REFDES | COMP_DEVICE_TYPE | SYM_NAME |
C3844 | CAP NP_C0201_100NF | C0201 |
CN1 | HDMI_TYPEA_HDMI_HDMI_A_FEMAL_SMD | HDMI |
CN3 | TFCARD_SOCKET_3_SD3_SD3 | SD3 |
CON1 | AV_2_AV_5_AV | AV_5 |
CON2 | M-DIN_2_S-VIDEO_S-VIDEO | S-VIDEO |
CON3 | DIODE ZENER_1_R0402_NC/SD05C | R0402 |
CON4 | TMP_151315_2PIN1_25-ME_FAN | 2PIN1_25-ME |
D2 | DIODE ZENER2_ESD0603_PSUR1610DNV07 | ESD0603 |
D3 | DIODE_SOD_323_B5819WS | SOD_323 |
D4 | DIODE DOUBLE_SOT_23_BAT54C | SOT_23 |
D8 | DIODE_SOD-323N_IN5819 | SOD-323N |
D9 | DIODE_1_SOD_323_T4 | SOD_323 |
D10 | DIODE_DO_214AB_SS32 | DO_214AB |
D11 | DIODE_1_SOD-123_SS54 | SOD-123 |
D12 | DIODE_1_SOD-123_SS54 | SOD-123 |
D13 | DIODE_SOD-323N_IN5819 | SOD-323N |
D14 | SD107WS_0_SOD_323_NC/SD103CWS | SOD_323 |
D15 | SM340A_0_SOD_323_1N5819 | SOD_323 |
D16 | RCLAMP0524P_SLP2510P8_BTRD10D01 | SLP2510P8 |
D17 | RCLAMP0524P_SLP2510P8_NC/RCLAMP0524P | SLP2510P8 |
D18 | RCLAMP0524P_SLP2510P8_NC/RCLAMP0524P | SLP2510P8 |
D24 | DIODE_2_SOD-323N_RB751V | SOD-323N |
D25 | DIODE ZENER_1_ESD0402_NC/ESD | ESD0402 |
D42 | DIODE ZENER_1_ESD0402_NC/ESD | ESD0402 |
D43 | DIODE_SOD_323_B5819W | SOD_323 |
D44 | DIODE_SOD_323_B5819WS | SOD_323 |
D45 | DIODE_SOD_523_RB520S-30 | SOD_523 |
D46 | DIODE DOUBLE F_SOT-23A_BAT54SW | SOT-23A |
D47 | DIODE DOUBLE F_SOT-23A_BAT54SW | SOT-23A |
D48 | DIODE ZENER_1_SOD_323_MMPZ5233BPT/18V | SOD_323 |
D49 | DIODE ZENER_1_SOD_323_MMPZ5233BPT/6.8V | SOD_323 |
D50 | BAT54S_SOT-23_BAT54S | SOT-23 |
D51 | BAT54C_SOT-23_BAT54C | SOT-23 |
D52 | ESD_DFN1006-2L_JEB05DFCS | DFN1006-2L |
ED1 | DIODE ZENER_1_ESD0402_NC/ESD | ESD0402 |
ED2 | DIODE ZENER_1_ESD0402_NC/ESD | ESD0402 |
ED3 | DIODE BI_DIR TRIG_ESD0402_ESD5451N | ESD0402 |
ED4 | DIODE BI_DIR TRIG_ESD0402_ESD5451N | ESD0402 |
ED5 | DIODE BI_DIR TRIG_ESD0402_ESD5451N | ESD0402 |
ED6 | DIODE BI_DIR TRIG_ESD0402_ESD5451N | ESD0402 |
ED7 | DIODE BI_DIR TRIG_ESD0402_ESD5341N | ESD0402 |
ED8 | DIODE BI_DIR TRIG_ESD0402_ESD5341N | ESD0402 |
ED9 | DIODE BI_DIR TRIG_ESD0402_ESD5341N | ESD0402 |
ED10 | DIODE BI_DIR TRIG_ESD0402_ESD5341N | ESD0402 |
ED11 | DIODE BI_DIR TRIG_ESD0402_ESD5341N | ESD0402 |
ED12 | ESD_ESD73034D_SON10_2R50X1R00X0R50_ESD73034D | SON10_2R50X1R00X0R50 |
