[其他器件] ARUBA 320 SERIES ACCESS POINTS Datasheet
查看763 | 回复1 | 2016-6-5 06:55:19 | 显示全部楼层 |阅读模式
AP-320 SERIES SPECIFICATIONS
• AP-325 and IAP-325
- 5 GHz (1,733 Mbps max rate) and 2.4 GHz (800 Mbps
max rate) radios, each with 4x4 MIMO support
and a total of eight integrated omni-directional
downtilt antennas.
• AP-324 and IAP-324
max rate) radios, each with 4x4 MIMO support and a
total of four combined, diplexed (dual-band) external
RP-SMA antenna connectors.
DS_AP320Series datasheet.pdf (1.07 MB, 下载次数: 1)
bidezhi7777 | 2016-12-24 15:31:36 | 显示全部楼层
