[Allegro17.4以下] L6564DTR+L6599ATDTR+LM2902DT 做的一个PCB文件共享
查看2315 | 回复12 | 2019-9-23 17:01:25 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
A2TEST POINT SMD 107RND_TP-45RD2TEST POINT SMD 107RNDTP-45RD25
A3TEST POINT SMD 107RND_TP-45RD2TEST POINT SMD 107RNDTP-45RD25
B2TEST POINT SMD 107RND_TP-45RD2TEST POINT SMD 107RNDTP-45RD25
B3TEST POINT SMD 107RND_TP-45RD2TEST POINT SMD 107RNDTP-45RD25
D2LED166_S_200V_1A_SOD123_DIO-SODSMD1200PLDIO-SOD123
D7LED181_600V_5V_UF_TO220_DIO-STTSTTH5L06FPDIO-STTH5L06FP
D8LED066_400V_3A_ES3G_SMC_DIO-SMCES3GDIO-SMC
D9LED066_400V_3A_ES3G_SMC_DIO-SMCES3GDIO-SMC
D10LED166_S_200V_1A_SOD123_DIO-SODSMD1200PLDIO-SOD123
D11LED166_S_200V_1A_SOD123_DIO-SODSMD1200PLDIO-SOD123
D12LED066_400V_3A_ES3G_SMC_DIO-SMCES3GDIO-SMC
D13LED066_400V_3A_ES3G_SMC_DIO-SMCES3GDIO-SMC
D14LED166_S_200V_1A_SOD123_DIO-SODSMD1200PLDIO-SOD123
D15LED051_BAS21HT1_SOD323_SOD323W_BAS21HT1SOD323W
D17LED184_Z_18V_500MW_SOD123_SOD1218VSOD123
D18LED002_1N4148_SOD323_SOD323_1N41N4148SOD323
D20LED002_1N4148_SOD323_SOD323W_1N1N4148SOD323W
D21LED047_BAS16HT1_SOD323_SOD323W_BAS16HT1SOD323W
D22LED022_Z_15V_SOD323_SOD323W_15V15VSOD323W
D23LED051_BAS21HT1_SOD323_SOD323W_BAS21HT1SOD323W
D24LED002_1N4148_SOD323_SOD323W_1N1N4148SOD323W
D25LED002_1N4148_SOD323_SOD323W_1N1N4148SOD323W
D26LED002_1N4148_SOD323_SOD323W_1N1N4148SOD323W
D27LED022_Z_15V_SOD323_SOD323_15V15VSOD323
D28LED047_BAS16HT1_SOD323_SOD323W_BAS16HT1SOD323W
D29LED047_BAS16HT1_SOD323_SOD323W_BAS16HT1SOD323W
D30LED002_1N4148_SOD323_SOD323W_1N1N4148SOD323W
D31LED002_1N4148_SOD323_SOD323_1N41N4148SOD323
D32LED047_BAS16HT1_SOD323_SOD323W_BAS16HT1SOD323W
D33LED047_BAS16HT1_SOD323_SOD323W_BAS16HT1SOD323W
D34LED047_BAS16HT1_SOD323_SOD323_BBAS16HT1SOD323
D35LED047_BAS16HT1_SOD323_SOD323W_BAS16HT1SOD323W
D36LED047_BAS16HT1_SOD323_SOD323W_BAS16HT1SOD323W
D37LED047_BAS16HT1_SOD323_SOD323_BBAS16HT1SOD323
D38LED047_BAS16HT1_SOD323_SOD323_BBAS16HT1SOD323
D39LED047_BAS16HT1_SOD323_SOD323W_BAS16HT1SOD323W
D40LED047_BAS16HT1_SOD323_SOD323W_BAS16HT1SOD323W
D41LED190_Z_6.2V_500MW_SOD123_SOD16.2VSOD123
D42LED002_1N4148_SOD323_SOD323W_1N1N4148SOD323W
D43LED182_BRIDGE_800V_8A_GBU8K_BRIGBU8K-BPBRIDGE-GBU8X
D44LED047_BAS16HT1_SOD323_SOD323W_BAS16HT1SOD323W
D45LED047_BAS16HT1_SOD323_SOD323W_BAS16HT1SOD323W
D46LED047_BAS16HT1_SOD323_SOD323W_BAS16HT1SOD323W
D47LED187_TVS_188V_300W_SMA_DIO-SMSMAJ188A-E3/61DIO-SMA
D48LED188_TVS_350V_600W_SMB_DIO-SMP6SMB350ADIO-SMB
D49LED188_TVS_350V_600W_SMB_DIO-_1240V ZenerBZG03C240-TR3DIO-SMB
D50LED183_TVS_70V_400W_SMA_DIO-SMASMAT70A-13-FDIO-SMA
D51LED185_Z_7.5V_500MW_SOD123_SOD17.5VSOD123
