[Allegro16.6以下] 采用FT230XS芯片设计的JN517x_Main_Board原理图与PCB文件
查看3662 | 回复14 | 2018-12-18 08:24:25 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
游客,如果您要查看本帖隐藏内容请回复
Bill of Material ReportSYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDESBUBBLE_DIAM8BUBBLE_CI_BUBBLE_DIAM8_BUBBLE1(BUBBLE1(x1) IC1BUBBLE_DIAM8BUBBLE_BLUE_JUMPER_2MM00_BUBBLEBUBBLE2(x9) IC2BUBBLE_DIAM8BUBBLE_VIS_M3X6_BUBBLE_DIAM8_BUBUBBLE3(x4) IC3BUBBLE_DIAM8BUBBLE_ENTRETOISE_NYLON_M3X15_BBUBBLE4(x4) IC4ANT_6T_40MM5X24MM5ANTENNA_ANT_6T_40MM5X24MM5_ANTEAntenna ICANT1CASEC_JENNICCAP POL_CASEC_JENNIC_100UF_10%100UF10%ICC1CASEC_JENNICCAP POL_CASEC_JENNIC_100UF_10%100UF10%ICC20603_NXP_JENNICCAP 0603 COG 50V 5%_0603_NXP__4NC ICC30603_NXP_JENNICCAP 0603 COG 50V 5%_0603_NXP__4NC ICC40603_NXP_JENNICCAP 0603 COG 50V 5%_0603_NXP__4NC ICC5CASEA_JENNICCAP POL_CASEA_JENNIC_10UF_10%10uF10%ICC6CASEA_JENNICCAP POL_CASEA_JENNIC_15UF_20%15uF20%ICC70603_NXP_JENNICCAP 0603 COG 50V 5%_0603_NXP__2100nF10%ICC80603_NXP_JENNICCAP 0603 COG 50V 5%_0603_NXP__5470nF ICC90603_NXP_JENNICCAP 0603 COG 50V 5%_0603_NXP_JE10nF ICC100603_NXP_JENNICCAP 0603 COG 50V 5%_0603_NXP__147pF ICC110603_NXP_JENNICCAP 0603 COG 50V 5%_0603_NXP__147pF ICC120603_NXP_JENNICCAP 0603 COG 50V 5%_0603_NXP__2100nF10%ICC130603_NXP_JENNICCAP 0402 X7R 16V 10%_0603_NXP_J15pF ICC140603_NXP_JENNICCAP 0603 COG 50V 5%_0603_NXP__312pF ICC150603_NXP_JENNICCAP 0603 COG 50V 5%_0603_NXP__312pF ICC16CASEA_JENNICCAP POL_CASEA_JENNIC_NCNC ICC17CASEA_JENNICCAP POL_CASEA_JENNIC_NCNC ICC180603_NXP_JENNICCAP 0603 COG 50V 5%_0603_NXP_JE10nF ICC19SIP-8P_JENNICHEADER_8P_SIP-8P_JENNIC_CON8_OPCON8_OP1 ICCN1SIP-8P_JENNICHEADER_8P_SIP-8P_JENNIC_CON8_OPCON8_OP1 ICCN2SIP-6P_JENNICHEADER_6P_SIP-6P_JENNIC_CON6_OPCON6_OP1 ICCN3SIP-6P_JENNICHEADER_6P_SIP-6P_JENNIC_CON6_OPCON6_OP1 ICCN4SOT23BAT754_SOT23_BAT754BAT754 ICD1LED_0603_JENNICKP-1608EC_LED_0603_JENNIC_LED_SLED_SMD ICD2LED_0603_JENNICKP-1608EC_LED_0603_JENNIC_LED_SLED_SMD ICD3SOD128_A1_K2DIODE SCHOTTKY_SOD128_A1_K2_PMEPMEG3020CEP ICD4LED_0603_JENNICKP-1608EC_LED_0603_JENNIC_LED_SLED_SMD ICD5LED_0603_JENNICKP-1608EC_LED_0603_JENNIC_LED_SLED_SMD ICD6LED_0603_JENNICKP-1608EC_LED_0603_JENNIC_LED_SLED_SMD ICD7SOT23BAT754_SOT23_BAT754BAT754 ICD8SOT23BAT754_SOT23_BAT754BAT754 ICD9LED_0603_JENNICKP-1608EC_LED_0603_JENNIC_LED_SLED_SMD ICD10LED_0603_JENNICKP-1608EC_LED_0603_JENNIC_LED_SLED_SMD ICD11LED_0603_JENNICKP-1608EC_LED_0603_JENNIC_LED_SLED_SMD ICD12SOT23BAT754_SOT23_BAT754BAT754 ICD130603_NXP_JENNICFERRITE_0603_NXP_JENNIC_FERRITEFERRITE ICFE1SC70_5P_JENNIC74LVC1G125_SC70_5P_JENNIC_74LVC74LVC1G125_NC ICIC1SC70_5P_JENNIC74LVC1G125_SC70_5P_JENNIC_74LVC74LVC1G125_NC ICIC2SC70_5P_JENNIC74LVC1G125_SC70_5P_JENNIC_74LVC74LVC1G125_NC ICIC3SC70_5P_JENNIC74LVC1G125_SC70_5P_JENNIC_74LVC74LVC1G125_NC ICIC4SC70_5P_JENNIC74LVC1G125_SC70_5P_JENNIC_74LVC74LVC1G125_NC ICIC5SC70_5P_JENNIC74LVC1G125_SC70_5P_JENNIC_74LVC74LVC1G125_NC ICIC6SC70_5P_JENNIC74LVC1G125_SC70_5P_JENNIC_74LVC74LVC1G125_NC ICIC7SC70_5P_JENNIC74LVC1G125_SC70_5P_JENNIC_74LVC74LVC1G125_NC ICIC8SC70_5P_JENNIC74LVC1G125_SC70_5P_JENNIC_74LVC74LVC1G125_NC ICIC9SC70_5P_JENNIC74LVC1G125_SC70_5P_JENNIC_74LVC74LVC1G125_NC ICIC10SC70_5P_JENNIC74LVC1G125_SC70_5P_JENNIC_74LVC74LVC1G125_NC ICIC11SC70_5P_JENNIC74LVC1G125_SC70_5P_JENNIC_74LVC74LVC1G125_NC