AMW006 • Embedded Wi-Fi Networking Solution datasheet
Features
Self-contained ultra-low power Wi-Fi module with
microcontroller and secure TCP network stack.
Integrated SPI-serial flash for software upgrades
and user accessible read/write file system
Wi-Fi
Broadcom single band 2.4GHz IEEE 802.11b/g/n
1x1 Wi-Fi transceiver
Includes support for all Wi-Fi security modes including Open, WEP, WPA, and WPA2-PSK
Microprocessor
ARM Cortex M4 based microprocessor operating at
up to 84MHz for 105 DMIPs
Interfaces*
UART: 2 x 4-wire up to 10.5Mbit/s
SPI : SPI-Master (42Mbit/s), SPI-Slave (21Mbit/s)
GPIO: Up to 21 GPIOs (overlaid with peripherals)
A/D converter: 9 channel input, 12-bit resolution,
2.4MSPS sampling in single-shot or scan mode
PWM: Up to 14 PWM outputs
Wake-up: Wake pin for ultra-low power operation
Two external antennas for diversity and improved
range
*Some interfaces share module pins
AMW006 • Embedded Wi-Fi Networking Solution datasheet.pdf
(1.63 MB, 下载次数: 0)
