[IC] CANTUS 128A MCU datasheet
查看774 | 回复0 | 2016-6-4 09:30:31 | 显示全部楼层 |阅读模式
Features
▫ High-performance, Low-power 32-bit EISC Microprocessor
▫ 32-bit EISC Architecture
  - AE32000C
  - Up to 96MIPS Throughput at 96MHz
  - 2 Way Set Associative cache with I-Cache(8KB) and D-Cache(4KB)
▫ Program and Data Memories
  - 128KBytes , 512KBytes of Re-programmable NOR Flash
      Endurance: 100,000 Erase Cycles
      JTAG Programming
      ISP (In System Programming)
  - 80KBytes Internal SRAM
  - External Static Memory Interface with ALE
▫ Peripherals
  - 32-bit Watchdog Timer
  - 2 External Interrupts
  - 8 Channel 32-bit Timer/Counter with 15-bit Pre-scaler, Capture mode, PWM mode,
      and Output Compare Mode
  - 8 Channel UART with 16Bytes FIFO, Functionally compatible with the 16550
  - Master/Slave SPI with 8Bytes FIFO
  - Two Wire Interface
  - Direct Memory Access Controller(DMAC)
  - NAND Flash Controller with 4bit ECC
  - I2S with ADPCM
  - USB 1.1 Full Speed Device
  - 53 Port In/Out
  - 32.768KHz crystal oscillator for RTC
  - 2MHz ~ 15MHz crystal oscillator
  - Power Controller
  - JTAG Debugger
▫ Special Features
  - Embedded two 1.8v Voltage Regulators (LDOs)
  - Power On Reset
  - On-chip PLL
       The PLL generates the clock to operate the overall device (including USB device).
  - 14-bit Voice Codec with 4Ch Input
  - Power Mode: Normal, Idle and Deep Idle mode
  - Woken by PWK pin or RTC interrupt from Deep mode
▫ Operating Voltage Range
  - Core: 1.8V
  - I/O: 3.3V
▫ Operating frequency
  - Up to 96MHz
▫ Package
  - 100-pin TQFP Package
CANTUS 128A MCU datasheet.pdf (6.85 MB, 下载次数: 0)