ICIC12SO8M1_JENNICM25PX0_SO8_SO8M1_JENNIC_M25PX0_M25PX0_SO8 ICIC13JEDEC_MO137_AB_SSOP16FT230XS_JEDEC_MO137_AB_SSOP16_FFT230XS ICIC14SOT902-3NT3H1201_SOT902-3_NT3H1101NT3H1101 ICIC15SOT23-5_JENNICLP2985IM5_2.5_SOT23-5_JENNIC_LPLP2992 ICIC16SC70_5P_JENNIC74LVC1G125_SC70_5P_JENNIC_74LVC74LVC1G125_NC ICIC17SC70_5P_JENNIC74LVC1G125_SC70_5P_JENNIC_74LVC74LVC1G125_NC ICIC18SC70_5P_JENNIC74LVC1G125_SC70_5P_JENNIC_74LVC74LVC1G125_NC ICIC19AMPMODU_REC20_NOHOLES_JENNICCON2X10_HE10_AMPMODU_AMPMODU_RECON2X10_HE10_AMPMODU ICJ1AMPMODU_REC20_NOHOLES_JENNICCON2X10_HE10_AMPMODU_AMPMODU_RECON2X10_HE10_AMPMODU ICJ2HEADER34_JENNICHEADER_2X17_HEADER34_JENNIC_HEAHEADER_2X17 ICJ3CON_PWR_SMD_JENNICCON_PWR_0_CON_PWR_SMD_JENNIC_COCON_PWR_3P ICJ4USB_MINIB_JENNICUSB_MINIB_USB_MINIB_JENNIC_USB_USB_MINIB ICJ5SAMTEC_FTSH-105-01-L-DVHEADER_2X5_SAMTEC_FTSH-105-01-LHEADER_2X5 ICJ6BATCON_SMD_JENNICBATCON_BATCON_SMD_JENNIC_BATCONBATCON ICJ7BATCON_SMD_JENNICBATCON_BATCON_SMD_JENNIC_BATCONBATCON ICJ11BATCON_SMD_JENNICBATCON_BATCON_SMD_JENNIC_BATCONBATCON ICJ12BATCON_SMD_JENNICBATCON_BATCON_SMD_JENNIC_BATCONBATCON ICJ13CAV2MM_2POS_12BAR_1X3_MD_JUMPER_1-2_2MM_CAV2MBARx3 ICJP1M22-5320205HEADER_2_M22-5320205_M22-532020M22-5320205 ICJP2HDR6_SMT_APPSHDR6_2X3_HDR6_SMT_APPS_HDR6_2X3HDR6_2X3 ICJP3HDR6_SMT_APPSHDR6_2X3_HDR6_SMT_APPS_HDR6_2X3HDR6_2X3 ICJP4CAV2MM_2POS_12BAR_1X3_MD_JUMPER_1-2_2MM_CAV2MBARx3 ICJP5CAV2MM_2POS_12BAR_1X3_MD_JUMPER_1-2_2MM_CAV2MBARx3 ICJP6TROU3MM2_M_VIS_C_HEX12_PACKAGEMNT_HOLE_TROU3MM2_M_VIS_C_HEX12MNT_HOLE ICM1TROU3MM2_M_VIS_C_HEX12_PACKAGEMNT_HOLE_TROU3MM2_M_VIS_C_HEX12MNT_HOLE ICM2TROU3MM2_M_VIS_C_HEX12_PACKAGEMNT_HOLE_TROU3MM2_M_VIS_C_HEX12MNT_HOLE ICM3TROU3MM2_M_VIS_C_HEX12_PACKAGEMNT_HOLE_TROU3MM2_M_VIS_C_HEX12MNT_HOLE ICM4TP2-HA_APPSMNT_HOLE_TP2-HA_APPS_MNT_HOLEMNT_HOLE ICM5TP2-HA_APPSMNT_HOLE_TP2-HA_APPS_MNT_HOLEMNT_HOLE ICM60603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JENNDNF ICR10603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_10R ICR20603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_10R ICR30603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_10R ICR40603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_10R ICR50603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_30R_DNF ICR60603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_10R ICR70603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_10R ICR80603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_10R ICR90603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_10R ICR100603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_10R ICR110603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_10R ICR120603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_10R ICR130603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_10R ICR140603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_10R ICR150603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_2680R ICR160603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_2680R ICR170603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_10R ICR180603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_30R_DNF ICR190603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_10R ICR200603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_30R_DNF ICR210603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_30R_DNF