ED13 | ESD56161D24_DFN3_2R00X2R00X0R65_ESD56161D24 | DFN3_2R00X2R00X0R65 |
ED14 | DIODE BI_DIR TRIG_ESD0402_ESD5341N | ESD0402 |
ED15 | ESD_ESD73034D_SON10_2R50X1R00X0R50_ESD73034D | SON10_2R50X1R00X0R50 |
ED16 | DIODE BI_DIR TRIG_ESD0402_ESD5311X | ESD0402 |
ED17 | DIODE BI_DIR TRIG_ESD0402_ESD5311X | ESD0402 |
ED18 | DIODE BI_DIR TRIG_ESD0402_ESD5311X | ESD0402 |
ED19 | DIODE BI_DIR TRIG_ESD0402_ESD5311X | ESD0402 |
ED20 | DIODE BI_DIR TRIG_ESD0402_ESD5341N | ESD0402 |
ED21 | DIODE BI_DIR TRIG_ESD0402_ESD5341N | ESD0402 |
ED22 | DIODE BI_DIR TRIG_ESD0402_ESD5471X | ESD0402 |
ED23 | DIODE BI_DIR TRIG_ESD0402_NC/ESD5341N | ESD0402 |
ED24 | DIODE BI_DIR TRIG_ESD0402_NC/ESD5341N | ESD0402 |
ED25 | DIODE BI_DIR TRIG_ESD0402_NC/ESD5341N | ESD0402 |
ED26 | DIODE BI_DIR TRIG_ESD0402_NC/ESD5341N | ESD0402 |
ED27 | DIODE BI_DIR TRIG_ESD0402_NC/ESD5341N | ESD0402 |
ED28 | DIODE BI_DIR TRIG_ESD0402_NC/ESD5341N | ESD0402 |
ED29 | ESD_ESD73034D_SLP2510P8_ESD73034D | SLP2510P8 |
ED30 | DIODE BI_DIR TRIG_ESD0402_NC/ESD5341N | ESD0402 |
ED70 | DIODE BI_DIR TRIG_ESD0402_ESD5341N | ESD0402 |
ED71 | ESD_ESD73034D_SLP2510P8_ESD73034D | SLP2510P8 |
ED72 | DIODE BI_DIR TRIG_ESD0402_ESD5341N | ESD0402 |
ED74 | DIODE BI_DIR TRIG_ESD0402_ESD5341N | ESD0402 |
ED75 | DIODE BI_DIR TRIG_ESD0402_ESD5341N | ESD0402 |
ED76 | DIODE BI_DIR TRIG_ESD0402_ESD5341N | ESD0402 |
F3 | FUSE_F8050_JK-SMD150L | F8050 |
FB1 | BEAD_L0603_120R-100M | L0603 |
FB11 | BEAD_L0402_220R-100M | L0402 |
FB19 | INDUCTOR_0_L0402_FB60R | L0402 |
FB20 | BEAD_L0603_220R-100M | L0603 |
FB21 | FERRITBEAD_L0603_FB120R | L0603 |
FB22 | FERRITBEAD_L0603_FB120R | L0603 |
FB23 | FERRITBEAD_L0603_FB300R/NC | L0603 |
FB24 | FERRITBEAD_L0603_FB120R | L0603 |
FB25 | FERRITBEAD_L0603_FB120R | L0603 |
FB26 | BEAD_L0603_120R-100M | L0603 |
FB27 | BEAD_L0603_120R-100M | L0603 |
FB28 | FERRITBEAD_L0603_FB120R | L0603 |
FB29 | BEAD_L0603_120R-100M | L0603 |
FB30 | BEAD_L0603_120R-100M | L0603 |
IR1 | IRM_3638_IJ3_IRM_3638_IRM_3638 | IJ3_IRM_3638 |
J1 | CON_BATTERY-20MM_CAPFL_CR1220-3V | CAPFL |
J5 | TEST POINT_TP_TP | TP |
J6 | Y83989 MIPI LCD_0_FPC_30PIN_0R5_FPC30-05 | FPC_30PIN_0R5 |
J7 | Y83989 MIPI LCD_2_FPC_30PIN_0R5_FPC30-05 | FPC_30PIN_0R5 |
