[Allegro16.6以下] 采用MK64FN1M0VMD12芯片设计的NXP Rapid IoT Prototyping Kit原理图与P
查看7125 | 回复41 | 2018-12-16 14:24:35 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
PWA, MAIN SLN-RPK-NODE
游客,如果您要查看本帖隐藏内容请回复
Bill of Material ReportSYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDESCC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC1CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC2CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC3CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC4CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC5CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC6CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC7CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_718PF DISCRETEC8CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_718PF DISCRETEC9CC0402_25CAP_NP_CC0402_25_DISCRETE_0.642.2uF DISCRETEC10CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC11CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC12CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC13CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M12PF DISCRETEC14CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M12PF DISCRETEC15CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_10.9PF DISCRETEC16CC0402_25CAP_NP_CC0402_25_DISCRETE_0.7MM10uF DISCRETEC18CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_31uF DISCRETEC19CC0402_25CAP_NP_CC0402_25_DISCRETE_0.7MM10uF DISCRETEC20CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC21CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_43pF DISCRETEC22CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_43pF DISCRETEC23CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC24CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC25CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC26CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC27CC0402_25CAP_NP_CC0402_25_DISCRETE_0.74M15PF DISCRETEC28CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC29CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC30CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_14.7uF DISCRETEC31CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC32CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC33CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC34CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_31uF DISCRETEC35CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC36CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC37CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC38CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC40CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC41CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC42CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC43CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC44CC0402_25CAP_NP_CC0402_25_DISCRETE_0.7MM10uF DISCRETEC45CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4522uF DISCRETEC46CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_5100PF DISCRETEC47CC0402_25CAP_NP_CC0402_25_DISCRETE_0.7MM10uF DISCRETEC48CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_31uF DISCRETEC50CC0402_25CAP_NP_CC0402_25_DISCRETE_0.642.2uF DISCRETEC51CC0402_25CAP_NP_CC0402_25_DISCRETE_0.7MM10uF DISCRETEC52CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_31uF DISCRETEC53CC0402_25CAP_NP_CC0402_25_DISCRETE_0.7MM10uF