[其他器件] AGN20024 datasheet
查看625 | 回复1 | 2016-6-3 08:37:21 | 显示全部楼层 |阅读模式
AGN20024 GN  High Sensitivity Relay, with 100mW nominal operating power,
in a compact and space saving case
TYPICAL APPLICATIONS
1. Telephonic equipment
2. Telecommunications equipment
3. Security equipment
4. Test and Measurement equipment
5. Electronic Consumer and Audio Visual equipment
AGN20024 datasheet.pdf (118 KB, 下载次数: 0)
chinatiger11 | 2016-6-3 10:22:58 | 显示全部楼层
