重要提示:PCB作品文件展下载说明
Name | Part Type | PCB Decal | Value | CM01 | E-CAP | CAP5.0 | 100u/16V | DM1 | DIO-MELF | MELF | 1N4148 | DM2 | BAV99 | SOT23 | bav99 | DM3 | DIO-MELF | MELF | 1N4148 | DM4 | BAV99 | SOT23 | bav99 | DM5 | DIO-MELF | MELF | 1N4148 | DM8 | BAV99 | SOT23 | bav99 | DM701 | DIO-MELF | MELF | NC | DM702 | BAV99 | SOT23 | bav99 | ICM01 | ENME0509 | PLCC44-MTV230 | | ICM02 | ST24C16 | DIP8 | | ICM03 | KM432S2030C | TSOP86 | | ICM04 | TVP5147 | QFP80-1 | | ICM05 | AMS1117 | AS1117 | AMS1117-3V3 | ICM06 | AS1117 | AS1117 | AMS1117-3.3V | ICM07 | AMS1117 | AS1117 | AMS1117-1V8 | ICM10 | CF1080C | S2300A | | ICM11 | AMS1117 | AS1117 | AMS1117-3V3 | ICM13 | AMS1117 | AS1117 | AMS1117-1V8 | ICM19 | ST24C02 | DIP8 | | ICM20 | ST24C02 | DIP8 | | ICM301 | TB1307FG | PQFP48 | | ICM601 | 9023 | TQFP-144 | MST3383B-B | ICM602 | AMS1117 | AS1117 | ASM1117-1V8 | ICM603 | AMS1117 | AS1117 | ASM1117-3V3 | ICM701 | FS-TUNER(B) | TUNER(B) | | ICM702 | TDA9881TS | DIP24-1.778 | TDA9881TS | ICM703 | R2S15900SP | SOP28 | R2S15900SP | ICM704 | 4052 | SO16MB | cd74hc4052 | ICM801 | 7805 | AS1117 | 7809 | ICM901 | TDA7495SSA | TDA7495SSA | TDA7495SSA | LM01 | INDU-0805 | FB0805 | FB | LM1A | INDU-0603 | 603 | 3.3UH | LM2 | INDU-0805 | FB0805 | EMI 100MHZ 100R | LM03 | INDU-1005 | 1005MIL | 100UH | LM702A | INDU-1005 | 1005MIL | 100UH | LM704 | INDU-1005 | 1005MIL | 100UH | LM706 | INDU | L10 | 0.82uH or 1uh | LM707 | INDU-1005 | 1005MIL | 100uh | LM708 | INDU-1005 | 1005MIL | 100UH | LM709 | EMI-FIL | EMI-FIL | EMI FILTER COIL 17.5T : 17.5T | LM710 | EMI-FIL | EMI-FIL | EMI FILTER COIL 17.5T : 17.5T | LM711 | EMI-FIL | EMI-FIL | EMI FILTER COIL 17.5T : 17.5T | LM716 | INDU-1005 | 1005MIL | 100UH | LM718 | INDU-1005 | 1005MIL | 100UH | LM802 | PK-L5(10) | PK-L5(10) | 100UH | PCBMARK1 | PADS-TEST | PCBMARK | | PCBMARK2 | PADS-TEST | PCBMARK | | PCBMARK3 | PADS-TEST | PCBMARK | | PCBMARK4 | PADS-TEST | PCBMARK | | PCBMARK5 | PADS-TEST | PCBMARK | | PCBMARK6 | PADS-TEST | PCBMARK | | PCBMARK7 | PADS-TEST | PCBMARK | | QM01 | SMD_NPN | SOT23 | 2SC1815 | QM2 | SMD_NPN | SOT23 | | QM03 | SMD_NPN | SOT23 | | QM04 | SMD_NPN | SOT23 | | QM5 | PNP | SOT23 | 2SA1015 | QM6 | PNP | SOT23 | 2SA1015 | QM720 | SMD_NPN | SOT23 | 2SC1815 | QM801 | KTC2026Y | TO-220IS | | QM901 | SMD_NPN | SOT23 | 2SC1815 | QM903 | PNP | SOT23 | 2SA1015 | RM801 | R(12.5-15)1W | R(12.5-15)1W | 3.3K | RM802 | R(10)1/4W | R(12.5-15)1W | 2K | RM901 | R(10)1/4W | R(12.5-15)1W | 2.2R | RM902 | R(10)1/4W | R(12.5-15)1W | 2.2R | RNM606 | 4RA | RP8\4R\SMD | 47R*4 | S1 | S1A | S1A | | S2 | SCREW_4 | SCREW_01 | | S3 | S1A | S1A | | S4 | SCREW_9_4 | SCREW_9_4 | | S5 | SCREW_9_4 | SCREW_9_4 | | S6 | SCREW_5 | SCREW_5 | | S7 | S1A | S1A | | S8 | SCREW_9_4 | SCREW_9_4 | | SR10 | SCREW_SR | SCREW_SR | | VRM701 | VR3 | RDJ-3P | | W1 | H34628A | H34628 | | W6 | H34628A | H34628 | | XM1 | CON3 | CON\2.5MM\3PIN\A | | XM11 | CON5 | CON\2.5MM\5PIN\A | | XM13 | CON15 | CON\VGAAAA | | XM601 | CON\HDMI | CON_HDMI\SM\RA | | XM602 | CON\HDMI | CON_HDMI\SM\RA | | XM706 | CON2\X | SIP\2P\X | | XM712 | CON2 | SIP\2P | | XM714 | AV-12P | 12P_AV | | XM717 | CON11 | CON\2.5MM\11PIN\A | | XM801 | CON13 | CON\2.5MM\13PIN\A | | XM901 | CON2 | SIP\2P | | XM902 | CON2 | SIP\2P | | ZDM1 | DIODEZ-L | MLL34L | 5V1 | ZDM49 | 0603ESDA | 603 | 0603ESDA | ZDM802 | KA33V | ZD10 | KA33V | ZM01 | CRYSTAL | XTAL5.0 | 22.1184MHZ | ZM02 | CRYSTAL | XTAL5.0 | 14.318MHZ | ZM03 | CRYSTAL | XTAL5.0 | 14.318MHZ | ZM4 | CRYSTAL(T) | XTAL5.0-T | 12MHZ | ZM601 | CRYSTAL | XTAL5.0 | 27MHZ | ZM704 | CRYSTAL | XTAL5.0 | 4MHZ | ZM706 | SAW-SIP5 | COIL | K9352 | ZM707 | SAW-SIP5 | COIL | K6274D |
重要提示:PCB作品文件展下载说明