DISCRETEC56CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC57CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC58CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC59CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC60CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_31uF DISCRETEC61CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC62CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC63CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_14.7uF DISCRETEC65CC0402_25CAP_NP_CC0402_25_DISCRETE_0.56M10pF DISCRETEC66CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6 M0.1uF DISCRETEC72CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_43pF DISCRETEC76CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_43pF DISCRETEC77DSN1006-2DIODE_SCHTKY_DSN1006-2_IC_0.3MMPMEG3010AESBYL ICD3DSN1006-2DIODE_SCHTKY_DSN1006-2_IC_0.3MMPMEG3010AESBYL ICD4DSN1006-2DIODE_SCHTKY_DSN1006-2_IC_0.3MMPMEG3010AESBYL ICD5LED_1X0P6_SMLED_LED_1X0P6_SM_IC_0.4MM_370-7BLUE ICD7ANTENNA_2P_3P4X1P8ANTENNA_WE-MCA_ANTENNA_2P_3P4X1AMCA31-2R450G-S1F-T ICE1CON5_MICROUSB_SKT_SMMICRO_USB_CON5_MICROUSB_SKT_SM_47346-0001 IOJ3CON2X25_0P5_SM_DF12DPCONN_2X25_SH_DF12_CON2X25_0P5_SDF12(4.0)-50DP-0.5V(86) IOJ4FFC1X10_0P5_9P9X5P45CONN_10X1_SH_FFC1X10_0P5_9P9X5PCON_1X10_FPC IOJ5CON4_FPC_0P5_SMCONN_FPC_4P_CON4_FPC_0P5_SM_IO_CON_1X4_FPC IOJ6CON2X10_0P5_SM_DF12DPCON2X10_SFP_CON2X10_0P5_SM_DF12DF12(4.0)-20DP-0.5V(86) IOJ7CON2X10_0P5_SM_DF12DSCON2X10_SFP_CON2X10_0P5_SM_DF_1CON2X10_SKT IOJ8SPRINGCLIP_2P4X1P3SPRING_SOCKET_SPRINGCLIP_2P4X1P105439-0005 IOJ9SPRINGCLIP_2P4X1P3SPRING_SOCKET_SPRINGCLIP_2P4X1P105439-0005 IOJ10CON2_1MM_5P6X4P3CONN_2X1_SH_CON2_1MM_5P6X4P3_IOCON_1x2 IOJ11IND_1608BEAD_IND_1608_DISCRETE_0.95MM_1600 OHM DISCRETEL4IND_1608BEAD_IND_1608_DISCRETE_0.95MM_1600 OHM DISCRETEL5IND_0603IND_FERRITE_IND_0603_DISCRETE_0330 OHM@100MHZ25%DISCRETEL6IND_0603IND_FERRITE_IND_0603_DISCRETE_0330 OHM@100MHZ25%DISCRETEL7IND_0402INDUCTOR_IND_0402_DISCRETE_0.554.7nH0.1nHDISCRETEL8BUZZER_4X4MM_SMSPEAKER_BUZZER_4X4MM_SM_IC_2.5MCMT-4023S-SMT ICLS1SC70_3MOSFET_P_SC70_3_IC_1.1MM_480-79SI1317DL-T1-GE3 ICQ1SC70_3MOSFET_P_SC70_3_IC_1.1MM_480-79SI1317DL-T1-GE3 ICQ2SOT-23MOSFET_N_SOT-23_IC_1.2MM_480-79Si2302CDS ICQ3RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_10K DISCRETER1RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_10K DISCRETER2RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_10K DISCRETER3RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110M DISCRETER4RC0402_25RES_RC0402_25_DISCRETE_0.41MM_14.7K DISCRETER7RC0402_25RES_RC0402_25_DISCRETE_0.41MM_14.7K DISCRETER8RC0402_25RES_RC0402_25_DISCRETE_0.4MM_47100K DISCRETER9RC0402_25RES_RC0402_25_DISCRETE_0.4MM_47100K DISCRETER10RC0402_25RES_RC0402_25_DISCRETE_0.4MM_47100K DISCRETER12RC0402_25RES_RC0402_25_DISCRETE_0.45MM_41.0M DISCRETER13RC0402_25RES_RC0402_25_DISCRETE_0.4MM_47100K DISCRETER14RC0402_25RES_RC0402_25_DISCRETE_0.45MM_41.0M DISCRETER15RC0402_25RES_RC0402_25_DISCRETE_0.4MM_47100K DISCRETER16RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110M DISCRETER17RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110M DISCRETER18RC0402_25RES_RC0402_25_DISCRETE_0.4MM__218K DISCRETER19RC0402_25RES_RC0402_25_DISCRETE_0.4MM_47100K DISCRETER20RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110M DISCRETER21RC0402_25RES_RC0402_25_DISCRETE_0.4MM_47100K DISCRETER22RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110M