IC
U5
ADG715
IC
U6
SO8_1P27_4X5
OPAMP_DUAL_8P_D_SO8_1P27_4X5_IC
MCP6V07
IC
U21
MSOP_10_0P5_3X3
MCP4728_MSOP_10_0P5_3X3_IC_1.1M
MCP4728
IC
U23
SO8_1P27_4X5
MCP6V07
IC
U24
重要提示:PCB作品文件展下载说明
mini | 2018-12-10 19:38:21 | 显示全部楼层
SCH.rar (99 KB, 下载次数: 2)
洛洛123456 | 2018-12-10 20:11:12 | 显示全部楼层
bidezhi7777 | 2018-12-10 21:15:11 | 显示全部楼层
yangxf0120 | 2018-12-10 22:00:30 | 显示全部楼层
谢谢分享KITPF3000FRDMEVM评估套件-PF30001电源管理集成电路原理图PCB
郑先生 | 2018-12-11 08:07:12 | 显示全部楼层
fxliuqq | 2018-12-11 08:20:37 | 显示全部楼层
谢谢分享谢谢分享谢谢分享
小顺430 | 2018-12-11 08:22:26 | 显示全部楼层
boatxin | 2018-12-11 08:34:24 | 显示全部楼层
bidinghong | 2018-12-11 08:42:29 | 显示全部楼层
