[其他器件] ALM-1412 1.575 GHz GPS Low Noise Amplifier Datasheet
查看470 | 回复0 | 2016-6-17 09:40:31 | 显示全部楼层 |阅读模式
ALM-1412 1.575 GHz GPS Low Noise Amplifier with Integrated Filter and Variable Current/Shutdown Function
Features
Very Low Noise Figure: 0.82 dB typical
High Gain: 13.5 dB typical
High IIP3 and IP1dB
Exceptional Cell/PCS-Band rejection
Advanced GaAs E-pHEMT Technology
Low external component count
Wide Supply Voltage: 1 V to 3.6 V
• Shutdown current: < 0.1 µA
• CMOS compatible shutdown pin (SD) current @ 2.8 V:
0.1 mA
• Adjustable current via single external
resistor/voltage
• Meets MSL3 and Lead-Free
• ESD-protected RF input: 3 kV HBM
• Small package dimension: 3.3(L)x2.1(W)x1.1(H) mm3
ALM-1412.pdf (830 KB, 下载次数: 0)