J8 | CON3X1X254MM_0_CON2X1X254MM_CON2X1X254MM | CON2X1X254MM |
J10 | CON_BATTERY-20MM_BAT2032_CR1220-3V | BAT2032 |
J12 | TEST POINT_TP_TP | TP |
J13 | PHONEJACK STEREO SW_10_PJ-326-2_PHONEJACK | PJ-326-2 |
J14 | PHONEJACK STEREO SW_9_PJ-326-2_PHONEJACK | PJ-326-2 |
J15 | HR911130C_RJ45_HR911130C_HR911130C | RJ45_HR911130C |
J16 | AUDIO_SPK_JACK_1_2PIN1_25-ME_AUDIO_SPK_JACK_2P_V | 2PIN1_25-ME |
J17 | AUDIO_SPK_JACK_1_2PIN1_25-ME_AUDIO_SPK_JACK_2P_V | 2PIN1_25-ME |
J18 | USB30_TYPE-C RECEPTACLE_3_TYPE-C-24P-QCHT_USB30_TYPE-C | TYPE-C-24P-QCHT |
J19 | USBA_4_USB30_AF_SMT_THF_USB30_AF_SMT_THF | USB30_AF_SMT_THF |
J20 | PHONEJACK STEREO SW_10_PJ-326-2_PHONEJACK | PJ-326-2 |
J21 | HDMI_A_HDMI_HDMI_A | HDMI |
J23 | CON4_1X4_CN4M_2R54_V_DIP_CN4M_2R54_V_DIP | CN4M_2R54_V_DIP |
J24 | RADIATOR_0_RADIATOR_38RX38RX10R_RADIATOR_38X38 | RADIATOR_38RX38RX10R |
J25 | DCJACK_0_DC_005B_DC-005B | DC_005B |
J26 | CON_BATTERY-20MM_0_4PIN1_25-SMD_BAT_3.7V*2 | 4PIN1_25-SMD |
J27 | CON_BATTERY-20MM_0_4PIN1_25-SMD_BAT_3.7V*2 | 4PIN1_25-SMD |
J28 | HDMI_TYPE_A_HDMI_HDMI | HDMI |
J29 | PHONEJACK STEREO SW_9_PJ-326-2_PHONEJACK | PJ-326-2 |
J30 | RADIATOR_FAN_2_RADIATOR_FAN_RADIATOR_FAN_65X65 | RADIATOR_FAN |
J31 | TEST POINT_TP_TP | TP |
J32 | TEST POINT_TP_TP | TP |
J33 | TEST POINT_TP_TP | TP |
L1 | INDUCTORS OF FERRITE_IND_667028_4.7UH | IND_667028 |
L2 | INDUCTORS OF FERRITE_IND_404020_2.2UH | IND_404020 |
L3 | INDUCTORS OF FERRITE_IND_201610_0.47UH | IND_201610 |
L4 | INDUCTORS OF FERRITE_IND_252012_0.24UH | IND_252012 |
L5 | INDUCTORS OF FERRITE_IND_201610_0.47UH | IND_201610 |
L6 | INDUCTORS OF FERRITE_IND_252012_0.24UH | IND_252012 |
L7 | INDUCTORS OF FERRITE_IND_201610_0.47UH | IND_201610 |
L8 | INDUCTORS OF FERRITE_IND_252012_0.24UH | IND_252012 |
L9 | INDUCTORS OF FERRITE_IND_201610_0.47UH | IND_201610 |
L10 | INDUCTORS OF FERRITE_IND_252012_0.24UH | IND_252012 |
L11 | INDUCTORS OF FERRITE_IND_201610_0.47UH | IND_201610 |
L12 | INDUCTORS OF FERRITE_IND_201610_0.47UH | IND_201610 |
L13 | INDUCTORS OF FERRITE_IND_252010_1.0UH | IND_252010 |
L14 | INDUCTORS OF FERRITE_IND_252010_1.0UH | IND_252010 |
L15 | INDUCTORS OF FERRITE_PI43_4.7UH/4026 | PI43 |