D52LED012_Z_12V_SOD323_SOD323W_12V12VSOD323W
D53LED188_TVS_350V_600W_SMB_DIO-_2220V ZenerBZG03C220-TR3DIO-SMB
D54LED047_BAS16HT1_SOD323_SOD323W_BAS16HT1SOD323W
D55LED128_200V_3A_DO-201AD_DIO-DO-1N5406DIO-DO-201AD-V
D56LED002_1N4148_SOD323_SOD323W_1N1N4148SOD323W
D57LED002_1N4148_SOD323_SOD323W_BOBOM=NONESOD323W
D58LED185_Z_7.5V_500MW_SOD123_SO_13.3VSOD123
D59LED185_Z_7.5V_500MW_SOD123_SO_13.3VSOD123
F1LEF034_8A_500V_0477_TH_FUSE-0478A 500VACFUSE-0477-V_5A
J3CONN PCB3_CONN3-100_CONN PCB 3CONN PCB 3CONN3-100
J4CONN PCB4_CONN4-100_CONN PCB 4CONN PCB 4CONN4-100
J5TEST POINT SMD 107RND_TP-107RDTEST POINT SMD 107RNDTP-107RD87
J6TEST POINT SMD 107RND_TP-107RDTEST POINT SMD 107RNDTP-107RD87
J7TEST POINT SMD 107RND_TP-107RDTEST POINT SMD 107RNDTP-107RD87
J822_AWG_TP-107RD87_22_AWG22_AWGTP-107RD87
J922_AWG_TP-107RD87_22_AWG22_AWGTP-107RD87
J1018_AWG_TP-95OB75PTH_18_AWG18_AWGTP-95OB75PTH
J11TEST POINT SMD 30RND_TP-45RD25TEST POINT SMD 30 RNDTP-45RD25
J12TEST POINT SMD 30RND_TP-45RD25TEST POINT SMD 30 RNDTP-45RD25
J14TEST POINT SMD 107RND_TP-107RDTEST POINT SMD 107RNDTP-107RD87
J15TEST POINT SMD 107RND_TP-107RDTEST POINT SMD 107RNDTP-107RD87
J16TEST POINT SMD 107RND_TP-107RDTEST POINT SMD 107RNDTP-107RD87
J1718_AWG_TP-95OB75PTH_18_AWG18_AWGTP-95OB75PTH
J1818_AWG_TP-95OB75PTH_18_AWG18_AWGTP-95OB75PTH
J1918_AWG_TP-95OB75PTH_18_AWG18_AWGTP-95OB75PTH
L1LET0011_FERRITE_0603_200MA_FB06HZ0603B751R-10FB0603W
L2LET0011_FERRITE_0603_200MA_FB06HZ0603B751R-10FB0603W
L16LET0121_CM_2.95MH_21.3X13.5MM_I2.95mHIND-LET0121-21P3X13P5
L17LET0120_CM_20MH_29X15MM_IND-LET20mHIND-LET0120-29X15
L19LET0163_CM_LC9-752_IND-LET0163_6.0uHIND-LET0163
L20LET0081_CM_LC9-671_IND-LC9_6.0U6.0uHIND-LC9
L21LET0029_CM_1.0MH_EE8-3P4M1-0-0010mHIND-EE8-3P4M1
L22LET0030_IND_SMT_BK2125HS470-T_F47ohmF0805
L23LET0030_IND_SMT_BK2125HS470-T_F47ohmF0805
Q1LEN008_FET_N_60V_2N7002_SOT23_S2N7002SOT23_3-12
Q3LEN008_FET_N_60V_2N7002_SOT23_S2N7002SOT23_3-12
Q5LEN128_FET_N_650V_11A_TO220_TO2SPA11N60C3TO220-3-OFFSET
Q6LEN128_FET_N_650V_11A_TO220_TO2SPA11N60C3TO220-3-OFFSET
Q7LEN128_FET_N_650V_11A_TO220_TO2SPA11N60C3TO220-3-OFFSET
Q8LEN008_FET_N_60V_2N7002_SOT23_S2N7002SOT23_3-12
Q9LEN008_FET_N_60V_2N7002_SOT23_S2N7002SOT23_3-12
Q10LEN008_FET_N_60V_2N7002_SOT23_S2N7002SOT23_3-12
Q21LEN006_NPN_40V_MMBT3904_SOT23_SMMBT3904SOT23_1-32
Q23LEN006_NPN_40V_MMBT3904_SOT23_SMMBT3904SOT23_1-32
Q24LEN128_FET_N_650V_11A_TO220_TO2SPA11N60C3TO220-3
Q25LEN006_NPN_40V_MMBT3904_SOT23_SMMBT3904SOT23_1-32
Q26LEN006_NPN_40V_MMBT3904_SOT23_SMMBT3904SOT23_1-32
Q27LEN132_THYRIS_400V_1.5A_TO-92_TMCR22-6RLRAGTO-92-KGA
