[Allegro17.4以下] novatek联咏NT96675带4G功能高清行车记录仪PCB文件和datasheet pdf
查看6323 | 回复112 | 2023-4-3 11:57:00 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
D2DIODE_SOD323_1N41481N4148SOD323
D4DIODE_SOD323_1N41481N4148SOD323
D19DIODE_SOD323_1N41481N4148SOD323
J5USB-C-DIP_TYPE_USB-C-DIP_TYPE-CUSB_TYPE_CUSB-C-DIP_TYPE-C16PINCB
J6CON4_CON4PIN-2_0DIP_CON4PIN-2.0CON4PIN-2.0SIPCON4PIN-2_0DIP
J8K3-2336S_K3-2336S-F1_SK-23D06SK-23D06K3-2336S-F1
J11ANTENNA_0_ANT_4P_20279-001E-0120279-001E-01ANT_4P
J930FPC40_FPC40_PT0_5_H2B_LS23001LS23001FPC40_PT0_5_H2B
J931CON10A_IDC10_M_SMDL_CON10ACON10AIDC10_M_SMDL
J932CON2_2_CON2PIN-1_25SMD_CON2PIN-CON2PIN-1.25SMDCON2PIN-1_25SMD
J933MICROSIM_2_SIM-SMD_P7_MICROSIMMicroSIMSIM-SMD_P7
L2INDUCTORIRON_L4020_2.2UH2.2uHL4020
L4INDUCTORIRON_L4020_2.2UH2.2uHL4020
L5INDUCTORIRON_L4020_2.2UH2.2uHL4020
L6INDUCTORIRON_L4020_2.2UH2.2uHL4020
L19EMCL_USB-L3-L2-4P_120R/100MHZ120R/100MHZUSB-L3-L2-4P
MARK5MARK_FD40_MARKMARKFD40
MARK6MARK_FD40_MARKMARKFD40
MARK7MARK_FD40_MARKMARKFD40
MARK8MARK_FD40_MARKMARKFD40
Q1DDTC_SOT-523_DTC114EEDTC114EESOT-523
Q3DDTC_SOT-523_DTC114EEDTC114EESOT-523
Q5DDTC_SOT-523_DTC114EEDTC114EESOT-523
Q10MOSFET_EP_DGS_SOT-23_AO3401A/NCAO3401A/NCSOT-23
Q11MOSFETP SGD_1_SOT23_SI2302SI2302SOT23
Q14DDTC_SOT-523_DTC114EEDTC114EESOT-523
Q15DDTC_SOT-523_DTC114EEDTC114EESOT-523
Q312N3904_SOT-23_2N39042N3904SOT-23
Q322N3904_SOT-23_2N39042N3904SOT-23
Q33DDTC_SOT-523_DTC114EEDTC114EESOT-523
Q38DDTC_SOT-523_DTC114EEDTC114EESOT-523
Q39DDTC_SOT-523_DTC114EEDTC114EESOT-523
RV127V_VR1005BBA270_0805_MF58DMF58D805
SD1MICROSD+CD_1_MICROSD_MICROSD+CDMicroSD+CDMICROSD
SW1SWPUSHBUTTON_4_TS-8048_TS-8048TS-8048TS-8048
SW4SWPUSHBUTTON_4_TS-8048_TS-8048TS-8048TS-8048
SW5SWPUSHBUTTON_4_TS-8048_TS-8048TS-8048TS-8048
SW6SWPUSHBUTTON_4_TS-8048_TS-8048TS-8048TS-8048
SW7SWPUSHBUTTON_4_TS-8048_TS-8048TS-8048TS-8048
SW8SWPUSHBUTTON_4_TS-8048_TS-8048TS-8048TS-8048
T1ESD_T0402_ESD/5VESD/5VT0402
U2N655JM_0_SOT23-6_N670JMN670JMSOT23-6
U3RT8008-SOT23_3_SOT23-5_ETA3409SETA3409S2FSOT23-5
U4RT8008-SOT23_3_SOT23-5_ETA3409SETA3409S2FSOT23-5
U5RT8008-SOT23_3_SOT23-5_ETA3409SETA3409S2FSOT23-5
U6RT8008-SOT23_3_SOT23-5_ETA3409SETA3409S2FSOT23-5
U7SERIALFLASH_WSON8_8X6_GD5F1GQ4GD5F1GQ4UBYIGWSON8_8X6
U13TXS0102DCUR_SSOP8_0_5MM_TXS0102TXS0102DCURSSOP8_0_5MM
U20RT9193-33_3_SOT23-5_RT9020-18GBRT9020-18GBSOT23-5
U21STC8F_0_QFP32_STC8F2K16S2STC8F2K16S2QFP32
U30SN74LVC1G08_SOT23-5_SN74LVC1G08SN74LVC1G08SOT23-5
U31TS3USB221_TS3_USB221_TS3USB221TS3USB221TS3_USB221
U32EG915U_EG915U_EG915UEG915UEG915U
U33NT96675_1_BGA-280P-0_65MM_12X12NT96675BGA-280P-0_65MM_12X12A
U34LCD2_0_22RGB_FPC22_PT0_5_H2_LCDLCD2.0_RGBFPC22_PT0_5_H2
Y1XM/SM_0_OSC3225_12MHZ_322512MHz_3225OSC3225
Y2CRYSTAL_2_SMD32768_32.768KHZ(+/32.768KHz(+/-20ppm)SMD32768
评分
参与人数 1威望 +2 收起 理由
yhgwork + 2 好资料,支持分享
查看全部评分
重要提示:PCB作品文件展下载说明
老吴 | 2023-4-3 11:58:18 | 显示全部楼层
PCB文件和datasheet 。回复可见下载
游客,如果您要查看本帖隐藏内容请回复
bidezhi7777 | 2023-4-3 12:16:22 | 显示全部楼层
xpluto | 2023-4-3 13:23:31 | 显示全部楼层
jielove2003 | 2023-4-3 14:38:44 | 显示全部楼层
shuszhao | 2023-4-3 15:17:51 | 显示全部楼层
旧尔一 | 2023-4-4 00:07:26 | 显示全部楼层
晕哥 | 2023-4-4 00:10:48 | 显示全部楼层
cityhu | 2023-4-4 00:29:43 | 显示全部楼层
yhgwork | 2023-4-4 00:31:52 | 显示全部楼层