L16 | INDUCTORS OF FERRITE_PI43_10UH/4026 | PI43 |
L17 | INDUCTORS OF FERRITE_IND_303015_3.3UH | IND_303015 |
L19 | FERRITBEAD_L0603_120R/300MA | L0603 |
L20 | FERRITBEAD_L0603_300R/300MA | L0603 |
L21 | FERRITBEAD_L0603_120R/1.5A | L0603 |
L22 | INDUCTORS OF FERRITE_IND_303015_2.2UH | IND_303015 |
L23 | L0603-M_BEAD_300R_1A5_CHILISI_0_L0603_300R/1A5 | L0603 |
L24 | L0603-M_BEAD_300R_1A5_CHILISI_0_L0603_300R/1A5 | L0603 |
L25 | L0603-M_BEAD_300R_1A5_CHILISI_0_L0603_300R/1A5 | L0603 |
L26 | FERRITBEAD_L0603_120R/300MA | L0603 |
L27 | L0603-M_BEAD_300R_1A5_CHILISI_0_L0603_300R/1A5 | L0603 |
L28 | L0603-M_BEAD_300R_1A5_CHILISI_0_L0603_300R/1A5 | L0603 |
L29 | INDUCTOR COM_RP2_0405_NC | RP2_0405 |
L30 | INDUCTOR COM_RP2_0405_NC | RP2_0405 |
L32 | BEAD_L0603_FB300R | L0603 |
L33 | L0603-M_BEAD_300R_1A5_CHILISI_0_L0603_300R/1A5 | L0603 |
L34 | INDUCTORS OF FERRITE_L-SH2016_2.2UH | L-SH2016 |
L35 | INDUCTORS OF FERRITE_L-SH2016_2.2UH | L-SH2016 |
LED3 | LED_LED0603AC_LED_BLUE | LED0603AC |
LED4 | LED_LED0603AC_LED_RED | LED0603AC |
LED5 | LED_LED0603AC_LED_GREEN | LED0603AC |
LED6 | LED_LED0603AC_LED_GREEN | LED0603AC |
LED7 | LED_LED0603AC_LED_BLUE | LED0603AC |
LED8 | LED_LED0603AC_LED_BLUE | LED0603AC |
LED9 | LED_LED0603AC_LED_BLUE | LED0603AC |
LED10 | LED_LED0603AC_LED_GREEN | LED0603AC |
LED11 | LED_LED0603AC_LED_GREEN | LED0603AC |
LED12 | LED_LED0603AC_LED_GREEN | LED0603AC |
LED13 | LED_LED0603AC_LED_GREEN | LED0603AC |
LED14 | LED_LED0603AC_LED_GREEN | LED0603AC |
M1 | MARK_MARK_MARK | MARK |
M2 | MARK_MARK_MARK | MARK |
M3 | MARK_MARK_MARK | MARK |
M4 | MARK_MARK_MARK | MARK |
M5 | MARK_MARK_MARK | MARK |
M6 | MARK_MARK_MARK | MARK |
P1 | TP_TP1_TP | TP1 |
Q2 | MOSFET N_SOT_23_WNM2016-3/TR | SOT_23 |
Q3 | MOSFET N_SOT_323_WNM2021-3/TR | SOT_323 |
Q11 | MOSFET P_SOT_23_TSM2301 | SOT_23 |
Q12 | MOSFET P_SOT_23_WPM2341-3/TR | SOT_23 |
Q13 | NPN_SOT_23_MMBT3904 | SOT_23 |
Q14 | NPN_SOT_23_S8050 | SOT_23 |
Q15 | NPN_SOT_23_S8050 | SOT_23 |
Q16 | MOSFET P_SOT_23_TSM2301 | SOT_23 |
Q17 | MOSFET P_SOT_23_WPM2341-3/TR | SOT_23 |
Q18 | NPN_SOT_23_MMBT3904 | SOT_23 |
Q19 | MOSFET N_SOT_323_WNM6002-3/TR | SOT_323 |
Q20 | MOSFET N_SOT_323_WNM6002-3/TR | SOT_323 |