DISCRETER23RC0402_25RES_RC0402_25_DISCRETE_0.4MM_47100K DISCRETER24RC0402_25RES_RC0402_25_DISCRETE_0.40 M_133K DISCRETER25RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_10K DISCRETER26RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_10K DISCRETER27RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_10K DISCRETER28RC0402_25RES_RC0402_25_DISCRETE_0.45MM_41.0M DISCRETER30RC0402_25RES_RC0402_25_DISCRETE_0.4MM_47100K DISCRETER31RC0402_25RES_RC0402_25_DISCRETE_0.4MM_47100K DISCRETER32RC0402_25RES_RC0402_25_DISCRETE_0.4MM_47100K DISCRETER33RC0402_25RES_RC0402_25_DISCRETE_0.4MM_47100K DISCRETER34RC0402_25RES_RC0402_25_DISCRETE_0.4 MM_468 DISCRETER36RC0402_25RES_RC0402_25_DISCRETE_0.40 M_282K DISCRETER38RC0402_25RES_RC0402_25_DISCRETE_0.4MM__333 DISCRETER39RC0402_25RES_RC0402_25_DISCRETE_0.4MM__333 DISCRETER40RC0402_25RES_RC0402_25_DISCRETE_0.4MM__4150K DISCRETER41RC0402_25RES_RC0402_25_DISCRETE_0.45MM_41.0M DISCRETER42RC0402_25RES_RC0402_25_DISCRETE_0.41MM_447 DISCRETER43RC0402_25RES_RC0402_25_DISCRETE_0.45MM_41.0M DISCRETER44RC0402_25RES_RC0402_25_DISCRETE_0.45MM_41.0M DISCRETER45RC0402_25RES_RC0402_25_DISCRETE_0.4MM__51K DISCRETER46RC0402_25RES_RC0402_25_DISCRETE_0.4MM__51K DISCRETER47RC0402_25RES_RC0402_25_DISCRETE_0.41MM_14.7K DISCRETER49RC0402_25RES_RC0402_25_DISCRETE_0.41MM_14.7K DISCRETER50RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_40 DISCRETER51RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_10K DISCRETER52RC0402_25RES_RC0402_25_DISCRETE_0.45MM_41.0M DISCRETER53RC0402_25RES_RC0402_25_DISCRETE_0.4MM_47100K DISCRETER54RC0402_25RES_RC0402_25_DISCRETE_0.4MM_47100K DISCRETER55RC0402_25RES_RC0402_25_DISCRETE_0.4MM__6150 DISCRETER64RC0402_25RES_RC0402_25_DISCRETE_0.4MM__51K DISCRETER65RC0402_25RES_RC0402_25_DISCRETE_0.4MM__51K DISCRETER66RC0402_25RES_RC0402_25_DISCRETE_0.4MM__51K DISCRETER67RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_40 DISCRETER68RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_40 DISCRETER70RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110M DISCRETER72RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110M DISCRETER73RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110M DISCRETER74RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110M DISCRETER75SW_SIDE_PUSH_SKRT_SMSW_SPST_3P_PB_SW_SIDE_PUSH_SKRTSKRTLBE010 ICSW1SW_SIDE_PUSH_SKRT_SMSW_SPST_3P_PB_SW_SIDE_PUSH_SKRTSKRTLBE010 ICSW2SW_SIDE_PUSH_SKRT_SMSW_SPST_3P_PB_SW_SIDE_PUSH_SKRTSKRTLBE010 ICSW3SW_SIDE_PUSH_SKRT_SMSW_SPST_3P_PB_SW_SIDE_PUSH_SKRTSKRTLBE010 ICSW4SW4_4P2X2P8_SMSW4_PB_SPST_4P_SW4_4P2X2P8_SM_IKMR231NG LFS ICSW5TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP1TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP2TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP3TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP4TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP5TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP6TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP7TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP8TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP9TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP10TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP11TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP12TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP13TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP14TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP15TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP16TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP17TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP18TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP19TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP20TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP21TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP22TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP23TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP24TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP25TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP26TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP27TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP28TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP29TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP30TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP31T_POINT0_7MM_R_1_2MMT POINT TH_T_POINT0_7MM_R_1_2MMTESTPOINT ICTP32T_POINT0_7MM_R_1_2MMT POINT TH_T_POINT0_7MM_R_1_2MMTESTPOINT ICTP33TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP34TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP35TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP36MAPBGA144_1_13X13PK64FN1M0VMD12_BGA_144P_MAPBGA1MK64FN1M0VMD12 ICU1MAPLGA48_7X7_0P5MMKW41Z512_64P_MAPLGA48_7X7_0P5MMMKW41Z512VHT4 ICU2DFN8_1P27_6X5MM_3P1MT25QL256ABA1EW9_9P_DFN8_1P27_6MT25QL128ABA1EW7-0SIT ICU3XQFN10_0P5_1P65X2P1NX3L2267GM_QFN10_XQFN10_0P5_1P6NX3L2267GM,115 ICU4QFN8_1P6X1P6MMNT3H2211W0FHK_QFN8_1P6X1P6MM_ICNT3H2211W0FHK ICU5QFN5X3_0P5_3X3FXOS8700CQ_QFN_16P_QFN5X3_0P5_3FXOS8700CQ ICU6QFN24_0P5_4X4_ASYM_EXPFXAS21002CQ_QFN_24P_QFN24_0P5_4FXAS21002CQ ICU7QFN4_0P95_2X2ENS210-LQFM_QFN4_0P95_2X2_IC_0.ENS210-LQFM ICU8XQFN10_0P5_1P65X2P1NX3L2267GM_QFN10_XQFN10_0P5_1P6NX3L2267GM,115 ICU10LGA10_0P6_2P7X4CCS811B_LGA_11P_LGA10_0P6_2P7X4CCS811B-JOPD500 ICU11LGA8_1P25_3X5_0P5PPL3115A2_LGA_8P_LGA8_1P25_3X5_MPL3115A2 ICU12USPN4_0P55_1P2X0P9XC8102AA017R-G_4P_USPN4_0P55_1PXC8102AA017R-G ICU13IC8_2P1X2P6_SMTXCL220B1_IC8_2P1X2P6_SMT_IC_1.0XCL210A321GR-G ICU14WLCSP4_0P4_0P8X0P8_SMDPADP172_CSP_4P_WLCSP4_0P4_0P8X0PNX3P191UK ICU15WLCSP4_0P4_0P8X0P8_SMDPADP172_CSP_4P_WLCSP4_0P4_0P8X0PNX3P191UK ICU16DFN_8_0P5_2X3MC34671AEP_DFN_8_0P5_2X3_IC_0.6MC34671AEP ICU17WLCSP4_0P4_0P8X0P8_SMDPADP172_CSP_4P_WLCSP4_0P4_0P8X0PNX3P191UK ICU18SOT-563_6P_0P5_SMTNX3008_SOT666_6PIN_SOT-563_6P_0DMG1016V-7 ICU19QFN16_0P5_3X3MMPCF2123BS_QFN16_QFN16_0P5_3X3MMPCF2123BS/1,518 ICU21DFN1616-6RCLAMP1654P_NEW_DFN1616-6_IC_0.PUSBM5V5X4-TL ICU23WLCSP4_0P4_0P97X1P06A1006UK_WLCSP4_WLCSP4_0P4_0P97XA1006UK ICU25XTAL_4_3P3X2P6MMXTAL_13_XTAL_4_3P3X2P6MM_IC_1MM12MHz ICY1XTAL4_2P1X1P7MM_SMXTAL_13_XTAL4_2P1X1P7MM_SM_IC_032MHZ ICY2XTAL2-3P2X1P5-SMXTAL_XTAL2-3P2X1P5-SM_IC_0.9MM_32.768KHz ICY3XTAL2_2P15X1P3_SMXTAL_XTAL2_2P15X1P3_SM_IC_0.6 M32.768 KHZ ICY4
重要提示:PCB作品文件展下载说明
生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙!
topdenzengzhi | 2018-12-16 14:29:32 | 显示全部楼层
PWA, TOUCH SLN-RPK-NODE
LAY-30014_brd.zip (348 KB, 下载次数: 6)
带刀的老鼠 | 2019-1-4 09:16:39 | 显示全部楼层
xianrui1989 | 2019-1-4 10:24:54 | 显示全部楼层
lbmone | 2019-1-7 12:59:33 | 显示全部楼层
feipeng | 2019-2-11 09:05:02 | 显示全部楼层
ymz000 | 2019-6-23 15:35:51 | 显示全部楼层
cdl511 | 2019-6-23 16:37:56 | 显示全部楼层
allegro | 2019-6-24 08:31:14 | 显示全部楼层
dqh520 | 2019-6-26 00:07:12 | 显示全部楼层