ICR220603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_10R ICR230603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_2680R ICR240603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_2680R ICR250603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_4100K ICR260603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_4100K ICR270603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_4100K ICR280603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_4100K ICR290603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_556K2 ICR300603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_556K2 ICR310603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_556K2 ICR320603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_556K2 ICR330603_NXP_JENNICRES 0402 1% 1/16W_0603_NXP_JENN0R ICR340603_NXP_JENNICRES 0402 1% 1/16W_0603_NXP_JENN0R ICR350603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_2680R ICR360603_NXP_JENNICRES 0402 1% 1/16W_0603_NXP_JE_14K7 ICR370603_NXP_JENNICRES 0402 1% 1/16W_0603_NXP_JE_2NC ICR380603_NXP_JENNICRES 0402 1% 1/16W_0603_NXP_JE_14K7 ICR390603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_64K7 ICR400603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_718K ICR410603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_10R ICR420603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_10R ICR430603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_810K ICR440603_NXP_JENNICRES 0402 1% 1/16W_0603_NXP_JENN0R ICR450603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_2680R ICR460603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_2680R ICR470603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_2680R ICR480603_NXP_JENNICRES 0402 1% 1/16W_0603_NXP_JE_14K7 ICR490603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_90R_NC ICR500603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_90R_NC ICR510603_NXP_JENNICRES 0603 5% 1/16W_0603_NXP_JE_10R ICR52DPAK4_APPSLM1117IDT-3.3_DPAK4_APPS_LM1117LM1117_DPAK ICRG1PLOT050TP MK2_PLOT050_SPARESPARE ICSP1PLOT050TP MK2_PLOT050_SPARESPARE ICSP2PLOT050TP MK2_PLOT050_SPARESPARE ICSP3PLOT050TP MK2_PLOT050_SPARESPARE ICSP4PLOT050TP MK2_PLOT050_SPARESPARE ICSP5PLOT050TP MK2_PLOT050_SPARESPARE ICSP6PLOT050TP MK2_PLOT050_SPARESPARE ICSP7PLOT050TP MK2_PLOT050_SPARESPARE ICSP8PLOT050TP MK2_PLOT050_SPARESPARE ICSP9PLOT050TP MK2_PLOT050_SPARESPARE ICSP10PLOT050TP MK2_PLOT050_SPARESPARE ICSP11PLOT050TP MK2_PLOT050_SPARESPARE ICSP12ST_MERCEDESST_MERCEDES_0_ST_MERCEDES_STRAPSTRAP ICST1ST_MERCEDESST_MERCEDES_0_ST_MERCEDES_STRAPSTRAP ICST2SW_SMD_SPST_JENNICSW_SPST_SW_SMD_SPST_JENNIC_SW_SSW_SPST ICSW1SW_SMD_SPST_JENNICSW_SPST_SW_SMD_SPST_JENNIC_SW_SSW_SPST ICSW2PLOT050TP MK2_PLOT050_CTSCTS ICTP1PLOT050TP MK2_PLOT050_RTSRTS ICTP2PLOT050TP MK2_PLOT050_NFC_A1NFC_A1 ICTP3PLOT050TP MK2_PLOT050_NFC_A2NFC_A2 ICTP4XTAL_FC135XTAL_FC135_XTAL_FC135_32.768KHZ32.768kHz ICY1
重要提示:PCB作品文件展下载说明
生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙!
longxuekai | 2018-12-18 08:29:59 | 显示全部楼层
kbh2006@163.com | 2018-12-18 08:43:00 | 显示全部楼层
zhang172057 | 2018-12-18 08:44:18 | 显示全部楼层
boatxin | 2018-12-18 08:45:30 | 显示全部楼层
doomy | 2018-12-18 08:56:08 | 显示全部楼层
feichi87 | 2018-12-18 08:58:45 | 显示全部楼层
带刀的老鼠 | 2018-12-18 09:11:16 | 显示全部楼层
益达 | 2018-12-20 09:22:01 | 显示全部楼层
zhongsi120 | 2019-4-29 18:41:28 | 显示全部楼层