Q23 | MOSFET N_SOT23_WNM2016-3/TR | SOT23 |
Q24 | MOSFET N_SOT23_WNM2016-3/TR | SOT23 |
Q25 | MOSFET N_SOT_323_WNM6002-3/TR | SOT_323 |
Q26 | MOSFET N_SOT_323_WNM6002-3/TR | SOT_323 |
Q27 | NP4419_P_ESOP-8_PDFN_3X3_8L_AP20P03DF | PDFN_3X3_8L |
Q28 | NP4419_P_ESOP-8_PDFN_3X3_8L_AP20P03DF | PDFN_3X3_8L |
Q29 | NP4419_P_ESOP-8_PDFN_3X3_8L_AP20P03DF | PDFN_3X3_8L |
Q30 | MOSFET N_SOT_23_SI2302 | SOT_23 |
Q31 | NP4419_P_ESOP-8_PDFN_3X3_8L_AP20P03DF | PDFN_3X3_8L |
Q32 | NP4419_P_ESOP-8_PDFN_3X3_8L_AP20P03DF | PDFN_3X3_8L |
Q33 | NP4446_N_ESOP-8_PDFN_3X3_8L_AP68N03DF | PDFN_3X3_8L |
Q34 | NP4446_N_ESOP-8_PDFN_3X3_8L_AP68N03DF | PDFN_3X3_8L |
Q35 | NPN_SOT_23_MMBT3904 | SOT_23 |
Q36 | MOSFET N_SOT_23_WNM3003-3/TR | SOT_23 |
Q37 | MOSFET N_SOT_323_2SK3018 | SOT_323 |
Q38 | MOSFET N_SOT_323_WNM6002-3/TR | SOT_323 |
Q39 | MOSFET N_SOT_323_WNM6002-3/TR | SOT_323 |
Q40 | MOSFET N_SOT_323_2SK3018 | SOT_323 |
Q41 | MOSFET N_SOT_323_2SK3018 | SOT_323 |
Q42 | MOSFET N_SOT_323_2SK3018 | SOT_323 |
Q43 | MOSFET N_SOT_323_2SK3018 | SOT_323 |
Q44 | NPN_SOT_23_MMBT3904 | SOT_23 |
R3804 | RESISTOR5_NC_R0201_240R | R0201 |
RN1 | RESARR_IS_4/SO_RP0402X4_47R | RP0402X4 |
RN2 | RESARR_IS_4/SO_RP0402X4_47R | RP0402X4 |
S3 | BR-11C-11P6 | 2PIN1_25-ME |
SW1 | SW4P_0_SW-SMD-5_2X5_2X1_5_UP | SW-SMD-5_2X5_2X1_5 |
SW15 | SW4P_0_SW-SMD-5_2X5_2X1_5_DOWN/MIC | SW-SMD-5_2X5_2X1_5 |
U1 | SOC_RK3576_BGA698_16R1X17R2X1R18__RK3576 | BGA698_16R1X17R2X1R18 |
U2 | GD25Q40E/20E_SOP-8_3R90X4R90X1R27_HK25Q40E | SOP-8_3R90X4R90X1R27 |
U3 | FP6809_SOT-23_FP6809-29NS3G | SOT-23 |
U6 | TMI3255S_SOT_23_6_TMI3255S | SOT_23_6 |
U7 | TMI3253SH_SOT_23_6_TMI3253SH | SOT_23_6 |
U8 | PMIC_RK806S-5_QFN68_7R00X7R00X0R80_T_RK806S-5 | QFN68_7R00X7R00X0R80_T |
U9 | DCDC_ETA3409_SOT_23_5_TMI3112H | SOT_23_5 |
U10 | DCDC_ETA3409_SOT_23_5_TMI3112H | SOT_23_5 |
U11 | CW3301_LOAD SWITCH_WLCSP4_0R80X0R80X0R50_CW3301 | WLCSP4_0R80X0R80X0R50 |
U12 | SWITCH_SY6280_SOT_23_5_SGM2590D | SOT_23_5 |
U13 | LDO_PT5108_SOT_23_5_TMI6050-33 | SOT_23_5 |
U14 | RTC_HYM8563_TSSOP8_3R10X3R10X1R10_HYM8563TS | TSSOP8_3R10X3R10X1R10 |
U16 | DCDC_MP1488_SOT-23-6_AP3031 | SOT-23-6 |
U17 | DCDC_SY7069_0_SOT-23-6_CP2121ST | SOT-23-6 |
