重要提示:PCB作品文件展下载说明
Name | Part Type | PCB Decal | Value | BAT1 | MS621FEFL11E | MS621FEFL11E | MS621FEFL11E | CN1 | SD_SOCKET_TOP_A_PANASONIC | SD_STANDARD_A | SD_Socket_Top_A_Panasonic | CN2 | USB_A_RECEPTACLE_SMD_4P | CN_USB_A | USB_A_SMD | CN3 | USB_A_RECEPTACLE_SMD_4P | CN_USB_A | USB_A_SMD | CON1 | HDMI_M_0 | CN_HDMI_19_050_ | CON/HDMI | CT1 | 47UF_6.3V_20%_B_CASE | CAP_B_3528 | 47uF,6.3V | CW13 | 0.01UF_50V_20%_SMD0402 | C0402 | 0.01uF | D1 | RB551V-30_SOD323 | SOD323 | RB551V-30 | D2 | RB551V-30_SOD323 | SOD323 | RB551V-30 | D3 | RCLAMP0520B_SOT-523 | RCLAMP0502B | NC(RClamp0520B) | D4 | RCLAMP0520B_SOT-523 | RCLAMP0502B | NC(RClamp0520B) | D5 | RCLAMP0524P_SLP2510P8 | RCLAMP0524P | NC(RClamp0524P) | D6 | RCLAMP0524P_SLP2510P8 | RCLAMP0524P | NC(RClamp0524P) | D7 | RB551V-30_SOD323 | SOD323 | RB551V-30 | FB1 | FB/0805 | L0805 | FB/0805 | FB15 | 100M_30H[_400MA_SMD0603_2 | L0603 | 100M,30£[ | FB24 | 100M_30H[_400MA_SMD0603 | L0603 | 100M,30£[ | FB25 | FB/0805 | L0805 | FB/0805 | FB26 | FB/0805 | L0805 | FB/0805 | J1 | 1X8P_MALE_DIP_2.0 | SIP_8P_200 | NC(1X8P_2.0M) | J2 | 1X8P_MALE_DIP_2.0 | SIP_8P_200 | NC(1X8P_2.0M) | J3 | RJ45_0 | RJ45_PA6T | RJ45 | J4 | 2X20P_FEMALE_DIP_2.0 | CN20X2_200 | 2X20P_2.0F | J5 | 2X15P_MALE_2LAYER_DIP_2.0 | CN15X2_200 | 2X15P_2.0F_2L | J6 | 1X2P_MALE_DIP_1.27 | SIP_2P_127 | 1X2P_1.27M | J7 | RCA_JACK_90D_YELLOW_DIP_2P | RCA_JACK | RCA_Yellow | J8 | 2X20P_FEMALE_DIP_2.0 | CN20X2_200 | 2X20P_2.0F | J9 | 1X4P_MALE_DIP_2.54 | SIP_4P | 1X4P_2.54M | J10 | 1X5P_MALE_DIP_2.54 | SIP_5P | 1X5P_2.54M | J11 | 2X10P_MALE_DIP_1.27 | CN10X2_127 | 2X10P_1.27M | J12 | 1X4P_MALE_DIP_2.54 | SIP_4P | 1X4P_2.54M | J13 | DC_JACK | PJ20_3P | DC_JACK | J15 | 2X20P_FEMALE_DIP_2.0 | CN20X2_200 | 2X20P_2.0F | J16 | PHONEJACK_STEREO_SW | PHONE_JACK | STEREO PHONEJACK | L2 | 2.2UH_1.85A_20%_SMD_SR0302 | L4018-4R7 | 4.7uH | L3 | 2.2UH_1.85A_20%_SMD_SR0302 | L4018-4R7 | 4.7uH | L4 | 2.2UH_1.85A_20%_SMD_SR0302 | L4018-4R7 | 4.7uH | L5 | 2.2UH_1.85A_20%_SMD_SR0302 | L4018-4R7 | 4.7uH | LED1 | RED__SMD0603 | LED0603 | RED | MIC1 | MIC-MICROPHONE0 | MIC | MIC-EM5BPS | PB8 | PUSH_BOTTOM_BLUE_SMD_2P | SW_SMD_2P | KEY8 | Q1 | AO3415_SOT23 | SOT23 | AO3415 | RP7 | 22_1/16W_5%_8P4R_0402 | RP_4_0402 | 22 | RP8 | 22_1/16W_5%_8P4R_0402 | RP_4_0402 | 22 | RP9 | 33_1/32W_5%_16P8R | RP_8 | 33 | RP10 | 33_1/32W_5%_16P8R | RP_8 | 33 | SW6 | SWITCH_4_PORT_SMD_8P | SW_HDS404 | SW_SMD | SW7 | SW_SPDT3_DIP | SW_SPDT3_1 | SW-SPDT3 | U1 | GM8138_EPAD_LQFP176_SKT_18 | QFP128_14SKT_38X38+EPAD | GM8136S_EPAD_LQFP128_SKT | U2 | DS1307_SOIC8 | SOIC8_150 | DS1307,SOIC8 | U3 | G9131-28T73UF_ | SOT23 | S1206-28 | U4 | G9131-18T73UF | SOT23 | G9131-18T73Uf | U6 | W25P80/16 | SOIC8_208 | W25Q128FVSG SO8 | U7 | SPI_FLASH_SOP16 | SOP16_300 | NC(SPI_FLASH,SOP16) | U9 | IP101GR | TQFN32_040+EPAD | IP101GR | U10 | H1102_1 | TS8121C | TS8121C | U11 | AKU2002C | MIC_AKU2002C | ZTS6032 | U13 | CAT6612_0 | QFP80_050 | CAT6612 | U14 | G9131-18T73UF | SOT23 | G9131-18T73Uf | U15 | IR_0 | ECM_A38_N3 | IRM3638T,3.3V | U17 | G5628ADJT1U_SOT25_1 | SOT26 | MP1470_SOT23-6 | U18 | G5628ADJT1U_SOT25_1 | SOT26 | MP1470_SOT23-6 | U19 | G5628ADJT1U_SOT25_1 | SOT26 | MP1470_SOT23-6 | U20 | G5628ADJT1U_SOT25_1 | SOT26 | MP1470_SOT23-6 | Y1 | 32.768KHZ_CRY_30PPM_SIZE_2X6 | XTAL_0P7L | 32.768KHz | Y2 | 12MHZ_OSC_30PPM_SMD5X3_0 | XTAL_SMD_50X32 | 30MHz | Y3 | XTAL_25MHZ_0 | XTAL_127L | NC(32.768K) |
重要提示:PCB作品文件展下载说明