Q28LEN183_FET_SOT223_SOT223-4_FQT1FQT1N60CTSOT223-4
RV1LEV026_14MM_S14K320E2_320RMS_VA320RMSVAR-S22K320
RV2LEV028_7MM_TVR07271_175RMS_VAR-175RMSVAR-7MM_TVR_S07
RV3LEV028_7MM_TVR07271_175RMS_VAR-175RMSVAR-7MM_TVR_S07
RV5LEV035_B572238S_7P5MM_VAR-7P5-BInrush CurrentLimiterVAR-7P5-B57238S
RV6LEV035_B572238S_7P5MM_VAR-7P5-BInrush CurrentLimiterVAR-7P5-B57238S
T2LEX0048_XFRM_PQ3225_300UH_XFMR-150uHXFMR-PQ32-25_LEX0048_KEY4-C
T3LEX0065_XFRM_ETD-34-H-12P_XFMR-210uHXFMR-TXFA-12PIN-C
TP6TEST POINT SMD 60RND_TPS-60RD_TEST POINT SMD 60 RNDTPS-60RD
TP7TEST POINT SMD 60RND_TPS-60RD_TEST POINT SMD 60 RNDTPS-60RD
TP8TEST POINT SMD 60RND_TPS-60RD_TEST POINT SMD 60 RNDTPS-60RD
TP10_OVPTEST POINT SMD 60RND_TPS-60RD_TEST POINT SMD 60 RNDTPS-60RD
TP11_P_BIASTEST POINT SMD 60RND_TPS-60RD_TEST POINT SMD 60 RNDTPS-60RD
TP12_PROTECTEST POINT SMD 60RND_TPS-60RD_TEST POINT SMD 60 RNDTPS-60RD
TP1_P_DCTEST POINT SMD 60RND_TPS-60RD_TEST POINT SMD 60 RNDTPS-60RD
TP2_VB+TEST POINT SMD 60RND_TPS-60RD_TEST POINT SMD 60 RNDTPS-60RD
TP3_P_GNDTEST POINT SMD 60RND_TPS-60RD_TEST POINT SMD 60 RNDTPS-60RD
TP4_S_BIASTEST POINT SMD 60RND_TPS-60RD_TEST POINT SMD 60 RNDTPS-60RD
TP5_S_VSECTEST POINT SMD 60RND_TPS-60RD_TEST POINT SMD 60 RNDTPS-60RD
TP6_S_GNDTEST POINT SMD 60RND_TPS-60RD_TEST POINT SMD 60 RNDTPS-60RD
TP7_DIMMER_12VTEST POINT SMD 60RND_TPS-60RD_TEST POINT SMD 60 RNDTPS-60RD
TP8_DIMMER_GNDTEST POINT SMD 60RND_TPS-60RD_TEST POINT SMD 60 RNDTPS-60RD
TP9_DIMMER_D_IN1_BTEST POINT SMD 60RND_TPS-60RD_TEST POINT SMD 60 RNDTPS-60RD
U9LEU094_ZTL431AFTA_SOT23_SOT23_1TL431AQDBZRSOT23_1-32
U10LEU094_ZTL431AFTA_SOT23_SOT23_1TL431AQDBZRSOT23_1-32
U11LEU094_ZTL431AFTA_SOT23_SOT23_1TL431AQDBZRSOT23_1-32
U12LEU094_ZTL431AFTA_SOT23_SOT23_1TL431AQDBZRSOT23_1-32
U13LEU078_L6564_SSO-10_L6564DTRL6564DTRSSO-10
U20LEU168_L6599ATDTR_SO16_SO-16_L6L6599ATDTRSO-16
U22LEU169_TCLT1003_SOP-4L_OPTO-SOPTCLT1003OPTO-SOP-4L
U23LEU169_TCLT1003_SOP-4L_OPTO-SOPTCLT1003OPTO-SOP-4L
U25LEU172_LM2902DT_SO14_SO-14_LM29LM2902DTSO-14
U27LEU169_TCLT1003_SOP-4L_OPTO-SOPTCLT1003OPTO-SOP-4L
U29LEU172_LM2902DT_SO14_SO-14_LM29LM2902DTSO-14
重要提示:PCB作品文件展下载说明
armclub | 2019-9-23 17:02:09 | 显示全部楼层
GREE_PCB.7z (1.16 MB, 下载次数: 6)
zgh393484673 | 2019-9-23 21:30:04 | 显示全部楼层
zhifang88 | 2019-9-23 22:12:54 | 显示全部楼层
天翼麒麟 | 2019-9-24 08:06:39 | 显示全部楼层
学海无涯 | 2019-9-25 08:06:00 | 显示全部楼层
带刀的老鼠 | 2019-9-25 09:14:38 | 显示全部楼层
xianrui1989 | 2019-9-25 10:22:15 | 显示全部楼层
mikewen | 2020-1-9 08:57:21 | 显示全部楼层
非凡 | 2020-1-9 08:59:19 | 显示全部楼层
终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