U18 | LT7911C_0_LT6911C_QFN64_EPAD_ LT6911UXE/UXC | LT6911C_QFN64_EPAD |
U19 | DCDC_SY8088_SOT_23_5_SY8088AAC | SOT_23_5 |
U21 | INAND_EMMC_153_2L_BGA153_EMMC_EMMC_B153_2L | BGA153_EMMC |
U22 | 02. ADI_ADV7180_LFCSP32_LFCSP_32P_ADI_ADV7180_LFCSP32 | LFCSP_32P |
U23 | LDO_PT5108_SOT_23_5_SGM2019 | SOT_23_5 |
U24 | LDO_PT5108_SOT_23_5_SGM2019 | SOT_23_5 |
U25 | 07_CRY3225-12M_XTL571300-W79-00_CRY3325_12.288MHZ/NC | CRY3325 |
U26 | 02_0. WOLFSON_WM8960_QFN32_QFN-32P_0_5_5X5_NAU88C22YG/QFN32 | QFN-32P_0_5_5X5 |
U27 | MS7124_SOIC8-1_27-150MIL_MS7124 | SOIC8-1_27-150MIL |
U28 | 27_ALC5640-VB-CG_QFN48B-6X6-040_QFN48B-6X6-040_ALC5640-VB-CG | QFN48B-6X6-040 |
U29 | ETHERNET_RK631A_QFN40_5R00X5R00X0R90_T_RK631A | QFN40_5R00X5R00X0R90_T |
U30 | 08_LP5907MFX-3.1/NOPB_SOT23-5_SOT23-5_LP5907MFX-3.1/NOPB | SOT23-5 |
U31 | LDO_PT5108_SOT_23_5_SGM2019 | SOT_23_5 |
U32 | USB_FUSB302B_MLP14_2R50X2R50X0R80_HUSB311 | MLP14_2R50X2R50X0R80 |
U33 | WS3221_CSP6L_1R25X0R77X0R63_WS3221C | CSP6L_1R25X0R77X0R63 |
U34 | SWITCH_SY6280_SOT_23_5_SGM2590D | SOT_23_5 |
U35 | SWITCH_SY6280_SOT_23_5_SGM2590D | SOT_23_5 |
U36 | SWITCH_SY6280_SOT_23_5_SGM2590D | SOT_23_5 |
U38 | LDO_PT5108_SOT_23_5_SGM2019 | SOT_23_5 |
U42 | XBM3215_SOT-23-6_BM3215 | SOT-23-6 |
U43 | XBM3215_SOT-23-6_BM3215 | SOT-23-6 |
U44 | 12_FR9853TS9_TSOT6-095_0_SOT_23_6_SW2001 | SOT_23_6 |
U47 | SGM2549_SOT-23-6_SGM2549 | SOT-23-6 |
U48 | GSV6127_V0P1_QFN64_8R00X8R00X0R40_GSV6127 | QFN64_8R00X8R00X0R40 |
U49 | RCLAMP0524P_SLP2510P8_RCLAMP0524PATCT | SLP2510P8 |
U50 | RCLAMP0524P_SLP2510P8_RCLAMP0524PATCT | SLP2510P8 |
U51 | RCLAMP0524P_SLP2510P8_RCLAMP0524PATCT | SLP2510P8 |
U52 | DCDC_SY8088_SOT_23_5_BL8028 | SOT_23_5 |
U53 | DCDC_SY8088_SOT_23_5_BL8028 | SOT_23_5 |
U3800 | LPDDR4_1_BGA200_15R00X10R00X0R90_LPDDR4_200P | BGA200_15R00X10R00X0R90 |
W1 | TMP_0_GH_1_25_6_SMD_LT_A1250-WV-6PIN | GH_1_25_6_SMD_LT |
Y1 | CRYSTAL_4P_XTAL3_2X2_5_24MHZ | XTAL3_2X2_5 |
Y3 | CRYSTAL_0_CRY2_6R90X1R40X1R30_32.768KHZ | CRY2_6R90X1R40X1R30 |
Y5 | 07_CRY3225-12M_XTL571300-W79-00_XTAL3_2X2_5_28.6363MHZ | XTAL3_2X2_5 |
Y6 | CRYSTAL_4P_XTAL3_2X2_5_NC/25MHZ | XTAL3_2X2_5 |
Y7 | CRYSTAL_4PIN_CRY_3225_24MHZ/+-20PPM | CRY_3225 |
Y8 | CRY_SMD3225_CRY_3225_25MHZ | CRY_3225 |
